[petsc-users] Valgrind Errors
James Balasalle James.Balasalle at digitalglobe.com
Fri Sep 12 13:39:16 CDT 2014
Hello,
I'm getting some valgrind errors in my PETSc code that looks like it's related to MatTranspose().  I just figured I was doing something wrong.  But I ran one of the examples (snes/ex70) which uses MatTranpose() through valgrind and see the same errors there as well.  It seems that when the result of a MatTranspose is used as input to a MatMatMult() call valgrind is unhappy.
Here's the valgrind output.  I'm not concerned with the first MPI uninitialized error.  But that invalid read of size 8 in mpiaij.c looks a bit concerning.
I'm probably doing something wrong.  Any ideas?
    James
bash-4.1$ valgrind ./ex70
==21117== Memcheck, a memory error detector
==21117== Copyright (C) 2002-2013, and GNU GPL'd, by Julian Seward et al.
==21117== Using Valgrind-3.9.0 and LibVEX; rerun with -h for copyright info
==21117== Command: ./ex70
==21117==
==21117== Syscall param writev(vector[...]) points to uninitialised byte(s)
==21117==    at 0x39898E0B2B: writev (in /lib64/libc-2.12.so)
==21117==    by 0x8996F16: mca_oob_tcp_msg_send_handler (oob_tcp_msg.c:249)
==21117==    by 0x8997F3C: mca_oob_tcp_peer_send (oob_tcp_peer.c:204)
==21117==    by 0x899A2DC: mca_oob_tcp_send_nb (oob_tcp_send.c:167)
==21117==    by 0x8388955: orte_rml_oob_send (rml_oob_send.c:136)
==21117==    by 0x8388B9F: orte_rml_oob_send_buffer (rml_oob_send.c:270)
==21117==    by 0x8DA4F97: modex (grpcomm_bad_module.c:573)
==21117==    by 0x6E31E6A: ompi_mpi_init (ompi_mpi_init.c:541)
==21117==    by 0x6E4860F: PMPI_Init_thread (pinit_thread.c:84)
==21117==    by 0x4DAA379: PetscInitialize (pinit.c:781)
==21117==    by 0x409E29: main (ex70.c:668)
==21117==  Address 0x9c7e261 is 161 bytes inside a block of size 256 alloc'd
==21117==    at 0x4A06C9C: realloc (vg_replace_malloc.c:687)
==21117==    by 0x6EB7FF2: opal_dss_buffer_extend (dss_internal_functions.c:63)
==21117==    by 0x6EB81B4: opal_dss_copy_payload (dss_load_unload.c:164)
==21117==    by 0x6E90C36: orte_grpcomm_base_pack_modex_entries (grpcomm_base_modex.c:861)
==21117==    by 0x8DA4F4C: modex (grpcomm_bad_module.c:563)
==21117==
==21117== Invalid read of size 8
==21117==    at 0x553E504: MatGetBrowsOfAoCols_MPIAIJ (mpiaij.c:5220)
==21117==    by 0x557D53D: MatMatMultSymbolic_MPIAIJ_MPIAIJ (mpimatmatmult.c:677)
==21117==    by 0x55758FC: MatMatMult_MPIAIJ_MPIAIJ (mpimatmatmult.c:33)
==21117==    by 0x5601808: MatMatMult (matrix.c:8714)
==21117==    by 0x4067D0: StokesSetupApproxSchur (ex70.c:379)
==21117==    by 0x406DB5: StokesSetupMatrix (ex70.c:399)
==21117==    by 0x40A0D3: main (ex70.c:679)
==21117==  Address 0x9cdd420 is 0 bytes after a block of size 48 alloc'd
==21117==    at 0x4A055DC: memalign (vg_replace_malloc.c:755)
==21117==    by 0x4D42117: PetscMallocAlign (mal.c:27)
==21117==    by 0x5016A8A: VecScatterCreate (vscat.c:1168)
==21117==    by 0x5547B10: MatSetUpMultiply_MPIAIJ (mmaij.c:116)
==21117==    by 0x5509F30: MatAssemblyEnd_MPIAIJ (mpiaij.c:702)
==21117==    by 0x55D978A: MatAssemblyEnd (matrix.c:4901)
==21117==    by 0x551D7AD: MatTranspose_MPIAIJ (mpiaij.c:2024)
==21117==    by 0x55D394A: MatTranspose (matrix.c:4382)
==21117==    by 0x405CE4: StokesSetupMatBlock10 (ex70.c:337)
==21117==    by 0x406C60: StokesSetupMatrix (ex70.c:396)
==21117==
==21117==    at 0x553E516: MatGetBrowsOfAoCols_MPIAIJ (mpiaij.c:5221)
==21117==  Address 0x9cdd3d0 is not stack'd, malloc'd or (recently) free'd
==21117==
==21117==    at 0x553E64D: MatGetBrowsOfAoCols_MPIAIJ (mpiaij.c:5226)
==21117==  Address 0x9cdd3b0 is 0 bytes after a block of size 16 alloc'd
==21117==    by 0x5016A58: VecScatterCreate (vscat.c:1168)
==21117==
==21117==    at 0x553E66B: MatGetBrowsOfAoCols_MPIAIJ (mpiaij.c:5228)
==21117==  Address 0x9cdd3b8 is 8 bytes after a block of size 16 alloc'd
==21117==
==21117==    by 0x557C680: MatMatMultNumeric_MPIAIJ_MPIAIJ_Scalable (mpimatmatmult.c:560)
==21117==    by 0x5575BBE: MatMatMult_MPIAIJ_MPIAIJ (mpimatmatmult.c:39)
==21117==
==21117==
==21117==
==21117==
 residual u = 3.56267e-06
residual p = 1.14951e-05
residual [u,p] = 1.20346e-05
discretization error u = 0.0106477
discretization error p = 1.85783
discretization error [u,p] = 1.85786
==21117==
==21117== HEAP SUMMARY:
==21117==     in use at exit: 345,301 bytes in 3,773 blocks
==21117==   total heap usage: 24,730 allocs, 20,957 frees, 16,608,714 bytes allocated
==21117==
==21117== LEAK SUMMARY:
==21117==    definitely lost: 42,743 bytes in 40 blocks
==21117==    indirectly lost: 11,134 bytes in 28 blocks
==21117==      possibly lost: 0 bytes in 0 blocks
==21117==    still reachable: 291,424 bytes in 3,705 blocks
==21117==         suppressed: 0 bytes in 0 blocks
==21117== Rerun with --leak-check=full to see details of leaked memory
==21117==
==21117== For counts of detected and suppressed errors, rerun with: -v
==21117== Use --track-origins=yes to see where uninitialised values come from
==21117== ERROR SUMMARY: 9 errors from 9 contexts (suppressed: 6 from 6)
This electronic communication and any attachments may contain confidential and proprietary
information of DigitalGlobe, Inc. If you are not the intended recipient, or an agent or employee
responsible for delivering this communication to the intended recipient, or if you have received
this communication in error, please do not print, copy, retransmit, disseminate or
otherwise use the information. Please indicate to the sender that you have received this
communication in error, and delete the copy you received. DigitalGlobe reserves the
right to monitor any electronic communication sent or received by its employees, agents
or representatives.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140912/6a2a0016/attachment-0001.html>
