[petsc-users] speedup for TS solver using DMDA
Katy Ghantous katyghantous at gmail.com
Mon Sep 15 13:42:12 CDT 2014
Matt, thanks! i will look into that and find other ways to make the
computation faster.
Barry, the benchmark reports up to 2 speedup, but says 1 node in the end.
but either way i was expecting a higher speedup.. 2 is the limit for two
cpus despite the multiple cores?
please let me know if the file attached is what you are asking for.
Thank you!
On Mon, Sep 15, 2014 at 8:23 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    Please send the output from running
>     make steams NPMAX=32
>     in the PETSc root directory.
>    Barry
>   My guess is that it reports “one node” is just because it uses the
> “hostname” to distinguish nodes and though your machine has two CPUs, from
> the point of view of the OS it has only a single hostname and hence reports
> just one “node”.
> On Sep 15, 2014, at 12:45 PM, Katy Ghantous <katyghantous at gmail.com>
> wrote:
> > Hi,
> > I am using DMDA to run in parallel TS to solves a set of N equations. I
> am using DMDAGetCorners in the RHSfunction with setting the stencil size at
> 2 to solve a set of coupled ODEs on 30 cores.
> > The machine has 32 cores (2 physical CPUs with 2x8 core each with speed
> of 3.4Ghz per core).
> > However, mpiexec with more than one core is showing no speedup.
> > Also at the configuring/testing stage for petsc on that machine, there
> was no speedup and it only reported one node.
> > Is there somehting wrong with how i configured petsc or is the approach
> inappropriate for the machine?
> > I am not sure what files (or sections of the code) you would need to be
> able to answer my question.
> > Thank you!
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140915/d0b64389/attachment-0001.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140915/d0b64389/attachment-0001.bin>
