[petsc-users] Best way to save entire solution history of a TS
Miguel Angel Salazar de Troya salazardetroya at gmail.com
Sat Sep 27 12:31:18 CDT 2014
Hello
I'm performing an adjoint sensitivity analysis in a transient problem and I
need to save the entire solution history. I don't have many degrees of
freedom or time steps so I should be able to avoid memory problems. I've
thought of creating a std::vector<Vec> and save all the PETSc Vec that I
get from TSGetSolution there. Would this be a problem if I'm running the
simulation in parallel? Is there a better way to save the entire solution
history in memory?
Thanks
Miguel
*Miguel Angel Salazar de Troya*
Graduate Research Assistant
Department of Mechanical Science and Engineering
University of Illinois at Urbana-Champaign
(217) 550-2360
salaza11 at illinois.edu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140927/7b01b50e/attachment.html>
