[petsc-users] DMPlex with spring elements
Miguel Angel Salazar de Troya salazardetroya at gmail.com
Tue Sep 23 15:01:11 CDT 2014
Hi all
I was wondering if it could be possible to build a model similar to the
example snes/ex12.c, but with spring elements (for elasticity) instead of
simplicial elements. Spring elements in a grid, therefore each element
would have two nodes and each node two components. There would be more
differences, because instead of calling the functions f0,f1,g0,g1,g2 and g3
to build the residual and the jacobian, I would call a routine that would
build the residual vector and the jacobian matrix directly. I would not
have shape functions whatsoever. My problem is discrete, I don't have a PDE
and my equations are algebraic. What is the best way in petsc to solve this
problem? Is there any example that I can follow? Thanks in advance
Miguel
*Miguel Angel Salazar de Troya*
Graduate Research Assistant
Department of Mechanical Science and Engineering
University of Illinois at Urbana-Champaign
(217) 550-2360
salaza11 at illinois.edu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140923/270b8fc5/attachment.html>
