[petsc-users] FETI-DP implementation and call sequence
Wed Sep 3 09:18:09 CDT 2014
On Wed, Sep 3, 2014 at 8:51 AM, Alp Kalpalp <alpkalpalp at gmail.com> wrote:
> Dear Matt,
> While searcing inside of the petsc bundle, I have seen
> PCBDDCMatFETIDPGetRHS
> PCBDDCMatFETIDPGetSolution
> PCBDDCCreateFETIDPOperators
> also there is an example in
> petsc-3.5.1\src\ksp\ksp\examples\tutorials\ex59.c
> however I could not see it on webbrowser interface. Is this an pre-release
> code?
That is my understanding, but you should really talk to Stefano Zampini
directly.
   Matt
> On Wed, Sep 3, 2014 at 2:09 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Wed, Sep 3, 2014 at 3:10 AM, Alp Kalpalp <alpkalpalp at gmail.com> wrote:
>>> Hi,
>>> I need to investigate the performance of FETI-DP on a heteregenous
>>> problem with a proposed preconditioner/scaling and different parameters. I
>>> do not want to reinvent the known. I need to investigate the outcomes of my
>>> research on top of FETI-DP.
>>> I have seen several papers in literature discuss about the FETI-DP
>>> implementations in PetSc. However, seems none of them is provided in
>>> public. I have come across several functions in PetSc with *FETIDP* names.
>>> But, since this algorithm is quite different then the ksp algorithms, I
>>> could not figure out how to use them.
>>> I have two concrete questions;
>>> 1- Is it possible to complete a FETI-DP solution with the provided
>>> functions in current PetSc release?
>> There is no FETI-DP in PETSc. However, I recommend mailing Oliver
>> Rheinbach to see about collaboration (http://www.uni-koeln.de/~orheinba/)
>>   Thanks,
>>       Matt
>>> 2- If so, what  is the calling sequence for these functions?
>>> Thanks in advance,
>>> Alp
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140903/65ae2dd5/attachment-0001.html>
