[petsc-users] FETI-DP implementation and call sequence
Sat Sep 6 01:18:58 CDT 2014
On Fri, 5 Sep 2014, Jed Brown wrote:
> Satish Balay <balay at mcs.anl.gov> writes:
> > Perhaps the following is the fix [with proper comments, more error
> > checks?]. But someone more familiar with this code should check this..
> > Satish
> > $ git diff |cat
> > diff --git a/src/ksp/pc/impls/is/pcis.c b/src/ksp/pc/impls/is/pcis.c
> > index dab5836..0fa0217 100644
> > --- a/src/ksp/pc/impls/is/pcis.c
> > +++ b/src/ksp/pc/impls/is/pcis.c
> > @@ -140,6 +140,8 @@ PetscErrorCode  PCISSetUp(PC pc)
> >    ierr = PetscObjectTypeCompare((PetscObject)pc->pmat,MATIS,&flg);CHKERRQ(ierr);
> >    if (!flg) SETERRQ(PetscObjectComm((PetscObject)pc),PETSC_ERR_ARG_WRONG,"Preconditioner type of Neumann Neumman requires matrix of type MATIS");
> >    matis = (Mat_IS*)pc->pmat->data;
> > +  PetscObjectReference((PetscObject)pc->pmat);
> > +  pcis->pmat = pc->pmat;
> Uh, PCISSetUp can be called more than once?
I have no idea..
> And simply destroying the pcis->pmat reference is not enough because
> that extra reference could significantly increase the peak memory usage.
Curently the object (pc->pmat) is destroyed at the end anyway [perhaps
duing PCDestroy()]. This fix changes the order a bit so that its
destoryed only after its last use.
> The right solution is to not hold that reference and not hold the info.
> >    pcis->pure_neumann = matis->pure_neumann;
> > @@ -378,8 +380,9 @@ PetscErrorCode  PCISDestroy(PC pc)
> >    ierr = VecScatterDestroy(&pcis->global_to_B);CHKERRQ(ierr);
> >    ierr = PetscFree(pcis->work_N);CHKERRQ(ierr);
> >    if (pcis->ISLocalToGlobalMappingGetInfoWasCalled) {
> > -    ierr = ISLocalToGlobalMappingRestoreInfo((ISLocalToGlobalMapping)0,&(pcis->n_neigh),&(pcis->neigh),&(pcis->n_shared),&(pcis->shared));CHKERRQ(ierr);
> > +    ierr = ISLocalToGlobalMappingRestoreInfo(((Mat_IS*)pcis->pmat->data)->mapping,&(pcis->n_neigh),&(pcis->neigh),&(pcis->n_shared),&(pcis->shared));CHKERRQ(ierr);
> Why not restore the info at the place it is gotten, like we do with
> every other accessor?
Looks like this info is stashed in 'pcis->n_neigh, pcis->neigh' etc -
and reused later multple times. [perhaps preventing multiple
mallocs/frees]
$ git grep -l 'pcis->n_neigh'
src/ksp/pc/impls/bddc/bddcfetidp.c
src/ksp/pc/impls/is/nn/nn.c
Or perhaps this info should be stashed in the IS so multiple
ISLocalToGlobalMappingGetInfo() calls are cheap [but then the malloc'd
memory will live until IS is destroyed anyway]
I guess there are 2 issues you are touching on. A fix for this crash -
and code cleanup. My patch gets the examples working.
But I'll defer both isses to Stefano [asuming he is aquainted with the
above sources].
Satish
> > +  ierr = MatDestroy(&pcis->pmat);CHKERRQ(ierr);
> >    ierr = PetscObjectComposeFunction((PetscObject)pc,"PCISSetUseStiffnessScaling_C",NULL);CHKERRQ(ierr);
> >    ierr = PetscObjectComposeFunction((PetscObject)pc,"PCISSetSubdomainScalingFactor_C",NULL);CHKERRQ(ierr);
> >    ierr = PetscObjectComposeFunction((PetscObject)pc,"PCISSetSubdomainDiagonalScaling_C",NULL);CHKERRQ(ierr);
> > diff --git a/src/ksp/pc/impls/is/pcis.h b/src/ksp/pc/impls/is/pcis.h
> > index 4a42cf9..736ea8c 100644
> > --- a/src/ksp/pc/impls/is/pcis.h
> > +++ b/src/ksp/pc/impls/is/pcis.h
> > @@ -73,6 +73,7 @@ typedef struct {
> >    /* We need:        */
> >    /* proc[k].loc_to_glob(proc[k].shared[i][m]) == proc[l].loc_to_glob(proc[l].shared[j][m])   */
> >    /* for all 0 <= m < proc[k].n_shared[i], or equiv'ly, for all 0 <= m < proc[l].n_shared[j]  */
> > +  Mat pmat;
> >  } PC_IS;
> >  PETSC_EXTERN PetscErrorCode PCISSetUp(PC pc);
