[petsc-users] Memory requirements in SUPERLU_DIST
Jed Brown jed at jedbrown.org
Tue Sep 23 19:14:15 CDT 2014
Zin Lin <zinlin.zinlin at gmail.com> writes:
> What I don't understand is  why memory per core matters rather than the
> total memory? If the work space is distributed across the processors,
> shouldn't it work as long as I choose a sufficient number of smaller-memory
> cores?
METIS is a serial partitioner.  ParMETIS is parallel, but often performs
worse and still doesn't scale to very large numbers of cores, so it is
not the default for most direct solver packages.
> What kind of role does the memory per core play in the algorithm in
> contrast to the total memory over all the cores?
> The issue is I would rather use a large number of small-memory cores than
> any number of the large-memory cores. The latter are two times more
> expensive in terms of service units (I am running on STAMPEDE at TACC) and
> not many cores are available either.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140923/725f13a2/attachment.pgp>
