[petsc-users] Mat indices
Sun Sep 21 10:57:09 CDT 2014
  Mat indices always start with 0 in global indexing used by MatSetValues, MatSetValuesBlocked
  With “local orderings” on can chose to use whatever indexing makes sense for your local ordering, this is used with MatSetValuesLocal(), MatSetValuesBlockedLocal().
   Barry
On Sep 21, 2014, at 10:35 AM, Feng Shi <fshi at fit.edu> wrote:
> Hi all,
> When setting the Mat indices, like the example: src/ts/examples/tutorials/ex10, I noticed that on line
> 508:     col[0] = i-1;
> 509:     col[1] = i;
> 510:     col[2] = i+1<info.mx ? i+1 : -1;
> 511:     MatSetValuesBlocked<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatSetValuesBlocked.html#MatSetValuesBlocked>(B,1,&i,3,col,&K[0][0],INSERT_VALUES<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/INSERT_VALUES.html#INSERT_VALUES>);
> How about the case that when i=0, then col[0]=-1 and i=info.mx then col[2]=-1?
> My question is, is the Mat default indices starting from -1?
> Thank you in advance!
> Best regards,
> Feng
