[petsc-users] PCFieldSplitSetSchurPre in fortran
Wed Sep 3 09:38:26 CDT 2014
On Wed, Sep 3, 2014 at 9:23 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
>  Matt,
> Thanks, after applying the fix to my petsc-3.5.1 install, the
> small Fortran program works as expected.
> Now, I would like to change the fortran strategy to the
> option "3) Using Fortran modules". So, in the small fortran
> program I replace these seven lines
> #include <finclude/petscsys.h>
> #include <finclude/petscis.h>
> #include <finclude/petscvec.h>
> #include <finclude/petscmat.h>
> #include <finclude/petscpc.h>
> #include <finclude/petscksp.h>
> #include <finclude/petscviewer.h>
> by the two following lines
> use petscksp
> #include <finclude/petsckspdef.>
> This still compiles but I get the two old problem back...
I have no idea why. Can you look at the values of those enumerations?
  Matt
> Chris
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* Wednesday, September 03, 2014 2:12 PM
> *To:* Klaij, Christiaan
> *Cc:* petsc-users at mcs.anl.gov
> *Subject:* Re: [petsc-users] PCFieldSplitSetSchurPre in fortran
>   On Wed, Sep 3, 2014 at 7:00 AM, Klaij, Christiaan <C.Klaij at marin.nl>
> wrote:
>>   Matt,
>> Thanks for the fix. If I understand correctly, in an existing
>> install of petsc-3.5.1, I would only need to replace the
>> file "finclude/petscpc.h" by the new file for the fix to
>> work? (instead of downloading dev, configuring, installing on
>> various machines).
>  Yes
>     Matt
>>  Chris
>> MARIN news: Bas Buchner speaker at Lowpex conference at SMM Hamburg
>> <http://www.marin.nl/web/News/News-items/Bas-Buchner-speaker-at-Lowpex-conference-at-SMM-Hamburg.htm>
>> This e-mail may be confidential, privileged and/or protected by
>> copyright. If you are not the intended recipient, you should return it to
>> the sender immediately and delete your copy from your system.
>> *Sent:* Tuesday, September 02, 2014 5:42 PM
>>   On Tue, Sep 2, 2014 at 2:08 AM, Klaij, Christiaan <C.Klaij at marin.nl>
>> wrote:
>>>   Matt,
>>> Attached is a small Fortran code that replicates the second problem.
>>  This was a Fortran define problem. I fixed it on next
>> https://bitbucket.org/petsc/petsc/branch/knepley/fix-pc-fieldsplit-fortran
>>  and it will be in maint and master tomorrow.
>>    Thanks,
>>       Matt
>>>  Chris
>>>       dr. ir. Christiaan Klaij
>>> CFD Researcher
>>>   Research & Development
>>> *MARIN*
>>>   2, Haagsteeg  E C.Klaij at marin.nl P.O. Box 28 T +31 317 49 39 11  6700
>>> AA Wageningen F +31 317 49 32 45  T  +31 317 49 33 44 The Netherlands I
>>>  www.marin.nl
>>> MARIN news: MARIN at SMM, Hamburg, September 9-12
>>> <http://www.marin.nl/web/News/News-items/MARIN-at-SMM-Hamburg-September-912.htm>
>>> *From:* Klaij, Christiaan
>>> *Sent:* Friday, August 29, 2014 4:42 PM
>>> *To:* Matthew Knepley
>>> *Subject:* RE: [petsc-users] PCFieldSplitSetSchurPre in fortran
>>>   Matt,
>>> The small test code (ex70) is in C and it works fine, the problem
>>> happens in a big Fortran code. I will try to replicate the
>>> problem in a small Fortran code, but that will take some time.
>>> Chris
>>> *Sent:* Friday, August 29, 2014 4:14 PM
>>>   On Fri, Aug 29, 2014 at 8:55 AM, Klaij, Christiaan <C.Klaij at marin.nl>
>>> wrote:
>>>> I'm trying PCFieldSplitSetSchurPre with
>>>> PC_FIELDSPLIT_SCHUR_PRE_SELFP in petsc-3.5.1 using fortran.
>>>> The first problem is that PC_FIELDSPLIT_SCHUR_PRE_SELFP seems to
>>>> be missing in fortran, I get the compile error:
>>>> This name does not have a type, and must have an explicit type.
>>>>  [PC_FIELDSPLIT_SCHUR_PRE_SELFP]
>>>> while compilation works fine with _A11, _SELF and _USER.
>>>  Mark Adams has just fixed this.
>>>> The second problem is that the call doesn't seem to have any
>>>> effect. For example, I have
>>>> CALL PCFieldSplitSetSchurPre(pc,PC_FIELDSPLIT_SCHUR_PRE_USER,aa,ierr)
>>>> CALL
>>>> PCFieldSplitSetSchurFactType(pc,PC_FIELDSPLIT_SCHUR_FACT_LOWER,ierr)
>>>> This compiles and runs, but ksp_view tells me
>>>> PC Object:(sys_) 3 MPI processes
>>>>   type: fieldsplit
>>>>     FieldSplit with Schur preconditioner, factorization LOWER
>>>>     Preconditioner for the Schur complement formed from A11
>>>> So changing the factorization from the default FULL to LOWER did
>>>> work, but changing the preconditioner from A11 to USER didn't.
>>>> I've also tried to run directly from the command line using
>>>> -sys_pc_fieldsplit_schur_precondition user -sys_ksp_view
>>>> This works in the sense that I don't get the "WARNING! There are
>>>> options you set that were not used!" message, but still ksp_view
>>>> reports A11 instead of user provided matrix.
>>>  Can you send a small test code, since I use this everyday here and it
>>> works.
>>>    Thanks,
>>>       Matt
>>>> Chris
>>>> CFD Researcher
>>>> E mailto:C.Klaij at marin.nl
>>>> T +31 317 49 33 44
>>>> MARIN
>>>> 2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
>>>> T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140903/058e5a05/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140903/058e5a05/attachment-0002.jpe>
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140903/058e5a05/attachment-0003.jpe>
