[petsc-users] What is "You must specify a path for MPI with --with-mpi-dir=<directory>"
Nan Zhang Nan.Zhang at colorado.edu
Tue Sep 30 18:20:24 CDT 2014
Hi there,
I am trying to install petsc with its own mpicc. I download it and untar it
under my directory. I export PETSC_DIR=`pwd` and export PETSC_ARCH=x86_64.
When I do configure:
./config/configure.py –with-shared-libraries=1 –with-x=0 –with-mpi=1
-download-hypre=1 –download-f-blas-lapack=1 –download-mpich=1
-download-mpicc=1 –download-f2cblaslapack=1
I got an error report:
The version of PETSc you are using is out-of-date, we recommend updating to
the new release
 Available Version: 3.5.2   Installed Version: 3.4.2
http://www.mcs.anl.gov/petsc/download/index.html
             Configuring PETSc to compile on your system
TESTING: check from
config.libraries(config/BuildSystem/config/libraries.py:145)
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
details):
If you do not want MPI, then give --with-mpi=0
You might also consider using --download-mpi instead
How to solve this? I also attach my configure.log below.
Thanks!
Nan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140930/65dc38af/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140930/65dc38af/attachment-0001.obj>
