[petsc-users] Unequal sparse matrix row distribution for MPI MatMult
Steena M stm8086 at yahoo.com
Wed Apr 1 15:10:53 CDT 2015
Thanks Barry. Attached is the driver program, the binary mat file, and the corresponding mtx file.
Runtime command used:
sierra324 at monteiro:time srun -n 2 -ppdebug ./petsc-mpibaij-unequalrows -fin trefethen.dat -matload_block_size 1
     On Wednesday, April 1, 2015 12:28 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
  Send a data file you generated and your reader program and we'll debug it.
  Barry
> On Apr 1, 2015, at 2:18 PM, Steena M <stm8086 at yahoo.com> wrote:
> Thanks Barry. I removed the Preallocation calls. It is still complaining about the malloc and incorrect data in the matrix file. I generate binary matrix files using PETSc's pythonscript to loop through a set of UFL sparse matrices. For this use case:
> mtx_mat = scipy.io.mmread('trefethen.mtx')
> PetscBinaryIO.PetscBinaryIO().writeMatSciPy(open('trefnew.dat','w'), mtx_mat)
> On Tuesday, March 31, 2015 9:15 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  You should not need to call any preallocation routines when using MatLoad()
>  How did you generate the file? Are you sure it has the correct information for the matrix?
>  Barry
> > On Mar 31, 2015, at 11:05 PM, Steena M <stm8086 at yahoo.com> wrote:
> > Thanks Matt. I'm still getting the malloc error
> > [0]PETSC ERROR: Argument out of range!
> > [0]PETSC ERROR: New nonzero at (2,18) caused a malloc!
> > and
> > a new incorrect matrix file error:
> > [0]PETSC ERROR: Unexpected data in file!
> > [0]PETSC ERROR: not matrix object!
> > Maybe the order of calls is mixed up. This is the code snippet:
> >    if (rank ==0)
> >    PetscPrintf (PETSC_COMM_WORLD,"\n On rank %d ", rank);
> >        CHKERRQ(MatSetSizes(A, 15, PETSC_DETERMINE, 20, 20));
> >        CHKERRQ(MatSetType(A, MATMPIBAIJ));
> >        CHKERRQ( MatMPIBAIJSetPreallocation(A,1,1,NULL,1,NULL));
> >        CHKERRQ( MatLoad(A,fd));
> >    CHKERRQ(MatSetOption(A,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_FALSE));
> >    else
> >        CHKERRQ( MatSetSizes(A, 5, PETSC_DETERMINE, 20, 20) );
> >        CHKERRQ(MatLoad(A,fd));
> > Is there something I'm missing?
> > Thanks,
> > Steena
> > On Tuesday, March 31, 2015 6:10 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Tue, Mar 31, 2015 at 6:51 PM, Steena M <stm8086 at yahoo.com> wrote:
> > Thanks Barry. I'm still getting the malloc error with NULL. Is there a way to distribute the matrix without explicit preallocation? Different matrices will be loaded during runtime and assigning preallocation parameters would mean an additional preprocessing step.
> > 1) MatSetOption(MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE)
>> > 2) Note that this is never ever ever more efficient than making another pass and preallocating
> >  Thanks,
> >      Matt
> > On Sun, 3/29/15, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >  Subject: Re: [petsc-users] Unequal sparse matrix row distribution for MPI MatMult
> >  To: "Steena M" <stm8086 at yahoo.com>
> >  Cc: "Matthew Knepley" <knepley at gmail.com>, petsc-users at mcs.anl.gov
> >  Date: Sunday, March 29, 2015, 9:26 PM
> >  > On
> >  Mar 29, 2015, at 11:05 PM, Steena M <stm8086 at yahoo.com>
> >  wrote:
> >  > Thanks
> >  Matt. I used PETSC_DETERMINE but I'm now getting an
> >  allocation-based error:
> >  > [0]PETSC ERROR: ---------------------
> >  Error Message ------------------------------------
> >  > [0]PETSC ERROR: Argument out of range!
> >  > [0]PETSC ERROR: New nonzero at (2,18)
> >  caused a malloc!
> >  > [0]PETSC ERROR:
> >  > I tried
> >  preallocating on each rank for the diagonal and off diagonal
> >  section of the matrix as the next step  My current
> >  approximations for preallocation
> >  > CHKERRQ(
> >  MatMPIBAIJSetPreallocation(A,1,5,PETSC_DEFAULT,5,PETSC_DEFAULT));
> >    These
> >  arguments where you pass PETSC_DEFAULT are expecting a
> >  pointer not an integer. You can pass NULL in those
> >  locations. Though it is better to provide the correct
> >  preallocation rather than some defaults.
> >    Barry
> >  > are throwing segmentation errors.
> >  > [0]PETSC ERROR:
> >  Caught signal number 11 SEGV: Segmentation Violation,
> >  probably memory access out of range
> >  > Any insights into what I'm doing
> >  wrong?
> >  > Thanks,
> >  > Steena
> >  > On Sun, 3/29/15, Matthew Knepley <knepley at gmail.com>
> >  wrote:
> >  > Subject:
> >  MPI MatMult
> >  > To: "Steena M"
> >  > Cc: "Barry Smith" <bsmith at mcs.anl.gov>,
> >  > Date: Sunday, March 29, 2015, 10:02 PM
> >  > On Sun, Mar 29, 2015
> >  at
> >  > 9:56 PM, Steena M <stm8086 at yahoo.com>
> >  > wrote:
> >  > Hi
> >  > Barry,
> >  > I am trying to partition a 20 row and 20
> >  col sparse matrix
> >  > between two procs
> >  such that proc 0 has 15 rows and 20 cols
> >  > and proc 1 has 5 rows and 20 cols. The
> >  code snippet:
> >    CHKERRQ(MatCreate(PETSC_COMM_WORLD,&A));
> >  > at runtime: -matload_block_size 1
> >    if (rank ==0)
> >    CHKERRQ( MatSetSizes(A, 15, 20, 20,
> >  > 20) ); //rank 0 gets 75% of the rows
> >    CHKERRQ( MatSetType(A, MATMPIBAIJ)
> >  >                CHKERRQ(
> >  MatLoad(A,fd) );
> >  >        else
> >  20, 20,
> >  > 20) ); //rank 1 gets 25% of the
> >  rows
> >  >                CHKERRQ(
> >  MatLoad(A,fd) );
> >  > This throws the following error (probably
> >  from psplit.c):
> >  [1]PETSC ERROR: --------------------- Error Message
> >  > [1]PETSC ERROR:
> >  Nonconforming object sizes!
> >  > [1]PETSC ERROR: Sum of local lengths 40
> >  does not equal
> >  > global length 20, my
> >  local length 20
> >  >  likely a call to
> >  VecSetSizes() or MatSetSizes() is
> >  wrong.
> >  > See
>http://www.mcs.anl.gov/petsc/documentation/faq.html#split!
> >  > This error printout
> >  doesn't quite make sense to me.
> >  I'm trying to specify a total matrix size of 20x20...
> >  I
> >  > haven't yet figured out where the
> >  '40' comes
> >  > from in the error
> >  message.
> >  > Any thoughts on what
> >  might be going wrong?
> >  > Its the column specification. Just
> >  > use PETSC_DETERMINE for the local columns
> >  since all our
> >  > sparse matrixformats are
> >  row divisions
> >  > anyway.
> >  > Thanks,
> >  >  Matt
> >  > Thanks in advance,
> >  > Steena
> >  > On Sun, 3/22/15,
> >  > wrote:
> >  >  Subject: Re: [petsc-users] Unequal
> >  sparse matrix row
> >  > distribution for MPI
> >  MatMult
> >  >  To:
> >  >  Cc: petsc-users at mcs.anl.gov
> >  >  Date: Sunday,
> >  March 22, 2015, 3:58 PM
> >  >  Steena,
> >  >    I am
> >  >  a little unsure of your question.
> >  >    1)
> >  you can create a MPIBAIJ
> >  >  matrix with any distribution of block
> >  rows per process
> >  > you
> >  >  want, just set the
> >  local row size for each process to
> >  be
> >  >  what you
> >  like.  Use MatCreateVecs() to get
> >  correspondingly
> >  laid out vectors.
> >    or 2) if you have a MPIBAIJ
> >  >  matrix with
> >  "equal" row layout and you want a
> >  > new
> >  >  one with uneven row layout you can
> >  simply use
> >  MatGetSubMatrix() to create that new matrix.
> >  >    Barry
> >  >  Unless you have
> >  another reason to have the
> >  >  matrix with an equal number row layout I
> >  would just
> >  > generate
> >  >  the matrix with
> >  the layout you want.
> >  >  > On Mar 22, 2015, at 5:50 PM, Steena
> >  M
> >  >  <stm8086 at yahoo.com>
> >  >  wrote:
> >  >  > Hello,
> >  >  > I need to
> >  distribute
> >  >  a
> >  sparse matrix such that each proc owns an unequal
> >  > number
> >  >  of blocked rows before I proceed with
> >  MPI MatMult. My
> >  initial thoughts on doing this:
> >  >  > 1) Use  MatGetSubMatrices() on the
> >  test
> >  >  MATMPIBAIJ
> >  matrix to produce a new matrix where each
> >  > proc
> >  >  has an unequal number of rows.
> >  >  > 2) Provide
> >  scatter context for vector X
> >  >  (for MatMult )using IS iscol from
> >  MatGetSubMatrices()
> >  > while
> >  >  creating the
> >  vector X.
> >  >  > 3)
> >  Call MatMult()
> >  >  > Will
> >  MatMult_MPIBAIJ continue to scatter
> >  >  this matrix and vector such that each
> >  proc will own an
> >  > equal
> >  >  number of matrix
> >  rows and corresponding diagonal vector
> >  >  elements? Should I write my own
> >  MPIMatMult function to
> >  >  retain my redistribution of the matrix
> >  and vector?
> >  Thanks in
> >  advance,
> >  Steena
> >  > What most
> >  experimenters
> >  > take for granted before
> >  they begin their experiments is
> >  infinitely more interesting than any results to which
> >  their
> >  > experiments lead.
> >  > -- Norbert
> >  > Wiener
> > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150401/c0298363/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150401/c0298363/attachment-0003.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150401/c0298363/attachment-0004.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150401/c0298363/attachment-0005.obj>
