[petsc-users] Problem with MPI, MatAXPY and SAME_NONZERO_PATTERN
Klaus Kaiser kaiser at igpm.rwth-aachen.de
Wed Apr 8 01:46:40 CDT 2015
Hallo Metthew,
you were albe to reconstruct this problem on your petsc installation?
Best
Klaus
On 03/30/2015 01:43 PM, Matthew Knepley wrote:
> On Mon, Mar 30, 2015 at 5:18 AM, Klaus Kaiser
> <kaiser at igpm.rwth-aachen.de <mailto:kaiser at igpm.rwth-aachen.de>> wrote:
>     Hallo Metthew,
>     at the weekend I updated petsc to the newest release version 3.5.2
>     and I still got this strange behavior.
> Okay, I will check it out. The first thing I am going to do is try
> with AIJ matrices instead of BAIJ, which
> you can probably do before me. If you get the right result, then its a
> bug in the BAIJ implementation,
> which I am confident has not been tested as thoroughly.
>   Thanks,
>      Matt
>     Best
>     Klaus
>     On 03/27/2015 05:07 PM, Klaus Kaiser wrote:
>>     Hallo Matthew,
>>     here is a short example I used for 8 cores:
>>         int d_nnz[3];
>>         int o_nnz[3];
>>         d_nnz[0] = 3; d_nnz[1] = 3; d_nnz[2] = 3;
>>         o_nnz[0] = 6; o_nnz[1] = 6; o_nnz[2] = 6;
>>         ierr = MatCreateBAIJ(PETSC_COMM_WORLD, 3, 9, 9, 72, 72, 0,
>>     d_nnz, 0, o_nnz,&A);
>>         ierr = MatSetOption(A,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_TRUE);
>>         ierr = MatSetOption(A,MAT_KEEP_NONZERO_PATTERN,PETSC_TRUE);
>>         ierr = MatSetOption(A,MAT_IGNORE_OFF_PROC_ENTRIES,PETSC_TRUE);
>>     d_nnz, 0, o_nnz,&Ah);
>>     d_nnz, 0, o_nnz,&At);
>>         std::vector<double> insert(3*3*3*3, 1.0);
>>         for(int i=0;i<8;++i)
>>             int rows[3] = {i,i+1,i+3};
>>             int cols[3] = {i,i+1,i+3};
>>             MatSetValuesBlocked(A, 3, rows, 3, cols, &insert[0],
>>     ADD_VALUES);
>>         MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);
>>         MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);
>>         MatDuplicate(A,MAT_COPY_VALUES,&Ah);
>>         MatDuplicate(A,MAT_COPY_VALUES,&At);
>>         MatAssemblyBegin(Ah,MAT_FINAL_ASSEMBLY);
>>         MatAssemblyEnd(Ah,MAT_FINAL_ASSEMBLY);
>>         MatAssemblyBegin(At,MAT_FINAL_ASSEMBLY);
>>         MatAssemblyEnd(At,MAT_FINAL_ASSEMBLY);
>>         MatAXPY(Ah,1.,At,SAME_NONZERO_PATTERN);
>>         MatAXPY(A,1.,Ah,SAME_NONZERO_PATTERN);
>>     The result is, that only some values are computed correctly.
>>     Best and Thank you a lot
>>     Klaus
>>     On 03/27/2015 04:26 PM, Matthew Knepley wrote:
>>>     On Fri, Mar 27, 2015 at 10:16 AM, Klaus Kaiser
>>>     wrote:
>>>         Hallo Matthew,
>>>         thanks for your fast response. With "no beside the nonzero
>>>         structure" I meant, that I do not create a different
>>>         non-zero structure while I'm adding values to my matrices.
>>>         I also tried MAT_COPY_VALUES and the result was the same.
>>>     Please send the small example and we will figure out what is
>>>     going wrong.
>>>       Thanks,
>>>          Matt
>>>         I do not get a error message but the resulting matrix is
>>>         wrong. Here I have a short example. The first 9 rows and
>>>         first 3 colomn of the matrices Ah, At and Ah+At on the first
>>>         processor (of 8):
>>>         Ah:
>>>         0: 60.3553 -0.249975              2.77556e-17
>>>         1: 0 60.3553                        0
>>>         2: 0 0                  60.3553
>>>         3: 17.6777 0.374962                 0.124987
>>>         4: 0 17.6777                        0
>>>         5: 0 0                  17.6777
>>>         6: -7.32233 -0.124987                 0.374962
>>>         7: 0 -7.32233                        0
>>>         8: 0 0                 -7.32233
>>>         At:
>>>         0: 0 0                        0
>>>         1: 2500 0                        0
>>>         2: -4.54747e-13 0                        0
>>>         3: 0 0                        0
>>>         4: 1250 0                        0
>>>         5: 1250 0                        0
>>>         6: 0 0                        0
>>>         7: 1250 0                        0
>>>         8: 3750 0                        0
>>>         Ah+At
>>>         1: 2500 60.3553                        0
>>>         2: -4.54747e-13 0                  60.3553
>>>         4: 0 17.6777                        0
>>>         5: 0 0                  17.6777
>>>         7: 0 -7.32233                        0
>>>         8: 0 0                 -7.32233
>>>         you can see the first 3 rows of the resulting matrix looks
>>>         exactly like what I would expect, but the last 6 rows only
>>>         consists of the values of Ah. When you would also look on
>>>         the matrix A and A+Ah+At you would also see, that values
>>>         where both matrices have an nonzero entry are not sum correctly.
>>>         Best
>>>         Klaus
>>>         On 03/27/2015 03:59 PM, Matthew Knepley wrote:
>>>>         On Fri, Mar 27, 2015 at 9:48 AM, Klaus Kaiser
>>>>             Hallo,
>>>>             I have a strange behavior in my code concerning the
>>>>             function MatAXPY. I create 3 different Matrices
>>>>                 ierr = MatCreateBAIJ(PETSC_COMM_WORLD, block_size,
>>>>             local_size, local_size, system_size, system_size, 0,
>>>>                 ierr =
>>>>                 ierr =
>>>>                 ierr =
>>>>                 ierr =
>>>>             MatSetOption(At,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_TRUE);
>>>>                 ierr =
>>>>             MatSetOption(At,MAT_KEEP_NONZERO_PATTERN,PETSC_TRUE);
>>>>                 ierr =
>>>>             MatSetOption(At,MAT_IGNORE_OFF_PROC_ENTRIES,PETSC_TRUE);
>>>>                 ierr =
>>>>             MatSetOption(Ah,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_TRUE);
>>>>                 ierr =
>>>>             MatSetOption(Ah,MAT_KEEP_NONZERO_PATTERN,PETSC_TRUE);
>>>>                 ierr =
>>>>             MatSetOption(Ah,MAT_IGNORE_OFF_PROC_ENTRIES,PETSC_TRUE);
>>>>         These creations are superfluous since you use
>>>>         MatDuplicate() below.
>>>>             and want to sum these three matrixes with different
>>>>             factors. First I fill the Matrix A with some values,
>>>>             and duplicate the structure of A to the other two matrices:
>>>>             MatDuplicate(A,MAT_DO_NOT_COPY_VALUES,&Ah);
>>>>             MatDuplicate(A,MAT_DO_NOT_COPY_VALUES,&At);
>>>>             After this I fill the matrices At and Ah with some
>>>>             other values, which are not beside the non zero
>>>>             structure (I also tried with just copying the Matrix
>>>>             A). Now after another MatAssembly
>>>>         I do not understand "no beside the nonzero structure". Do
>>>>         you mean that the nonzero structure is the same?
>>>>         Can you first test with MAT_COPY_VALUES?
>>>>             I want to add these Matrices in the form A+c*(Ah+d*At):
>>>>             MatAXPY(Ah,c,At,SAME_NONZERO_PATTERN);
>>>>             MatAXPY(A,d,Ah,SAME_NONZERO_PATTERN);
>>>>             When I run the method with mpi and one core everything
>>>>             works fine. Starting the same method with more cores,
>>>>             the sum of the matrices fails. It seems like some
>>>>             values are added
>>>>         Please send the full output of a failure when you use
>>>>         MAT_COPY_VALUES on 2 procs.
>>>>           Thanks,
>>>>              Matt
>>>>             correctly and many values are missed. Using
>>>>             DIFFERENT_NONZERO_STRUCTURE leads to the right behavior
>>>>             in the multi-core case, but is very slow. I checked
>>>>             with a viewer if all matrices have the same nonzero
>>>>             structure and this is the case.
>>>>             Does anyone know why this fails, or do I have made any
>>>>             wrong thoughts?
>>>>             I'm corrently working with a petsc version (Petsc
>>>>             Release Version 3.3.0, Patch 5, Sat Dec  1 15:10:41 CST
>>>>             2012), I looked into the changelogs up to the current
>>>>             version and did not find any note about MatAXPY or MatAYPX.
>>>>             Best and Thanks a lot for your help
>>>>             Klaus
>>>>         What most experimenters take for granted before they begin
>>>>         their experiments is infinitely more interesting than any
>>>>         results to which their experiments lead.
>>>>         -- Norbert Wiener
>>>     What most experimenters take for granted before they begin their
>>>     experiments is infinitely more interesting than any results to
>>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150408/1b710b11/attachment-0001.html>
