[petsc-users] Lookup error in PetscTableFind()
Tue Oct 28 11:33:47 CDT 2014
    Hmm, this should never happen. In the code
  ierr = PetscTableCreate(aij->B->rmap->n,mat->cmap->N+1,&gid1_lid1);CHKERRQ(ierr);
  for (i=0; i<aij->B->rmap->n; i++) {
    for (j=0; j<B->ilen[i]; j++) {
      PetscInt data,gid1 = aj[B->i[i] + j] + 1;
      ierr = PetscTableFind(gid1_lid1,gid1,&data);CHKERRQ(ierr);
Now mat->cmap->N+1 is the total number of columns in the matrix and gid1 are column entries which must always be smaller. Most likely there has been memory corruption somewhere before this point. Can you run with valgrind? http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
  Barry
> On Oct 28, 2014, at 10:04 AM, Luc Berger-Vergiat <lb2653 at columbia.edu> wrote:
> Hi,
> I am running a code on CETUS and I use PETSc for as a linear solver.
> Here is my submission command:
> qsub -A shearbands -t 60 -n 4 -O 4nodes_32cores_Mult --mode script 4nodes_32cores_LU
> Here is "4nodes_32cores_LU":
> #!/bin/sh
> LOCARGS="--block $COBALT_PARTNAME ${COBALT_CORNER:+--corner} $COBALT_CORNER ${COBALT_SHAPE:+--shape} $COBALT_SHAPE"
> echo "Cobalt location args: $LOCARGS" >&2
> #   32 cores on 4 nodes jobs   #
> runjob --np 32 -p 8 --block $COBALT_PARTNAME --cwd /projects/shearbands/job1/200/4nodes_32cores/LU --verbose=INFO --envs FEAPHOME8_3=/projects/shearbands/ShearBands352 PETSC_DIR=/projects/shearbands/petsc-3.5.2 PETSC_ARCH=arch-linux2-c-opt : /projects/shearbands/ShearBands352/parfeap/feap -ksp_type preonly -pc_type lu -pc_factor_mat_solver_package mumps -ksp_diagonal_scale -malloc_log mlog -log_summary time.log           < /projects/shearbands/job1/yesfile
> I get the following error message:
> [7]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [7]PETSC ERROR: Argument out of range
> [7]PETSC ERROR: Petsc Release Version 3.5.2, unknown
> [7]PETSC ERROR: key 532150 is greater than largest key allowed 459888
> [7]PETSC ERROR: Configure options --known-mpi-int64_t=1 --download-cmake=1 --download-hypre=1 --download-metis=1 --download-parmetis=1 --download-plapack=1 --download-superlu_dist=1 --download-mumps=1 --download-ml=1 --known-bits-per-byte=8 --known-level1-dcache-assoc=0 --known-level1-dcache-linesize=32 --known-level1-dcache-size=32768 --known-memcmp-ok=1 --known-mpi-c-double-complex=1 --known-mpi-long-double=1 --known-mpi-shared-libraries=0 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-sizeof-char=1 --known-sizeof-double=8 --known-sizeof-float=4 --known-sizeof-int=4 --known-sizeof-long-long=8 --known-sizeof-long=8 --known-sizeof-short=2 --known-sizeof-size_t=8 --known-sizeof-void-p=8 --with-batch=1 --with-blacs-include=/soft/libraries/alcf/current/gcc/SCALAPACK/ --with-blacs-lib=/soft/libraries/alcf/current/gcc/SCALAPACK/lib/libscalapack.a --with-blas-lapack-lib="-L/soft/libraries/alcf/current/gcc/LAPACK/lib -llapack -L/soft/libraries/alcf/current/gcc/BLAS/lib -lblas" --with-cc=mpicc --with-cxx=mpicxx --with-debugging=0 --with-fc=mpif90 --with-fortran-kernels=1 --with-is-color-value-type=short --with-scalapack-include=/soft/libraries/alcf/current/gcc/SCALAPACK/ --with-scalapack-lib=/soft/libraries/alcf/current/gcc/SCALAPACK/lib/libscalapack.a --with-shared-libraries=0 --with-x=0 -COPTFLAGS=" -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction" -CXXOPTFLAGS=" -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction" -FOPTFLAGS=" -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction"
> [7]PETSC ERROR: #1 PetscTableFind() line 126 in /gpfs/mira-fs1/projects/shearbands/petsc-3.5.2/include/petscctable.h
> [7]PETSC ERROR: #2 MatSetUpMultiply_MPIAIJ() line 33 in /gpfs/mira-fs1/projects/shearbands/petsc-3.5.2/src/mat/impls/aij/mpi/mmaij.c
> [7]PETSC ERROR: #3 MatAssemblyEnd_MPIAIJ() line 702 in /gpfs/mira-fs1/projects/shearbands/petsc-3.5.2/src/mat/impls/aij/mpi/mpiaij.c
> [7]PETSC ERROR: #4 MatAssemblyEnd() line 4900 in /gpfs/mira-fs1/projects/shearbands/petsc-3.5.2/src/mat/interface/matrix.c
> Well at least that is what I think comes out after I read all the jammed up messages from my MPI processes...
> I would guess that I am trying to allocate more memory than I should which seems strange since the same problem runs fine on 2 nodes with 16 cores/node
> Thanks for the help
> Best,
> Luc
> On 10/27/2014 02:51 PM, Michael Povolotskyi wrote:
>> Hello,
>> will the eigenvectors that correspond to degenerate eigenvalues of a Hermitian matrix be orthogonal?
>> I'm using Krylov Schur method.
>> Thank you,
>> Michael.
