[petsc-users] superlu_dist and MatSolveTranspose
Hong hzhang at mcs.anl.gov
Mon Sep 22 12:47:46 CDT 2014
I'll add it. It would not take too long, just matter of priority.
I'll try to get it done in a day or two, then let you know when it works.
Hong
On Mon, Sep 22, 2014 at 12:11 PM, Antoine De Blois
<antoine.deblois at aero.bombardier.com> wrote:
> Dear all,
> Sorry for the delay on this topic.
> Thank you Gaetan for your suggestion. I had thought about doing that originally, but I had left it out since I thought that a rank owned the entire row of the matrix (and not only the sub-diagonal part). I will certainly give it a try.
> I still need the MatSolveTranspose since I need the ability to reuse the residual jacobian matrix from the flow (a 1st order approximation of it), which is assembled in a non-transposed format. This way the adjoint system is solved in a pseudo-time step manner, where the product of the exact jacobian matrix and the adjoint vector is used as a source term in the rhs.
> Hong, do you have an estimation of the time required to implement it in superlu_dist?
> Best,
> Antoine
> -----Message d'origine-----
> De : Hong [mailto:hzhang at mcs.anl.gov]
> Envoyé : Friday, August 29, 2014 9:14 PM
> À : Gaetan Kenway
> Cc : Antoine De Blois; petsc-users at mcs.anl.gov
> Objet : Re: [petsc-users] superlu_dist and MatSolveTranspose
> We can add MatSolveTranspose() to the petsc interface with superlu_dist.
> Jed,
> Are you working on it? If not, I can work on it.
> Hong
> On Fri, Aug 29, 2014 at 6:14 PM, Gaetan Kenway <gaetank at gmail.com> wrote:
>> Hi Antoine
>> We are also using PETSc for solving adjoint systems resulting from
>> CFD. To get around the matSolveTranspose issue we just assemble the
>> transpose matrix directly and then call KSPSolve(). If this is
>> possible in your application I think it is probably the best approach
>> Gaetan
>> On Fri, Aug 29, 2014 at 3:58 PM, Antoine De Blois
>>> Hello Jed,
>>> Thank you for your quick response. So I spent some time to dig deeper
>>> into my problem. I coded a shell script that passes through a bunch
>>> of ksp_type, pc_type and sub_pc_type. So please disregard the comment
>>> about the "does not converge properly for transpose". I had taken
>>> that conclusion from my own code (and not from the ex10 and extracted
>>> matrix), and a KSPSetFromOptions was missing. Apologies for that.
>>> What remains is the performance issue. The MatSolveTranspose takes a
>>> very long time to converge. For a matrix of 3 million rows,
>>> MatSolveTranspose takes roughly 5 minutes on 64 cpus, whereas the
>>> MatSolve is almost instantaneous!. When I gdb my code, petsc seems to
>>> be stalled in the MatLUFactorNumeric_SeqAIJ_Inode () for a long time.
>>> I also did a top on the compute node to check the RAM usage. It was
>>> hovering over 2 gig, so memory usage does not seem to be an issue here.
>>> #0  0x00002afe8dfebd08 in MatLUFactorNumeric_SeqAIJ_Inode ()
>>>    from
>>> /gpfs/fs2/aero/SOFTWARE/FLOW_SOLVERS/FANSC/EXT_LIB/petsc-3.5.1/lib/li
>>> bpetsc.so.3.5
>>> #1  0x00002afe8e07f15c in MatLUFactorNumeric ()
>>>    from
>>> bpetsc.so.3.5
>>> #2  0x00002afe8e2afa99 in PCSetUp_ILU ()
>>>    from
>>> bpetsc.so.3.5
>>> #3  0x00002afe8e337c0d in PCSetUp ()
>>>    from
>>> bpetsc.so.3.5
>>> #4  0x00002afe8e39d643 in KSPSetUp ()
>>>    from
>>> bpetsc.so.3.5
>>> #5  0x00002afe8e39e3ee in KSPSolveTranspose ()
>>>    from
>>> bpetsc.so.3.5
>>> #6  0x00002afe8e300f8c in PCApplyTranspose_ASM ()
>>>    from
>>> bpetsc.so.3.5
>>> #7  0x00002afe8e338c13 in PCApplyTranspose ()
>>>    from
>>> bpetsc.so.3.5
>>> #8  0x00002afe8e3a8a84 in KSPInitialResidual ()
>>>    from
>>> bpetsc.so.3.5
>>> #9  0x00002afe8e376c32 in KSPSolve_GMRES ()
>>>    from
>>> bpetsc.so.3.5
>>> #10 0x00002afe8e39e425 in KSPSolveTranspose ()
>>> For that particular application, I was using:
>>> ksp_type:                       gmres
>>> pc_type:                        asm
>>> sub_pc_type:                    ilu
>>> adj_sub_pc_factor_levels        1
>>> For small matrices, the MatSolveTranspose computing time is very
>>> similar to the simple MatSolve.
>>> And if I want to revert to a MatTranspose followed by the MatSolve,
>>> then the MatTranspose takes forever to finish... For a matrix of 3
>>> million rows, MatTranspose takes 30 minutes on 64 cpus!!
>>> So thank you for implementing the transpose solve in superlu_dist. It
>>> would also be nice to have it with hypre.
>>> Let me know what you think and ideas on how to improve my
>>> computational time, Regards, Antoine
>>> De : Jed Brown [mailto:jed at jedbrown.org] Envoyé : Thursday, August
>>> 28, 2014 5:01 PM À : Antoine De Blois; 'petsc-users at mcs.anl.gov'
>>> Antoine De Blois <antoine.deblois at aero.bombardier.com> writes:
>>> > Hello everyone,
>>> > I am trying to solve a A^T x = b system. For my applications, I had
>>> > realized that the MatSolveTranspose does not converge properly.
>>> What do you mean "does not converge properly"?  Can you send a test
>>> case where the transpose solve should be equivalent, but is not?  We
>>> have only a few tests for transpose solve and not all preconditioners
>>> support it, but where it is supported, we want to ensure that it is correct.
>>> > Therefore, I had implemented a MatTranspose followed by a MatSolve.
>>> > This proved to converge perfectly (which is strange since the
>>> > transposed matrix has the same eigenvalues as the untransposed...).
>>> > The problem is that for bigger matrices, the MatTranspose is very
>>> > costly and thus cannot be used.
>>> Costly in terms of memory?  (I want you to be able to use
>>> KSPSolveTranspose, but I'm curious what you're experiencing.)
>>> > I tried using the superlu_dist package. Although it the package
>>> > works perfectly for the MatSolve, I get the an "No support for this
>>> > operation for this object type" error  with MatSolveTransopse. I
>>> > reproduced the error using the MatView an ex10 tutorial. I can
>>> > provide the matrix and rhs upon request. My command line was:
>>> > ex10 -f0 A_and_rhs.bin -pc_type lu -pc_factor_mat_solver_package
>>> > superlu_dist -trans
>>> > So it there an additional parameter I need to use for the
>>> > transposed solve?
>>> > [0]PETSC ERROR: --------------------- Error Message
>>> > [0]PETSC ERROR: No support for this operation for this object type
>>> > [0]PETSC ERROR: Matrix type mpiaij
>>> This is easy to add.  I'll do it now.
>>> > [0]PETSC ERROR: See
>>> > http://www.mcs.anl.gov/petsc/documentation/faq.html
>>> > for trouble shooting.
>>> > [0]PETSC ERROR: Petsc Release Version 3.5.1, unknown [0]PETSC ERROR:
>>> > /gpfs/fs1/aero/SOFTWARE/TOOLS/PROGRAMMING/petsc/src/ksp/ksp/example
>>> > s/t
>>> > utorials/ex10 on a ARGUS_impi_opt named hpc-user11 by ad007804 Thu
>>> > Aug
>>> > 28 16:41:15 2014 [0]PETSC ERROR: Configure options --CFLAGS="-xHost
>>> > -axAVX" --download-hypre --download-metis --download-ml
>>> > --download-parmetis --download-scalapack --download-superlu_dist
>>> > --download-mumps --with-c2html=0 --with-cc=mpiicc
>>> > --with-fc=mpiifort --with-cxx=mpiicpc --with-debugging=yes
>>> > --prefix=/gpfs/fs1/aero/SOFTWARE/TOOLS/PROGRAMMING/petsc/petsc-3.5.
>>> > 1
>>> > --with-cmake=/gpfs/fs1/aero/SOFTWARE/TOOLS/CMAKE/cmake-2.8.7/bin/cm
>>> > ake
>>> > --with-valgrind=/gpfs/fs1/aero/SOFTWARE/TOOLS/PROGRAMMING/valgrind-
>>> > 3.9 .0/bin/valgrind --with-shared-libraries=0 [0]PETSC ERROR: #1
>>> > MatSolveTranspose() line 3473 in
>>> > /gpfs/fs2/aero/SOFTWARE/TOOLS/PROGRAMMING/petsc/src/mat/interface/m
>>> > atr ix.c [0]PETSC ERROR: #2 PCApplyTranspose_LU() line 214 in
>>> > /gpfs/fs2/aero/SOFTWARE/TOOLS/PROGRAMMING/petsc/src/ksp/pc/impls/fa
>>> > cto r/lu/lu.c [0]PETSC ERROR: #3 PCApplyTranspose() line 573 in
>>> > /gpfs/fs2/aero/SOFTWARE/TOOLS/PROGRAMMING/petsc/src/ksp/pc/interfac
>>> > e/p recon.c [0]PETSC ERROR: #4 KSP_PCApply() line 233 in
>>> > /gpfs/fs2/aero/SOFTWARE/TOOLS/PROGRAMMING/petsc/include/petsc-priva
>>> > te/ kspimpl.h [0]PETSC ERROR: #5 KSPInitialResidual() line 63 in
>>> > /gpfs/fs2/aero/SOFTWARE/TOOLS/PROGRAMMING/petsc/src/ksp/ksp/interfa
>>> > ce/ itres.c [0]PETSC ERROR: #6 KSPSolve_GMRES() line 234 in
>>> > /gpfs/fs2/aero/SOFTWARE/TOOLS/PROGRAMMING/petsc/src/ksp/ksp/impls/g
>>> > mre s/gmres.c [0]PETSC ERROR: #7 KSPSolveTranspose() line 704 in
>>> > ce/ itfunc.c [0]PETSC ERROR: #8 main() line 324 in
>>> > s/t
>>> > utorials/ex10.c
>>> > FYI, the transpose solve is a typical application for adjoint
>>> > optimization. There should be a big adjoint community of developers
>>> > that try to solve the transposed matrix.
>>> > Any help is much appreciated,
>>> > Best,
>>> > Antoine
>>> > Antoine DeBlois
>>> > Specialiste ingenierie, MDO lead / Engineering Specialist, MDO lead
>>> > Aéronautique / Aerospace 514-855-5001, x 50862
>>> > antoine.deblois at aero.bombardier.com<mailto:antoine.deblois at aero.bom
>>> > bar
>>> > dier.com>
>>> > 2351 Blvd Alfred-Nobel
>>> > Montreal, Qc
>>> > H4S 1A9
>>> > [Description : Description :
>>> > http://signatures.ca.aero.bombardier.net/eom_logo_164x39_fr.jpg]
>>> > CONFIDENTIALITY NOTICE - This communication may contain privileged
>>> > or confidential information.
>>> > If you are not the intended recipient or received this
>>> > communication by error, please notify the sender and delete the
>>> > message without copying
