[petsc-users] Valgrind Errors
James Balasalle James.Balasalle at digitalglobe.com
Mon Sep 15 16:40:43 CDT 2014
Hi Barry,
Thanks for the response.  You're right, it (both ex70 and my own code) doesn't give those valgrind errors when I run it in parallel.  Changing the type to MATAIJ also fixes the issue.
Thanks for the help, I appreciate it.
    James
> -----Original Message-----
> From: Hong [mailto:hzhang at mcs.anl.gov]
> Sent: Friday, September 12, 2014 4:29 PM
> To: Dominic Meiser
> Cc: Barry Smith; James Balasalle; Zhang, Hong; petsc-users at mcs.anl.gov
> Subject: Re: [petsc-users] Valgrind Errors
> I'll check it.
> Hong
> On Fri, Sep 12, 2014 at 3:40 PM, Dominic Meiser <dmeiser at txcorp.com>
> wrote:
> > On 09/12/2014 02:11 PM, Barry Smith wrote:
> >>     James (and Hong),
> >>      Do you ever see this problem in parallel runs?
> >>      You are not doing anything wrong.
> >>      Here is what is happening.
> >> MatGetBrowsOfAoCols_MPIAIJ() which is used by
> >> MatMatMult_MPIAIJ_MPIAIJ() assumes that the VecScatters for the
> >> matrix-vector products are
> >>    gen_to   = (VecScatter_MPI_General*)ctx->todata;
> >>    gen_from = (VecScatter_MPI_General*)ctx->from data;
> >> but when run on one process the scatters are not of that form; hence
> >> the code accesses values in what it thinks is one struct but is
> >> actually a different one. Hence the valgrind errors.
> >> But since the matrix only lives on one process there is actually
> >> nothing to move between processors hence no error happens in the
> >> computation. You can avoid the issue completely by using MATAIJ
> >> matrix for the type instead of MATMPIAIJ and then on one process it
> automatically uses MATSEQAIJ.
> >> I don’t think the bug has anything in particular to do with the
> >> MatTranspose.
> >>    Hong,
> >>      Can you please fix this code? Essentially you can by pass parts
> >> of the code when the Mat is on only one process. (Maybe this also
> >> happens for MPIBAIJ matrices?) Send a response letting me know you
> saw this.
> >>     Thanks
> >>       Barry
> > I had to fix a few issues similar to this a while back. The method
> > VecScatterGetTypes_Private introduced in pull request 176 might be
> > useful in this context.
> > Cheers,
> > Dominic
This electronic communication and any attachments may contain confidential and proprietary
information of DigitalGlobe, Inc. If you are not the intended recipient, or an agent or employee
responsible for delivering this communication to the intended recipient, or if you have received
this communication in error, please do not print, copy, retransmit, disseminate or
otherwise use the information. Please indicate to the sender that you have received this
communication in error, and delete the copy you received. DigitalGlobe reserves the
right to monitor any electronic communication sent or received by its employees, agents
or representatives.
