[petsc-users] How to set L1 norm as the converge test?
Wed Sep 24 14:15:42 CDT 2014
On Wed, Sep 24, 2014 at 2:08 PM, Brian Yang <brianyang1106 at gmail.com> wrote:
> Hi all,
> For example, I am using LSQR or CG to solve Ax=b.
> When we turn on the monitor option of solving the linear system, we could
> see iteration number and residual for each iteration. I believe it's L2
> norm of the objective function?
> If yes, is there a way that I could set it to L1 norm for solving the
> system?
Yes, you can use
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPSetConvergenceTest.html
and then use VecNorm() with NORM_1 instead.
     Matt
> Thanks.
> Brian Yang
> U of Houston
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140924/3cce1c29/attachment.html>
