[petsc-users] how to change KSP of A00 inside the Schur complement?
Klaij, Christiaan C.Klaij at marin.nl
Tue Sep 9 02:31:23 CDT 2014
In the program below, I'm using PCFieldSplitGetSubKSP to get the
sub KSP's of a Schur fieldsplit preconditioner. I'm setting
fieldsplit_0 to BICG+ILU and fieldsplit_1 to CG+ICC. Running
$ ./fieldsplittry -ksp_view
shows that this works as expected (full output below). Now, I
would like to change the KSP of A00 inside the Schur complement,
so I'm running
$ ./fieldsplittry -fieldsplit_1_inner_ksp_type preonly -fieldsplit_1_inner_pc_type jacobi -ksp_view
(full output below). To my surprise, this shows the
fieldsplit_1_inner_ KSP to be BICG+ILU while the fieldsplit_0_
KSP is changed to preonly; the fieldsplit_0_ PC is still ILU (no
Jacobi anywhere).  What am I doing wrong this time?
The bottom line is: how do I set the KSP of A00 inside the Schur
complement to preonly+jacobi while keeping the other settings?
Preferably directly in the code without command-line arguments.
Chris
$ cat fieldsplittry.F90
program fieldsplittry
  use petscksp
  implicit none
#include <finclude/petsckspdef.h>
  PetscErrorCode :: ierr
  PetscInt       :: size,i,j,start,end,n=4,numsplit=1
  PetscScalar    :: zero=0.0,one=1.0
  Vec            :: diag3,x,b
  Mat            :: A,subA(4),myS
  PC             :: pc,subpc(2)
  KSP            :: ksp,subksp(2)
  IS             :: isg(2)
  call PetscInitialize(PETSC_NULL_CHARACTER,ierr); CHKERRQ(ierr)
  call MPI_Comm_size(PETSC_COMM_WORLD,size,ierr); CHKERRQ(ierr);
  ! vectors
  call VecCreateMPI(MPI_COMM_WORLD,3*n,PETSC_DECIDE,diag3,ierr); CHKERRQ(ierr)
  call VecSet(diag3,one,ierr); CHKERRQ(ierr)
  call VecCreateMPI(MPI_COMM_WORLD,4*n,PETSC_DECIDE,x,ierr); CHKERRQ(ierr)
  call VecSet(x,zero,ierr); CHKERRQ(ierr)
  call VecDuplicate(x,b,ierr); CHKERRQ(ierr)
  call VecSet(b,one,ierr); CHKERRQ(ierr)
  ! matrix a00
  call MatCreateAIJ(MPI_COMM_WORLD,3*n,3*n,PETSC_DECIDE,PETSC_DECIDE,1,PETSC_NULL_INTEGER,0,PETSC_NULL_INTEGER,subA(1),ierr);CHKERRQ(ierr)
  call MatDiagonalSet(subA(1),diag3,INSERT_VALUES,ierr);CHKERRQ(ierr)
  call MatAssemblyBegin(subA(1),MAT_FINAL_ASSEMBLY,ierr);CHKERRQ(ierr)
  call MatAssemblyEnd(subA(1),MAT_FINAL_ASSEMBLY,ierr);CHKERRQ(ierr)
  ! matrix a01
  call MatCreateAIJ(MPI_COMM_WORLD,3*n,n,PETSC_DECIDE,PETSC_DECIDE,1,PETSC_NULL_INTEGER,1,PETSC_NULL_INTEGER,subA(2),ierr);CHKERRQ(ierr)
  call MatGetOwnershipRange(subA(2),start,end,ierr);CHKERRQ(ierr);
  do i=start,end-1
     j=mod(i,size*n)
     call MatSetValue(subA(2),i,j,one,INSERT_VALUES,ierr);CHKERRQ(ierr)
  end do
  call MatAssemblyBegin(subA(2),MAT_FINAL_ASSEMBLY,ierr);CHKERRQ(ierr)
  call MatAssemblyEnd(subA(2),MAT_FINAL_ASSEMBLY,ierr);CHKERRQ(ierr)
  ! matrix a10
  call  MatTranspose(subA(2),MAT_INITIAL_MATRIX,subA(3),ierr);CHKERRQ(ierr)
  ! matrix a11 (empty)
  call MatCreateAIJ(MPI_COMM_WORLD,n,n,PETSC_DECIDE,PETSC_DECIDE,0,PETSC_NULL_INTEGER,0,PETSC_NULL_INTEGER,subA(4),ierr);CHKERRQ(ierr)
  call MatAssemblyBegin(subA(4),MAT_FINAL_ASSEMBLY,ierr);CHKERRQ(ierr)
  call MatAssemblyEnd(subA(4),MAT_FINAL_ASSEMBLY,ierr);CHKERRQ(ierr)
  ! nested mat [a00,a01;a10,a11]
  call MatCreateNest(MPI_COMM_WORLD,2,PETSC_NULL_OBJECT,2,PETSC_NULL_OBJECT,subA,A,ierr);CHKERRQ(ierr)
  call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,ierr);CHKERRQ(ierr)
  call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,ierr);CHKERRQ(ierr)
  call MatNestGetISs(A,isg,PETSC_NULL_OBJECT,ierr);CHKERRQ(ierr);
  ! KSP and PC
  call KSPCreate(MPI_COMM_WORLD,ksp,ierr);CHKERRQ(ierr)
  call KSPSetOperators(ksp,A,A,ierr);CHKERRQ(ierr)
  call KSPSetType(ksp,KSPGCR,ierr);CHKERRQ(ierr)
  call KSPGetPC(ksp,pc,ierr);CHKERRQ(ierr)
  call PCSetType(pc,PCFIELDSPLIT,ierr);CHKERRQ(ierr)
  call PCFieldSplitSetType(pc,PC_COMPOSITE_SCHUR,ierr);CHKERRQ(ierr)
  call PCFieldSplitSetIS(pc,"0",isg(1),ierr);CHKERRQ(ierr)
  call PCFieldSplitSetIS(pc,"1",isg(2),ierr);CHKERRQ(ierr)
  call PCFieldSplitSetSchurFactType(pc,PC_FIELDSPLIT_SCHUR_FACT_LOWER,ierr);CHKERRQ(ierr)
  call PCFieldSplitSetSchurPre(pc,PC_FIELDSPLIT_SCHUR_PRE_SELFP,PETSC_NULL_OBJECT,ierr);CHKERRQ(ierr)
  call KSPSetUp(ksp,ierr);CHKERRQ(ierr);
  call PCFieldSplitGetSubKSP(pc,numsplit,subksp,ierr);CHKERRQ(ierr)
  call KSPSetType(subksp(1),KSPBICG,ierr);CHKERRQ(ierr)
  call KSPGetPC(subksp(1),subpc(1),ierr);CHKERRQ(ierr)
  call PCSetType(subpc(1),PCILU,ierr);CHKERRQ(ierr)
  call KSPSetType(subksp(2),KSPCG,ierr);CHKERRQ(ierr)
  call KSPGetPC(subksp(2),subpc(2),ierr);CHKERRQ(ierr)
  call PCSetType(subpc(2),PCICC,ierr);CHKERRQ(ierr)
!  call PetscFree(subksp);CHKERRQ(ierr);
  call KSPSetFromOptions(ksp,ierr);CHKERRQ(ierr)
  call KSPSolve(ksp,b,x,ierr);CHKERRQ(ierr)
  call KSPGetSolution(ksp,x,ierr);CHKERRQ(ierr)
!  call VecView(x,PETSC_VIEWER_STDOUT_WORLD,ierr);CHKERRQ(ierr)
  call PetscFinalize(ierr)
end program fieldsplittry
KSP Object: 1 MPI processes
  type: gcr
    GCR: restart = 30
    GCR: restarts performed = 1
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
  right preconditioning
  using UNPRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
  type: fieldsplit
    FieldSplit with Schur preconditioner, factorization LOWER
    Preconditioner for the Schur complement formed from Sp, an assembled approximation to S, which uses (the lumped) A00's diagonal's inverse
    Split info:
    Split number 0 Defined by IS
    Split number 1 Defined by IS
    KSP solver for A00 block
      KSP Object:      (fieldsplit_0_)       1 MPI processes
        type: bicg
        left preconditioning
        using PRECONDITIONED norm type for convergence test
      PC Object:      (fieldsplit_0_)       1 MPI processes
        type: ilu
          ILU: out-of-place factorization
          0 levels of fill
          tolerance for zero pivot 2.22045e-14
          using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
          matrix ordering: natural
          factor fill ratio given 1, needed 1
            Factored matrix follows:
              Mat Object:               1 MPI processes
                type: seqaij
                rows=12, cols=12
                package used to perform factorization: petsc
                total: nonzeros=12, allocated nonzeros=12
                total number of mallocs used during MatSetValues calls =0
                  not using I-node routines
        linear system matrix = precond matrix:
        Mat Object:        (fieldsplit_0_)         1 MPI processes
          type: seqaij
          rows=12, cols=12
    KSP solver for S = A11 - A10 inv(A00) A01
      KSP Object:      (fieldsplit_1_)       1 MPI processes
        type: cg
      PC Object:      (fieldsplit_1_)       1 MPI processes
        type: icc
          0 levels of fill
          using Manteuffel shift [POSITIVE_DEFINITE]
                type: seqsbaij
                rows=4, cols=4
                total: nonzeros=4, allocated nonzeros=4
                    block size is 1
        linear system matrix followed by preconditioner matrix:
        Mat Object:        (fieldsplit_1_)         1 MPI processes
          type: schurcomplement
          rows=4, cols=4
            Schur complement A11 - A10 inv(A00) A01
            A11
                type: seqaij
                rows=4, cols=4
                total: nonzeros=0, allocated nonzeros=0
                  using I-node routines: found 1 nodes, limit used is 5
            A10
                type: seqaij
                rows=4, cols=12
            KSP of A00
                type: bicg
                type: ilu
                  0 levels of fill
                        type: seqaij
                        rows=12, cols=12
                  type: seqaij
                  rows=12, cols=12
            A01
                type: seqaij
                rows=12, cols=4
          type: seqaij
          rows=4, cols=4
    type: nest
    rows=16, cols=16
      Matrix object:
        type=nest, rows=2, cols=2
        MatNest structure:
        (0,0) : prefix="fieldsplit_0_", type=seqaij, rows=12, cols=12
        (0,1) : type=seqaij, rows=12, cols=4
        (1,0) : type=seqaij, rows=4, cols=12
        (1,1) : prefix="fieldsplit_1_", type=seqaij, rows=4, cols=4
  type: gcr
    GCR: restart = 30
  type: fieldsplit
    Split info:
        type: preonly
        using NONE norm type for convergence test
        type: ilu
          0 levels of fill
                type: seqaij
                rows=12, cols=12
          type: seqaij
          rows=12, cols=12
        type: cg
        type: icc
          0 levels of fill
                type: seqsbaij
                rows=4, cols=4
                    block size is 1
          rows=4, cols=4
            A11
                type: seqaij
                rows=4, cols=4
            A10
                type: seqaij
                rows=4, cols=12
            KSP of A00
              KSP Object:              (fieldsplit_1_inner_)               1 MPI processes
                type: bicg
              PC Object:              (fieldsplit_1_inner_)               1 MPI processes
                type: ilu
                  0 levels of fill
                        type: seqaij
                        rows=12, cols=12
                  type: seqaij
                  rows=12, cols=12
            A01
                type: seqaij
                rows=12, cols=4
          type: seqaij
          rows=4, cols=4
    type: nest
    rows=16, cols=16
      Matrix object:
        MatNest structure:
dr. ir. Christiaan Klaij
CFD Researcher
Research & Development
E mailto:C.Klaij at marin.nl
T +31 317 49 33 44
MARIN
2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
