[petsc-users] fieldsplit_0_ monitor in combination with selfp
Thu Sep 4 17:36:39 CDT 2014
On Thu, Sep 4, 2014 at 7:26 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> Sorry, here's the ksp_view. I'm expecting
> -fieldsplit_1_inner_ksp_type preonly
> to set the ksp(A00) in the Schur complement only, but it seems to set it
> in the inv(A00) of the diagonal as well.
I think something is wrong in your example (we strongly advise against
using MatNest directly). I cannot reproduce this using SNES ex62:
  ./config/builder2.py check src/snes/examples/tutorials/ex62.c
--testnum=36 --args="-fieldsplit_pressure_inner_ksp_type preonly
-fieldsplit_pressure_inner_pc_type jacobi"
which translates to
  ex62 -run_type full -refinement_limit 0.00625 -bc_type dirichlet
-interpolate 1 -vel_petscspace_order 2 -pres_petscspace_order 1 -ksp_type
fgmres -ksp_gmres_restart 100 -ksp_rtol 1.0e-9 -pc_type fieldsplit
-pc_fieldsplit_type schur -pc_fieldsplit_schur_factorization_type full
-fieldsplit_pressure_ksp_rtol 1e-10 -fieldsplit_velocity_ksp_type gmres
-fieldsplit_velocity_pc_type lu -fieldsplit_pressure_pc_type jacobi
-snes_monitor_short -ksp_monitor_short -snes_converged_reason
-ksp_converged_reason -snes_view -show_solution 0
gives
  Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 1
SNES Object: 1 MPI processes
  type: newtonls
  maximum iterations=50, maximum function evaluations=10000
  tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
  total number of linear solver iterations=20
  total number of function evaluations=2
  SNESLineSearch Object:   1 MPI processes
    type: bt
      interpolation: cubic
      alpha=1.000000e-04
    maxstep=1.000000e+08, minlambda=1.000000e-12
    tolerances: relative=1.000000e-08, absolute=1.000000e-15,
lambda=1.000000e-08
    maximum iterations=40
  KSP Object:   1 MPI processes
    type: fgmres
      GMRES: restart=100, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
      GMRES: happy breakdown tolerance 1e-30
    maximum iterations=10000, initial guess is zero
    tolerances:  relative=1e-09, absolute=1e-50, divergence=10000
    right preconditioning
    has attached null space
    using UNPRECONDITIONED norm type for convergence test
  PC Object:   1 MPI processes
    type: fieldsplit
      FieldSplit with Schur preconditioner, factorization FULL
      Preconditioner for the Schur complement formed from A11
      Split info:
      Split number 0 Defined by IS
      Split number 1 Defined by IS
      KSP solver for A00 block
        KSP Object:        (fieldsplit_velocity_)         1 MPI processes
          type: gmres
            GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
          tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
          left preconditioning
          using PRECONDITIONED norm type for convergence test
        PC Object:        (fieldsplit_velocity_)         1 MPI processes
          type: lu
            LU: out-of-place factorization
            tolerance for zero pivot 2.22045e-14
            matrix ordering: nd
            factor fill ratio given 5, needed 3.45047
              Factored matrix follows:
                Mat Object:                 1 MPI processes
                  type: seqaij
                  rows=962, cols=962
                  package used to perform factorization: petsc
                  total: nonzeros=68692, allocated nonzeros=68692
                  total number of mallocs used during MatSetValues calls =0
                    using I-node routines: found 456 nodes, limit used is 5
          linear system matrix = precond matrix:
          Mat Object:          (fieldsplit_velocity_)           1 MPI
processes
            type: seqaij
            rows=962, cols=962
            total: nonzeros=19908, allocated nonzeros=19908
              using I-node routines: found 481 nodes, limit used is 5
      KSP solver for S = A11 - A10 inv(A00) A01
        KSP Object:        (fieldsplit_pressure_)         1 MPI processes
          type: gmres
          tolerances:  relative=1e-10, absolute=1e-50, divergence=10000
        PC Object:        (fieldsplit_pressure_)         1 MPI processes
          type: jacobi
          linear system matrix followed by preconditioner matrix:
          Mat Object:          (fieldsplit_pressure_)           1 MPI
processes
            type: schurcomplement
            rows=145, cols=145
              Schur complement A11 - A10 inv(A00) A01
              A11
      1 MPI processes
                  type: seqaij
                  rows=145, cols=145
                  total: nonzeros=945, allocated nonzeros=945
                    not using I-node routines
              A10
                  type: seqaij
                  rows=145, cols=962
                  total: nonzeros=4466, allocated nonzeros=4466
              KSP of A00
                KSP Object:                (fieldsplit_pressure_inner_)
            1 MPI processes
                  type: preonly
divergence=10000
                  using NONE norm type for convergence test
                PC Object:                (fieldsplit_pressure_inner_)
            1 MPI processes
                  type: jacobi
            1 MPI processes
                    type: seqaij
                    rows=962, cols=962
=0
5
              A01
                  type: seqaij
                  rows=962, cols=145
processes
            type: seqaij
            rows=145, cols=145
      type: seqaij
      rows=1107, cols=1107
      total: nonzeros=29785, allocated nonzeros=29785
        using I-node routines: found 513 nodes, limit used is 5
   Matt
> Chris
>   0 KSP Residual norm 1.229687498638e+00
>     Residual norms for fieldsplit_1_ solve.
>     0 KSP Residual norm 7.185799114488e+01
>     1 KSP Residual norm 3.873274154012e+01
>   1 KSP Residual norm 1.107969383366e+00
>   type: fgmres
>   maximum iterations=1, initial guess is zero
>   type: fieldsplit
>     FieldSplit with Schur preconditioner, factorization LOWER
>     Preconditioner for the Schur complement formed from Sp, an assembled
> approximation to S, which uses (the lumped) A00's diagonal's inverse
>     Split info:
>       KSP Object:      (fieldsplit_0_)       1 MPI processes
>         type: preonly
>       PC Object:      (fieldsplit_0_)       1 MPI processes
>         type: bjacobi
>           block Jacobi: number of blocks = 1
>           Local solve is same for all blocks, in the following KSP and PC
> objects:
>           KSP Object:          (fieldsplit_0_sub_)           1 MPI
> processes
>             type: preonly
>           PC Object:          (fieldsplit_0_sub_)           1 MPI processes
>             type: ilu
>               ILU: out-of-place factorization
>               0 levels of fill
>               using diagonal shift on blocks to prevent zero pivot
> [INBLOCKS]
>               matrix ordering: natural
>               factor fill ratio given 1, needed 1
>                     type: seqaij
>                     rows=48, cols=48
>                     total: nonzeros=200, allocated nonzeros=200
> =0
>             Mat Object:            (fieldsplit_0_)             1 MPI
> processes
>               type: seqaij
>               rows=48, cols=48
>               total: nonzeros=200, allocated nonzeros=240
>         Mat Object:        (fieldsplit_0_)         1 MPI processes
>           type: mpiaij
>           rows=48, cols=48
>           total: nonzeros=200, allocated nonzeros=480
>             not using I-node (on process 0) routines
>       KSP Object:      (fieldsplit_1_)       1 MPI processes
>         type: gmres
>       PC Object:      (fieldsplit_1_)       1 MPI processes
>         type: bjacobi
> objects:
>           KSP Object:          (fieldsplit_1_sub_)           1 MPI
> processes
>             type: preonly
>           PC Object:          (fieldsplit_1_sub_)           1 MPI processes
>             type: bjacobi
> PC objects:
>               KSP Object:
> (fieldsplit_1_sub_sub_)               1 MPI processes
>                 type: preonly
> divergence=10000
>               PC Object:
>                 type: ilu
>                   0 levels of fill
> [INBLOCKS]
>                         type: seqaij
>                         rows=24, cols=24
>                         total: nonzeros=120, allocated nonzeros=120
> calls =0
>                   type: seqaij
>                   rows=24, cols=24
>               type: mpiaij
>               rows=24, cols=24
>         Mat Object:        (fieldsplit_1_)         1 MPI processes
>           rows=24, cols=24
>             A11
> processes
>                 type: mpiaij
>                 rows=24, cols=24
>                 total: nonzeros=0, allocated nonzeros=0
>                   using I-node (on process 0) routines: found 5 nodes,
> limit used is 5
>             A10
>               Mat Object:              (a10_)               1 MPI processes
>                 type: mpiaij
>                 rows=24, cols=48
>                 total: nonzeros=96, allocated nonzeros=96
>             KSP of A00
>               KSP Object:              (fieldsplit_1_inner_)
> 1 MPI processes
>                 type: preonly
> divergence=10000
>               PC Object:              (fieldsplit_1_inner_)
> 1 MPI processes
>                 type: jacobi
> 1 MPI processes
>                   type: mpiaij
>                   rows=48, cols=48
>             A01
>               Mat Object:              (a01_)               1 MPI processes
>                 type: mpiaij
>                 rows=48, cols=24
>                 total: nonzeros=96, allocated nonzeros=480
>           type: mpiaij
>           rows=24, cols=24
>     type: nest
>     rows=72, cols=72
>       Matrix object:
>         type=nest, rows=2, cols=2
>         MatNest structure:
>         (0,0) : prefix="fieldsplit_0_", type=mpiaij, rows=48, cols=48
>         (0,1) : prefix="a01_", type=mpiaij, rows=48, cols=24
>         (1,0) : prefix="a10_", type=mpiaij, rows=24, cols=48
>         (1,1) : prefix="fieldsplit_1_", type=mpiaij, rows=24, cols=24
> From: Matthew Knepley <knepley at gmail.com>
> Sent: Thursday, September 04, 2014 2:20 PM
> To: Klaij, Christiaan
> Cc: petsc-users at mcs.anl.gov
> Subject: Re: [petsc-users] fieldsplit_0_ monitor in combination with selfp
> On Thu, Sep 4, 2014 at 7:06 AM, Klaij, Christiaan  <C.Klaij at marin.nl>
> wrote:
>  I'm playing with the selfp option in fieldsplit using
> snes/examples/tutorials/ex70.c. For example:
> mpiexec -n 2 ./ex70 -nx 4 -ny 6 \
> -ksp_type fgmres \
> -pc_type fieldsplit \
> -pc_fieldsplit_type schur \
> -pc_fieldsplit_schur_fact_type lower \
> -pc_fieldsplit_schur_precondition selfp \
> -fieldsplit_1_inner_ksp_type preonly \
> -fieldsplit_1_inner_pc_type jacobi \
> -fieldsplit_0_ksp_monitor -fieldsplit_0_ksp_max_it 1 \
> -fieldsplit_1_ksp_monitor -fieldsplit_1_ksp_max_it 1 \
> -ksp_monitor -ksp_max_it 1
> gives the following output
>     0 KSP Residual norm 2.330138480101e+01
>     1 KSP Residual norm 1.609000846751e+01
>   1 KSP Residual norm 1.180287268335e+00
> To my suprise I don't see anything for the fieldsplit_0_ solve,
> why?
> Always run with -ksp_view for any solver question.
>   Thanks,
>     Matt
>    Furthermore, if I understand correctly the above should be
> exactly equivalent with
> -ksp_type fgmres \
> -user_ksp \
>     Residual norms for fieldsplit_0_ solve.
>     0 KSP Residual norm 5.486639587672e-01
>     1 KSP Residual norm 6.348354253703e-02
>     0 KSP Residual norm 2.321938107977e+01
>     1 KSP Residual norm 1.605484031258e+01
>   1 KSP Residual norm 1.183225251166e+00
> because -user_ksp replaces the Schur complement by the simple
> approximation A11 - A10 inv(diag(A00)) A01. Beside the missing
> fielsplit_0_ part, the numbers are pretty close but not exactly
> the same. Any explanation?
> Chris
> dr. ir. Christiaan Klaij
> CFD Researcher
> Research & Development
> E mailto:C.Klaij at marin.nl
> T +31 317 49 33 44
> MARIN
> 2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
> T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140904/a44718d3/attachment-0001.html>
