[petsc-users] KSP_DIVERGED_INDEFINITE_PC message even with PCFactorSetShiftType
Evan Um evanum at gmail.com
Sun Sep 28 18:24:35 CDT 2014
Dear PETSC Users,
I try to solve a diffusion problem in the time domain. Its system matrix is
theoretically SPD. I use KSPCG solver. Direct MUMPS solver generates a
preconditioner. Thus, within 1-2 iterations, a solution is expected to
converge. Such convergence is observed in most test problems. However, in
some test problems, I get non-convergence with a message:
KSP_DIVERGED_INDEFINITE_PC. This problem is alleviated when I use
PCFactorSetShiftType(pc_fetd_dt,MAT_SHIFT_POSITIVE_DEFINITE). However, the
indefiniteness error message occurs later during time-stepping. I am aware
of PETSC function PCFactorSetShiftAmount. However, before I try this, I
couldn't find the information about a default shift amount when I use
PCFactorSetShiftType(pc_fetd_dt,MAT_SHIFT_POSITIVE_DEFINITE). How can I
find the default shift amount?
More generally, how can I stably solve SPD problems that are close to
indefiniteness using KSP options? To get the reference solution, I was able
to solve the same problem above using SuiteSparse (serial) but its solution
time was not practical.
In advance, thanks for your advice.
Evan
Sample Code:
KSPCreate(PETSC_COMM_WORLD, &ksp_fetd_dt);
KSPSetOperators(ksp_fetd_dt, A_dt, A_dt);
KSPSetType (ksp_fetd_dt, KSPPREONLY);
KSPGetPC(ksp_fetd_dt, &pc_fetd_dt);
MatSetOption(A_dt, MAT_SPD, PETSC_TRUE);
PCSetType(pc_fetd_dt, PCCHOLESKY);
PCFactorSetMatSolverPackage(pc_fetd_dt, MATSOLVERMUMPS);
PCFactorSetUpMatSolverPackage(pc_fetd_dt);
PCFactorGetMatrix(pc_fetd_dt, &F_dt);
KSPSetType(ksp_fetd_dt, KSPCG);
PCFactorSetShiftType(pc_fetd_dt,MAT_SHIFT_POSITIVE_DEFINITE);
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140928/63c4c7d5/attachment.html>
