[petsc-users] FETI-DP implementation and call sequence
Alp Kalpalp alpkalpalp at gmail.com
Fri Sep 5 17:48:14 CDT 2014
Sorry for the late response. I tried the same sequence. But I need to say
that I use git pull before it. Error is now during make all
you may find the logs in the attachment.
thanks beforehand
regards,
On Fri, Sep 5, 2014 at 2:51 PM, Matthew Knepley <knepley at gmail.com> wrote:
> Please send your configure.log and make.log
>   Thanks,
>     Matt
> On Fri, Sep 5, 2014 at 4:27 AM, Alp Kalpalp <alpkalpalp at gmail.com> wrote:
>> As I said before, I have checked out "master" branch and merged with your
>> stefano_zampini/pcbddc-primalfixe branch. configured, compiled successfully.
>> I have used --with-pcbddc option in configure as Barry suggested.
>> However, tests are failed with following reason:
>> akalpalp at a-kalpalp ~/petsc
>> $ make PETSC_DIR=/home/akalpalp/petsc PETSC_ARCH=arch-mswin-c-debug test
>> Running test examples to verify correct installation
>> Using PETSC_DIR=/home/akalpalp/petsc and PETSC_ARCH=arch-mswin-c-debug
>> *******************Error detected during compile or
>> link!*******************
>> See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> /home/akalpalp/petsc/src/snes/examples/tutorials ex19
>> /home/akalpalp/petsc/arch-mswin-c-debug/bin/mpicc -o ex19.o -c -Wall
>> -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0
>> -I/home/akalpalp/petsc/include
>> -I/home/akalpalp/petsc/arch-mswin-c-debug/include    `pwd`/ex19.c
>> /home/akalpalp/petsc/arch-mswin-c-debug/bin/mpicc -Wall -Wwrite-strings
>> -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  -o ex19  ex19.o
>> -L/home/akalpalp/petsc/arch-mswin-c-debug/lib  -lpetsc
>> -Wl,-rpath,/home/akalpalp/petsc/arch-mswin-c-debug/lib -lf2clapack
>> -lf2cblas -lpthread -lgdi32 -luser32 -ladvapi32 -lkernel32 -ldl
>> /home/akalpalp/petsc/arch-mswin-c-debug/lib/libpetsc.a(pcregis.o):pcregis.c:(.rdata$.refptr.PCCreate_BDDC[.refptr.PCCreate_BDDC]+0x0):
>> undefined reference to `PCCreate_BDDC'
>> collect2: error: ld returned 1 exit status
>> makefile:108: recipe for target 'ex19' failed
>> make[3]: [ex19] Error 1 (ignored)
>> /usr/bin/rm -f ex19.o
>> Completed test examples
>> Now to evaluate the computer systems you plan use - do:
>> make PETSC_DIR=/home/akalpalp/petsc PETSC_ARCH=arch-mswin-c-debug streams
>> NPMAX=<number of MPI processes you intend to use>
>> On Thu, Sep 4, 2014 at 5:37 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>    This is likely due to the horrible horrible fact that some of the
>>> bddc files only get compiled if ./configure is run with the option
>>> --with-pcbddc you will need to rerun ./configure and then make with that
>>> option.
>>>    I pray that someone removes that horrible confusing configure option.
>>>    Barry
>>> On Sep 4, 2014, at 8:52 AM, Alp Kalpalp <alpkalpalp at gmail.com> wrote:
>>> > Dear Stefano,
>>> stefano_zampini/pcbddc-primalfixe branch. configured, compiled and all
>>> tests are completed successfully.
>>> > Then, I tried to compile ex59 with make ex59, it results in unresolved
>>> external error. I believe your bddc_feti files are not included in
>>> compilation.
>>> > Since I am not experienced on how to solve issues in Petsc, I need to
>>> ask several questions;
>>> > 1-) Are there any global settings to add additonal directories to
>>> compilation  (src\ksp\pc\impls\bddc)
>>> > 2-) or should I include these files on top of ex59 (AFAIK, including
>>> .c files is not a good thing)
>>> > 3-) and finally what is the better way of helping you (creating
>>> another branch from yours or what)
>>> > Thanks in advance
>>> > On Wed, Sep 3, 2014 at 6:18 PM, Stefano Zampini <
>>> stefano.zampini at gmail.com> wrote:
>>> > FETIDP is in PETSc as a byproduct of the BDDC preconditioner (one is
>>> the dual of the other) and it does not have its own classes so far.
>>> > That said, you can experiment with FETI-DP only after having setup a
>>> BDDC preconditioner with the options and customization you prefer.
>>> > Use
>>> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/KSP/index.html
>>> for manual pages.
>>> > For an 'how to' with FETIDP, please see
>>> src/ksp/ksp/examples/tutorials/ex.59.c as Jed told you, specifically look
>>> at ComputeKSPFETIDP for obtaining the FETIDP matrix F (implemented
>>> Matrix-free) and the optimal FETIDP dirichlet preconditioner. Once you have
>>> F, you can use PCBDDCMatFETIDPGetRHS and PCBDDCMatFetiDPGetSolution to
>>> obtain a right-hand side for the FETIDP system and a physical solution from
>>> the solution of the FETIDP system.
>>> > I would recommend you to use the development version of the library
>>> and either use the ‘next’ branch or the ‘master' branch after having merged
>>> in the branch stefano_zampini/pcbddc-primalfixes. Note that ‘next’ also
>>> contains the new deluxe scaling operator for BDDC which is not available to
>>> use with FETI-DP.
>>> > If you have any other questions which can be useful for other PETSc
>>> users, please use the mailing list; otherwise you can contact me personally.
>>> > Stefano
>>> > On Sep 3, 2014, at 5:19 PM, Jed Brown <jed at jedbrown.org> wrote:
>>> >> Matthew Knepley <knepley at gmail.com> writes:
>>> >>>> 1- Is it possible to complete a FETI-DP solution with the provided
>>> >>>> functions in current PetSc release?
>>> >>> There is no FETI-DP in PETSc.
>>> >> Wrong.  There is PCBDDC, which has the same eigenvalues as FETI-DP.
>>> You
>>> >> can enable it by configuring --with-pcbddc.  This will be turned on by
>>> >> default soon.  It is fairly new, so you should use the branch 'master'
>>> >> instead of the release.  It has an option to do FETI-DP instead of
>>> BDDC.
>>> >> See src/ksp/ksp/examples/tutorials/ex59.c.
>>> >> For either of these methods, you have to assemble a MATIS.  If you use
>>> >> MatSetValuesLocal, most of your assembly code can stay the same.
>>> >> Hopefully we can get better examples before the next release.  Stefano
>>> >> (the author of PCBDDC, Cc'd) tests mostly with external packages, but
>>> we
>>> >> really need more complete tests within PETSc.
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140906/55d954ab/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140906/55d954ab/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140906/55d954ab/attachment-0003.obj>
