[petsc-users] Uninterpolating DMLabels?
Justin Chang jchang27 at uh.edu
Tue Apr 7 19:18:04 CDT 2015
Hi all,
So I am interpolating/uninterpolating my DMPlex mesh. This is the mesh
information for a cell-vertex mesh only:
DM Object: 1 MPI processes
  type: plex
DM_0x84000000_0 in 3 dimensions:
  0-cells: 159
  3-cells: 592
Labels:
  marker: 1 strata of sizes (100)
  depth: 2 strata of sizes (159, 592)
I am interpolating the mesh with the following lines:
  ierr = DMPlexInterpolate(*dm, &idm);CHKERRQ(ierr);
  ierr = DMPlexCopyCoordinates(*dm, idm);CHKERRQ(ierr);
  ierr = DMPlexCopyLabels(*dm, idm);CHKERRQ(ierr);
  ierr = DMPlexGetLabel(idm, "marker", &label);CHKERRQ(ierr);
  ierr = DMPlexMarkBoundaryFaces(idm,label);CHKERRQ(ierr);
  ierr = DMDestroy(dm);CHKERRQ(ierr);
  *dm = idm;
And the resulting mesh:
  type: plex
DM_0x84000000_1 in 3 dimensions:
  0-cells: 159
  1-cells: 845
  2-cells: 1280
  3-cells: 592
Labels:
  marker: 1 strata of sizes (292)
  depth: 4 strata of sizes (159, 845, 1280, 592)
The reason I did this is so that incase I decide to refine the mesh with
"-dm_refine <number>" the DM will be sure to include the "marker" points in
the refinement process. Now, if I decide to uninterpolate the mesh with the
following lines:
  ierr = DMPlexUninterpolate(*dm, &idm);CHKERRQ(ierr);
  *dm = idm;
I end up with this mesh:
  type: plex
DM_0x84000000_2 in 3 dimensions:
  0-cells: 159
  3-cells: 592
Labels:
The problem is that although the cells and vertices have gone back to the
original number, the "marker" label still includes face/edge points. This
gives me an error once I invoke DMCreateGobalVector(...).
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Argument out of range
[0]PETSC ERROR: Section point 755 should be in [0, 751)
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.5.3-2528-gbee642f  GIT
Date: 2015-03-29 20:36:38 -0500
[0]PETSC ERROR: ./cube_with_hole on a arch-linux2-c-debug named pacotaco by
justin Tue Apr  7 19:09:12 2015
[0]PETSC ERROR: Configure options --download-chaco --download-exodusii
--download-fblaslapack --download-hdf5 --download-metis --download-mpich
--download-mumps --download-netcdf --download-parmetis --download-scalapack
--download-triangle --with-cc=gcc --with-cmake=cmake --with-cxx=g++
--with-debugging=1 --with-fc=gfortran --with-valgrind=1
PETSC_ARCH=arch-linux2-c-debug
[0]PETSC ERROR: #1 PetscSectionGetDof() line 499 in
/home/justin/petsc-dev/src/vec/is/utils/vsectionis.c
[0]PETSC ERROR: #2 DMPlexGetConeSize() line 841 in
/home/justin/petsc-dev/src/dm/impls/plex/plex.c
[0]PETSC ERROR: #3 DMPlexGetTransitiveClosure() line 1342 in
[0]PETSC ERROR: #4 DMPlexLabelComplete() line 88 in
/home/justin/petsc-dev/src/dm/impls/plex/plexsubmesh.c
[0]PETSC ERROR: #5 DMCreateDefaultSection_Plex() line 5605 in
[0]PETSC ERROR: #6 DMGetDefaultSection() line 3035 in
/home/justin/petsc-dev/src/dm/interface/dm.c
[0]PETSC ERROR: #7 DMGetDefaultGlobalSection() line 3266 in
[0]PETSC ERROR: #8 DMCreateGlobalVector_Section_Private() line 13 in
/home/justin/petsc-dev/src/dm/interface/dmi.c
[0]PETSC ERROR: #9 DMCreateGlobalVector_Plex() line 1170 in
/home/justin/petsc-dev/src/dm/impls/plex/plexcreate.c
[0]PETSC ERROR: #10 DMCreateGlobalVector() line 698 in
[0]PETSC ERROR: #11 main() line 363 in
/home/justin/Dropbox/Research_Topics/Code_PETSc/Nonneg/cube_with_hole.c
>From this error, it seems it's trying to access sieve points that non
longer exist. And I think it has to do with the label "marker" still
contains data from the interpolated mesh. Is there a way to "uninterpolate"
or remove such points? Or is there a better way of approaching this whole
thing?
Justin Chang
PhD Candidate, Civil Engineering - Computational Sciences
University of Houston, Department of Civil and Environmental Engineering
Houston, TX 77004
(512) 963-3262
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150407/0990aee9/attachment.html>
