[petsc-users] Using MUMPS and (PT)SCOTCH with PETSC
Fri Sep 5 11:25:16 CDT 2014
   Set a new value for PETSC_ARCH
   Obtain the Scotch 5.1.12b tar ball.  Used ./configure —download-ptscotch=nameoftarball.tar.gz —download-mumps —download-scalapack etc
   It will use the provided tar ball instead of downloading 6.0.0  Send errors to petsc-maint at mcs.anl.gov
   Barry
On Sep 5, 2014, at 10:06 AM, Evan Um <evanum at gmail.com> wrote:
> Dear PETSC users,
> I tried to use SCOTCH 5.1.12b in my PETSC codes since MUMPS has compatibility issues with the latest SCOTCH library.
> I was told that SCOTCH/6.0.0 that comes with PETSC/3.5.0 is automatically downloaded and installed. Is it still possible to use old SCOTCH library 5.1.2b in PETSC? As mentioned in MUMPS's FAQ, MUMPS has compatibility issues with the latest SCOTCH. MUMPS developers suggest that MUMPS should work with SCOTCH 5.1.12b. In advance, thanks for your kind comments.
> Regards,
> Evan
> Errors from MUMPS with SCOTCH 6.0.0 and PETSC 3.5.0:
> (5): ERROR: stratParserParse: invalid method parameter name "type", before "h,vert=100,low=h{pass=10},asc=b{width=3,bnd=f{bal=0.2},org=h{pass=10}f{bal=0.2}}}}},ole=s,ose=s,osq=n{sep=/(vert>120)?m{type=h,vert=100,low=h{pass=10},asc=b{width=3,bnd=f{bal=0.2},org=h{pass=10}f{bal=0.2}}};,ole=f{cmin=15,cmax=100000,frat=0.0},ose=g}}
