[petsc-users] How to set L1 norm as the converge test?
Brian Yang brianyang1106 at gmail.com
Wed Sep 24 14:24:30 CDT 2014
Thanks Mat and Barry,
Yes I want to use the L1 norm in the convergence test. For the ||Ax-b||, I
always want to calculate L1 norm instead of L2. Is Mat's way gonna work on
this?
On Wed, Sep 24, 2014 at 2:17 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Brian,
>    Do you wish to monitor the convergence of the L1 norm, or do you wish
> to use the L1 norm in the convergence test?   Regardless you cannot change
> the LSQR or CG to be a different algorithm (with different convergence
> properties) with the L1 norm.
>   Barry
> On Sep 24, 2014, at 2:08 PM, Brian Yang <brianyang1106 at gmail.com> wrote:
> > Hi all,
> > For example, I am using LSQR or CG to solve Ax=b.
> > When we turn on the monitor option of solving the linear system, we
> could see iteration number and residual for each iteration. I believe it's
> L2 norm of the objective function?
> > If yes, is there a way that I could set it to L1 norm for solving the
> system?
> > Thanks.
> > Brian Yang
> > U of Houston
Brian Yang
U of Houston
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140924/57b7033a/attachment.html>
