[petsc-users] MatMatMult with dense matrices.
James A Charles charlesj at purdue.edu
Sun Apr 5 17:15:50 CDT 2015
Hi Hong,
A is also dense. It was converted to dense in an intermediate calculation before this particular multiplication. So far I have only been doing this in our code. Let me write a stand alone PETSc cdoe and I will get back to you.
James
----- Original Message -----
To: "Barry Smith" <bsmith at mcs.anl.gov>
Cc: "James A Charles" <charlesj at purdue.edu>, "Hong" <hzhang at mcs.anl.gov>, dlemus at purdue.edu, "PETSc users list" <petsc-users at mcs.anl.gov>, "Daniel Mejia" <denphi at denphi.com>, "Tillmann Kubis" <tkubis at purdue.edu>
Sent: Sunday, April 5, 2015 6:13:42 PM
Subject: Re: [petsc-users] MatMatMult with dense matrices.
James,
My understanding is that
you call MatMatMult in sequential for computing C = A*B, in which
A is in aij format, and B is dense, and the product C is dense, but gives different values than what you got from Matlab.
Do you have a stand-alone petsc code to reproduce this so I can investigate what goes wrong?
Hong
On Sun, Apr 5, 2015 at 3:44 PM, Barry Smith < bsmith at mcs.anl.gov > wrote:
We would need to see the PETSc side of the code to see if there is anything wrong there.
> On Apr 5, 2015, at 3:35 PM, James A Charles < charlesj at purdue.edu > wrote:
> Hi Hong,
> You can open up matmatmult_comparison.mat in MATLAB ( load matmatmult_comparison.mat ). That .mat contains A, B, C, and C_MATLAB. I called matmatmult in sequential. We use AIJ when A2 was sparse but at the time of this multiplication everything was dense.
> Thanks,
> James
> From: "Hong" < hzhang at mcs.anl.gov >
> To: "James A Charles" < charlesj at purdue.edu >
> Cc: "PETSc users list" < petsc-users at mcs.anl.gov >, dlemus at purdue.edu , "Daniel Mejia" < denphi at denphi.com >, "Tillmann Kubis" < tkubis at purdue.edu >
> Sent: Sunday, April 5, 2015 4:25:39 PM
> James:
> I'm multiplying two dense matrices. I compared the results against MATLAB and I am getting different results. Attached you will see a zip that contains a .mat file that has the A, B, and C. C_MATLAB is the multiplication of A*B in MATLAB and C is the PETSc 3.4.3 result. I also attached the .m files A, B, and C that were saved from PETSc. Is there something I'm doing wrong or
> What is the file type of matmatmult_comparison.mat?
> How to read it?
> I need to see how it defers from C.m.
> any reason due to the shape of the matrices that this would fail? If it gives any more information we convert the previous matrix that A is formed of A2 (A = A1*A2) to dense prior to the multiplication using MatConvert.
> It seems both A and B are dense, complex square matrices.
> Did you call MatMatMult() in sequential or parallel? What matrix format did you use?
> Hong
