[petsc-users] getting EPS to rebuild the BV context
Andrew Spott ansp6066 at colorado.edu
Thu Apr 2 11:54:29 CDT 2015
Thanks for fixing it so quickly!
-Andrew
On Thu, Apr 2, 2015 at 7:37 AM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> I was able to fix this without changing the BV API, so the patch will go both to maint and master (after passing nightly tests).
> https://bitbucket.org/slepc/slepc/commits/5f17011
> Thanks for reporting this.
> Jose
> El 02/04/2015, a las 00:03, Andrew Spott escribió:
>> >Are you using master?
>> This problem was run into on 3.5.3, but I’m working on trying to get the code to work on master. A cursory glance at the code for master seems to tell me that this problem hasn’t changed.
>> -Andrew
>> On Wed, Apr 1, 2015 at 4:00 PM, Jose E. Roman <jroman at dsic.upv.es> wrote:
>> El 01/04/2015, a las 22:32, Andrew Spott escribió:
>> > When resizing an EPS (adjusting the nev, ncv and/or mpd values) after a deflation space has been entered, SLEPC complains that you can’t “resize a BV with constraints”.
>> > Is there a way of forcing this issue by killing the BV and remaking it? (re-adding the constraints).
>> > -Andrew
>> This case is not handled well. A workaround is to call EPSReset(), but probably there should be a better way to do this. Are you using master?
>> Jose
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150402/0c27ee22/attachment.html>
