[petsc-users] PCFieldSplitSetSchurPre in fortran
Wed Sep 3 10:02:12 CDT 2014
On Wed, Sep 3, 2014 at 9:46 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
>   print *, PC_FIELDSPLIT_SCHUR_PRE_USER
> gives: 2.
> (changing to *_SELFP gives: This name does not have a type, and must have
> an explicit type.   [PC_FIELDSPLIT_SCHUR_PRE_SELFP])
I have
next:/PETSc3/petsc/petsc-pylith$ find include/finclude/ -type f | xargs
grep USER
find include/finclude/ -type f | xargs grep USER
include/finclude//petscerrordef.h:#define PETSC_ERR_USER             83
include/finclude//petscpc.h:      PetscEnum PC_FIELDSPLIT_SCHUR_PRE_USER
include/finclude//petscpc.h:      parameter (PC_FIELDSPLIT_SCHUR_PRE_USER=3)
include/finclude//petsctao.h:      PetscEnum TAO_CONVERGED_USER
include/finclude//petsctao.h:      PetscEnum TAO_DIVERGED_USER
include/finclude//petsctao.h:      parameter ( TAO_CONVERGED_USER = 8)
include/finclude//petsctao.h:      parameter ( TAO_DIVERGED_USER = -8)
Where could it possibly be getting this value from? I think from some
compiled module which you need to rebuild.
   Matt
> MARIN news: MARIN Report 112: Hydro-structural
> <http://www.marin.nl/web/News/News-items/MARIN-Report-112-Hydrostructural.htm>
> This e-mail may be confidential, privileged and/or protected by copyright.
> If you are not the intended recipient, you should return it to the sender
> immediately and delete your copy from your system.
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* Wednesday, September 03, 2014 4:44 PM
> *To:* Klaij, Christiaan
> *Cc:* petsc-users at mcs.anl.gov
> *Subject:* Re: [petsc-users] PCFieldSplitSetSchurPre in fortran
>   On Wed, Sep 3, 2014 at 9:43 AM, Klaij, Christiaan <C.Klaij at marin.nl>
> wrote:
>>   I'm sorry, how do I do that?
>  print it
>     Matt
>>  Chris
>> MARIN news: Applied Hydrodynamics of Floating Offshore Structures
>> course, Oct 8 - 10, Houston
>> <http://www.marin.nl/web/News/News-items/Applied-Hydrodynamics-of-Floating-Offshore-Structures-course-Oct-8-10-Houston.htm>
>> copyright. If you are not the intended recipient, you should return it to
>> the sender immediately and delete your copy from your system.
>> *Sent:* Wednesday, September 03, 2014 4:38 PM
>>   On Wed, Sep 3, 2014 at 9:23 AM, Klaij, Christiaan <C.Klaij at marin.nl>
>> wrote:
>>>  Matt,
>>> Thanks, after applying the fix to my petsc-3.5.1 install, the
>>> small Fortran program works as expected.
>>> Now, I would like to change the fortran strategy to the
>>> option "3) Using Fortran modules". So, in the small fortran
>>> program I replace these seven lines
>>> #include <finclude/petscsys.h>
>>> #include <finclude/petscis.h>
>>> #include <finclude/petscvec.h>
>>> #include <finclude/petscmat.h>
>>> #include <finclude/petscpc.h>
>>> #include <finclude/petscksp.h>
>>> #include <finclude/petscviewer.h>
>>> by the two following lines
>>> use petscksp
>>> #include <finclude/petsckspdef.>
>>> This still compiles but I get the two old problem back...
>>  I have no idea why. Can you look at the values of those enumerations?
>>    Matt
>>>  Chris
>>> *Sent:* Wednesday, September 03, 2014 2:12 PM
>>>   On Wed, Sep 3, 2014 at 7:00 AM, Klaij, Christiaan <C.Klaij at marin.nl>
>>> wrote:
>>>>   Matt,
>>>> Thanks for the fix. If I understand correctly, in an existing
>>>> install of petsc-3.5.1, I would only need to replace the
>>>> file "finclude/petscpc.h" by the new file for the fix to
>>>> work? (instead of downloading dev, configuring, installing on
>>>> various machines).
>>>  Yes
>>>     Matt
>>>>  Chris
>>>> MARIN news: Bas Buchner speaker at Lowpex conference at SMM Hamburg
>>>> <http://www.marin.nl/web/News/News-items/Bas-Buchner-speaker-at-Lowpex-conference-at-SMM-Hamburg.htm>
>>>> *Sent:* Tuesday, September 02, 2014 5:42 PM
>>>>   On Tue, Sep 2, 2014 at 2:08 AM, Klaij, Christiaan <C.Klaij at marin.nl>
>>>> wrote:
>>>>>   Matt,
>>>>> Attached is a small Fortran code that replicates the second problem.
>>>>  This was a Fortran define problem. I fixed it on next
>>>> https://bitbucket.org/petsc/petsc/branch/knepley/fix-pc-fieldsplit-fortran
>>>>  and it will be in maint and master tomorrow.
>>>>    Thanks,
>>>>       Matt
>>>>>  Chris
>>>>>       dr. ir. Christiaan Klaij
>>>>> CFD Researcher
>>>>>   Research & Development
>>>>> *MARIN*
>>>>>   2, Haagsteeg  E C.Klaij at marin.nl P.O. Box 28 T +31 317 49 39 11  6700
>>>>> AA Wageningen F +31 317 49 32 45  T  +31 317 49 33 44 The Netherlands I
>>>>>  www.marin.nl
>>>>> MARIN news: MARIN at SMM, Hamburg, September 9-12
>>>>> <http://www.marin.nl/web/News/News-items/MARIN-at-SMM-Hamburg-September-912.htm>
>>>>> *From:* Klaij, Christiaan
>>>>> *Sent:* Friday, August 29, 2014 4:42 PM
>>>>> *To:* Matthew Knepley
>>>>> *Subject:* RE: [petsc-users] PCFieldSplitSetSchurPre in fortran
>>>>>   Matt,
>>>>> The small test code (ex70) is in C and it works fine, the problem
>>>>> happens in a big Fortran code. I will try to replicate the
>>>>> problem in a small Fortran code, but that will take some time.
>>>>> Chris
>>>>> *Sent:* Friday, August 29, 2014 4:14 PM
>>>>>   On Fri, Aug 29, 2014 at 8:55 AM, Klaij, Christiaan <C.Klaij at marin.nl
>>>>> > wrote:
>>>>>> I'm trying PCFieldSplitSetSchurPre with
>>>>>> PC_FIELDSPLIT_SCHUR_PRE_SELFP in petsc-3.5.1 using fortran.
>>>>>> The first problem is that PC_FIELDSPLIT_SCHUR_PRE_SELFP seems to
>>>>>> be missing in fortran, I get the compile error:
>>>>>> This name does not have a type, and must have an explicit type.
>>>>>> while compilation works fine with _A11, _SELF and _USER.
>>>>>  Mark Adams has just fixed this.
>>>>>> The second problem is that the call doesn't seem to have any
>>>>>> effect. For example, I have
>>>>>> CALL PCFieldSplitSetSchurPre(pc,PC_FIELDSPLIT_SCHUR_PRE_USER,aa,ierr)
>>>>>> CALL
>>>>>> PCFieldSplitSetSchurFactType(pc,PC_FIELDSPLIT_SCHUR_FACT_LOWER,ierr)
>>>>>> This compiles and runs, but ksp_view tells me
>>>>>> PC Object:(sys_) 3 MPI processes
>>>>>>   type: fieldsplit
>>>>>>     FieldSplit with Schur preconditioner, factorization LOWER
>>>>>>     Preconditioner for the Schur complement formed from A11
>>>>>> So changing the factorization from the default FULL to LOWER did
>>>>>> work, but changing the preconditioner from A11 to USER didn't.
>>>>>> I've also tried to run directly from the command line using
>>>>>> -sys_pc_fieldsplit_schur_precondition user -sys_ksp_view
>>>>>> This works in the sense that I don't get the "WARNING! There are
>>>>>> options you set that were not used!" message, but still ksp_view
>>>>>> reports A11 instead of user provided matrix.
>>>>>  Can you send a small test code, since I use this everyday here and
>>>>> it works.
>>>>>    Thanks,
>>>>>       Matt
>>>>>> Chris
>>>>>> CFD Researcher
>>>>>> E mailto:C.Klaij at marin.nl
>>>>>> T +31 317 49 33 44
>>>>>> MARIN
>>>>>> 2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
>>>>>> T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140903/2d6c7eb0/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140903/2d6c7eb0/attachment-0002.jpe>
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140903/2d6c7eb0/attachment-0003.jpe>
