[petsc-users] Book for the PETSc finite volume method
Jed Brown jed at jedbrown.org
Tue Oct 28 11:15:10 CDT 2014
Rongliang Chen <rongliang.chan at gmail.com> writes:
> Thanks Matt and Jed,
> I am trying to write a parallel FVM code on unstructured grid for
> compressible NS equations. I found that the finite volume code on the
> structured mesh is easy to write but for the unstructured mesh, it is
> really untrivial. I want to follow the PETSc's DMPlexFV but it is not
> easy to read, so I want to find a good book for it.
There is no book specific to PETSc's interfaces.  What sort of equations
are you solving?  For hyperbolic systems, you can look at
src/ts/examples/tutorials/ex11.c.  Make sure to set up global/tags so
you can jump to the library implementations, or look at an older version
that doesn't hide the actual discretization in overly-specialized
library functions.  (Matt and I wrote this example together, but
disagree about which parts belong in the library.)
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141028/4f31b8b3/attachment.pgp>
