[petsc-users] Problem with diagonal MPIAIJ matrix
Lukasz Kaczmarczyk Lukasz.Kaczmarczyk at glasgow.ac.uk
Tue Apr 7 06:38:01 CDT 2015
Hello,
Pleas see attached following code,
http://userweb.eng.gla.ac.uk/lukasz.kaczmarczyk/MoFem/html/_p_c_m_g_set_up_via_approx_orders_8cpp_source.html
I encounter following error, if restriction and interpolation operator is the same for multigrid solver. This happens when  I use hierarchical approx. basis and my R matrix is has only values on diagonal. If I set PCMGSetRestriction it works great, but I believe that this is not optimal solution. Could you advise some solution for this?
  176                 // Petsc Development GIT revision: v3.5.3-1524-gee900cc  GIT Date: 2015-01-31 17:44:15 -0600
  178                 // [0]PETSC ERROR: [0] MatPtAPSymbolic_MPIAIJ_MPIAIJ line 124 /opt/petsc/src/mat/impls/aij/mpi/mpiptap.c
  179                 // [0]PETSC ERROR: [0] MatPtAP_MPIAIJ_MPIAIJ line 80 /opt/petsc/src/mat/impls/aij/mpi/mpiptap.c
  180                 // [0]PETSC ERROR: [0] MatPtAP line 8458 /opt/petsc/src/mat/interface/matrix.c
  181                 // [0]PETSC ERROR: [0] PCSetUp_MG line 552 /opt/petsc/src/ksp/pc/impls/mg/mg.c
  182                 // [0]PETSC ERROR: [0] KSPSetUp line 220 /opt/petsc/src/ksp/ksp/interface/itfunc.c
  183
  184                 // ==4284== Invalid read of size 8
  185                 // ==4284==    at 0x5CAC873: MatPtAPSymbolic_MPIAIJ_MPIAIJ (mpiptap.c:154)
  186                 // ==4284==    by 0x5CABA74: MatPtAP_MPIAIJ_MPIAIJ (mpiptap.c:83)
  187                 // ==4284==    by 0x5D566D1: MatPtAP (matrix.c:8537)
  188                 // ==4284==    by 0x61F27D6: PCSetUp_MG (mg.c:642)
  189                 // ==4284==    by 0x612BD9C: PCSetUp (precon.c:909)
  190                 // ==4284==    by 0x62C1A51: KSPSetUp (itfunc.c:306)
  191                 // ==4284==    by 0xB98326: main (elasticity.cpp:403)
  192                 // ==4284==  Address 0x208 is not stack'd, malloc'd or (recently) free'd
Kind regards,
Lukasz
