[petsc-users] Set matrix column to vector
Florian Lindner mailinglists at xgm.de
Tue Sep 2 03:41:34 CDT 2014
Am 01.09.2014 16:11, schrieb Matthew Knepley:
> I recommend running using the debugger so you can get a stack trace,
> and
> perhaps see
> exactly what the problem is. You can also run under valgrind as the
> error
> says.
This of course I tried, but had no real success. It crashes in
ISLocalToGlobalMappingApply, on the first line: PetscInt i,bs =
mapping->bs,Nmax = bs*mapping->n;
It crashes only when using MatSetValuesLocal, not when using
MatSetValues.
I've created an example that compiles just fine:
http://pastebin.com/iEkLK9DZ
Sorry, I really got no idea what could be the problem her.
Thx,
Florian
#include <iostream>
#include "petscmat.h"
#include "petscviewer.h"
// Compiling with: mpic++ -g3 -Wall -I ~/software/petsc/include -I
~/software/petsc/arch-linux2-c-debug/include -L
~/software/petsc/arch-linux2-c-debug/lib -lpetsc test.cpp
// Running without mpirun.
int main(int argc, char **args)
   PetscInitialize(&argc, &args, "", NULL);
   PetscErrorCode ierr = 0;
   int num_rows = 10;
   Mat matrix;
   Vec vector;
   // Create dense matrix, but code should work for sparse, too (I hope).
   ierr = MatCreateDense(PETSC_COMM_WORLD, PETSC_DECIDE, PETSC_DECIDE,
num_rows, 4, NULL, &matrix); CHKERRQ(ierr);
   ierr = MatAssemblyBegin(matrix, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
   ierr = MatAssemblyEnd(matrix, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
   ierr = VecCreate(PETSC_COMM_WORLD, &vector); CHKERRQ(ierr);
   ierr = VecSetSizes(vector, PETSC_DECIDE, num_rows); CHKERRQ(ierr);
   ierr = VecSetFromOptions(vector); CHKERRQ(ierr);
   // Init vector with 0, 1, ... , num_rows-1
   PetscScalar *a;
   PetscInt range_start, range_end, pos = 0;
   VecGetOwnershipRange(vector, &range_start, &range_end);
   ierr = VecGetArray(vector, &a); CHKERRQ(ierr);
   for (PetscInt i = range_start; i < range_end; i++) {
     a[pos] = pos + range_start;
     pos++;
   VecRestoreArray(vector, &a);
   // VecAssemblyBegin(vector); VecAssemblyEnd(vector);  I don't think
it's needed here, changes nothing.
   ierr = VecView(vector, PETSC_VIEWER_STDOUT_WORLD); CHKERRQ(ierr);
   PetscInt irow[num_rows];
   const PetscInt col = 2;
   const PetscScalar *vec;
   for (int i = 0; i < num_rows; i++) {
     irow[i] = i;
   ierr = VecGetArrayRead(vector, &vec); CHKERRQ(ierr);
   // MatSetValuesLocal(Mat mat,PetscInt nrow,const PetscInt
irow[],PetscInt ncol,const PetscInt icol[],const PetscScalar
y[],InsertMode addv)
   ierr = MatSetValuesLocal(matrix, num_rows, irow, 1, &col, vec,
INSERT_VALUES); CHKERRQ(ierr);
   // Works fine with MatSetValues
   ierr = VecRestoreArrayRead(vector, &vec); CHKERRQ(ierr);
   ierr = MatView(matrix, PETSC_VIEWER_STDOUT_WORLD); CHKERRQ(ierr);
   PetscFinalize();
   return 0;
