[petsc-users] Lookup error in PetscTableFind()
Luc Berger-Vergiat lb2653 at columbia.edu
Thu Oct 30 09:21:39 CDT 2014
Sorry for the late reply, it took longer than I thought.
So a little update on my situation:
I have to use a custom version of valgrind on CETUS which has to be
linked to my code using -Wl,-e,_start_valgrind at compilation (I also
add object file and libraries).
After that I can run my code with the following arguments:
    feap
    --ignore-ranges=0x4000000000000-0x4063000000000,0x003fdc0000000-0x003fe00000000
    --suppressions=/soft/perftools/valgrind/cnk-baseline.supp
but I can't use the usual petsc argument (-ksp_type -pc_type ...) since
valgrind does not recognize them.
So I decided to use the PETSC_OPTIONS='-ksp_type preonly -pc_type lu
-pc_factor_mat_solver_package mumps -ksp_diagonal_scale', to pass my
arguments to PETSc.
However I am a little worried that Petsc still receive the command line
arguments that are used by valgrind since I get the following stderr
from valgrind:
stderr[0]: ==1==    by 0x38BEA3F: handle_SCSS_change (m_signals.c:963)
stderr[0]: ==1==    by 0x38C13A7: vgPlain_do_sys_sigaction
(m_signals.c:1114)
stderr[0]: ==1==    by 0x3962FBF:
vgSysWrap_linux_sys_rt_sigaction_before (syswrap-linux.c:3073)
stderr[0]: ==1==    by 0x3928BF7: vgPlain_client_syscall
(syswrap-main.c:1464)
stderr[0]: ==1==    by 0x3925F4B: vgPlain_scheduler (scheduler.c:1061)
stderr[0]: ==1==    by 0x3965EB3: run_a_thread_NORETURN
(syswrap-linux.c:103)
stderr[0]:
stderr[0]: sched status:
stderr[0]:   running_tid=1
stderr[0]:
stderr[0]: Thread 1: status = VgTs_Runnable
stderr[0]: ==1==    at 0x34290E4: __libc_sigaction (sigaction.c:80)
stderr[0]: ==1==    by 0x3BFF3A7: signal (signal.c:49)
stderr[0]: ==1==    by 0x1E710DF: PetscPushSignalHandler (in
/projects/shearbands/ShearBands/parfeap/feap)
stderr[0]: ==1==    by 0x18BEA87: PetscOptionsCheckInitial_Private (in
stderr[0]: ==1==    by 0x18E132F: petscinitialize (in
stderr[0]: ==1==    by 0x1027557: pstart (in
stderr[0]: ==1==    by 0x1000B1F: MAIN__ (feap83.f:213)
stderr[0]: ==1==    by 0x342ABD7: main (fmain.c:21)
stderr[0]:
stderr[0]:
stderr[0]: Note: see also the FAQ in the source distribution.
stderr[0]: It contains workarounds to several common problems.
stderr[0]: In particular, if Valgrind aborted or crashed after
stderr[0]: identifying problems in your program, there's a good chance
stderr[0]: that fixing those problems will prevent Valgrind aborting or
stderr[0]: crashing, especially if it happened in m_mallocfree.c.
stderr[0]:
stderr[0]: If that doesn't help, please report this bug to: www.valgrind.org
stderr[0]:
stderr[0]: In the bug report, send all the above text, the valgrind
stderr[0]: version, and what OS and version you are using.  Thank
stderr[0]: s.
stderr[0]:
I am only showing the output of rank[0] but it seems that all ranks have
about the same error message.
Since my problem happens in petscinitialize I have little possibilities
to check what's wrong...
Any ideas?
Best,
Luc
On 10/28/2014 02:53 PM, Barry Smith wrote:
>     You don’t care about checking for leaks. I use
> -q --tool=memcheck --num-callers=20 --track-origins=yes
>> On Oct 28, 2014, at 1:50 PM, Luc Berger-Vergiat <lb2653 at columbia.edu> wrote:
>> Yes, I am running with --leak-check=full
>> Reconfiguring and recompiling the whole library and my code in debug mode does take quite some time on CETUS/MIRA...
>> Hopefully the queue will go up fast and I can give you some details about the issue.
>> Best,
>> Luc
>> On 10/28/2014 02:25 PM, Barry Smith wrote:
>>>    You need to pass some options to valgrind telling it to check for memory corruption issues
>>>> On Oct 28, 2014, at 12:30 PM, Luc Berger-Vergiat <lb2653 at columbia.edu> wrote:
>>>> Ok, I'm recompiling PETSc in debug mode then.
>>>> Do you know what the call sequence should be on CETUS to get valgrind attached to PETSc?
>>>> Would this work for example:
>>>> runjob --np 32 -p 8 --block $COBALT_PARTNAME --cwd /projects/shearbands/job1/200/4nodes_32cores/LU --verbose=INFO --envs FEAPHOME8_3=/projects/shearbands/ShearBands352 PETSC_DIR=/projects/shearbands/petsc-3.5.2 PETSC_ARCH=arch-linux2-c-opt : /usr/bin/valgrind --log-file=valgrind.log.%p /projects/shearbands/ShearBands352/parfeap/feap -ksp_type preonly -pc_type lu -pc_factor_mat_solver_package mumps -ksp_diagonal_scale < /projects/shearbands/job1/yesfile
>>>> Best,
>>>> Luc
>>>> On 10/28/2014 12:33 PM, Barry Smith wrote:
>>>>>      Hmm, this should never happen. In the code
>>>>>    ierr = PetscTableCreate(aij->B->rmap->n,mat->cmap->N+1,&gid1_lid1);CHKERRQ(ierr);
>>>>>    for (i=0; i<aij->B->rmap->n; i++) {
>>>>>      for (j=0; j<B->ilen[i]; j++) {
>>>>>        PetscInt data,gid1 = aj[B->i[i] + j] + 1;
>>>>>        ierr = PetscTableFind(gid1_lid1,gid1,&data);CHKERRQ(ierr);
>>>>> Now mat->cmap->N+1 is the total number of columns in the matrix and gid1 are column entries which must always be smaller. Most likely there has been memory corruption somewhere before this point. Can you run with valgrind?
>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>>>    Barry
>>>>>> On Oct 28, 2014, at 10:04 AM, Luc Berger-Vergiat <lb2653 at columbia.edu>
>>>>>>   wrote:
>>>>>> Hi,
>>>>>> I am running a code on CETUS and I use PETSc for as a linear solver.
>>>>>> Here is my submission command:
>>>>>> qsub -A shearbands -t 60 -n 4 -O 4nodes_32cores_Mult --mode script 4nodes_32cores_LU
>>>>>> Here is "4nodes_32cores_LU":
>>>>>> #!/bin/sh
>>>>>> LOCARGS="--block $COBALT_PARTNAME ${COBALT_CORNER:+--corner} $COBALT_CORNER ${COBALT_SHAPE:+--shape} $COBALT_SHAPE"
>>>>>> echo "Cobalt location args: $LOCARGS" >&2
>>>>>> #   32 cores on 4 nodes jobs   #
>>>>>> runjob --np 32 -p 8 --block $COBALT_PARTNAME --cwd /projects/shearbands/job1/200/4nodes_32cores/LU --verbose=INFO --envs FEAPHOME8_3=/projects/shearbands/ShearBands352 PETSC_DIR=/projects/shearbands/petsc-3.5.2 PETSC_ARCH=arch-linux2-c-opt : /projects/shearbands/ShearBands352/parfeap/feap -ksp_type preonly -pc_type lu -pc_factor_mat_solver_package mumps -ksp_diagonal_scale -malloc_log mlog -log_summary time.log           < /projects/shearbands/job1/yesfile
>>>>>> I get the following error message:
>>>>>> [7]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
>>>>>> [7]PETSC ERROR: Argument out of range
>>>>>> [7]PETSC ERROR: Petsc Release Version 3.5.2, unknown
>>>>>> [7]PETSC ERROR: key 532150 is greater than largest key allowed 459888
>>>>>> [7]PETSC ERROR: Configure options --known-mpi-int64_t=1 --download-cmake=1 --download-hypre=1 --download-metis=1 --download-parmetis=1 --download-plapack=1 --download-superlu_dist=1 --download-mumps=1 --download-ml=1 --known-bits-per-byte=8 --known-level1-dcache-assoc=0 --known-level1-dcache-linesize=32 --known-level1-dcache-size=32768 --known-memcmp-ok=1 --known-mpi-c-double-complex=1 --known-mpi-long-double=1 --known-mpi-shared-libraries=0 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-sizeof-char=1 --known-sizeof-double=8 --known-sizeof-float=4 --known-sizeof-int=4 --known-sizeof-long-long=8 --known-sizeof-long=8 --known-sizeof-short=2 --known-sizeof-size_t=8 --known-sizeof-void-p=8 --with-batch=1 --with-blacs-include=/soft/libraries/alcf/current/gcc/SCALAPACK/ --with-blacs-lib=/soft/libraries/alcf/current/gcc/SCALAPACK/lib/libscalapack.a --with-blas-lapack-lib="-L/soft/libraries/alcf/current/gcc/LAPACK/lib -llapack -L/soft/libraries/alcf/current/gcc/BLAS/lib
>>>>>>     -lblas" -
>>>>>> -with-cc=mpicc --with-cxx=mpicxx --with-debugging=0 --with-fc=mpif90 --with-fortran-kernels=1 --with-is-color-value-type=short --with-scalapack-include=/soft/libraries/alcf/current/gcc/SCALAPACK/ --with-scalapack-lib=/soft/libraries/alcf/current/gcc/SCALAPACK/lib/libscalapack.a --with-shared-libraries=0 --with-x=0 -COPTFLAGS=" -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction" -CXXOPTFLAGS=" -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction" -FOPTFLAGS=" -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction"
>>>>>> [7]PETSC ERROR: #1 PetscTableFind() line 126 in /gpfs/mira-fs1/projects/shearbands/petsc-3.5.2/include/petscctable.h
>>>>>> [7]PETSC ERROR: #2 MatSetUpMultiply_MPIAIJ() line 33 in /gpfs/mira-fs1/projects/shearbands/petsc-3.5.2/src/mat/impls/aij/mpi/mmaij.c
>>>>>> [7]PETSC ERROR: #3 MatAssemblyEnd_MPIAIJ() line 702 in /gpfs/mira-fs1/projects/shearbands/petsc-3.5.2/src/mat/impls/aij/mpi/mpiaij.c
>>>>>> [7]PETSC ERROR: #4 MatAssemblyEnd() line 4900 in /gpfs/mira-fs1/projects/shearbands/petsc-3.5.2/src/mat/interface/matrix.c
>>>>>> Well at least that is what I think comes out after I read all the jammed up messages from my MPI processes...
>>>>>> I would guess that I am trying to allocate more memory than I should which seems strange since the same problem runs fine on 2 nodes with 16 cores/node
>>>>>> Thanks for the help
>>>>>> Best,
>>>>>> Luc
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141030/cd3ae3b5/attachment-0001.html>
