[petsc-users] Lookup error in PetscTableFind()
Fri Oct 31 16:48:56 CDT 2014
  I would first go back and build another PETSC_ARCH without optimization and run your job that previously crashed with that and see if it still crashes? If it runs then I would one at a time add back the various optimization flags -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction to see which triggers the problem.
  You could also overload your desktop with the much bigger problem to see if it finds anything else (sure it will run slowly but so what).
   Barry
> On Oct 31, 2014, at 3:11 PM, Luc Berger-Vergiat <lb2653 at columbia.edu> wrote:
> So when I run with -no-signal-handler I get an error from valgrind saying that it received a signal and was aborting...
> Is there a way to prune a little what PETSc will get from argc/argv in order to let it run correctly?
> I also ran an example on my local computer with the same parameters and with 4 mpi ranks (that's  all my desktop can do) and got the following outputs:
> luc at euler:~/research/simulations/Petsc_FS/parallel_ISFS/10elem_test/4cores$ mpirun -n 4 /usr/bin/valgrind --leak-check=full --tool=memcheck --track-origins=yes -q /home/luc/research/feap_repo/ShearBands/parfeap/feap -ksp_type preonly -pc_type lu -pc_factor_mat_solver_package mumps -ksp_diagonal_scale
>     F I N I T E   E L E M E N T   A N A L Y S I S   P R O G R A M
>            FEAP (C) Regents of the University of California
>                          All Rights Reserved.
>                        VERSION: Release 8.3.19
>                           DATE: 29 March 2011
>          Files are set as:   Status    Filename
>            Input   (read ) : Exists  ILU_0001
>            Output  (write) : Exists  OLU_0001
>            Restart (read ) : New     RLU_0001
>            Restart (write) : New     RLU_0001
>            Plots   (write) : New     PLU_0001
>          Caution, existing write files will be overwritten.
>          Are filenames correct? ( y or n; s = stop) :y
>          R U N N I N G    F E A P    P R O B L E M    N O W
>           --> Please report errors by e-mail to:
>               feap at ce.berkeley.edu
>  Saving Parallel data to PLU_000000.pvtu
> ==7933== Syscall param writev(vector[...]) points to uninitialised byte(s)
> ==7933==    at 0x6C2EF57: writev (writev.c:49)
> ==7933==    by 0x7360F30: MPL_large_writev (mplsock.c:32)
> ==7933==    by 0x65AB588: MPIDU_Sock_writev (sock_immed.i:610)
> ==7933==    by 0x65940B3: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> ==7933==    by 0x65862AC: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:550)
> ==7933==    by 0x658AB5C: MPID_Isend (mpid_isend.c:131)
> ==7933==    by 0x6625309: PMPI_Isend (isend.c:122)
> ==7933==    by 0x656671D: PMPI_ISEND (isendf.c:267)
> ==7933==    by 0x1AE7745: __dmumps_comm_buffer_MOD_dmumps_62 (dmumps_comm_buffer.F:567)
> ==7933==    by 0x1B6D1FC: dmumps_242_ (dmumps_part2.F:739)
> ==7933==    by 0x1AB264C: dmumps_249_ (dmumps_part8.F:6541)
> ==7933==    by 0x1AAB0F6: dmumps_245_ (dmumps_part8.F:3885)
> ==7933==  Address 0x8959098 is 8 bytes inside a block of size 336 alloc'd
> ==7933==    at 0x4C2AB80: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> ==7933==    by 0x1AE9465: __dmumps_comm_buffer_MOD_dmumps_2 (dmumps_comm_buffer.F:175)
> ==7933==    by 0x1AE9852: __dmumps_comm_buffer_MOD_dmumps_55 (dmumps_comm_buffer.F:123)
> ==7933==    by 0x1AC5FD5: dmumps_301_ (dmumps_part8.F:989)
> ==7933==    by 0x1B36855: dmumps_ (dmumps_part1.F:665)
> ==7933==    by 0x1A170C7: dmumps_f77_ (dmumps_part3.F:6651)
> ==7933==    by 0x19EDDCA: dmumps_c (mumps_c.c:422)
> ==7933==    by 0x13AF869: MatSolve_MUMPS (mumps.c:606)
> ==7933==    by 0xB58981: MatSolve (matrix.c:3122)
> ==7933==    by 0x152174C: PCApply_LU (lu.c:198)
> ==7933==    by 0x14BAB70: PCApply (precon.c:440)
> ==7933==    by 0x164AB13: KSP_PCApply (kspimpl.h:230)
> ==7933==  Uninitialised value was created by a stack allocation
> ==7933==    at 0x1AAE33D: dmumps_249_ (dmumps_part8.F:5817)
> ==7933==
> ==7932== Syscall param writev(vector[...]) points to uninitialised byte(s)
> ==7932==    at 0x6C2EF57: writev (writev.c:49)
> ==7932==    by 0x7360F30: MPL_large_writev (mplsock.c:32)
> ==7932==    by 0x65AB588: MPIDU_Sock_writev (sock_immed.i:610)
> ==7932==    by 0x65940B3: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> ==7932==    by 0x65862AC: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:550)
> ==7932==    by 0x658AB5C: MPID_Isend (mpid_isend.c:131)
> ==7932==    by 0x6625309: PMPI_Isend (isend.c:122)
> ==7932==    by 0x656671D: PMPI_ISEND (isendf.c:267)
> ==7932==    by 0x1AE7745: __dmumps_comm_buffer_MOD_dmumps_62 (dmumps_comm_buffer.F:567)
> ==7932==    by 0x1B6D1FC: dmumps_242_ (dmumps_part2.F:739)
> ==7932==    by 0x1AB264C: dmumps_249_ (dmumps_part8.F:6541)
> ==7932==    by 0x1AAB0F6: dmumps_245_ (dmumps_part8.F:3885)
> ==7932==  Address 0x86e4448 is 8 bytes inside a block of size 336 alloc'd
> ==7932==    at 0x4C2AB80: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> ==7932==    by 0x1AE9465: __dmumps_comm_buffer_MOD_dmumps_2 (dmumps_comm_buffer.F:175)
> ==7932==    by 0x1AE9852: __dmumps_comm_buffer_MOD_dmumps_55 (dmumps_comm_buffer.F:123)
> ==7932==    by 0x1AC5FD5: dmumps_301_ (dmumps_part8.F:989)
> ==7932==    by 0x1B36855: dmumps_ (dmumps_part1.F:665)
> ==7932==    by 0x1A170C7: dmumps_f77_ (dmumps_part3.F:6651)
> ==7932==    by 0x19EDDCA: dmumps_c (mumps_c.c:422)
> ==7932==    by 0x13AF869: MatSolve_MUMPS (mumps.c:606)
> ==7932==    by 0xB58981: MatSolve (matrix.c:3122)
> ==7932==    by 0x152174C: PCApply_LU (lu.c:198)
> ==7932==    by 0x14BAB70: PCApply (precon.c:440)
> ==7932==    by 0x164AB13: KSP_PCApply (kspimpl.h:230)
> ==7932==  Uninitialised value was created by a stack allocation
> ==7932==    at 0x1AAE33D: dmumps_249_ (dmumps_part8.F:5817)
> ==7932==
> ==7934== Syscall param writev(vector[...]) points to uninitialised byte(s)
> ==7934==    at 0x6C2EF57: writev (writev.c:49)
> ==7934==    by 0x7360F30: MPL_large_writev (mplsock.c:32)
> ==7934==    by 0x65AB588: MPIDU_Sock_writev (sock_immed.i:610)
> ==7934==    by 0x65940B3: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> ==7934==    by 0x65862AC: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:550)
> ==7934==    by 0x658AB5C: MPID_Isend (mpid_isend.c:131)
> ==7934==    by 0x6625309: PMPI_Isend (isend.c:122)
> ==7934==    by 0x656671D: PMPI_ISEND (isendf.c:267)
> ==7934==    by 0x1AE7745: __dmumps_comm_buffer_MOD_dmumps_62 (dmumps_comm_buffer.F:567)
> ==7934==    by 0x1B6D1FC: dmumps_242_ (dmumps_part2.F:739)
> ==7934==    by 0x1AB264C: dmumps_249_ (dmumps_part8.F:6541)
> ==7934==    by 0x1AAB0F6: dmumps_245_ (dmumps_part8.F:3885)
> ==7934==  Address 0x89ec648 is 8 bytes inside a block of size 336 alloc'd
> ==7934==    at 0x4C2AB80: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> ==7934==    by 0x1AE9465: __dmumps_comm_buffer_MOD_dmumps_2 (dmumps_comm_buffer.F:175)
> ==7934==    by 0x1AE9852: __dmumps_comm_buffer_MOD_dmumps_55 (dmumps_comm_buffer.F:123)
> ==7934==    by 0x1AC5FD5: dmumps_301_ (dmumps_part8.F:989)
> ==7934==    by 0x1B36855: dmumps_ (dmumps_part1.F:665)
> ==7934==    by 0x1A170C7: dmumps_f77_ (dmumps_part3.F:6651)
> ==7934==    by 0x19EDDCA: dmumps_c (mumps_c.c:422)
> ==7934==    by 0x13AF869: MatSolve_MUMPS (mumps.c:606)
> ==7934==    by 0xB58981: MatSolve (matrix.c:3122)
> ==7934==    by 0x152174C: PCApply_LU (lu.c:198)
> ==7934==    by 0x14BAB70: PCApply (precon.c:440)
> ==7934==    by 0x164AB13: KSP_PCApply (kspimpl.h:230)
> ==7934==  Uninitialised value was created by a stack allocation
> ==7934==    at 0x1AAE33D: dmumps_249_ (dmumps_part8.F:5817)
> ==7934==
> ==7935== Syscall param writev(vector[...]) points to uninitialised byte(s)
> ==7935==    at 0x6C2EF57: writev (writev.c:49)
> ==7935==    by 0x7360F30: MPL_large_writev (mplsock.c:32)
> ==7935==    by 0x65AB588: MPIDU_Sock_writev (sock_immed.i:610)
> ==7935==    by 0x65940B3: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> ==7935==    by 0x65862AC: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:550)
> ==7935==    by 0x658AB5C: MPID_Isend (mpid_isend.c:131)
> ==7935==    by 0x6625309: PMPI_Isend (isend.c:122)
> ==7935==    by 0x656671D: PMPI_ISEND (isendf.c:267)
> ==7935==    by 0x1AE7745: __dmumps_comm_buffer_MOD_dmumps_62 (dmumps_comm_buffer.F:567)
> ==7935==    by 0x1B6D1FC: dmumps_242_ (dmumps_part2.F:739)
> ==7935==    by 0x1AB264C: dmumps_249_ (dmumps_part8.F:6541)
> ==7935==    by 0x1AAB0F6: dmumps_245_ (dmumps_part8.F:3885)
> ==7935==  Address 0x85d8968 is 8 bytes inside a block of size 336 alloc'd
> ==7935==    at 0x4C2AB80: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> ==7935==    by 0x1AE9465: __dmumps_comm_buffer_MOD_dmumps_2 (dmumps_comm_buffer.F:175)
> ==7935==    by 0x1AE9852: __dmumps_comm_buffer_MOD_dmumps_55 (dmumps_comm_buffer.F:123)
> ==7935==    by 0x1AC5FD5: dmumps_301_ (dmumps_part8.F:989)
> ==7935==    by 0x1B36855: dmumps_ (dmumps_part1.F:665)
> ==7935==    by 0x1A170C7: dmumps_f77_ (dmumps_part3.F:6651)
> ==7935==    by 0x19EDDCA: dmumps_c (mumps_c.c:422)
> ==7935==    by 0x13AF869: MatSolve_MUMPS (mumps.c:606)
> ==7935==    by 0xB58981: MatSolve (matrix.c:3122)
> ==7935==    by 0x152174C: PCApply_LU (lu.c:198)
> ==7935==    by 0x14BAB70: PCApply (precon.c:440)
> ==7935==    by 0x164AB13: KSP_PCApply (kspimpl.h:230)
> ==7935==  Uninitialised value was created by a stack allocation
> ==7935==    at 0x1AAE33D: dmumps_249_ (dmumps_part8.F:5817)
> ==7935==
>  Saving Parallel data to PLU_000001.pvtu
>  Saving Parallel data to PLU_000002.pvtu
>  Saving Parallel data to PLU_000003.pvtu
>  Saving Parallel data to PLU_000004.pvtu
>  Saving Parallel data to PLU_000005.pvtu
>  Saving Parallel data to PLU_000006.pvtu
>  Saving Parallel data to PLU_000007.pvtu
>  Saving Parallel data to PLU_000008.pvtu
>  Saving Parallel data to PLU_000009.pvtu
>  Saving Parallel data to PLU_000010.pvtu
> ==7932== 13 bytes in 13 blocks are definitely lost in loss record 7 of 51
> ==7932==    by 0x1BBB3E1: mumps_397.3460 (mumps_static_mapping.F:3746)
> ==7932==    by 0x1BB8283: __mumps_static_mapping_MOD_mumps_369 (mumps_static_mapping.F:302)
> ==7932==    by 0x1A4BBF5: dmumps_537_ (dmumps_part5.F:1706)
> ==7932==    by 0x1A550AC: dmumps_26_ (dmumps_part5.F:447)
> ==7932==    by 0x1B346D6: dmumps_ (dmumps_part1.F:409)
> ==7932==    by 0x13B2F2B: MatLUFactorSymbolic_AIJMUMPS (mumps.c:972)
> ==7932==    by 0xB54FB5: MatLUFactorSymbolic (matrix.c:2842)
> ==7932==    by 0x15205A9: PCSetUp_LU (lu.c:127)
> ==7932==    by 0x14C0685: PCSetUp (precon.c:902)
> ==7932==
> ==7932== 13 bytes in 13 blocks are definitely lost in loss record 8 of 51
> ==7932==    by 0x1BBB5C7: mumps_397.3460 (mumps_static_mapping.F:3746)
> ==7932==
> All these mainly come from mumps and I don't think that they would create the memory problem that I described earlier.
> It really seems that the issue comes with larger problems with more mpi ranks.
> Best,
> Luc
> On 10/30/2014 12:23 PM, Barry Smith wrote:
>>    Run with the additional PETSc option -no_signal_handler  then PETSc won’t mess with the signals and it may get you past this point.
>>   Barry
>>> On Oct 30, 2014, at 9:21 AM, Luc Berger-Vergiat <lb2653 at columbia.edu>
>>>  wrote:
>>> Sorry for the late reply, it took longer than I thought.
>>> So a little update on my situation:
>>> I have to use a custom version of valgrind on CETUS which has to be linked to my code using -Wl,-e,_start_valgrind at compilation (I also add object file and libraries).
>>> After that I can run my code with the following arguments:
>>> feap --ignore-ranges=0x4000000000000-0x4063000000000,0x003fdc0000000-0x003fe00000000 --suppressions=/soft/perftools/valgrind/cnk-baseline.supp
>>> but I can't use the usual petsc argument (-ksp_type -pc_type ...) since valgrind does not recognize them.
>>> So I decided to use the PETSC_OPTIONS='-ksp_type preonly -pc_type lu -pc_factor_mat_solver_package mumps -ksp_diagonal_scale', to pass my arguments to PETSc.
>>> However I am a little worried that Petsc still receive the command line arguments that are used by valgrind since I get the following stderr from valgrind:
>>> stderr[0]: ==1==    by 0x38BEA3F: handle_SCSS_change (m_signals.c:963)
>>> stderr[0]: ==1==    by 0x38C13A7: vgPlain_do_sys_sigaction (m_signals.c:1114)
>>> stderr[0]: ==1==    by 0x3962FBF: vgSysWrap_linux_sys_rt_sigaction_before (syswrap-linux.c:3073)
>>> stderr[0]: ==1==    by 0x3928BF7: vgPlain_client_syscall (syswrap-main.c:1464)
>>> stderr[0]: ==1==    by 0x3925F4B: vgPlain_scheduler (scheduler.c:1061)
>>> stderr[0]: ==1==    by 0x3965EB3: run_a_thread_NORETURN (syswrap-linux.c:103)
>>> stderr[0]:
>>> stderr[0]: sched status:
>>> stderr[0]:   running_tid=1
>>> stderr[0]:
>>> stderr[0]: Thread 1: status = VgTs_Runnable
>>> stderr[0]: ==1==    at 0x34290E4: __libc_sigaction (sigaction.c:80)
>>> stderr[0]: ==1==    by 0x3BFF3A7: signal (signal.c:49)
>>> stderr[0]: ==1==    by 0x1E710DF: PetscPushSignalHandler (in /projects/shearbands/ShearBands/parfeap/feap)
>>> stderr[0]: ==1==    by 0x18BEA87: PetscOptionsCheckInitial_Private (in /projects/shearbands/ShearBands/parfeap/feap)
>>> stderr[0]: ==1==    by 0x18E132F: petscinitialize (in /projects/shearbands/ShearBands/parfeap/feap)
>>> stderr[0]: ==1==    by 0x1027557: pstart (in /projects/shearbands/ShearBands/parfeap/feap)
>>> stderr[0]: ==1==    by 0x1000B1F: MAIN__ (feap83.f:213)
>>> stderr[0]: ==1==    by 0x342ABD7: main (fmain.c:21)
>>> stderr[0]:
>>> stderr[0]:
>>> stderr[0]: Note: see also the FAQ in the source distribution.
>>> stderr[0]: It contains workarounds to several common problems.
>>> stderr[0]: In particular, if Valgrind aborted or crashed after
>>> stderr[0]: identifying problems in your program, there's a good chance
>>> stderr[0]: that fixing those problems will prevent Valgrind aborting or
>>> stderr[0]: crashing, especially if it happened in m_mallocfree.c.
>>> stderr[0]:
>>> stderr[0]: If that doesn't help, please report this bug to:
>>> www.valgrind.org
>>> stderr[0]:
>>> stderr[0]: In the bug report, send all the above text, the valgrind
>>> stderr[0]: version, and what OS and version you are using.  Thank
>>> stderr[0]: s.
>>> stderr[0]:
>>> I am only showing the output of rank[0] but it seems that all ranks have about the same error message.
>>> Since my problem happens in petscinitialize I have little possibilities to check what's wrong...
>>> Any ideas?
>>> Best,
>>> Luc
>>> On 10/28/2014 02:53 PM, Barry Smith wrote:
>>>>    You don’t care about checking for leaks. I use
>>>> -q --tool=memcheck --num-callers=20 --track-origins=yes
>>>>> On Oct 28, 2014, at 1:50 PM, Luc Berger-Vergiat <lb2653 at columbia.edu>
>>>>>  wrote:
>>>>> Yes, I am running with --leak-check=full
>>>>> Reconfiguring and recompiling the whole library and my code in debug mode does take quite some time on CETUS/MIRA...
>>>>> Hopefully the queue will go up fast and I can give you some details about the issue.
>>>>> Best,
>>>>> Luc
>>>>> On 10/28/2014 02:25 PM, Barry Smith wrote:
>>>>>>   You need to pass some options to valgrind telling it to check for memory corruption issues
>>>>>>> On Oct 28, 2014, at 12:30 PM, Luc Berger-Vergiat <lb2653 at columbia.edu>
>>>>>>>  wrote:
>>>>>>> Ok, I'm recompiling PETSc in debug mode then.
>>>>>>> Do you know what the call sequence should be on CETUS to get valgrind attached to PETSc?
>>>>>>> Would this work for example:
>>>>>>> runjob --np 32 -p 8 --block $COBALT_PARTNAME --cwd /projects/shearbands/job1/200/4nodes_32cores/LU --verbose=INFO --envs FEAPHOME8_3=/projects/shearbands/ShearBands352 PETSC_DIR=/projects/shearbands/petsc-3.5.2 PETSC_ARCH=arch-linux2-c-opt : /usr/bin/valgrind --log-file=valgrind.log.%p /projects/shearbands/ShearBands352/parfeap/feap -ksp_type preonly -pc_type lu -pc_factor_mat_solver_package mumps -ksp_diagonal_scale < /projects/shearbands/job1/yesfile
>>>>>>> Best,
>>>>>>> Luc
>>>>>>> On 10/28/2014 12:33 PM, Barry Smith wrote:
>>>>>>>>     Hmm, this should never happen. In the code
>>>>>>>>   ierr = PetscTableCreate(aij->B->rmap->n,mat->cmap->N+1,&gid1_lid1);CHKERRQ(ierr);
>>>>>>>>   for (i=0; i<aij->B->rmap->n; i++) {
>>>>>>>>     for (j=0; j<B->ilen[i]; j++) {
>>>>>>>>       PetscInt data,gid1 = aj[B->i[i] + j] + 1;
>>>>>>>>       ierr = PetscTableFind(gid1_lid1,gid1,&data);CHKERRQ(ierr);
>>>>>>>> Now mat->cmap->N+1 is the total number of columns in the matrix and gid1 are column entries which must always be smaller. Most likely there has been memory corruption somewhere before this point. Can you run with valgrind?
>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>>>>>>   Barry
>>>>>>>>> On Oct 28, 2014, at 10:04 AM, Luc Berger-Vergiat <lb2653 at columbia.edu>
>>>>>>>>>  wrote:
>>>>>>>>> Hi,
>>>>>>>>> I am running a code on CETUS and I use PETSc for as a linear solver.
>>>>>>>>> Here is my submission command:
>>>>>>>>> qsub -A shearbands -t 60 -n 4 -O 4nodes_32cores_Mult --mode script 4nodes_32cores_LU
>>>>>>>>> Here is "4nodes_32cores_LU":
>>>>>>>>> #!/bin/sh
>>>>>>>>> LOCARGS="--block $COBALT_PARTNAME ${COBALT_CORNER:+--corner} $COBALT_CORNER ${COBALT_SHAPE:+--shape} $COBALT_SHAPE"
>>>>>>>>> echo "Cobalt location args: $LOCARGS" >&2
>>>>>>>>> #   32 cores on 4 nodes jobs   #
>>>>>>>>> runjob --np 32 -p 8 --block $COBALT_PARTNAME --cwd /projects/shearbands/job1/200/4nodes_32cores/LU --verbose=INFO --envs FEAPHOME8_3=/projects/shearbands/ShearBands352 PETSC_DIR=/projects/shearbands/petsc-3.5.2 PETSC_ARCH=arch-linux2-c-opt : /projects/shearbands/ShearBands352/parfeap/feap -ksp_type preonly -pc_type lu -pc_factor_mat_solver_package mumps -ksp_diagonal_scale -malloc_log mlog -log_summary time.log           < /projects/shearbands/job1/yesfile
>>>>>>>>> I get the following error message:
>>>>>>>>> [7]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
>>>>>>>>> [7]PETSC ERROR: Argument out of range
>>>>>>>>> [7]PETSC ERROR: Petsc Release Version 3.5.2, unknown
>>>>>>>>> [7]PETSC ERROR: key 532150 is greater than largest key allowed 459888
>>>>>>>>> [7]PETSC ERROR: Configure options --known-mpi-int64_t=1 --download-cmake=1 --download-hypre=1 --download-metis=1 --download-parmetis=1 --download-plapack=1 --download-superlu_dist=1 --download-mumps=1 --download-ml=1 --known-bits-per-byte=8 --known-level1-dcache-assoc=0 --known-level1-dcache-linesize=32 --known-level1-dcache-size=32768 --known-memcmp-ok=1 --known-mpi-c-double-complex=1 --known-mpi-long-double=1 --known-mpi-shared-libraries=0 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-sizeof-char=1 --known-sizeof-double=8 --known-sizeof-float=4 --known-sizeof-int=4 --known-sizeof-long-long=8 --known-sizeof-long=8 --known-sizeof-short=2 --known-sizeof-size_t=8 --known-sizeof-void-p=8 --with-batch=1 --with-blacs-include=/soft/libraries/alcf/current/gcc/SCALAPACK/ --with-blacs-lib=/soft/libraries/alcf/current/gcc/SCALAPACK/lib/libscalapack.a --with-blas-lapack-lib="-L/soft/libraries/alcf/current/gcc/LAPACK/lib -llapack -L/soft/libraries/alcf/current/gcc/BLAS/lib
>>>>>>>>>    -lblas" -
>>>>>>>>> -with-cc=mpicc --with-cxx=mpicxx --with-debugging=0 --with-fc=mpif90 --with-fortran-kernels=1 --with-is-color-value-type=short --with-scalapack-include=/soft/libraries/alcf/current/gcc/SCALAPACK/ --with-scalapack-lib=/soft/libraries/alcf/current/gcc/SCALAPACK/lib/libscalapack.a --with-shared-libraries=0 --with-x=0 -COPTFLAGS=" -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction" -CXXOPTFLAGS=" -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction" -FOPTFLAGS=" -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction"
>>>>>>>>> [7]PETSC ERROR: #1 PetscTableFind() line 126 in /gpfs/mira-fs1/projects/shearbands/petsc-3.5.2/include/petscctable.h
>>>>>>>>> [7]PETSC ERROR: #2 MatSetUpMultiply_MPIAIJ() line 33 in /gpfs/mira-fs1/projects/shearbands/petsc-3.5.2/src/mat/impls/aij/mpi/mmaij.c
>>>>>>>>> [7]PETSC ERROR: #3 MatAssemblyEnd_MPIAIJ() line 702 in /gpfs/mira-fs1/projects/shearbands/petsc-3.5.2/src/mat/impls/aij/mpi/mpiaij.c
>>>>>>>>> [7]PETSC ERROR: #4 MatAssemblyEnd() line 4900 in /gpfs/mira-fs1/projects/shearbands/petsc-3.5.2/src/mat/interface/matrix.c
>>>>>>>>> Well at least that is what I think comes out after I read all the jammed up messages from my MPI processes...
>>>>>>>>> I would guess that I am trying to allocate more memory than I should which seems strange since the same problem runs fine on 2 nodes with 16 cores/node
>>>>>>>>> Thanks for the help
>>>>>>>>> Best,
>>>>>>>>> Luc
