[petsc-users] Using the PCASM interface to define minimally overlapping subdomains
Wed Sep 17 20:39:19 CDT 2014
On Wed, Sep 17, 2014 at 8:36 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Sep 17, 2014, at 7:29 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Wed, Sep 17, 2014 at 5:08 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Sep 17, 2014, at 3:38 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > > On Wed, Sep 17, 2014 at 3:12 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > > On Sep 17, 2014, at 3:03 PM, Patrick Sanan <patrick.sanan at gmail.com>
> wrote:
> > > > On 9/16/14 9:43 PM, Barry Smith wrote:
> > > >> On Sep 16, 2014, at 2:29 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > > >>> On Tue, Sep 16, 2014 at 2:23 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > > >>>    Patrick,
> > > >>>      This "local part of the subdomains for this processor” term
> in  PCASMSetLocalSubdomains is, IMHO, extremely confusing. WTHWTS? Anyways,
> I think that if you set the is_local[] to be different than the is[] you
> will always end up with a nonsymetric preconditioner. I think for one
> dimension you need to use
> > > >>> No I don't think that is right. The problem below is that you have
> overlap in only one direction. Process 0 overlaps
> > > >>> Process 1, but Process 1 has no overlap of Process 0. This is not
> how Schwarz is generally envisioned.
> > > >>   Sure it is.
> > > >>> Imagine the linear algebra viewpoint, which I think is cleaner
> here. You partition the matrix rows into non-overlapping
> > > >>> sets. These sets are is_local[]. Then any information you get from
> another domain is another row, which is put into
> > > >>> is[]. You can certainly have a non-symmetric overlap, which you
> have below, but it mean one way information
> > > >>> transmission which is strange for convergence.
> > > >>   No, not a all.
> > > >> |    0      1      2      3     4      5     6    |
> > > >>   Domain 0 is the region from  |   to  4  with Dirichlet boundary
> conditions at each end (| and 4). Domain 1 is from 2 to | with Dirichlet
> boundary conditions at each end (2 and |) .
> > > >>   If you look at the PCSetUp_ASM() and PCApply_ASM() you’ll see all
> kinds of VecScatter creations from the various is and is_local,
> “restriction”, “prolongation” and “localization” then in the apply the
> different scatters are applied in the two directions, which results in a
> non-symmetric operator.
> > > > I was able to get my uniprocessor example to give the (symmetric)
> preconditioner I expected by commenting out the check in PCSetUp_ASM (line
> 311 in asm.c)
> > >     if (firstRow != lastRow) SETERRQ2(PETSC_COMM_SELF,PETSC_ERR_PLIB,
> "Specified ASM subdomain sizes were invalid: %d != %d", firstRow, lastRow);
> > >    This check is absurd and needs to be removed.
> > > > and using PCASMSetLocalSubdomains with the same (overlapping) IS's
> for both is and is_local ([0 1 2 3] and [3 4 5 6] in the example above). It
> also works passing NULL for is_local.
> > >   Great.
> > > > I assume that the purpose of the check mentioned above is to ensure
> that every grid point is assigned to exactly one processor, which is needed
> by whatever interprocess scattering goes on in the implementation. Also, I
> assume that augmenting the domain definition with an explicit specification
> of the way domains are distributed over processes allows for more
> controllable use of PC_ASM_RESTRICT, with all its attractive properties.
> > > > Anyhow, Barry's advice previously in this thread works locally (for
> one test case) if you remove the check above, but the current
> implementation enforces something related to what Matt describes, which
> might be overly restrictive if multiple domains share a process.  The
> impression I got initially from the documentation was that if one uses
> PC_ASM_BASIC, the choice of is_local should only influence the details of
> the communication pattern, not (in exact arithmetic, with
> process-count-independent subsolves) the preconditioner being defined.
> > >    The “communication pattern” does determine the preconditioner being
> defined.
> > >     The introduction of is_local[] broke the clean usage of PC_ASM_*
> that use to exist, so your confusion is our fault, not yours.
> > > > For regular grids this all seems pretty pathological (in practice I
> imagine people want to use symmetric overlaps,
> > >    As I said above you are using "symmetric overlaps,”. It just looks
> “unsymmetric” if you introduce this concept of “non-overlapping initial
> subdomains” which is an unneeded harmful concept.
> > > I really do not understand what you are saying here. If you want to do
> RASM, then you must be able to
> > > tell the difference between your domain and the overlap. That is all
> that the distinction between is and
> > > islocal does. Your original implementation of RASM was wanting because
> it merely dropped communication.
> > > If you have several domains on a process, then this is not RASM.
> >    Correct.
> >    The problem is that your extra test prevented perfectly valid ASM
> configurations. You are right that these “perfectly valid ASM
> configurations” do not have an RASM form (if we define RASM as strictly
> requiring non-overlapping domains that then get extended and either the
> restriction or prolongation skips the overlap region) but they are still
> valid ASM preconditioners so shouldn’t error out just because they cannot
> be used for RASM.
> >    Barry
> > Note that I am calling any collection of domains which may or may not
> overlap, which may have a “single grid point” overlap or more as valid ASM
> configurations, because they are (i.e. the set of valid ASM configurations
> is larger than the set of RASM configurations). So my valid ASM
> configurations is more then just domains obtained by taking a
> non-overlapping set of domains and then "growing the domains” and I wanted
> the code to support this, hence I removed the extra test.
> > That is fine. We must make sure PETSc properly throws an error if
> someone selects PC_ASM_RESTRICT.
>   I’m not sure. It depends on your definition of PC_ASM_RESTRICT
I would disable it when is == isLocal, since at the least it would be very
misleading.
   Matt
> >    Matt
> > >   Matt
> > >    Barry
> > > > and I assume that one domain per node is the most common use case),
> but I could imagine it being more of a real concern when working with
> unstructured grids.
> > > >>    Barry
> > > >>>   Matt
> > > >>>> is[0] <-- 0 1 2 3
> > > >>>> is[1] <-- 3 4 5 6
> > > >>>> is_local[0] <-- 0 1 2 3
> > > >>>> is_local[1] <-- 3 4 5 6
> > > >>> Or you can pass NULL for is_local use PCASMSetOverlap(pc,0);
> > > >>>   Barry
> > > >>> Note that is_local[] doesn’t have to be non-overlapping or
> anything.
> > > >>> On Sep 16, 2014, at 10:48 AM, Patrick Sanan <
> patrick.sanan at gmail.com> wrote:
> > > >>>> For the purposes of reproducing an example from a paper, I'd like
> to use PCASM with subdomains which 'overlap minimally' (though this is
> probably never a good idea in practice).
> > > >>>> In one dimension with 7 unknowns and 2 domains, this might look
> like
> > > >>>> 0  1  2  3  4  5  6  (unknowns)
> > > >>>> ------------          (first subdomain  : 0 .. 3)
> > > >>>>         -----------  (second subdomain : 3 .. 6)
> > > >>>> The subdomains share only a single grid point, which differs from
> the way PCASM is used in most of the examples.
> > > >>>> In two dimensions, minimally overlapping rectangular subdomains
> would overlap one exactly one row or column of the grid. Thus, for example,
> if the grid unknowns were
> > > >>>> 0  1  2  3  4  5  |
> > > >>>> 6  7  8  9  10 11 | |
> > > >>>> 12 13 14 15 16 17   |
> > > >>>> then one minimally-overlapping set of 4 subdomains would be
> > > >>>> 0 1 2 3 6 7 8 9
> > > >>>> 3 4 5 9 10 11
> > > >>>> 6 7 8 9 12 13 14 15
> > > >>>> 9 10 11 15 16 17
> > > >>>> as suggested by the dashes and pipes above. The subdomains only
> overlap by a single row or column of the grid.
> > > >>>> My question is whether and how one can use the PCASM interface to
> work with these sorts of decompositions (It's fine for my purposes to use a
> single MPI process). In particular, I don't quite understand if should be
> possible to define these decompositions by correctly providing is and
> is_local arguments to PCASMSetLocalSubdomains.
> > > >>>> I have gotten code to run defining the is_local entries to be
> subsets of the is entries which define a partition of the global degrees of
> freedom*, but I'm not certain that this was the correct choice, as it
> appears to produce an unsymmetric preconditioner for a symmetric system
> when I use direct subdomain solves and the 'basic' type for PCASM.
> > > >>>> * For example, in the 1D example above this would correspond to
> > > >>>> is[0] <-- 0 1 2 3
> > > >>>> is[1] <-- 3 4 5 6
> > > >>> What most experimenters take for granted before they begin their
> experiments lead.
> > > >>> -- Norbert Wiener
> experiments lead.
> > > -- Norbert Wiener
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140917/1231d941/attachment.html>
