[petsc-users] TSSetIJacobian is never called
Sharp Stone thronesf at gmail.com
Tue Oct 28 09:22:11 CDT 2014
Hi Matt and Jed,
Thank you for your replies. Now I see Petsc will calculate functions'
residue in SNES before form the Jacobian. In order to get a initial
non-zero residues of the functions, we cannot initialize some of the
discretized spatial nodes of the functions to zero, am I right? In my
problem, initially only a small region will be initialized with some
values, while other spatial nodes remain zero. I don't know how the SNES
calculate the initial residue? If it is a sum residue on all discretized
nodes, then I should not get a zero residue, or at least, I should get a
small residue which is not zero. But I still get the exact zero residue. So
I wonder how the SNES calculate the residue?
Thanks in advance!
On Mon, Oct 27, 2014 at 4:09 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Oct 27, 2014 at 2:58 PM, Sharp Stone <thronesf at gmail.com> wrote:
>> Hi Matt,
>> That is why we asked this. We do not think the calculation of DAE
>> F-functions are wrong. But even if the F-functions are not accurate, we
>> expect the TS solver would still call TSSetIJacobian(), but actually it
>> does not call TSSetIJacobian() routine at all...
> SNES is not solving anything. It gets an initial residual of 0.0 so it
> never iterates and never forms a Jacobian. Something
> is wrong with your residual calculation. Also, you seem to be solving a
> linear equations somewhere. Give that solve a
> prefix so that it does not interfere with the other output.
>   Matt
>> Thank you in advance!
>> On Mon, Oct 27, 2014 at 3:39 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Mon, Oct 27, 2014 at 2:31 PM, Sharp Stone <thronesf at gmail.com> wrote:
>>>> Hi Matt,
>>>> Thank you for your reply and suggestion. I use the command line options
>>>> to make the output on the screen. It was very long and attached below.
>>>> Thanks a million in advance!
>>> Notice that you never actually solve anything. There is something wrong
>>> with your formulation. Try something where you
>>> know the exact solution first. Also run with
>>>   -snes_converged_reason -ksp_converged_reason
>>>     Matt
>>>> 0 KSP preconditioned resid norm 5.607581107219e-11 true resid norm
>>>> 9.787719465322e-12 ||r(i)||/||b|| 6.796750851600e-16
>>>> 0 TS dt 2e-12 time 0
>>>>   0 KSP preconditioned resid norm 3.622586114352e+17 true resid norm
>>>> 5.225681998280e+16 ||r(i)||/||b|| 1.000000000000e+00
>>>>   1 KSP preconditioned resid norm 3.704153274287e+17 true resid norm
>>>> 1.035782762954e+17 ||r(i)||/||b|| 1.982100639294e+00
>>>>   2 KSP preconditioned resid norm 2.842418683024e+17 true resid norm
>>>> 7.903974218109e+16 ||r(i)||/||b|| 1.512524914587e+00
>>>>   3 KSP preconditioned resid norm 2.393970839759e+17 true resid norm
>>>> 4.943510895366e+16 ||r(i)||/||b|| 9.460030091754e-01
>>>>   4 KSP preconditioned resid norm 2.271787411557e+17 true resid norm
>>>> 4.669216610635e+16 ||r(i)||/||b|| 8.935133466162e-01
>>>>   5 KSP preconditioned resid norm 2.360179849286e+17 true resid norm
>>>> 4.108243474851e+16 ||r(i)||/||b|| 7.861640789094e-01
>>>>   6 KSP preconditioned resid norm 2.619090922116e+17 true resid norm
>>>> 4.955060344596e+16 ||r(i)||/||b|| 9.482131416009e-01
>>>>   7 KSP preconditioned resid norm 2.333689240438e+17 true resid norm
>>>> 4.336784470641e+16 ||r(i)||/||b|| 8.298982739609e-01
>>>>   8 KSP preconditioned resid norm 3.244607818183e+17 true resid norm
>>>> 5.407474341938e+16 ||r(i)||/||b|| 1.034788252274e+00
>>>>   9 KSP preconditioned resid norm 3.024748487424e+17 true resid norm
>>>> 6.388129145873e+16 ||r(i)||/||b|| 1.222448887624e+00
>>>>  10 KSP preconditioned resid norm 2.127860348138e+17 true resid norm
>>>> 3.704786520226e+16 ||r(i)||/||b|| 7.089575143389e-01
>>>>  11 KSP preconditioned resid norm 4.652609350461e+16 true resid norm
>>>> 8.497318285406e+15 ||r(i)||/||b|| 1.626068767331e-01
>>>>  12 KSP preconditioned resid norm 2.920260091494e+16 true resid norm
>>>> 4.651858168992e+15 ||r(i)||/||b|| 8.901915904036e-02
>>>>  13 KSP preconditioned resid norm 2.527529714994e+16 true resid norm
>>>> 3.813962069025e+15 ||r(i)||/||b|| 7.298496292505e-02
>>>>  14 KSP preconditioned resid norm 2.224122069397e+16 true resid norm
>>>> 4.355442499437e+15 ||r(i)||/||b|| 8.334687225268e-02
>>>>  15 KSP preconditioned resid norm 2.040909225547e+16 true resid norm
>>>> 5.536568280983e+15 ||r(i)||/||b|| 1.059492001772e-01
>>>>  16 KSP preconditioned resid norm 1.834652616545e+16 true resid norm
>>>> 3.131287565910e+15 ||r(i)||/||b|| 5.992112736559e-02
>>>>  17 KSP preconditioned resid norm 1.760978175265e+16 true resid norm
>>>> 3.245011634605e+15 ||r(i)||/||b|| 6.209738050790e-02
>>>>  18 KSP preconditioned resid norm 1.385338263500e+16 true resid norm
>>>> 3.596318213647e+15 ||r(i)||/||b|| 6.882007391247e-02
>>>>  19 KSP preconditioned resid norm 1.488783377120e+16 true resid norm
>>>> 2.508274919240e+15 ||r(i)||/||b|| 4.799899649588e-02
>>>>  20 KSP preconditioned resid norm 1.320707251811e+16 true resid norm
>>>> 2.042806338080e+15 ||r(i)||/||b|| 3.909166954193e-02
>>>>  21 KSP preconditioned resid norm 7.616453043037e+15 true resid norm
>>>> 1.348500002677e+15 ||r(i)||/||b|| 2.580524423647e-02
>>>>  22 KSP preconditioned resid norm 8.879333117289e+15 true resid norm
>>>> 1.392661876801e+15 ||r(i)||/||b|| 2.665033726238e-02
>>>>  23 KSP preconditioned resid norm 8.820610261864e+15 true resid norm
>>>> 1.365093600480e+15 ||r(i)||/||b|| 2.612278360851e-02
>>>>  24 KSP preconditioned resid norm 7.993346710634e+15 true resid norm
>>>> 1.790642691323e+15 ||r(i)||/||b|| 3.426620088847e-02
>>>>  25 KSP preconditioned resid norm 7.525623400757e+15 true resid norm
>>>> 1.148549131012e+15 ||r(i)||/||b|| 2.197893272859e-02
>>>>  26 KSP preconditioned resid norm 7.109494224141e+15 true resid norm
>>>> 1.253098862904e+15 ||r(i)||/||b|| 2.397962339302e-02
>>>>  27 KSP preconditioned resid norm 9.199926655972e+15 true resid norm
>>>> 1.867276980934e+15 ||r(i)||/||b|| 3.573269444158e-02
>>>>  28 KSP preconditioned resid norm 1.121259577312e+16 true resid norm
>>>> 3.202544820818e+15 ||r(i)||/||b|| 6.128472459426e-02
>>>>  29 KSP preconditioned resid norm 4.340241766754e+15 true resid norm
>>>> 6.879443404198e+14 ||r(i)||/||b|| 1.316468052680e-02
>>>>  30 KSP preconditioned resid norm 4.050053526588e+15 true resid norm
>>>> 6.673524276162e+14 ||r(i)||/||b|| 1.277062836652e-02
>>>>  31 KSP preconditioned resid norm 3.675002682668e+15 true resid norm
>>>> 5.703629309888e+14 ||r(i)||/||b|| 1.091461231618e-02
>>>>  32 KSP preconditioned resid norm 3.175854297440e+15 true resid norm
>>>> 4.918363244864e+14 ||r(i)||/||b|| 9.411906898435e-03
>>>>  33 KSP preconditioned resid norm 2.534108954658e+15 true resid norm
>>>> 3.888660709280e+14 ||r(i)||/||b|| 7.441441539229e-03
>>>>  34 KSP preconditioned resid norm 1.517593193539e+15 true resid norm
>>>> 2.347716358056e+14 ||r(i)||/||b|| 4.492650641255e-03
>>>>  35 KSP preconditioned resid norm 1.238737221149e+15 true resid norm
>>>> 4.944967490035e+14 ||r(i)||/||b|| 9.462817468922e-03
>>>>  36 KSP preconditioned resid norm 8.673662184926e+14 true resid norm
>>>> 1.322920275286e+14 ||r(i)||/||b|| 2.531574396837e-03
>>>>  37 KSP preconditioned resid norm 7.206551748402e+14 true resid norm
>>>> 1.263301396525e+14 ||r(i)||/||b|| 2.417486171069e-03
>>>>  38 KSP preconditioned resid norm 5.143409845488e+14 true resid norm
>>>> 7.953540049469e+13 ||r(i)||/||b|| 1.522009960056e-03
>>>>  39 KSP preconditioned resid norm 4.261910201431e+14 true resid norm
>>>> 7.194412501613e+13 ||r(i)||/||b|| 1.376741352417e-03
>>>>  40 KSP preconditioned resid norm 4.660682952219e+14 true resid norm
>>>> 7.611539723637e+13 ||r(i)||/||b|| 1.456563894654e-03
>>>>  41 KSP preconditioned resid norm 3.209169783039e+14 true resid norm
>>>> 4.903825175831e+13 ||r(i)||/||b|| 9.384086474158e-04
>>>>   0 KSP preconditioned resid norm 5.647841057638e+16 true resid norm
>>>> 8.145493103696e+15 ||r(i)||/||b|| 1.000000000000e+00
>>>>   1 KSP preconditioned resid norm 5.871590984109e+16 true resid norm
>>>> 1.629681152051e+16 ||r(i)||/||b|| 2.000715157823e+00
>>>>   2 KSP preconditioned resid norm 4.554798588549e+16 true resid norm
>>>> 1.256325647853e+16 ||r(i)||/||b|| 1.542356775532e+00
>>>>   3 KSP preconditioned resid norm 3.879559549735e+16 true resid norm
>>>> 7.930640596410e+15 ||r(i)||/||b|| 9.736231429392e-01
>>>>   4 KSP preconditioned resid norm 3.752982759961e+16 true resid norm
>>>> 7.738765648717e+15 ||r(i)||/||b|| 9.500671782787e-01
>>>>   5 KSP preconditioned resid norm 3.847367502586e+16 true resid norm
>>>> 6.717373650268e+15 ||r(i)||/||b|| 8.246736649031e-01
>>>>   6 KSP preconditioned resid norm 4.072409022879e+16 true resid norm
>>>> 7.643006165053e+15 ||r(i)||/||b|| 9.383110473184e-01
>>>>   7 KSP preconditioned resid norm 3.699615223300e+16 true resid norm
>>>> 6.864744274739e+15 ||r(i)||/||b|| 8.427659550315e-01
>>>>   8 KSP preconditioned resid norm 4.452919179646e+16 true resid norm
>>>> 7.438964756180e+15 ||r(i)||/||b|| 9.132614393603e-01
>>>>   9 KSP preconditioned resid norm 4.218921641123e+16 true resid norm
>>>> 8.817640722426e+15 ||r(i)||/||b|| 1.082517732220e+00
>>>>  10 KSP preconditioned resid norm 2.723066166891e+18 true resid norm
>>>> 4.777495288747e+17 ||r(i)||/||b|| 5.865200826920e+01
>>>>  11 KSP preconditioned resid norm 1.543090703715e+16 true resid norm
>>>> 2.978277930467e+15 ||r(i)||/||b|| 3.656350686879e-01
>>>>  12 KSP preconditioned resid norm 5.543831189057e+15 true resid norm
>>>> 9.036431670746e+14 ||r(i)||/||b|| 1.109378100958e-01
>>>>  13 KSP preconditioned resid norm 4.835578439031e+15 true resid norm
>>>> 7.302084941558e+14 ||r(i)||/||b|| 8.964570773800e-02
>>>>  14 KSP preconditioned resid norm 4.632268883924e+15 true resid norm
>>>> 7.764942849443e+14 ||r(i)||/||b|| 9.532808819050e-02
>>>>  15 KSP preconditioned resid norm 4.279662320804e+15 true resid norm
>>>> 7.279053691611e+14 ||r(i)||/||b|| 8.936295935612e-02
>>>>  16 KSP preconditioned resid norm 4.003909782590e+15 true resid norm
>>>> 6.398763789786e+14 ||r(i)||/||b|| 7.855588002257e-02
>>>>  17 KSP preconditioned resid norm 3.778065018292e+15 true resid norm
>>>> 9.619695351776e+14 ||r(i)||/||b|| 1.180983794267e-01
>>>>  18 KSP preconditioned resid norm 4.432967840881e+15 true resid norm
>>>> 1.765362859847e+15 ||r(i)||/||b|| 2.167287894512e-01
>>>>  19 KSP preconditioned resid norm 3.349713073090e+15 true resid norm
>>>> 5.343310168427e+14 ||r(i)||/||b|| 6.559836341894e-02
>>>>  20 KSP preconditioned resid norm 3.170973083244e+15 true resid norm
>>>> 4.905381423867e+14 ||r(i)||/||b|| 6.022203151385e-02
>>>>  21 KSP preconditioned resid norm 7.415620721710e+15 true resid norm
>>>> 1.207250421775e+15 ||r(i)||/||b|| 1.482108457286e-01
>>>>  22 KSP preconditioned resid norm 1.972990201442e+15 true resid norm
>>>> 3.077655556372e+14 ||r(i)||/||b|| 3.778353891154e-02
>>>>  23 KSP preconditioned resid norm 2.209676808077e+15 true resid norm
>>>> 3.428403970507e+14 ||r(i)||/||b|| 4.208958164793e-02
>>>>  24 KSP preconditioned resid norm 2.003292171306e+15 true resid norm
>>>> 4.370066270665e+14 ||r(i)||/||b|| 5.365011319796e-02
>>>>  25 KSP preconditioned resid norm 1.896876965875e+15 true resid norm
>>>> 2.911542588080e+14 ||r(i)||/||b|| 3.574421524903e-02
>>>>  26 KSP preconditioned resid norm 1.776666236555e+15 true resid norm
>>>> 2.752957912495e+14 ||r(i)||/||b|| 3.379731438537e-02
>>>>  27 KSP preconditioned resid norm 2.106240629900e+15 true resid norm
>>>> 3.329282684307e+14 ||r(i)||/||b|| 4.087269661791e-02
>>>>  28 KSP preconditioned resid norm 1.993718847257e+15 true resid norm
>>>> 3.265440954005e+14 ||r(i)||/||b|| 4.008892908550e-02
>>>>  29 KSP preconditioned resid norm 1.305019272390e+15 true resid norm
>>>> 2.016059917794e+14 ||r(i)||/||b|| 2.475061843560e-02
>>>>  30 KSP preconditioned resid norm 1.188165021558e+15 true resid norm
>>>> 2.349019593212e+14 ||r(i)||/||b|| 2.883827367242e-02
>>>>  31 KSP preconditioned resid norm 1.072198412006e+15 true resid norm
>>>> 1.660526922017e+14 ||r(i)||/||b|| 2.038583669371e-02
>>>>  32 KSP preconditioned resid norm 9.531727749289e+14 true resid norm
>>>> 1.481127635008e+14 ||r(i)||/||b|| 1.818340051551e-02
>>>>  33 KSP preconditioned resid norm 8.113851256730e+14 true resid norm
>>>> 1.246949236714e+14 ||r(i)||/||b|| 1.530845610990e-02
>>>>  34 KSP preconditioned resid norm 1.978771889204e+15 true resid norm
>>>> 3.123099443158e+14 ||r(i)||/||b|| 3.834144113069e-02
>>>>  35 KSP preconditioned resid norm 5.701229171299e+14 true resid norm
>>>> 9.665965877556e+13 ||r(i)||/||b|| 1.186664300676e-02
>>>>  36 KSP preconditioned resid norm 4.923209980376e+14 true resid norm
>>>> 8.358449899120e+13 ||r(i)||/||b|| 1.026144125679e-02
>>>>  37 KSP preconditioned resid norm 4.337271696165e+14 true resid norm
>>>> 7.056948273999e+13 ||r(i)||/||b|| 8.663623164566e-03
>>>>  38 KSP preconditioned resid norm 3.355561922811e+14 true resid norm
>>>> 5.206223795577e+13 ||r(i)||/||b|| 6.391539136181e-03
>>>>  39 KSP preconditioned resid norm 2.948796430248e+14 true resid norm
>>>> 4.783720648479e+13 ||r(i)||/||b|| 5.872843531485e-03
>>>>  40 KSP preconditioned resid norm 2.903844355011e+14 true resid norm
>>>> 4.553096332971e+13 ||r(i)||/||b|| 5.589712341546e-03
>>>>  41 KSP preconditioned resid norm 2.470740134237e+14 true resid norm
>>>> 3.845088511805e+13 ||r(i)||/||b|| 4.720510425650e-03
>>>>  42 KSP preconditioned resid norm 2.144333147632e+14 true resid norm
>>>> 4.199300915233e+13 ||r(i)||/||b|| 5.155367344584e-03
>>>>  43 KSP preconditioned resid norm 1.666875797521e+14 true resid norm
>>>> 2.786670988964e+13 ||r(i)||/||b|| 3.421120064173e-03
>>>>  44 KSP preconditioned resid norm 1.097596670806e+14 true resid norm
>>>> 1.683182082477e+13 ||r(i)||/||b|| 2.066396792741e-03
>>>>  45 KSP preconditioned resid norm 1.086486049833e+14 true resid norm
>>>> 1.868163126673e+13 ||r(i)||/||b|| 2.293492981813e-03
>>>>  46 KSP preconditioned resid norm 9.986155841385e+13 true resid norm
>>>> 1.544797785039e+13 ||r(i)||/||b|| 1.896506160367e-03
>>>>  47 KSP preconditioned resid norm 9.193832565781e+13 true resid norm
>>>> 1.424417809082e+13 ||r(i)||/||b|| 1.748718943038e-03
>>>>  48 KSP preconditioned resid norm 7.868838175665e+13 true resid norm
>>>> 1.234477959732e+13 ||r(i)||/||b|| 1.515534963957e-03
>>>>  49 KSP preconditioned resid norm 6.573261298706e+13 true resid norm
>>>> 1.037919549254e+13 ||r(i)||/||b|| 1.274225557668e-03
>>>>  50 KSP preconditioned resid norm 6.394833480259e+13 true resid norm
>>>> 1.032066032237e+13 ||r(i)||/||b|| 1.267039354277e-03
>>>>  51 KSP preconditioned resid norm 6.650072664422e+13 true resid norm
>>>> 2.391163155719e+13 ||r(i)||/||b|| 2.935565870940e-03
>>>>  52 KSP preconditioned resid norm 6.239223696051e+13 true resid norm
>>>> 9.858797480463e+12 ||r(i)||/||b|| 1.210337711291e-03
>>>>  53 KSP preconditioned resid norm 6.247432830217e+13 true resid norm
>>>> 9.562224327829e+12 ||r(i)||/||b|| 1.173928233208e-03
>>>>  54 KSP preconditioned resid norm 6.218810094746e+13 true resid norm
>>>> 9.709963371483e+12 ||r(i)||/||b|| 1.192065753156e-03
>>>>  55 KSP preconditioned resid norm 6.285033387840e+13 true resid norm
>>>> 9.623710764220e+12 ||r(i)||/||b|| 1.181476755515e-03
>>>>  56 KSP preconditioned resid norm 5.407058856328e+13 true resid norm
>>>> 9.490503427247e+12 ||r(i)||/||b|| 1.165123253611e-03
>>>>   0 KSP preconditioned resid norm 9.075431914728e+17 true resid norm
>>>> 1.310345788054e+17 ||r(i)||/||b|| 1.000000000000e+00
>>>>   1 KSP preconditioned resid norm 8.641655528143e+17 true resid norm
>>>> 2.471138002109e+17 ||r(i)||/||b|| 1.885867092974e+00
>>>>   2 KSP preconditioned resid norm 6.384433252903e+17 true resid norm
>>>> 1.816534419632e+17 ||r(i)||/||b|| 1.386301567259e+00
>>>>   3 KSP preconditioned resid norm 5.179227150533e+17 true resid norm
>>>> 1.107056703740e+17 ||r(i)||/||b|| 8.448584441089e-01
>>>>   4 KSP preconditioned resid norm 4.625114083211e+17 true resid norm
>>>> 9.438923102711e+16 ||r(i)||/||b|| 7.203383403647e-01
>>>>   5 KSP preconditioned resid norm 4.977065165555e+17 true resid norm
>>>> 8.614996614554e+16 ||r(i)||/||b|| 6.574597860420e-01
>>>>   6 KSP preconditioned resid norm 6.630931668382e+17 true resid norm
>>>> 1.310543864565e+17 ||r(i)||/||b|| 1.000151163542e+00
>>>>   7 KSP preconditioned resid norm 5.452278853431e+17 true resid norm
>>>> 1.019521297074e+17 ||r(i)||/||b|| 7.780551564087e-01
>>>>   8 KSP preconditioned resid norm 1.958476842674e+18 true resid norm
>>>> 3.244825770314e+17 ||r(i)||/||b|| 2.476312588551e+00
>>>>   9 KSP preconditioned resid norm 1.577830260132e+18 true resid norm
>>>> 3.469004540765e+17 ||r(i)||/||b|| 2.647396261651e+00
>>>>  10 KSP preconditioned resid norm 1.081897998863e+17 true resid norm
>>>> 1.828781621979e+16 ||r(i)||/||b|| 1.395648109568e-01
>>>>  11 KSP preconditioned resid norm 5.614465792481e+16 true resid norm
>>>> 9.930812946447e+15 ||r(i)||/||b|| 7.578772746079e-02
>>>>  12 KSP preconditioned resid norm 4.960081715579e+16 true resid norm
>>>> 8.035214375965e+15 ||r(i)||/||b|| 6.132132792135e-02
>>>>  13 KSP preconditioned resid norm 3.329600867897e+16 true resid norm
>>>> 6.602562228940e+15 ||r(i)||/||b|| 5.038793797127e-02
>>>>  14 KSP preconditioned resid norm 3.130960732609e+16 true resid norm
>>>> 4.730473520325e+15 ||r(i)||/||b|| 3.610095566719e-02
>>>>  15 KSP preconditioned resid norm 2.560518921527e+16 true resid norm
>>>> 3.945110867578e+15 ||r(i)||/||b|| 3.010740297365e-02
>>>>  16 KSP preconditioned resid norm 1.584886017619e+16 true resid norm
>>>> 3.416780637867e+15 ||r(i)||/||b|| 2.607541207073e-02
>>>>  17 KSP preconditioned resid norm 1.443824757417e+16 true resid norm
>>>> 2.286337927483e+15 ||r(i)||/||b|| 1.744835560449e-02
>>>>  18 KSP preconditioned resid norm 1.039145582094e+16 true resid norm
>>>> 1.711526931765e+15 ||r(i)||/||b|| 1.306164332627e-02
>>>>  19 KSP preconditioned resid norm 1.018242603191e+16 true resid norm
>>>> 1.657426513724e+15 ||r(i)||/||b|| 1.264877201754e-02
>>>>  20 KSP preconditioned resid norm 8.198983478967e+15 true resid norm
>>>> 1.311419876212e+15 ||r(i)||/||b|| 1.000819698256e-02
>>>>  21 KSP preconditioned resid norm 6.481494503642e+15 true resid norm
>>>> 1.039872641976e+15 ||r(i)||/||b|| 7.935864345546e-03
>>>>  22 KSP preconditioned resid norm 6.325821399407e+15 true resid norm
>>>> 1.165377948147e+15 ||r(i)||/||b|| 8.893667295849e-03
>>>>  23 KSP preconditioned resid norm 5.405294478066e+15 true resid norm
>>>> 1.922243319095e+15 ||r(i)||/||b|| 1.466974089297e-02
>>>>  24 KSP preconditioned resid norm 4.960676496180e+15 true resid norm
>>>> 8.018184223519e+14 ||r(i)||/||b|| 6.119136106374e-03
>>>>  25 KSP preconditioned resid norm 4.419138742847e+15 true resid norm
>>>> 7.148418830282e+14 ||r(i)||/||b|| 5.455368266491e-03
>>>>  26 KSP preconditioned resid norm 2.795870478230e+15 true resid norm
>>>> 4.843283048525e+14 ||r(i)||/||b|| 3.696186985663e-03
>>>>  27 KSP preconditioned resid norm 2.911201681995e+15 true resid norm
>>>> 4.441742607418e+14 ||r(i)||/||b|| 3.389748452592e-03
>>>>  28 KSP preconditioned resid norm 2.776697567476e+15 true resid norm
>>>> 5.074732182061e+14 ||r(i)||/||b|| 3.872819089681e-03
>>>>  29 KSP preconditioned resid norm 1.941501506934e+15 true resid norm
>>>> 2.950418833153e+14 ||r(i)||/||b|| 2.251633774878e-03
>>>>  30 KSP preconditioned resid norm 8.413150178496e+14 true resid norm
>>>> 1.695476752862e+14 ||r(i)||/||b|| 1.293915520864e-03
>>>>   0 KSP preconditioned resid norm 1.415973479575e+17 true resid norm
>>>> 2.042710742436e+16 ||r(i)||/||b|| 1.000000000000e+00
>>>>   1 KSP preconditioned resid norm 1.440919303250e+17 true resid norm
>>>> 4.045863378014e+16 ||r(i)||/||b|| 1.980634503928e+00
>>>>   2 KSP preconditioned resid norm 1.100352174605e+17 true resid norm
>>>> 3.072773288453e+16 ||r(i)||/||b|| 1.504262558872e+00
>>>>   3 KSP preconditioned resid norm 9.218323125716e+16 true resid norm
>>>> 1.914173874994e+16 ||r(i)||/||b|| 9.370753456316e-01
>>>>   4 KSP preconditioned resid norm 8.672799672395e+16 true resid norm
>>>> 1.779286318286e+16 ||r(i)||/||b|| 8.710417394506e-01
>>>>   5 KSP preconditioned resid norm 9.059066321416e+16 true resid norm
>>>> 1.574500663517e+16 ||r(i)||/||b|| 7.707898288327e-01
>>>>   6 KSP preconditioned resid norm 1.027848583976e+17 true resid norm
>>>> 1.954996111922e+16 ||r(i)||/||b|| 9.570596909823e-01
>>>>   7 KSP preconditioned resid norm 9.069106612200e+16 true resid norm
>>>> 1.686428629204e+16 ||r(i)||/||b|| 8.255836688812e-01
>>>>   8 KSP preconditioned resid norm 1.359707392060e+17 true resid norm
>>>> 2.263432282464e+16 ||r(i)||/||b|| 1.108053252691e+00
>>>>   9 KSP preconditioned resid norm 1.256447896822e+17 true resid norm
>>>> 2.668588264948e+16 ||r(i)||/||b|| 1.306395570116e+00
>>>>  10 KSP preconditioned resid norm 5.661761773340e+16 true resid norm
>>>> 9.807578010522e+15 ||r(i)||/||b|| 4.801256392682e-01
>>>>  11 KSP preconditioned resid norm 1.597811133832e+16 true resid norm
>>>> 2.854210532053e+15 ||r(i)||/||b|| 1.397266129148e-01
>>>>  12 KSP preconditioned resid norm 1.141170314391e+16 true resid norm
>>>> 1.817769027418e+15 ||r(i)||/||b|| 8.898807793264e-02
>>>>  13 KSP preconditioned resid norm 9.557798166843e+15 true resid norm
>>>> 1.455009507586e+15 ||r(i)||/||b|| 7.122934624852e-02
>>>>  14 KSP preconditioned resid norm 7.997842098400e+15 true resid norm
>>>> 2.021581420109e+15 ||r(i)||/||b|| 9.896562338034e-02
>>>>  15 KSP preconditioned resid norm 7.518666379332e+15 true resid norm
>>>> 2.232979183117e+15 ||r(i)||/||b|| 1.093145072735e-01
>>>>  16 KSP preconditioned resid norm 6.614897634500e+15 true resid norm
>>>> 1.222952133628e+15 ||r(i)||/||b|| 5.986908024822e-02
>>>>  17 KSP preconditioned resid norm 6.199437182741e+15 true resid norm
>>>> 1.163257046730e+15 ||r(i)||/||b|| 5.694673369870e-02
>>>>  18 KSP preconditioned resid norm 4.584922270319e+15 true resid norm
>>>> 9.962391827866e+14 ||r(i)||/||b|| 4.877044811535e-02
>>>>  19 KSP preconditioned resid norm 5.012002077991e+15 true resid norm
>>>> 8.755757394511e+14 ||r(i)||/||b|| 4.286342266977e-02
>>>>  20 KSP preconditioned resid norm 4.312819580189e+15 true resid norm
>>>> 6.706322150678e+14 ||r(i)||/||b|| 3.283050317090e-02
>>>>  21 KSP preconditioned resid norm 2.607093537931e+15 true resid norm
>>>> 5.192589254045e+14 ||r(i)||/||b|| 2.542009079490e-02
>>>>  22 KSP preconditioned resid norm 2.989363098445e+15 true resid norm
>>>> 4.636989016003e+14 ||r(i)||/||b|| 2.270017442838e-02
>>>>  23 KSP preconditioned resid norm 3.016276187245e+15 true resid norm
>>>> 4.674022912685e+14 ||r(i)||/||b|| 2.288147222994e-02
>>>>  24 KSP preconditioned resid norm 2.901859180715e+15 true resid norm
>>>> 4.492447164798e+14 ||r(i)||/||b|| 2.199257619530e-02
>>>>  25 KSP preconditioned resid norm 2.843000955863e+15 true resid norm
>>>> 5.109023428494e+14 ||r(i)||/||b|| 2.501099799574e-02
>>>>  26 KSP preconditioned resid norm 2.741940909323e+15 true resid norm
>>>> 4.263494245202e+14 ||r(i)||/||b|| 2.087174731415e-02
>>>>  27 KSP preconditioned resid norm 1.296293793548e+15 true resid norm
>>>> 2.124064840417e+14 ||r(i)||/||b|| 1.039826538477e-02
>>>>  28 KSP preconditioned resid norm 9.720512789714e+14 true resid norm
>>>> 2.091841490290e+14 ||r(i)||/||b|| 1.024051740089e-02
>>>>  29 KSP preconditioned resid norm 1.459179957917e+15 true resid norm
>>>> 2.244723575034e+14 ||r(i)||/||b|| 1.098894487800e-02
>>>>  30 KSP preconditioned resid norm 1.339547884067e+15 true resid norm
>>>> 2.746667338979e+14 ||r(i)||/||b|| 1.344618835119e-02
>>>>  31 KSP preconditioned resid norm 1.186062213325e+15 true resid norm
>>>> 1.831856176134e+14 ||r(i)||/||b|| 8.967770806105e-03
>>>>  32 KSP preconditioned resid norm 9.909356538944e+14 true resid norm
>>>> 1.788908155328e+14 ||r(i)||/||b|| 8.757520671747e-03
>>>>  33 KSP preconditioned resid norm 7.609550150745e+14 true resid norm
>>>> 1.203572113192e+14 ||r(i)||/||b|| 5.892033992812e-03
>>>>  34 KSP preconditioned resid norm 5.051711143811e+14 true resid norm
>>>> 7.920683224412e+13 ||r(i)||/||b|| 3.877535404237e-03
>>>>  35 KSP preconditioned resid norm 5.443461822227e+14 true resid norm
>>>> 8.557198028123e+13 ||r(i)||/||b|| 4.189138408269e-03
>>>>  36 KSP preconditioned resid norm 4.648220720251e+14 true resid norm
>>>> 7.162139608842e+13 ||r(i)||/||b|| 3.506193735634e-03
>>>>  37 KSP preconditioned resid norm 3.842876907480e+14 true resid norm
>>>> 6.998069618798e+13 ||r(i)||/||b|| 3.425873998417e-03
>>>>  38 KSP preconditioned resid norm 2.822934553902e+14 true resid norm
>>>> 5.594039593962e+13 ||r(i)||/||b|| 2.738537316003e-03
>>>>  39 KSP preconditioned resid norm 2.288268021627e+14 true resid norm
>>>> 3.624972614121e+13 ||r(i)||/||b|| 1.774589293929e-03
>>>>  40 KSP preconditioned resid norm 3.336880274482e+14 true resid norm
>>>> 5.633095049288e+13 ||r(i)||/||b|| 2.757656741242e-03
>>>>  41 KSP preconditioned resid norm 1.655073694079e+14 true resid norm
>>>> 2.539321805860e+13 ||r(i)||/||b|| 1.243113747388e-03
>>>>  42 KSP preconditioned resid norm 1.317678812236e+14 true resid norm
>>>> 2.429513710603e+13 ||r(i)||/||b|| 1.189357680523e-03
>>>>   0 KSP preconditioned resid norm 4.735355646927e+18 true resid norm
>>>> 6.977368406398e+17 ||r(i)||/||b|| 1.000000000000e+00
>>>>   1 KSP preconditioned resid norm 1.655056377336e+18 true resid norm
>>>> 5.433322725028e+17 ||r(i)||/||b|| 7.787065851426e-01
>>>>   2 KSP preconditioned resid norm 8.847192945348e+17 true resid norm
>>>> 2.725627800798e+17 ||r(i)||/||b|| 3.906383670810e-01
>>>>   3 KSP preconditioned resid norm 5.344946494044e+17 true resid norm
>>>> 1.588736353868e+17 ||r(i)||/||b|| 2.276985048419e-01
>>>>   4 KSP preconditioned resid norm 3.198139750974e+17 true resid norm
>>>> 6.624530455539e+16 ||r(i)||/||b|| 9.494310848578e-02
>>>>   5 KSP preconditioned resid norm 3.286368493485e+17 true resid norm
>>>> 6.812427209313e+16 ||r(i)||/||b|| 9.763605434775e-02
>>>>   6 KSP preconditioned resid norm 4.284030910438e+17 true resid norm
>>>> 1.696553569581e+17 ||r(i)||/||b|| 2.431509232084e-01
>>>>   7 KSP preconditioned resid norm 1.587968810131e+18 true resid norm
>>>> 3.732963000458e+17 ||r(i)||/||b|| 5.350101618592e-01
>>>>   8 KSP preconditioned resid norm 6.621891209840e+16 true resid norm
>>>> 1.229792367414e+16 ||r(i)||/||b|| 1.762544695628e-02
>>>>   9 KSP preconditioned resid norm 5.638286198157e+16 true resid norm
>>>> 2.091986582514e+16 ||r(i)||/||b|| 2.998245843800e-02
>>>>  10 KSP preconditioned resid norm 1.309067125882e+16 true resid norm
>>>> 2.099826104432e+15 ||r(i)||/||b|| 3.009481486611e-03
>>>>  11 KSP preconditioned resid norm 1.075925809079e+16 true resid norm
>>>> 2.578010577039e+15 ||r(i)||/||b|| 3.694817912546e-03
>>>>  12 KSP preconditioned resid norm 9.319606428298e+15 true resid norm
>>>> 2.026298982436e+15 ||r(i)||/||b|| 2.904102040216e-03
>>>>  13 KSP preconditioned resid norm 4.070270220193e+15 true resid norm
>>>> 2.216532493559e+15 ||r(i)||/||b|| 3.176745678968e-03
>>>>  14 KSP preconditioned resid norm 3.400982828163e+15 true resid norm
>>>> 9.161069365806e+14 ||r(i)||/||b|| 1.312969135671e-03
>>>>  15 KSP preconditioned resid norm 4.173720697476e+14 true resid norm
>>>> 7.019272258636e+13 ||r(i)||/||b|| 1.006005681483e-04
>>>>  16 KSP preconditioned resid norm 2.871344308441e+14 true resid norm
>>>> 8.503915375563e+13 ||r(i)||/||b|| 1.218785490496e-04
>>>>  17 KSP preconditioned resid norm 8.731930916187e+13 true resid norm
>>>> 2.939915802842e+13 ||r(i)||/||b|| 4.213502328681e-05
>>>>  18 KSP preconditioned resid norm 7.273170647297e+13 true resid norm
>>>> 2.554194915512e+13 ||r(i)||/||b|| 3.660685184933e-05
>>>>  19 KSP preconditioned resid norm 5.198384943683e+13 true resid norm
>>>> 8.213409786802e+12 ||r(i)||/||b|| 1.177150081293e-05
>>>>  20 KSP preconditioned resid norm 2.826075121950e+13 true resid norm
>>>> 1.225537290577e+13 ||r(i)||/||b|| 1.756446297795e-05
>>>>   0 KSP preconditioned resid norm 7.535755573391e+17 true resid norm
>>>> 1.091530949677e+17 ||r(i)||/||b|| 1.000000000000e+00
>>>>   1 KSP preconditioned resid norm 5.749658535033e+17 true resid norm
>>>> 1.739986551510e+17 ||r(i)||/||b|| 1.594078987889e+00
>>>>   2 KSP preconditioned resid norm 3.832130567981e+17 true resid norm
>>>> 1.138657236506e+17 ||r(i)||/||b|| 1.043174485197e+00
>>>>   3 KSP preconditioned resid norm 2.820261830557e+17 true resid norm
>>>> 6.703201541200e+16 ||r(i)||/||b|| 6.141100756863e-01
>>>>   4 KSP preconditioned resid norm 2.196333397214e+17 true resid norm
>>>> 4.464718002673e+16 ||r(i)||/||b|| 4.090326530819e-01
>>>>   5 KSP preconditioned resid norm 2.438749906836e+17 true resid norm
>>>> 4.259961207836e+16 ||r(i)||/||b|| 3.902739733672e-01
>>>>   6 KSP preconditioned resid norm 7.293863369143e+17 true resid norm
>>>> 1.861518427200e+17 ||r(i)||/||b|| 1.705419738901e+00
>>>>   7 KSP preconditioned resid norm 3.735172838302e+17 true resid norm
>>>> 7.178953918634e+16 ||r(i)||/||b|| 6.576958647631e-01
>>>>   8 KSP preconditioned resid norm 2.306462817079e+17 true resid norm
>>>> 3.812340554474e+16 ||r(i)||/||b|| 3.492654565226e-01
>>>>   9 KSP preconditioned resid norm 2.324630150277e+17 true resid norm
>>>> 5.879635462988e+16 ||r(i)||/||b|| 5.386595281360e-01
>>>>  10 KSP preconditioned resid norm 2.486084300490e+16 true resid norm
>>>> 3.943582532938e+15 ||r(i)||/||b|| 3.612891172811e-02
>>>>  11 KSP preconditioned resid norm 2.044336976942e+16 true resid norm
>>>> 4.427406712026e+15 ||r(i)||/||b|| 4.056143999707e-02
>>>>  12 KSP preconditioned resid norm 1.903964203761e+16 true resid norm
>>>> 3.227987898262e+15 ||r(i)||/||b|| 2.957303133931e-02
>>>>  13 KSP preconditioned resid norm 6.823460749064e+15 true resid norm
>>>> 1.876444880951e+15 ||r(i)||/||b|| 1.719094526368e-02
>>>>  14 KSP preconditioned resid norm 7.090194359812e+15 true resid norm
>>>> 1.450790953432e+15 ||r(i)||/||b|| 1.329134051455e-02
>>>>  15 KSP preconditioned resid norm 4.884314111756e+15 true resid norm
>>>> 8.008003608330e+14 ||r(i)||/||b|| 7.336487903253e-03
>>>>  16 KSP preconditioned resid norm 1.603299777176e+15 true resid norm
>>>> 2.941609026573e+14 ||r(i)||/||b|| 2.694938725689e-03
>>>>  17 KSP preconditioned resid norm 1.548805654760e+15 true resid norm
>>>> 2.838534773138e+14 ||r(i)||/||b|| 2.600507822503e-03
>>>>  18 KSP preconditioned resid norm 1.022454633110e+15 true resid norm
>>>> 2.215058790848e+14 ||r(i)||/||b|| 2.029313773928e-03
>>>>  19 KSP preconditioned resid norm 9.587995256078e+14 true resid norm
>>>> 2.226912518453e+14 ||r(i)||/||b|| 2.040173500451e-03
>>>>  20 KSP preconditioned resid norm 7.709554287637e+14 true resid norm
>>>> 1.253194818485e+14 ||r(i)||/||b|| 1.148107452983e-03
>>>>  21 KSP preconditioned resid norm 3.692994290799e+14 true resid norm
>>>> 6.513442758709e+13 ||r(i)||/||b|| 5.967254305192e-04
>>>>  22 KSP preconditioned resid norm 3.577186864519e+14 true resid norm
>>>> 5.884014914924e+13 ||r(i)||/||b|| 5.390607491859e-04
>>>>  23 KSP preconditioned resid norm 1.723423887037e+14 true resid norm
>>>> 4.313917181929e+13 ||r(i)||/||b|| 3.952171198816e-04
>>>>  24 KSP preconditioned resid norm 1.656260736170e+14 true resid norm
>>>> 3.420915571267e+13 ||r(i)||/||b|| 3.134052746997e-04
>>>>  25 KSP preconditioned resid norm 1.188400863617e+14 true resid norm
>>>> 1.877160245085e+13 ||r(i)||/||b|| 1.719749903236e-04
>>>>  26 KSP preconditioned resid norm 8.416275062676e+13 true resid norm
>>>> 1.813244070153e+13 ||r(i)||/||b|| 1.661193455568e-04
>>>>  27 KSP preconditioned resid norm 5.224466611453e+13 true resid norm
>>>> 8.293327735079e+12 ||r(i)||/||b|| 7.597886012791e-05
>>>>  28 KSP preconditioned resid norm 4.471999764526e+13 true resid norm
>>>> 9.742703301619e+12 ||r(i)||/||b|| 8.925723365429e-05
>>>>  29 KSP preconditioned resid norm 9.410327220658e+14 true resid norm
>>>> 1.612776349391e+14 ||r(i)||/||b|| 1.477536069746e-03
>>>>  30 KSP preconditioned resid norm 5.783713583723e+14 true resid norm
>>>> 1.102180319983e+14 ||r(i)||/||b|| 1.009756361291e-03
>>>>  31 KSP preconditioned resid norm 1.833775181615e+13 true resid norm
>>>> 4.198845362007e+12 ||r(i)||/||b|| 3.846748791915e-05
>>>>  32 KSP preconditioned resid norm 1.462922686654e+13 true resid norm
>>>> 3.704838629537e+12 ||r(i)||/||b|| 3.394167275452e-05
>>>>  33 KSP preconditioned resid norm 1.053043620710e+13 true resid norm
>>>> 1.904310347574e+12 ||r(i)||/||b|| 1.744623318411e-05
>>>>  34 KSP preconditioned resid norm 8.014167149326e+13 true resid norm
>>>> 1.458222541169e+13 ||r(i)||/||b|| 1.335942459168e-04
>>>>  35 KSP preconditioned resid norm 5.245679087504e+12 true resid norm
>>>> 1.495201096266e+12 ||r(i)||/||b|| 1.369820156459e-05
>>>>   0 KSP preconditioned resid norm 1.124208361458e+16 true resid norm
>>>> 6.487794900041e+15 ||r(i)||/||b|| 1.232063762752e-01
>>>>   1 KSP preconditioned resid norm 5.136632948471e+15 true resid norm
>>>> 1.030125368299e+15 ||r(i)||/||b|| 1.956258107611e-02
>>>>   2 KSP preconditioned resid norm 4.225773164973e+15 true resid norm
>>>> 7.107211019673e+14 ||r(i)||/||b|| 1.349693892375e-02
>>>>   3 KSP preconditioned resid norm 4.144329493920e+15 true resid norm
>>>> 7.618007419548e+14 ||r(i)||/||b|| 1.446696609651e-02
>>>>   4 KSP preconditioned resid norm 4.333716562490e+15 true resid norm
>>>> 8.456727780045e+14 ||r(i)||/||b|| 1.605973679776e-02
>>>>   5 KSP preconditioned resid norm 4.885745055980e+15 true resid norm
>>>> 7.972847407816e+14 ||r(i)||/||b|| 1.514082446881e-02
>>>>   6 KSP preconditioned resid norm 6.011621624545e+15 true resid norm
>>>> 9.523510473075e+14 ||r(i)||/||b|| 1.808560894548e-02
>>>>   7 KSP preconditioned resid norm 7.637951309150e+15 true resid norm
>>>> 1.487731882292e+15 ||r(i)||/||b|| 2.825275103643e-02
>>>>   8 KSP preconditioned resid norm 8.460249904060e+15 true resid norm
>>>> 1.336944180115e+15 ||r(i)||/||b|| 2.538921933447e-02
>>>>   9 KSP preconditioned resid norm 8.381050292195e+15 true resid norm
>>>> 1.752911449852e+15 ||r(i)||/||b|| 3.328863982216e-02
>>>>  10 KSP preconditioned resid norm 7.434169027728e+15 true resid norm
>>>> 1.180498665014e+15 ||r(i)||/||b|| 2.241824301708e-02
>>>>  11 KSP preconditioned resid norm 5.682629267055e+15 true resid norm
>>>> 9.983854763086e+14 ||r(i)||/||b|| 1.895982511114e-02
>>>>  12 KSP preconditioned resid norm 3.541898147790e+15 true resid norm
>>>> 5.480576756264e+14 ||r(i)||/||b|| 1.040788145188e-02
>>>>  13 KSP preconditioned resid norm 2.510644084392e+15 true resid norm
>>>> 4.650369826671e+14 ||r(i)||/||b|| 8.831278169411e-03
>>>>  14 KSP preconditioned resid norm 2.282038802861e+15 true resid norm
>>>> 3.635360161467e+14 ||r(i)||/||b|| 6.903725516148e-03
>>>>  15 KSP preconditioned resid norm 2.130130680848e+15 true resid norm
>>>> 3.489368266499e+14 ||r(i)||/||b|| 6.626479816775e-03
>>>>  16 KSP preconditioned resid norm 1.929984942209e+15 true resid norm
>>>> 3.145683546766e+14 ||r(i)||/||b|| 5.973805841227e-03
>>>>  17 KSP preconditioned resid norm 1.692158321133e+15 true resid norm
>>>> 2.756020615583e+14 ||r(i)||/||b|| 5.233817008974e-03
>>>>  18 KSP preconditioned resid norm 1.473781775606e+15 true resid norm
>>>> 2.951884895649e+14 ||r(i)||/||b|| 5.605772789952e-03
>>>>  19 KSP preconditioned resid norm 1.275239549902e+15 true resid norm
>>>> 1.993708462138e+14 ||r(i)||/||b|| 3.786149204063e-03
>>>>  20 KSP preconditioned resid norm 1.159341081209e+15 true resid norm
>>>> 2.011812256624e+14 ||r(i)||/||b|| 3.820529189093e-03
>>>>  21 KSP preconditioned resid norm 1.026465449352e+15 true resid norm
>>>> 1.599378003014e+14 ||r(i)||/||b|| 3.037296509548e-03
>>>>  22 KSP preconditioned resid norm 9.313333291328e+14 true resid norm
>>>> 1.626450968383e+14 ||r(i)||/||b|| 3.088709385718e-03
>>>>  23 KSP preconditioned resid norm 8.475207473455e+14 true resid norm
>>>> 1.311587742521e+14 ||r(i)||/||b|| 2.490768826892e-03
>>>>  24 KSP preconditioned resid norm 7.894756750239e+14 true resid norm
>>>> 1.443612018407e+14 ||r(i)||/||b|| 2.741489339222e-03
>>>>  25 KSP preconditioned resid norm 7.370222420808e+14 true resid norm
>>>> 1.135397001576e+14 ||r(i)||/||b|| 2.156174052249e-03
>>>>  26 KSP preconditioned resid norm 6.874978587995e+14 true resid norm
>>>> 1.225152011526e+14 ||r(i)||/||b|| 2.326623175549e-03
>>>>  27 KSP preconditioned resid norm 6.203646083349e+14 true resid norm
>>>> 9.547951255722e+13 ||r(i)||/||b|| 1.813202317882e-03
>>>>  28 KSP preconditioned resid norm 5.655995299941e+14 true resid norm
>>>> 9.635247011837e+13 ||r(i)||/||b|| 1.829780205963e-03
>>>>  29 KSP preconditioned resid norm 5.170668664072e+14 true resid norm
>>>> 7.945307015395e+13 ||r(i)||/||b|| 1.508852392597e-03
>>>>  30 KSP preconditioned resid norm 4.771681972381e+14 true resid norm
>>>> 7.711681382438e+13 ||r(i)||/||b|| 1.464485750178e-03
>>>>  31 KSP preconditioned resid norm 4.347723667483e+14 true resid norm
>>>> 6.696963877348e+13 ||r(i)||/||b|| 1.271785967477e-03
>>>>  32 KSP preconditioned resid norm 4.053435837983e+14 true resid norm
>>>> 6.425971653178e+13 ||r(i)||/||b|| 1.220323227897e-03
>>>>  33 KSP preconditioned resid norm 3.774514402447e+14 true resid norm
>>>> 5.808746381526e+13 ||r(i)||/||b|| 1.103109150945e-03
>>>>  34 KSP preconditioned resid norm 3.533225997981e+14 true resid norm
>>>> 5.617172311710e+13 ||r(i)||/||b|| 1.066728304612e-03
>>>>   0 KSP preconditioned resid norm 1.117659190837e+16 true resid norm
>>>> 6.478857863821e+15 ||r(i)||/||b|| 6.224768870229e-01
>>>>   1 KSP preconditioned resid norm 5.124485271748e+15 true resid norm
>>>> 1.017923791746e+15 ||r(i)||/||b|| 9.780026764454e-02
>>>>   2 KSP preconditioned resid norm 4.246328499709e+15 true resid norm
>>>> 7.102918780385e+14 ||r(i)||/||b|| 6.824355255393e-02
>>>>   3 KSP preconditioned resid norm 4.210000472667e+15 true resid norm
>>>> 7.697163273299e+14 ||r(i)||/||b|| 7.395294562682e-02
>>>>   4 KSP preconditioned resid norm 4.471596919519e+15 true resid norm
>>>> 8.475637573508e+14 ||r(i)||/||b|| 8.143238520100e-02
>>>>   5 KSP preconditioned resid norm 5.135403291038e+15 true resid norm
>>>> 8.255731593574e+14 ||r(i)||/||b|| 7.931956851781e-02
>>>>   6 KSP preconditioned resid norm 6.474268664840e+15 true resid norm
>>>> 1.007942498042e+15 ||r(i)||/||b|| 9.684128308834e-02
>>>>   7 KSP preconditioned resid norm 8.529281532903e+15 true resid norm
>>>> 1.642696055823e+15 ||r(i)||/||b|| 1.578272511369e-01
>>>>   8 KSP preconditioned resid norm 9.784577605090e+15 true resid norm
>>>> 1.538078623395e+15 ||r(i)||/||b|| 1.477757983909e-01
>>>>   9 KSP preconditioned resid norm 1.010006302597e+16 true resid norm
>>>> 2.046930405602e+15 ||r(i)||/||b|| 1.966653526923e-01
>>>>  10 KSP preconditioned resid norm 9.531884877717e+15 true resid norm
>>>> 1.482620346274e+15 ||r(i)||/||b|| 1.424474679309e-01
>>>>  11 KSP preconditioned resid norm 7.931210548314e+15 true resid norm
>>>> 1.282982557872e+15 ||r(i)||/||b|| 1.232666321002e-01
>>>>  12 KSP preconditioned resid norm 5.236526900965e+15 true resid norm
>>>> 7.915538690853e+14 ||r(i)||/||b|| 7.605105694487e-02
>>>>  13 KSP preconditioned resid norm 3.885416517845e+15 true resid norm
>>>> 6.196979959619e+14 ||r(i)||/||b|| 5.953945703529e-02
>>>>  14 KSP preconditioned resid norm 3.337626627490e+15 true resid norm
>>>> 7.828597862542e+14 ||r(i)||/||b|| 7.521574526958e-02
>>>>  15 KSP preconditioned resid norm 3.054301414200e+15 true resid norm
>>>> 4.972852337202e+14 ||r(i)||/||b|| 4.777826134714e-02
>>>>  16 KSP preconditioned resid norm 2.784835626497e+15 true resid norm
>>>> 4.900149140724e+14 ||r(i)||/||b|| 4.707974225054e-02
>>>>  17 KSP preconditioned resid norm 2.551999131175e+15 true resid norm
>>>> 4.223064940199e+14 ||r(i)||/||b|| 4.057444032459e-02
>>>>  18 KSP preconditioned resid norm 2.358735848485e+15 true resid norm
>>>> 3.867160573888e+14 ||r(i)||/||b|| 3.715497586533e-02
>>>>  19 KSP preconditioned resid norm 2.111367549832e+15 true resid norm
>>>> 3.463614183500e+14 ||r(i)||/||b|| 3.327777549857e-02
>>>>  20 KSP preconditioned resid norm 1.933287196882e+15 true resid norm
>>>> 3.127201079650e+14 ||r(i)||/||b|| 3.004557954614e-02
>>>>  21 KSP preconditioned resid norm 1.712007284199e+15 true resid norm
>>>> 2.787684847304e+14 ||r(i)||/||b|| 2.678356929917e-02
>>>>  22 KSP preconditioned resid norm 1.556420935486e+15 true resid norm
>>>> 2.516757515483e+14 ||r(i)||/||b|| 2.418054874112e-02
>>>>  23 KSP preconditioned resid norm 1.424455851932e+15 true resid norm
>>>> 2.267048417314e+14 ||r(i)||/||b|| 2.178138911521e-02
>>>>  24 KSP preconditioned resid norm 1.341093049266e+15 true resid norm
>>>> 2.200423231461e+14 ||r(i)||/||b|| 2.114126643990e-02
>>>>  25 KSP preconditioned resid norm 1.265242012282e+15 true resid norm
>>>> 1.979405460182e+14 ||r(i)||/||b|| 1.901776786755e-02
>>>>  26 KSP preconditioned resid norm 1.190343462827e+15 true resid norm
>>>> 1.929502180424e+14 ||r(i)||/||b|| 1.853830622649e-02
>>>>  27 KSP preconditioned resid norm 1.080874612432e+15 true resid norm
>>>> 1.688981747210e+14 ||r(i)||/||b|| 1.622742962325e-02
>>>>  28 KSP preconditioned resid norm 9.890419339482e+14 true resid norm
>>>> 1.571112460256e+14 ||r(i)||/||b|| 1.509496293914e-02
>>>>  29 KSP preconditioned resid norm 9.054720544549e+14 true resid norm
>>>> 1.411421952126e+14 ||r(i)||/||b|| 1.356068556375e-02
>>>>  30 KSP preconditioned resid norm 8.347895469778e+14 true resid norm
>>>> 1.302020126144e+14 ||r(i)||/||b|| 1.250957270554e-02
>>>>  31 KSP preconditioned resid norm 7.581633555103e+14 true resid norm
>>>> 1.198729260222e+14 ||r(i)||/||b|| 1.151717284080e-02
>>>>  32 KSP preconditioned resid norm 7.073149016328e+14 true resid norm
>>>> 1.097657041094e+14 ||r(i)||/||b|| 1.054608933119e-02
>>>>  33 KSP preconditioned resid norm 6.626892210136e+14 true resid norm
>>>> 1.045304064903e+14 ||r(i)||/||b|| 1.004309145207e-02
>>>>  34 KSP preconditioned resid norm 6.277118615935e+14 true resid norm
>>>> 9.735143814138e+13 ||r(i)||/||b|| 9.353349222222e-03
>>>>  35 KSP preconditioned resid norm 6.007031548284e+14 true resid norm
>>>> 9.325545854852e+13 ||r(i)||/||b|| 8.959814948147e-03
>>>>  36 KSP preconditioned resid norm 5.720600717487e+14 true resid norm
>>>> 8.974565981239e+13 ||r(i)||/||b|| 8.622599865294e-03
>>>>  37 KSP preconditioned resid norm 5.429834406497e+14 true resid norm
>>>> 8.373407335142e+13 ||r(i)||/||b|| 8.045017565303e-03
>>>>  38 KSP preconditioned resid norm 5.122271874419e+14 true resid norm
>>>> 8.063599233502e+13 ||r(i)||/||b|| 7.747359572588e-03
>>>>  39 KSP preconditioned resid norm 4.877390474820e+14 true resid norm
>>>> 7.540978455988e+13 ||r(i)||/||b|| 7.245235029160e-03
>>>>  40 KSP preconditioned resid norm 4.664511103016e+14 true resid norm
>>>> 7.249582547116e+13 ||r(i)||/||b|| 6.965267136580e-03
>>>>  41 KSP preconditioned resid norm 4.430412921029e+14 true resid norm
>>>> 6.907345898754e+13 ||r(i)||/||b|| 6.636452385624e-03
>>>>  42 KSP preconditioned resid norm 4.184290025581e+14 true resid norm
>>>> 6.506826627971e+13 ||r(i)||/||b|| 6.251640750440e-03
>>>>  43 KSP preconditioned resid norm 3.961557540211e+14 true resid norm
>>>> 6.169515842630e+13 ||r(i)||/||b|| 5.927558679138e-03
>>>>  44 KSP preconditioned resid norm 3.628856632080e+14 true resid norm
>>>> 5.666822624927e+13 ||r(i)||/||b|| 5.444580172956e-03
>>>>  45 KSP preconditioned resid norm 3.439726178254e+14 true resid norm
>>>> 5.290740915351e+13 ||r(i)||/||b|| 5.083247702381e-03
>>>>  46 KSP preconditioned resid norm 3.808130490503e+14 true resid norm
>>>> 7.046303156753e+13 ||r(i)||/||b|| 6.769959993302e-03
>>>>  47 KSP preconditioned resid norm 2.548925306353e+14 true resid norm
>>>> 3.911087819219e+13 ||r(i)||/||b|| 3.757702085387e-03
>>>>  48 KSP preconditioned resid norm 1.722230117103e+14 true resid norm
>>>> 2.660198748286e+13 ||r(i)||/||b|| 2.555870603278e-03
>>>>  49 KSP preconditioned resid norm 8.498499404656e+13 true resid norm
>>>> 1.314954336818e+13 ||r(i)||/||b|| 1.263384225066e-03
>>>>  50 KSP preconditioned resid norm 1.168755498979e+14 true resid norm
>>>> 2.563042385986e+13 ||r(i)||/||b|| 2.462524536378e-03
>>>>  51 KSP preconditioned resid norm 5.069372366763e+13 true resid norm
>>>> 7.752336990767e+12 ||r(i)||/||b|| 7.448304467540e-04
>>>>   0 KSP preconditioned resid norm 2.551555721110e+16 true resid norm
>>>> 1.503348678660e+16 ||r(i)||/||b|| 1.139781099215e-01
>>>>   1 KSP preconditioned resid norm 1.135435821514e+16 true resid norm
>>>> 2.150528625386e+15 ||r(i)||/||b|| 1.630448022690e-02
>>>>   2 KSP preconditioned resid norm 8.921910642422e+15 true resid norm
>>>> 1.462019059252e+15 ||r(i)||/||b|| 1.108446572695e-02
>>>>   3 KSP preconditioned resid norm 8.401630743802e+15 true resid norm
>>>> 1.508644008325e+15 ||r(i)||/||b|| 1.143795814332e-02
>>>>   4 KSP preconditioned resid norm 8.507938797573e+15 true resid norm
>>>> 1.437822857483e+15 ||r(i)||/||b|| 1.090101943907e-02
>>>>   5 KSP preconditioned resid norm 9.195685552195e+15 true resid norm
>>>> 1.421948919345e+15 ||r(i)||/||b|| 1.078066935052e-02
>>>>   6 KSP preconditioned resid norm 1.067998630800e+16 true resid norm
>>>> 1.627316531548e+15 ||r(i)||/||b|| 1.233768753335e-02
>>>>   7 KSP preconditioned resid norm 1.295276293823e+16 true resid norm
>>>> 2.221334900964e+15 ||r(i)||/||b|| 1.684130615262e-02
>>>>   8 KSP preconditioned resid norm 1.417997817727e+16 true resid norm
>>>> 2.186215590047e+15 ||r(i)||/||b|| 1.657504505585e-02
>>>>   9 KSP preconditioned resid norm 1.359372910192e+16 true resid norm
>>>> 2.107067442870e+15 ||r(i)||/||b|| 1.597497427073e-02
>>>>  10 KSP preconditioned resid norm 1.179811021994e+16 true resid norm
>>>> 3.232410469947e+15 ||r(i)||/||b|| 2.450689191967e-02
>>>>  11 KSP preconditioned resid norm 7.523875759744e+15 true resid norm
>>>> 1.204652282825e+15 ||r(i)||/||b|| 9.133209897209e-03
>>>>  12 KSP preconditioned resid norm 3.961884677960e+15 true resid norm
>>>> 7.586571607759e+14 ||r(i)||/||b|| 5.751846560354e-03
>>>>  13 KSP preconditioned resid norm 2.175818220311e+15 true resid norm
>>>> 3.487257134817e+14 ||r(i)||/||b|| 2.643904123366e-03
>>>>  14 KSP preconditioned resid norm 1.788448374434e+15 true resid norm
>>>> 3.516091940967e+14 ||r(i)||/||b|| 2.665765563440e-03
>>>>  15 KSP preconditioned resid norm 1.604495215225e+15 true resid norm
>>>> 2.568394922627e+14 ||r(i)||/||b|| 1.947258164179e-03
>>>>  16 KSP preconditioned resid norm 1.391089499920e+15 true resid norm
>>>> 2.519771358465e+14 ||r(i)||/||b|| 1.910393649516e-03
>>>>  17 KSP preconditioned resid norm 1.231055803595e+15 true resid norm
>>>> 2.082047844556e+14 ||r(i)||/||b|| 1.578528530720e-03
>>>>  18 KSP preconditioned resid norm 1.101068654831e+15 true resid norm
>>>> 1.838589386072e+14 ||r(i)||/||b|| 1.393947699032e-03
>>>>  19 KSP preconditioned resid norm 9.356667448723e+14 true resid norm
>>>> 1.565965285410e+14 ||r(i)||/||b|| 1.187254600129e-03
>>>>  20 KSP preconditioned resid norm 8.181513038456e+14 true resid norm
>>>> 1.328185221533e+14 ||r(i)||/||b|| 1.006978908651e-03
>>>>   0 KSP preconditioned resid norm 2.272810589988e+16 true resid norm
>>>> 1.323636987884e+16 ||r(i)||/||b|| 5.438005326146e-01
>>>>   1 KSP preconditioned resid norm 1.026969580669e+16 true resid norm
>>>> 1.999385093393e+15 ||r(i)||/||b|| 8.214236143606e-02
>>>>   2 KSP preconditioned resid norm 8.322628960001e+15 true resid norm
>>>> 1.379596337850e+15 ||r(i)||/||b|| 5.667907667911e-02
>>>>   3 KSP preconditioned resid norm 8.076035080201e+15 true resid norm
>>>> 1.472961452514e+15 ||r(i)||/||b|| 6.051487150403e-02
>>>>   4 KSP preconditioned resid norm 8.405382352119e+15 true resid norm
>>>> 1.516410203314e+15 ||r(i)||/||b|| 6.229991181666e-02
>>>>   5 KSP preconditioned resid norm 9.416373856303e+15 true resid norm
>>>> 1.470293081560e+15 ||r(i)||/||b|| 6.040524465323e-02
>>>>   6 KSP preconditioned resid norm 1.145894310132e+16 true resid norm
>>>> 1.749278072065e+15 ||r(i)||/||b|| 7.186701157399e-02
>>>>   7 KSP preconditioned resid norm 1.439168534642e+16 true resid norm
>>>> 2.685145033101e+15 ||r(i)||/||b|| 1.103159939254e-01
>>>>   8 KSP preconditioned resid norm 1.556059742979e+16 true resid norm
>>>> 2.450465189043e+15 ||r(i)||/||b|| 1.006744513151e-01
>>>>   9 KSP preconditioned resid norm 1.521075410830e+16 true resid norm
>>>> 2.889962061237e+15 ||r(i)||/||b|| 1.187306582184e-01
>>>>  10 KSP preconditioned resid norm 1.335253374250e+16 true resid norm
>>>> 2.051263914753e+15 ||r(i)||/||b|| 8.427374118333e-02
>>>>  11 KSP preconditioned resid norm 9.966633192923e+15 true resid norm
>>>> 1.537352185287e+15 ||r(i)||/||b|| 6.316028826844e-02
>>>>  12 KSP preconditioned resid norm 5.467457389741e+15 true resid norm
>>>> 8.244964108686e+14 ||r(i)||/||b|| 3.387345559797e-02
>>>>  13 KSP preconditioned resid norm 7.465607339270e+15 true resid norm
>>>> 1.255988023601e+15 ||r(i)||/||b|| 5.160077592599e-02
>>>>  14 KSP preconditioned resid norm 3.395725692367e+15 true resid norm
>>>> 8.163584192182e+14 ||r(i)||/||b|| 3.353911587836e-02
>>>>  15 KSP preconditioned resid norm 2.979451058224e+15 true resid norm
>>>> 4.736799198293e+14 ||r(i)||/||b|| 1.946057680844e-02
>>>>  16 KSP preconditioned resid norm 2.589762095203e+15 true resid norm
>>>> 5.000061827618e+14 ||r(i)||/||b|| 2.054216004731e-02
>>>>  17 KSP preconditioned resid norm 2.297387399767e+15 true resid norm
>>>> 3.733072000155e+14 ||r(i)||/||b|| 1.533688285047e-02
>>>>  18 KSP preconditioned resid norm 2.076822069911e+15 true resid norm
>>>> 3.563941616114e+14 ||r(i)||/||b|| 1.464203075912e-02
>>>>  19 KSP preconditioned resid norm 1.810897092306e+15 true resid norm
>>>> 2.945299484347e+14 ||r(i)||/||b|| 1.210041305100e-02
>>>>  20 KSP preconditioned resid norm 1.630399807803e+15 true resid norm
>>>> 2.670493324597e+14 ||r(i)||/||b|| 1.097140458866e-02
>>>>  21 KSP preconditioned resid norm 1.416015877821e+15 true resid norm
>>>> 2.289562555093e+14 ||r(i)||/||b|| 9.406395773998e-03
>>>>  22 KSP preconditioned resid norm 1.270953330458e+15 true resid norm
>>>> 2.078621859272e+14 ||r(i)||/||b|| 8.539770983461e-03
>>>>  23 KSP preconditioned resid norm 1.149572826465e+15 true resid norm
>>>> 1.837793084226e+14 ||r(i)||/||b|| 7.550354569913e-03
>>>>  24 KSP preconditioned resid norm 1.075403245776e+15 true resid norm
>>>> 1.776412893147e+14 ||r(i)||/||b|| 7.298181346390e-03
>>>>  25 KSP preconditioned resid norm 1.008390645992e+15 true resid norm
>>>> 1.577927704554e+14 ||r(i)||/||b|| 6.482728527673e-03
>>>>  26 KSP preconditioned resid norm 9.445856732256e+14 true resid norm
>>>> 1.515432067895e+14 ||r(i)||/||b|| 6.225972628492e-03
>>>>  27 KSP preconditioned resid norm 8.526344464253e+14 true resid norm
>>>> 1.348203382746e+14 ||r(i)||/||b|| 5.538933441126e-03
>>>>  28 KSP preconditioned resid norm 7.744588594030e+14 true resid norm
>>>> 1.215509014949e+14 ||r(i)||/||b|| 4.993774394172e-03
>>>>  29 KSP preconditioned resid norm 7.032530926217e+14 true resid norm
>>>> 1.102818922582e+14 ||r(i)||/||b|| 4.530800536453e-03
>>>>  30 KSP preconditioned resid norm 6.388922318141e+14 true resid norm
>>>> 9.838037383987e+13 ||r(i)||/||b|| 4.041840790388e-03
>>>>  31 KSP preconditioned resid norm 5.692116056101e+14 true resid norm
>>>> 9.317411265002e+13 ||r(i)||/||b|| 3.827947734067e-03
>>>>  32 KSP preconditioned resid norm 5.208032879647e+14 true resid norm
>>>> 8.007380640801e+13 ||r(i)||/||b|| 3.289737214338e-03
>>>>  33 KSP preconditioned resid norm 4.765676071483e+14 true resid norm
>>>> 7.802986158610e+13 ||r(i)||/||b|| 3.205764169389e-03
>>>>  34 KSP preconditioned resid norm 4.409793613234e+14 true resid norm
>>>> 6.791885197478e+13 ||r(i)||/||b|| 2.790365350662e-03
>>>>  35 KSP preconditioned resid norm 4.123618028942e+14 true resid norm
>>>> 6.437750648670e+13 ||r(i)||/||b|| 2.644873378149e-03
>>>>  36 KSP preconditioned resid norm 3.827034276493e+14 true resid norm
>>>> 5.974308940262e+13 ||r(i)||/||b|| 2.454473857604e-03
>>>>  37 KSP preconditioned resid norm 3.509107846575e+14 true resid norm
>>>> 5.419166518671e+13 ||r(i)||/||b|| 2.226400188387e-03
>>>>  38 KSP preconditioned resid norm 3.170601404687e+14 true resid norm
>>>> 4.972345072887e+13 ||r(i)||/||b|| 2.042828905305e-03
>>>>  39 KSP preconditioned resid norm 2.901553052614e+14 true resid norm
>>>> 4.518683026559e+13 ||r(i)||/||b|| 1.856447242750e-03
>>>>  40 KSP preconditioned resid norm 2.667015211684e+14 true resid norm
>>>> 4.122270495295e+13 ||r(i)||/||b|| 1.693585863377e-03
>>>>  41 KSP preconditioned resid norm 2.422095249996e+14 true resid norm
>>>> 3.839959453856e+13 ||r(i)||/||b|| 1.577601725654e-03
>>>>  42 KSP preconditioned resid norm 2.195894402502e+14 true resid norm
>>>> 3.399029120498e+13 ||r(i)||/||b|| 1.396450736130e-03
>>>>  43 KSP preconditioned resid norm 1.983452570770e+14 true resid norm
>>>> 3.143816040870e+13 ||r(i)||/||b|| 1.291599474113e-03
>>>>  44 KSP preconditioned resid norm 1.779873290535e+14 true resid norm
>>>> 2.755766172822e+13 ||r(i)||/||b|| 1.132173795580e-03
>>>>  45 KSP preconditioned resid norm 1.542400485092e+14 true resid norm
>>>> 2.400274515345e+13 ||r(i)||/||b|| 9.861242710910e-04
>>>>  46 KSP preconditioned resid norm 1.223281336233e+14 true resid norm
>>>> 1.907355666953e+13 ||r(i)||/||b|| 7.836144177513e-04
>>>>   0 KSP preconditioned resid norm 7.586062313136e+16 true resid norm
>>>> 4.608637352265e+16 ||r(i)||/||b|| 6.590757061047e-02
>>>>   1 KSP preconditioned resid norm 2.763422737801e+16 true resid norm
>>>> 5.227955984017e+15 ||r(i)||/||b|| 7.476437216213e-03
>>>>   2 KSP preconditioned resid norm 1.553456028419e+16 true resid norm
>>>> 2.906104653716e+15 ||r(i)||/||b|| 4.155985447023e-03
>>>>   3 KSP preconditioned resid norm 1.040767126705e+16 true resid norm
>>>> 2.091654777018e+15 ||r(i)||/||b|| 2.991250436342e-03
>>>>   4 KSP preconditioned resid norm 7.531366829970e+15 true resid norm
>>>> 1.318758653617e+15 ||r(i)||/||b|| 1.885940950392e-03
>>>>   5 KSP preconditioned resid norm 5.773017012836e+15 true resid norm
>>>> 9.450385953724e+14 ||r(i)||/||b|| 1.351488372664e-03
>>>>   6 KSP preconditioned resid norm 4.731507925306e+15 true resid norm
>>>> 7.935497854840e+14 ||r(i)||/||b|| 1.134846040642e-03
>>>>   7 KSP preconditioned resid norm 3.788639277852e+15 true resid norm
>>>> 7.524409398539e+14 ||r(i)||/||b|| 1.076056773034e-03
>>>>   8 KSP preconditioned resid norm 2.738698664678e+15 true resid norm
>>>> 4.915430614067e+14 ||r(i)||/||b|| 7.029498429037e-04
>>>>   9 KSP preconditioned resid norm 1.837368414949e+15 true resid norm
>>>> 3.357340764188e+14 ||r(i)||/||b|| 4.801292802316e-04
>>>>  10 KSP preconditioned resid norm 1.059331899595e+15 true resid norm
>>>> 1.989071439556e+14 ||r(i)||/||b|| 2.844547234496e-04
>>>>  11 KSP preconditioned resid norm 4.945892712172e+14 true resid norm
>>>> 8.452757650210e+13 ||r(i)||/||b|| 1.208818744245e-04
>>>>  12 KSP preconditioned resid norm 1.987888303244e+14 true resid norm
>>>> 3.594134462521e+13 ||r(i)||/||b|| 5.139928633259e-05
>>>>  13 KSP preconditioned resid norm 1.163784016975e+14 true resid norm
>>>> 2.571324386412e+13 ||r(i)||/||b|| 3.677220197779e-05
>>>>  14 KSP preconditioned resid norm 8.494315446492e+13 true resid norm
>>>> 1.429434206797e+13 ||r(i)||/||b|| 2.044216732982e-05
>>>>  15 KSP preconditioned resid norm 8.642186180523e+13 true resid norm
>>>> 1.607306715480e+13 ||r(i)||/||b|| 2.298590076546e-05
>>>>  16 KSP preconditioned resid norm 3.925619743667e+13 true resid norm
>>>> 1.371348923807e+13 ||r(i)||/||b|| 1.961149665703e-05
>>>>   0 KSP preconditioned resid norm 3.953744769406e+16 true resid norm
>>>> 2.171194598493e+16 ||r(i)||/||b|| 1.950905346919e-01
>>>>   1 KSP preconditioned resid norm 1.491502757726e+16 true resid norm
>>>> 3.091776185716e+15 ||r(i)||/||b|| 2.778084790914e-02
>>>>   2 KSP preconditioned resid norm 1.008617531922e+16 true resid norm
>>>> 1.691017660922e+15 ||r(i)||/||b|| 1.519447127732e-02
>>>>   3 KSP preconditioned resid norm 8.326895039450e+15 true resid norm
>>>> 1.670298498749e+15 ||r(i)||/||b|| 1.500830130298e-02
>>>>   4 KSP preconditioned resid norm 7.300566603499e+15 true resid norm
>>>> 1.589496633697e+15 ||r(i)||/||b|| 1.428226416804e-02
>>>>   5 KSP preconditioned resid norm 6.872352176548e+15 true resid norm
>>>> 1.096739362492e+15 ||r(i)||/||b|| 9.854642637499e-03
>>>>   6 KSP preconditioned resid norm 6.961475959227e+15 true resid norm
>>>> 1.092150928708e+15 ||r(i)||/||b|| 9.813413721358e-03
>>>>   7 KSP preconditioned resid norm 7.025042419735e+15 true resid norm
>>>> 1.296288429690e+15 ||r(i)||/||b|| 1.164767096595e-02
>>>>   8 KSP preconditioned resid norm 6.408702665765e+15 true resid norm
>>>> 1.056644614043e+15 ||r(i)||/||b|| 9.494375256645e-03
>>>>   9 KSP preconditioned resid norm 5.399106179995e+15 true resid norm
>>>> 1.078818901202e+15 ||r(i)||/||b|| 9.693620112044e-03
>>>>  10 KSP preconditioned resid norm 4.030707639439e+15 true resid norm
>>>> 7.107969460630e+14 ||r(i)||/||b|| 6.386795378039e-03
>>>>  11 KSP preconditioned resid norm 2.682586389004e+15 true resid norm
>>>> 4.368532286577e+14 ||r(i)||/||b|| 3.925301307393e-03
>>>>  12 KSP preconditioned resid norm 1.621400972048e+15 true resid norm
>>>> 2.499302020485e+14 ||r(i)||/||b|| 2.245723012904e-03
>>>>  13 KSP preconditioned resid norm 1.118646687359e+15 true resid norm
>>>> 1.825993809337e+14 ||r(i)||/||b|| 1.640728605602e-03
>>>>  14 KSP preconditioned resid norm 8.665732278929e+14 true resid norm
>>>> 1.337846645968e+14 ||r(i)||/||b|| 1.202108819167e-03
>>>>  15 KSP preconditioned resid norm 1.790412083411e+15 true resid norm
>>>> 2.690613625509e+14 ||r(i)||/||b|| 2.417624155910e-03
>>>>  16 KSP preconditioned resid norm 4.902192144952e+14 true resid norm
>>>> 8.615757491331e+13 ||r(i)||/||b|| 7.741603340972e-04
>>>>  17 KSP preconditioned resid norm 3.873085562421e+14 true resid norm
>>>> 6.966874756362e+13 ||r(i)||/||b|| 6.260016132563e-04
>>>>  18 KSP preconditioned resid norm 3.069894649217e+14 true resid norm
>>>> 4.954148501038e+13 ||r(i)||/||b|| 4.451500941838e-04
>>>>  19 KSP preconditioned resid norm 2.366855243734e+14 true resid norm
>>>> 4.444373941350e+13 ||r(i)||/||b|| 3.993448073197e-04
>>>>  20 KSP preconditioned resid norm 1.853280795186e+14 true resid norm
>>>> 2.839442050460e+13 ||r(i)||/||b|| 2.551352459311e-04
>>>>  21 KSP preconditioned resid norm 1.419103820891e+14 true resid norm
>>>> 2.714177608773e+13 ||r(i)||/||b|| 2.438797339086e-04
>>>>  22 KSP preconditioned resid norm 1.116662401807e+14 true resid norm
>>>> 1.710034207306e+13 ||r(i)||/||b|| 1.536534256654e-04
>>>>  23 KSP preconditioned resid norm 8.768706858701e+13 true resid norm
>>>> 1.892684059360e+13 ||r(i)||/||b|| 1.700652467538e-04
>>>>  24 KSP preconditioned resid norm 7.191985915577e+13 true resid norm
>>>> 1.104970014738e+13 ||r(i)||/||b|| 9.928598345972e-05
>>>>  25 KSP preconditioned resid norm 5.804472664630e+13 true resid norm
>>>> 1.353159760302e+13 ||r(i)||/||b|| 1.215868265996e-04
>>>>  26 KSP preconditioned resid norm 4.574262022619e+13 true resid norm
>>>> 6.915191476157e+12 ||r(i)||/||b|| 6.213576634340e-05
>>>>  27 KSP preconditioned resid norm 3.470073834736e+13 true resid norm
>>>> 8.786634213858e+12 ||r(i)||/||b|| 7.895142923224e-05
>>>>  28 KSP preconditioned resid norm 2.674822501624e+13 true resid norm
>>>> 4.041336605553e+12 ||r(i)||/||b|| 3.631302877201e-05
>>>>  29 KSP preconditioned resid norm 2.088626286399e+13 true resid norm
>>>> 5.261273540428e+12 ||r(i)||/||b|| 4.727465096287e-05
>>>>  30 KSP preconditioned resid norm 1.567496199145e+13 true resid norm
>>>> 2.371012817670e+12 ||r(i)||/||b|| 2.130450023603e-05
>>>>  31 KSP preconditioned resid norm 1.119841843422e+13 true resid norm
>>>> 3.387071792996e+12 ||r(i)||/||b|| 3.043419726606e-05
>>>>  32 KSP preconditioned resid norm 7.994377199528e+12 true resid norm
>>>> 1.204577998308e+12 ||r(i)||/||b|| 1.082361599145e-05
>>>>  33 KSP preconditioned resid norm 6.174157756589e+12 true resid norm
>>>> 1.362745552188e+12 ||r(i)||/||b|| 1.224481484110e-05
>>>>     0 SNES Function norm 0.000000000000e+00
>>>> 1 TS dt 3e-12 time 2e-12
>>>>   0 KSP preconditioned resid norm 2.220368634013e+19 true resid norm
>>>> 1.204306153911e+19 ||r(i)||/||b|| 2.302397943981e+02
>>>>   1 KSP preconditioned resid norm 5.390402695434e+18 true resid norm
>>>> 1.775960718595e+18 ||r(i)||/||b|| 3.395289722473e+01
>>>>   2 KSP preconditioned resid norm 2.218493119258e+18 true resid norm
>>>> 5.320083037595e+17 ||r(i)||/||b|| 1.017095877804e+01
>>>>   3 KSP preconditioned resid norm 1.401798813920e+18 true resid norm
>>>> 2.963744523802e+17 ||r(i)||/||b|| 5.666100165582e+00
>>>>   4 KSP preconditioned resid norm 1.004143331118e+18 true resid norm
>>>> 1.656359344976e+17 ||r(i)||/||b|| 3.166635276239e+00
>>>>   5 KSP preconditioned resid norm 8.673495646713e+17 true resid norm
>>>> 1.510463721187e+17 ||r(i)||/||b|| 2.887711363779e+00
>>>>   6 KSP preconditioned resid norm 7.389956702949e+17 true resid norm
>>>> 1.526304376340e+17 ||r(i)||/||b|| 2.917995599842e+00
>>>>   7 KSP preconditioned resid norm 5.566613599927e+17 true resid norm
>>>> 1.017416269196e+17 ||r(i)||/||b|| 1.945101018344e+00
>>>>   8 KSP preconditioned resid norm 3.566897773081e+17 true resid norm
>>>> 6.307244640523e+16 ||r(i)||/||b|| 1.205821878877e+00
>>>>   9 KSP preconditioned resid norm 1.893453815442e+17 true resid norm
>>>> 3.268203516935e+16 ||r(i)||/||b|| 6.248166243663e-01
>>>>  10 KSP preconditioned resid norm 6.894933140555e+16 true resid norm
>>>> 1.152954614680e+16 ||r(i)||/||b|| 2.204223839364e-01
>>>>  11 KSP preconditioned resid norm 5.103537427509e+16 true resid norm
>>>> 9.272910080166e+15 ||r(i)||/||b|| 1.772799136993e-01
>>>>  12 KSP preconditioned resid norm 4.991235858989e+16 true resid norm
>>>> 8.396555957121e+15 ||r(i)||/||b|| 1.605257359967e-01
>>>>  13 KSP preconditioned resid norm 4.918689912532e+16 true resid norm
>>>> 8.423517310572e+15 ||r(i)||/||b|| 1.610411843696e-01
>>>>  14 KSP preconditioned resid norm 5.686949456502e+16 true resid norm
>>>> 9.761258523981e+15 ||r(i)||/||b|| 1.866161813032e-01
>>>>  15 KSP preconditioned resid norm 1.616570395103e+17 true resid norm
>>>> 4.351134639515e+16 ||r(i)||/||b|| 8.318518854587e-01
>>>>  16 KSP preconditioned resid norm 4.128330778786e+16 true resid norm
>>>> 7.104207079385e+15 ||r(i)||/||b|| 1.358185517866e-01
>>>>  17 KSP preconditioned resid norm 2.161181135112e+16 true resid norm
>>>> 5.859480309696e+15 ||r(i)||/||b|| 1.120218091889e-01
>>>>  18 KSP preconditioned resid norm 1.410375919962e+16 true resid norm
>>>> 2.425065017616e+15 ||r(i)||/||b|| 4.636250252850e-02
>>>>  19 KSP preconditioned resid norm 1.082544604615e+16 true resid norm
>>>> 2.485306543509e+15 ||r(i)||/||b|| 4.751420274116e-02
>>>>  20 KSP preconditioned resid norm 8.996941383859e+15 true resid norm
>>>> 1.577914541048e+15 ||r(i)||/||b|| 3.016664145813e-02
>>>>  21 KSP preconditioned resid norm 7.748060569447e+15 true resid norm
>>>> 1.336297549587e+15 ||r(i)||/||b|| 2.554739690340e-02
>>>>  22 KSP preconditioned resid norm 6.873596381580e+15 true resid norm
>>>> 1.173018262854e+15 ||r(i)||/||b|| 2.242581612555e-02
>>>>  23 KSP preconditioned resid norm 6.175955090548e+15 true resid norm
>>>> 1.012331331012e+15 ||r(i)||/||b|| 1.935379610558e-02
>>>>  24 KSP preconditioned resid norm 5.614288705672e+15 true resid norm
>>>> 9.369191861544e+14 ||r(i)||/||b|| 1.791206331440e-02
>>>>  25 KSP preconditioned resid norm 5.220540757763e+15 true resid norm
>>>> 8.444260437985e+14 ||r(i)||/||b|| 1.614377524163e-02
>>>>  26 KSP preconditioned resid norm 5.059721722058e+15 true resid norm
>>>> 8.452379209101e+14 ||r(i)||/||b|| 1.615929674492e-02
>>>>  27 KSP preconditioned resid norm 4.893746226621e+15 true resid norm
>>>> 9.389168158486e+14 ||r(i)||/||b|| 1.795025408912e-02
>>>>  28 KSP preconditioned resid norm 4.794914716345e+15 true resid norm
>>>> 7.493396637157e+14 ||r(i)||/||b|| 1.432590953288e-02
>>>>  29 KSP preconditioned resid norm 4.860853428688e+15 true resid norm
>>>> 7.693465766642e+14 ||r(i)||/||b|| 1.470840259819e-02
>>>>  30 KSP preconditioned resid norm 5.112203028306e+15 true resid norm
>>>> 8.019578406020e+14 ||r(i)||/||b|| 1.533186621496e-02
>>>>  31 KSP preconditioned resid norm 5.649006086453e+15 true resid norm
>>>> 8.938106702489e+14 ||r(i)||/||b|| 1.708791276044e-02
>>>>  32 KSP preconditioned resid norm 8.383819984522e+15 true resid norm
>>>> 1.347106201218e+15 ||r(i)||/||b|| 2.575403719341e-02
>>>>  33 KSP preconditioned resid norm 1.617520068743e+16 true resid norm
>>>> 2.603058585140e+15 ||r(i)||/||b|| 4.976539159104e-02
>>>>  34 KSP preconditioned resid norm 3.383001122808e+16 true resid norm
>>>> 5.541435636245e+15 ||r(i)||/||b|| 1.059414167582e-01
>>>>  35 KSP preconditioned resid norm 6.256166371964e+15 true resid norm
>>>> 1.029049029941e+15 ||r(i)||/||b|| 1.967340582872e-02
>>>>  36 KSP preconditioned resid norm 3.290396673886e+15 true resid norm
>>>> 5.409340387326e+14 ||r(i)||/||b|| 1.034160138236e-02
>>>>  37 KSP preconditioned resid norm 2.075346751579e+15 true resid norm
>>>> 3.809761571158e+14 ||r(i)||/||b|| 7.283519377531e-03
>>>>  38 KSP preconditioned resid norm 1.750045982315e+15 true resid norm
>>>> 2.837816436037e+14 ||r(i)||/||b|| 5.425350278670e-03
>>>>  39 KSP preconditioned resid norm 1.596755323762e+15 true resid norm
>>>> 2.766061504317e+14 ||r(i)||/||b|| 5.288168876146e-03
>>>>  40 KSP preconditioned resid norm 1.469812007135e+15 true resid norm
>>>> 2.359521384401e+14 ||r(i)||/||b|| 4.510943638858e-03
>>>>  41 KSP preconditioned resid norm 1.314668041488e+15 true resid norm
>>>> 2.158813968118e+14 ||r(i)||/||b|| 4.127230293966e-03
>>>>  42 KSP preconditioned resid norm 1.190446489712e+15 true resid norm
>>>> 1.941922420158e+14 ||r(i)||/||b|| 3.712576053042e-03
>>>>  43 KSP preconditioned resid norm 1.100371263474e+15 true resid norm
>>>> 1.837040226442e+14 ||r(i)||/||b|| 3.512061801423e-03
>>>>  44 KSP preconditioned resid norm 1.032027622009e+15 true resid norm
>>>> 1.624908335172e+14 ||r(i)||/||b|| 3.106507093655e-03
>>>>  45 KSP preconditioned resid norm 8.066010465859e+14 true resid norm
>>>> 2.499636130742e+14 ||r(i)||/||b|| 4.778815643705e-03
>>>>  46 KSP preconditioned resid norm 6.546087590187e+14 true resid norm
>>>> 1.014535455422e+14 ||r(i)||/||b|| 1.939593465560e-03
>>>>  47 KSP preconditioned resid norm 6.561404017041e+14 true resid norm
>>>> 1.083911025925e+14 ||r(i)||/||b|| 2.072225994564e-03
>>>>  48 KSP preconditioned resid norm 6.834623592895e+14 true resid norm
>>>> 1.073483632090e+14 ||r(i)||/||b|| 2.052290855937e-03
>>>>  49 KSP preconditioned resid norm 8.808387787841e+14 true resid norm
>>>> 1.369903526339e+14 ||r(i)||/||b|| 2.618987748466e-03
>>>>  50 KSP preconditioned resid norm 3.995486126369e+14 true resid norm
>>>> 1.237415046233e+14 ||r(i)||/||b|| 2.365695673849e-03
>>>>  51 KSP preconditioned resid norm 3.217227010099e+14 true resid norm
>>>> 4.935649374236e+13 ||r(i)||/||b|| 9.435996764234e-04
>>>>   0 KSP preconditioned resid norm 6.543260687832e+18 true resid norm
>>>> 3.546137973950e+18 ||r(i)||/||b|| 4.156987252753e+02
>>>>   1 KSP preconditioned resid norm 1.591265056482e+18 true resid norm
>>>> 5.223494588784e+17 ||r(i)||/||b|| 6.123281321796e+01
>>>>   2 KSP preconditioned resid norm 6.570987793466e+17 true resid norm
>>>> 1.552598280892e+17 ||r(i)||/||b|| 1.820045161730e+01
>>>>   3 KSP preconditioned resid norm 4.166120135488e+17 true resid norm
>>>> 8.739095834512e+16 ||r(i)||/||b|| 1.024447166228e+01
>>>>   4 KSP preconditioned resid norm 2.995238174583e+17 true resid norm
>>>> 4.935051588719e+16 ||r(i)||/||b|| 5.785151817748e+00
>>>>   5 KSP preconditioned resid norm 2.594691834001e+17 true resid norm
>>>> 4.470128066210e+16 ||r(i)||/||b|| 5.240141676921e+00
>>>>   6 KSP preconditioned resid norm 2.219773011977e+17 true resid norm
>>>> 4.652509796902e+16 ||r(i)||/||b|| 5.453940050023e+00
>>>>   7 KSP preconditioned resid norm 1.675026903695e+17 true resid norm
>>>> 2.988993956885e+16 ||r(i)||/||b|| 3.503870934691e+00
>>>>   8 KSP preconditioned resid norm 1.081971008730e+17 true resid norm
>>>> 1.908275119338e+16 ||r(i)||/||b|| 2.236990044975e+00
>>>>   9 KSP preconditioned resid norm 5.710427760412e+16 true resid norm
>>>> 9.635681698385e+15 ||r(i)||/||b|| 1.129550127097e+00
>>>>  10 KSP preconditioned resid norm 1.779335357179e+16 true resid norm
>>>> 2.952424081259e+15 ||r(i)||/||b|| 3.461001619416e-01
>>>>  11 KSP preconditioned resid norm 1.125492898955e+16 true resid norm
>>>> 2.030196257790e+15 ||r(i)||/||b|| 2.379913028263e-01
>>>>  12 KSP preconditioned resid norm 1.086499382749e+16 true resid norm
>>>> 1.877721745252e+15 ||r(i)||/||b|| 2.201173619461e-01
>>>>  13 KSP preconditioned resid norm 1.075258231290e+16 true resid norm
>>>> 1.822442508498e+15 ||r(i)||/||b|| 2.136372113085e-01
>>>>  14 KSP preconditioned resid norm 1.173739259962e+16 true resid norm
>>>> 2.130298543993e+15 ||r(i)||/||b|| 2.497258695795e-01
>>>>  15 KSP preconditioned resid norm 4.943363278431e+16 true resid norm
>>>> 1.361259414632e+16 ||r(i)||/||b|| 1.595746718229e+00
>>>>  16 KSP preconditioned resid norm 1.782643390767e+17 true resid norm
>>>> 3.375538781586e+16 ||r(i)||/||b|| 3.957001049961e+00
>>>>  17 KSP preconditioned resid norm 3.253381322946e+16 true resid norm
>>>> 8.720742251900e+15 ||r(i)||/||b|| 1.022295653525e+00
>>>>  18 KSP preconditioned resid norm 2.077141437527e+16 true resid norm
>>>> 3.948414579285e+15 ||r(i)||/||b|| 4.628559067708e-01
>>>>  19 KSP preconditioned resid norm 1.484650052668e+16 true resid norm
>>>> 3.391990202104e+15 ||r(i)||/||b|| 3.976286352982e-01
>>>>  20 KSP preconditioned resid norm 1.135224344133e+16 true resid norm
>>>> 2.492450462789e+15 ||r(i)||/||b|| 2.921794041305e-01
>>>>  21 KSP preconditioned resid norm 8.560056764067e+15 true resid norm
>>>> 1.658566536392e+15 ||r(i)||/||b|| 1.944267256456e-01
>>>>  22 KSP preconditioned resid norm 6.591497757947e+15 true resid norm
>>>> 1.287448297256e+15 ||r(i)||/||b|| 1.509221073626e-01
>>>>  23 KSP preconditioned resid norm 4.783676751639e+15 true resid norm
>>>> 9.069671731055e+14 ||r(i)||/||b|| 1.063199177517e-01
>>>>  24 KSP preconditioned resid norm 3.029245298062e+15 true resid norm
>>>> 6.184462851213e+14 ||r(i)||/||b|| 7.249783687627e-02
>>>>  25 KSP preconditioned resid norm 1.567581368038e+15 true resid norm
>>>> 2.751547089998e+14 ||r(i)||/||b|| 3.225522036225e-02
>>>>  26 KSP preconditioned resid norm 1.174427256669e+15 true resid norm
>>>> 2.270458347820e+14 ||r(i)||/||b|| 2.661562093503e-02
>>>>  27 KSP preconditioned resid norm 1.068689317098e+15 true resid norm
>>>> 2.026010487900e+14 ||r(i)||/||b|| 2.375006227624e-02
>>>>  28 KSP preconditioned resid norm 1.006302654001e+15 true resid norm
>>>> 1.659657859887e+14 ||r(i)||/||b|| 1.945546568735e-02
>>>>  29 KSP preconditioned resid norm 9.398219810967e+14 true resid norm
>>>> 1.788496139471e+14 ||r(i)||/||b|| 2.096578223407e-02
>>>>  30 KSP preconditioned resid norm 8.922669862958e+14 true resid norm
>>>> 1.448103190511e+14 ||r(i)||/||b|| 1.697549996037e-02
>>>>  31 KSP preconditioned resid norm 8.611553511040e+14 true resid norm
>>>> 1.569494235094e+14 ||r(i)||/||b|| 1.839851572749e-02
>>>>  32 KSP preconditioned resid norm 8.275858647114e+14 true resid norm
>>>> 1.327021986732e+14 ||r(i)||/||b|| 1.555611632568e-02
>>>>  33 KSP preconditioned resid norm 7.965262562283e+14 true resid norm
>>>> 1.578752878362e+14 ||r(i)||/||b|| 1.850705087847e-02
>>>>  34 KSP preconditioned resid norm 7.584298711071e+14 true resid norm
>>>> 1.400338111929e+14 ||r(i)||/||b|| 1.641557018817e-02
>>>>  35 KSP preconditioned resid norm 7.453216416858e+14 true resid norm
>>>> 1.168697043482e+14 ||r(i)||/||b|| 1.370014011799e-02
>>>>  36 KSP preconditioned resid norm 7.552391370873e+14 true resid norm
>>>> 1.200616262811e+14 ||r(i)||/||b|| 1.407431559803e-02
>>>>  37 KSP preconditioned resid norm 7.900785942536e+14 true resid norm
>>>> 1.248526226554e+14 ||r(i)||/||b|| 1.463594379756e-02
>>>>  38 KSP preconditioned resid norm 8.292853068973e+14 true resid norm
>>>> 1.319608976445e+14 ||r(i)||/||b|| 1.546921674790e-02
>>>>  39 KSP preconditioned resid norm 8.694401463969e+14 true resid norm
>>>> 1.375708051207e+14 ||r(i)||/||b|| 1.612684242516e-02
>>>>  40 KSP preconditioned resid norm 9.345453545993e+14 true resid norm
>>>> 1.486706547594e+14 ||r(i)||/||b|| 1.742803075440e-02
>>>>  41 KSP preconditioned resid norm 1.186246552213e+15 true resid norm
>>>> 1.878863391090e+14 ||r(i)||/||b|| 2.202511922492e-02
>>>>  42 KSP preconditioned resid norm 2.140906233315e+15 true resid norm
>>>> 3.526342198473e+14 ||r(i)||/||b|| 4.133781504155e-02
>>>>  43 KSP preconditioned resid norm 1.599648547908e+16 true resid norm
>>>> 2.542842342413e+15 ||r(i)||/||b|| 2.980866306056e-01
>>>>  44 KSP preconditioned resid norm 1.201331553169e+15 true resid norm
>>>> 1.958292468332e+14 ||r(i)||/||b|| 2.295623263342e-02
>>>>  45 KSP preconditioned resid norm 6.227596295745e+14 true resid norm
>>>> 9.990152835185e+13 ||r(i)||/||b|| 1.171103276127e-02
>>>>  46 KSP preconditioned resid norm 4.228157632423e+14 true resid norm
>>>> 6.914757907633e+13 ||r(i)||/||b|| 8.105877630555e-03
>>>>  47 KSP preconditioned resid norm 2.986102023248e+14 true resid norm
>>>> 4.782856914894e+13 ||r(i)||/||b|| 5.606740452011e-03
>>>>  48 KSP preconditioned resid norm 1.831310965020e+14 true resid norm
>>>> 3.038059690813e+13 ||r(i)||/||b|| 3.561388615047e-03
>>>>  49 KSP preconditioned resid norm 1.519167951348e+14 true resid norm
>>>> 2.657532215634e+13 ||r(i)||/||b|| 3.115312383591e-03
>>>>  50 KSP preconditioned resid norm 1.784468495322e+14 true resid norm
>>>> 2.872094801120e+13 ||r(i)||/||b|| 3.366835008863e-03
>>>>  51 KSP preconditioned resid norm 1.082269784640e+14 true resid norm
>>>> 1.734196241756e+13 ||r(i)||/||b|| 2.032924754679e-03
>>>>  52 KSP preconditioned resid norm 7.941561433572e+13 true resid norm
>>>> 2.262252591710e+13 ||r(i)||/||b|| 2.651942833395e-03
>>>>  53 KSP preconditioned resid norm 1.279466501710e+14 true resid norm
>>>> 2.100188573520e+13 ||r(i)||/||b|| 2.461962053545e-03
>>>>  54 KSP preconditioned resid norm 1.148448766150e+14 true resid norm
>>>> 1.892568589516e+13 ||r(i)||/||b|| 2.218577945746e-03
>>>>  55 KSP preconditioned resid norm 4.111681106774e+13 true resid norm
>>>> 1.052257112253e+13 ||r(i)||/||b|| 1.233516415432e-03
>>>>   0 KSP preconditioned resid norm 1.892564880723e+19 true resid norm
>>>> 1.028289393047e+19 ||r(i)||/||b|| 7.840877673877e+01
>>>>   1 KSP preconditioned resid norm 4.581010831586e+18 true resid norm
>>>> 1.519789346059e+18 ||r(i)||/||b|| 1.158864657468e+01
>>>>   2 KSP preconditioned resid norm 1.874273717290e+18 true resid norm
>>>> 4.647134076709e+17 ||r(i)||/||b|| 3.543517036739e+00
>>>>   3 KSP preconditioned resid norm 1.173044525535e+18 true resid norm
>>>> 2.550993039028e+17 ||r(i)||/||b|| 1.945174627025e+00
>>>>   4 KSP preconditioned resid norm 8.299292116891e+17 true resid norm
>>>> 1.381054316961e+17 ||r(i)||/||b|| 1.053076889978e+00
>>>>   5 KSP preconditioned resid norm 7.051404070011e+17 true resid norm
>>>> 1.287518923939e+17 ||r(i)||/||b|| 9.817545968746e-01
>>>>   6 KSP preconditioned resid norm 5.863125538322e+17 true resid norm
>>>> 1.166548434193e+17 ||r(i)||/||b|| 8.895125861467e-01
>>>>   7 KSP preconditioned resid norm 4.330808264262e+17 true resid norm
>>>> 8.612437830885e+16 ||r(i)||/||b|| 6.567127110566e-01
>>>>   8 KSP preconditioned resid norm 2.702964509584e+17 true resid norm
>>>> 4.804107972053e+16 ||r(i)||/||b|| 3.663212243137e-01
>>>>   9 KSP preconditioned resid norm 1.547354820777e+17 true resid norm
>>>> 2.879372380790e+16 ||r(i)||/||b|| 2.195569337580e-01
>>>>  10 KSP preconditioned resid norm 9.913511217220e+16 true resid norm
>>>> 1.649311378149e+16 ||r(i)||/||b|| 1.257627361485e-01
>>>>  11 KSP preconditioned resid norm 9.246165206306e+16 true resid norm
>>>> 1.559859930326e+16 ||r(i)||/||b|| 1.189419144530e-01
>>>>  12 KSP preconditioned resid norm 9.248856361042e+16 true resid norm
>>>> 1.507587985844e+16 ||r(i)||/||b|| 1.149560917339e-01
>>>>  13 KSP preconditioned resid norm 7.088634726331e+16 true resid norm
>>>> 1.150049603396e+16 ||r(i)||/||b|| 8.769319532120e-02
>>>>  14 KSP preconditioned resid norm 2.014973749241e+17 true resid norm
>>>> 3.263663179758e+16 ||r(i)||/||b|| 2.488597464319e-01
>>>>  15 KSP preconditioned resid norm 1.687600147354e+16 true resid norm
>>>> 4.438944439784e+15 ||r(i)||/||b|| 3.384768975431e-02
>>>>  16 KSP preconditioned resid norm 1.189486995696e+16 true resid norm
>>>> 1.895011071195e+15 ||r(i)||/||b|| 1.444977464550e-02
>>>>  17 KSP preconditioned resid norm 1.038277428537e+16 true resid norm
>>>> 2.030560404119e+15 ||r(i)||/||b|| 1.548336085714e-02
>>>>  18 KSP preconditioned resid norm 9.585935517274e+15 true resid norm
>>>> 1.570427582757e+15 ||r(i)||/||b|| 1.197477155297e-02
>>>>  19 KSP preconditioned resid norm 8.986106113745e+15 true resid norm
>>>> 1.453955802798e+15 ||r(i)||/||b|| 1.108665485617e-02
>>>>  20 KSP preconditioned resid norm 8.480772996688e+15 true resid norm
>>>> 1.519414795393e+15 ||r(i)||/||b|| 1.158579056355e-02
>>>>  21 KSP preconditioned resid norm 8.009707085363e+15 true resid norm
>>>> 1.276353172356e+15 ||r(i)||/||b|| 9.732405255546e-03
>>>>  22 KSP preconditioned resid norm 7.603487959173e+15 true resid norm
>>>> 1.348218761629e+15 ||r(i)||/||b|| 1.028039232831e-02
>>>>  23 KSP preconditioned resid norm 7.264676993739e+15 true resid norm
>>>> 1.145141030012e+15 ||r(i)||/||b|| 8.731890843545e-03
>>>>  24 KSP preconditioned resid norm 6.442617339194e+15 true resid norm
>>>> 1.846348609557e+15 ||r(i)||/||b|| 1.407871528071e-02
>>>>  25 KSP preconditioned resid norm 5.874716908283e+15 true resid norm
>>>> 9.094105988409e+14 ||r(i)||/||b|| 6.934407093038e-03
>>>>  26 KSP preconditioned resid norm 5.974445043424e+15 true resid norm
>>>> 9.497988242860e+14 ||r(i)||/||b|| 7.242374030480e-03
>>>>  27 KSP preconditioned resid norm 6.328543343408e+15 true resid norm
>>>> 9.841709349231e+14 ||r(i)||/||b|| 7.504467091753e-03
>>>>  28 KSP preconditioned resid norm 1.045930080864e+16 true resid norm
>>>> 1.637386301334e+15 ||r(i)||/||b|| 1.248534292045e-02
>>>>  29 KSP preconditioned resid norm 1.763968686067e+16 true resid norm
>>>> 3.035143897342e+15 ||r(i)||/||b|| 2.314347710148e-02
>>>>  30 KSP preconditioned resid norm 3.994992144337e+15 true resid norm
>>>> 6.366779249631e+14 ||r(i)||/||b|| 4.854775086713e-03
>>>>  31 KSP preconditioned resid norm 2.497471912676e+15 true resid norm
>>>> 4.171284268487e+14 ||r(i)||/||b|| 3.180673642395e-03
>>>>  32 KSP preconditioned resid norm 1.774822233295e+15 true resid norm
>>>> 3.030553568855e+14 ||r(i)||/||b|| 2.310847508319e-03
>>>>  33 KSP preconditioned resid norm 1.554413264158e+15 true resid norm
>>>> 2.490797343960e+14 ||r(i)||/||b|| 1.899274408204e-03
>>>>  34 KSP preconditioned resid norm 1.363683273075e+15 true resid norm
>>>> 2.337415683510e+14 ||r(i)||/||b|| 1.782318340667e-03
>>>>  35 KSP preconditioned resid norm 1.216181955878e+15 true resid norm
>>>> 1.941708948493e+14 ||r(i)||/||b|| 1.480585372791e-03
>>>>  36 KSP preconditioned resid norm 1.106171392348e+15 true resid norm
>>>> 1.781889599099e+14 ||r(i)||/||b|| 1.358720460346e-03
>>>>  37 KSP preconditioned resid norm 9.985678909493e+14 true resid norm
>>>> 1.843602345870e+14 ||r(i)||/||b|| 1.405777456326e-03
>>>>  38 KSP preconditioned resid norm 9.306373857300e+14 true resid norm
>>>> 1.483324768155e+14 ||r(i)||/||b|| 1.131059810243e-03
>>>>  39 KSP preconditioned resid norm 8.621292024153e+14 true resid norm
>>>> 1.776747195898e+14 ||r(i)||/||b|| 1.354799292363e-03
>>>>   0 KSP preconditioned resid norm 6.470804796325e+18 true resid norm
>>>> 3.511545401133e+18 ||r(i)||/||b|| 1.662319590124e+02
>>>>   1 KSP preconditioned resid norm 1.571603694611e+18 true resid norm
>>>> 5.187449890798e+17 ||r(i)||/||b|| 2.455670820454e+01
>>>>   2 KSP preconditioned resid norm 6.468415902839e+17 true resid norm
>>>> 1.566954416728e+17 ||r(i)||/||b|| 7.417756930949e+00
>>>>   3 KSP preconditioned resid norm 4.084120869852e+17 true resid norm
>>>> 8.688409741290e+16 ||r(i)||/||b|| 4.112979349580e+00
>>>>   4 KSP preconditioned resid norm 2.920961241699e+17 true resid norm
>>>> 4.832079671037e+16 ||r(i)||/||b|| 2.287443213923e+00
>>>>   5 KSP preconditioned resid norm 2.515909976499e+17 true resid norm
>>>> 4.435653262803e+16 ||r(i)||/||b|| 2.099780145624e+00
>>>>   6 KSP preconditioned resid norm 2.133092401708e+17 true resid norm
>>>> 4.355815215083e+16 ||r(i)||/||b|| 2.061985859746e+00
>>>>   7 KSP preconditioned resid norm 1.601275153782e+17 true resid norm
>>>> 2.999237788966e+16 ||r(i)||/||b|| 1.419799877977e+00
>>>>   8 KSP preconditioned resid norm 1.019875018318e+17 true resid norm
>>>> 1.811096161004e+16 ||r(i)||/||b|| 8.573491964719e-01
>>>>   9 KSP preconditioned resid norm 5.552203589730e+16 true resid norm
>>>> 9.849208071572e+15 ||r(i)||/||b|| 4.662486072173e-01
>>>>  10 KSP preconditioned resid norm 2.614195079413e+16 true resid norm
>>>> 4.400774101946e+15 ||r(i)||/||b|| 2.083268807806e-01
>>>>  11 KSP preconditioned resid norm 2.230316715231e+16 true resid norm
>>>> 4.001821966241e+15 ||r(i)||/||b|| 1.894410093210e-01
>>>>  12 KSP preconditioned resid norm 2.202763899809e+16 true resid norm
>>>> 3.668851069689e+15 ||r(i)||/||b|| 1.736786032846e-01
>>>>  13 KSP preconditioned resid norm 2.171352861704e+16 true resid norm
>>>> 3.746836567903e+15 ||r(i)||/||b|| 1.773703346056e-01
>>>>  14 KSP preconditioned resid norm 2.756407833586e+16 true resid norm
>>>> 4.737724354756e+15 ||r(i)||/||b|| 2.242776643292e-01
>>>>  15 KSP preconditioned resid norm 1.909305469788e+16 true resid norm
>>>> 7.268311827741e+15 ||r(i)||/||b|| 3.440723601207e-01
>>>>  16 KSP preconditioned resid norm 8.249997128004e+15 true resid norm
>>>> 1.447767843213e+15 ||r(i)||/||b|| 6.853543305884e-02
>>>>  17 KSP preconditioned resid norm 5.434797146758e+15 true resid norm
>>>> 1.776552830818e+15 ||r(i)||/||b|| 8.409968364943e-02
>>>>  18 KSP preconditioned resid norm 4.166874856572e+15 true resid norm
>>>> 7.323760066865e+14 ||r(i)||/||b|| 3.466972071212e-02
>>>>  19 KSP preconditioned resid norm 3.463504540881e+15 true resid norm
>>>> 7.653814460137e+14 ||r(i)||/||b|| 3.623215497131e-02
>>>>  20 KSP preconditioned resid norm 3.008102754263e+15 true resid norm
>>>> 5.633011056242e+14 ||r(i)||/||b|| 2.666593639130e-02
>>>>  21 KSP preconditioned resid norm 2.629337883031e+15 true resid norm
>>>> 5.301916607139e+14 ||r(i)||/||b|| 2.509857864406e-02
>>>>  22 KSP preconditioned resid norm 2.387457188115e+15 true resid norm
>>>> 3.879435274146e+14 ||r(i)||/||b|| 1.836473836491e-02
>>>>  23 KSP preconditioned resid norm 2.223797660329e+15 true resid norm
>>>> 3.481194862204e+14 ||r(i)||/||b|| 1.647952042601e-02
>>>>  24 KSP preconditioned resid norm 2.082583007435e+15 true resid norm
>>>> 3.393016280495e+14 ||r(i)||/||b|| 1.606209457197e-02
>>>>  25 KSP preconditioned resid norm 1.971105202361e+15 true resid norm
>>>> 3.085385809365e+14 ||r(i)||/||b|| 1.460581222257e-02
>>>>  26 KSP preconditioned resid norm 1.916167824316e+15 true resid norm
>>>> 3.157123008884e+14 ||r(i)||/||b|| 1.494540672721e-02
>>>>  27 KSP preconditioned resid norm 1.825444848282e+15 true resid norm
>>>> 4.173235963436e+14 ||r(i)||/||b|| 1.975555233884e-02
>>>>  28 KSP preconditioned resid norm 1.787001647353e+15 true resid norm
>>>> 2.787303202952e+14 ||r(i)||/||b|| 1.319472821393e-02
>>>>  29 KSP preconditioned resid norm 1.896717764390e+15 true resid norm
>>>> 3.068021792990e+14 ||r(i)||/||b|| 1.452361324382e-02
>>>>  30 KSP preconditioned resid norm 2.229137880818e+15 true resid norm
>>>> 3.494609542895e+14 ||r(i)||/||b|| 1.654302376702e-02
>>>>  31 KSP preconditioned resid norm 3.112887805330e+15 true resid norm
>>>> 5.056849908847e+14 ||r(i)||/||b|| 2.393846499915e-02
>>>>  32 KSP preconditioned resid norm 2.024054955579e+16 true resid norm
>>>> 3.265471021005e+15 ||r(i)||/||b|| 1.545831202253e-01
>>>>  33 KSP preconditioned resid norm 2.565517746075e+15 true resid norm
>>>> 4.297071200158e+14 ||r(i)||/||b|| 2.034177212653e-02
>>>>  34 KSP preconditioned resid norm 1.151189963639e+15 true resid norm
>>>> 1.893961732619e+14 ||r(i)||/||b|| 8.965766724994e-03
>>>>  35 KSP preconditioned resid norm 7.095661584181e+14 true resid norm
>>>> 1.215463627012e+14 ||r(i)||/||b|| 5.753845579254e-03
>>>>  36 KSP preconditioned resid norm 5.356379112526e+14 true resid norm
>>>> 8.697359204859e+13 ||r(i)||/||b|| 4.117215908392e-03
>>>>  37 KSP preconditioned resid norm 4.260660574229e+14 true resid norm
>>>> 9.044225863386e+13 ||r(i)||/||b|| 4.281418040435e-03
>>>>  38 KSP preconditioned resid norm 3.822193347318e+14 true resid norm
>>>> 6.067358042990e+13 ||r(i)||/||b|| 2.872207812522e-03
>>>>  39 KSP preconditioned resid norm 3.556139762092e+14 true resid norm
>>>> 7.037316076443e+13 ||r(i)||/||b|| 3.331373238687e-03
>>>>  40 KSP preconditioned resid norm 3.319733183305e+14 true resid norm
>>>> 5.228450610578e+13 ||r(i)||/||b|| 2.475080024071e-03
>>>>  41 KSP preconditioned resid norm 3.093370284781e+14 true resid norm
>>>> 5.468964654818e+13 ||r(i)||/||b|| 2.588936221775e-03
>>>>  42 KSP preconditioned resid norm 2.908716641400e+14 true resid norm
>>>> 4.719126609844e+13 ||r(i)||/||b|| 2.233972714489e-03
>>>>  43 KSP preconditioned resid norm 2.664499581099e+14 true resid norm
>>>> 6.079882213095e+13 ||r(i)||/||b|| 2.878136590578e-03
>>>>  44 KSP preconditioned resid norm 2.513459163383e+14 true resid norm
>>>> 3.896503433878e+13 ||r(i)||/||b|| 1.844553679708e-03
>>>>  45 KSP preconditioned resid norm 2.506735910619e+14 true resid norm
>>>> 4.872960867423e+13 ||r(i)||/||b|| 2.306795836731e-03
>>>>  46 KSP preconditioned resid norm 2.610309833791e+14 true resid norm
>>>> 4.046617714344e+13 ||r(i)||/||b|| 1.915615813519e-03
>>>>  47 KSP preconditioned resid norm 3.265892246735e+14 true resid norm
>>>> 6.092635527969e+13 ||r(i)||/||b|| 2.884173842765e-03
>>>>  48 KSP preconditioned resid norm 6.619675585826e+14 true resid norm
>>>> 1.029872445074e+14 ||r(i)||/||b|| 4.875281237212e-03
>>>>  49 KSP preconditioned resid norm 6.614927581836e+14 true resid norm
>>>> 1.173864813817e+14 ||r(i)||/||b|| 5.556922247214e-03
>>>>  50 KSP preconditioned resid norm 2.572515469657e+14 true resid norm
>>>> 4.031945474821e+13 ||r(i)||/||b|| 1.908670167541e-03
>>>>  51 KSP preconditioned resid norm 1.432897312628e+14 true resid norm
>>>> 2.304000171834e+13 ||r(i)||/||b|| 1.090683497942e-03
>>>>  52 KSP preconditioned resid norm 8.898633954299e+13 true resid norm
>>>> 1.420071536381e+13 ||r(i)||/||b|| 6.722432617682e-04
>>>>   0 KSP preconditioned resid norm 6.694445614266e+18 true resid norm
>>>> 3.650633549648e+18 ||r(i)||/||b|| 5.229628447406e+00
>>>>   1 KSP preconditioned resid norm 1.597624793291e+18 true resid norm
>>>> 5.366629107368e+17 ||r(i)||/||b|| 7.687837156178e-01
>>>>   2 KSP preconditioned resid norm 6.300333922334e+17 true resid norm
>>>> 1.705382687722e+17 ||r(i)||/||b|| 2.443005493741e-01
>>>>   3 KSP preconditioned resid norm 3.642099405484e+17 true resid norm
>>>> 9.482515314454e+16 ||r(i)||/||b|| 1.358395225569e-01
>>>>   4 KSP preconditioned resid norm 2.247296120507e+17 true resid norm
>>>> 3.802694326323e+16 ||r(i)||/||b|| 5.447459504021e-02
>>>>   5 KSP preconditioned resid norm 1.557575416788e+17 true resid norm
>>>> 3.828791753195e+16 ||r(i)||/||b|| 5.484844753491e-02
>>>>   6 KSP preconditioned resid norm 1.004780833173e+17 true resid norm
>>>> 1.699813376802e+16 ||r(i)||/||b|| 2.435027309565e-02
>>>>   7 KSP preconditioned resid norm 7.104370054381e+16 true resid norm
>>>> 1.472894912543e+16 ||r(i)||/||b|| 2.109960649273e-02
>>>>   8 KSP preconditioned resid norm 5.767747590200e+16 true resid norm
>>>> 9.399551072817e+15 ||r(i)||/||b|| 1.346510380041e-02
>>>>   9 KSP preconditioned resid norm 4.524165642090e+16 true resid norm
>>>> 1.246569325329e+16 ||r(i)||/||b|| 1.785743300921e-02
>>>>  10 KSP preconditioned resid norm 3.195588487377e+16 true resid norm
>>>> 5.031148957130e+15 ||r(i)||/||b|| 7.207253029241e-03
>>>>  11 KSP preconditioned resid norm 2.437445149875e+16 true resid norm
>>>> 4.973530315557e+15 ||r(i)||/||b|| 7.124712811776e-03
>>>>  12 KSP preconditioned resid norm 1.257635618330e+16 true resid norm
>>>> 1.885290715052e+15 ||r(i)||/||b|| 2.700728468356e-03
>>>>  13 KSP preconditioned resid norm 2.495249888250e+15 true resid norm
>>>> 4.460762730080e+14 ||r(i)||/||b|| 6.390159777228e-04
>>>>  14 KSP preconditioned resid norm 7.692041830184e+14 true resid norm
>>>> 1.319158639688e+14 ||r(i)||/||b|| 1.889729400372e-04
>>>>  15 KSP preconditioned resid norm 5.963386353631e+14 true resid norm
>>>> 1.441107752347e+14 ||r(i)||/||b|| 2.064424707371e-04
>>>>  16 KSP preconditioned resid norm 3.269005832710e+14 true resid norm
>>>> 5.055770257989e+13 ||r(i)||/||b|| 7.242523689424e-05
>>>>  17 KSP preconditioned resid norm 1.442136448583e+14 true resid norm
>>>> 7.615238793008e+13 ||r(i)||/||b|| 1.090902959284e-04
>>>>  18 KSP preconditioned resid norm 5.418830608399e+13 true resid norm
>>>> 8.650648142713e+12 ||r(i)||/||b|| 1.239228068235e-05
>>>>  19 KSP preconditioned resid norm 3.534476706711e+13 true resid norm
>>>> 1.235947718863e+13 ||r(i)||/||b|| 1.770527570673e-05
>>>>   0 KSP preconditioned resid norm 4.827689913975e+18 true resid norm
>>>> 2.628955418091e+18 ||r(i)||/||b|| 2.387179080674e+01
>>>>   1 KSP preconditioned resid norm 1.161014015330e+18 true resid norm
>>>> 3.885001078629e+17 ||r(i)||/||b|| 3.527710374804e+00
>>>>   2 KSP preconditioned resid norm 4.696713579932e+17 true resid norm
>>>> 1.228966476828e+17 ||r(i)||/||b|| 1.115942493412e+00
>>>>   3 KSP preconditioned resid norm 2.869928353163e+17 true resid norm
>>>> 6.759586363313e+16 ||r(i)||/||b|| 6.137929555390e-01
>>>>   4 KSP preconditioned resid norm 1.966510821692e+17 true resid norm
>>>> 3.310379360335e+16 ||r(i)||/||b|| 3.005934716010e-01
>>>>   5 KSP preconditioned resid norm 1.592497528073e+17 true resid norm
>>>> 3.239157026660e+16 ||r(i)||/||b|| 2.941262464874e-01
>>>>   6 KSP preconditioned resid norm 1.230094082012e+17 true resid norm
>>>> 2.280559390645e+16 ||r(i)||/||b|| 2.070823883934e-01
>>>>   7 KSP preconditioned resid norm 8.598887604154e+16 true resid norm
>>>> 1.938013722659e+16 ||r(i)||/||b|| 1.759781008439e-01
>>>>   8 KSP preconditioned resid norm 5.549487092651e+16 true resid norm
>>>> 9.386421691835e+15 ||r(i)||/||b|| 8.523183524123e-02
>>>>   9 KSP preconditioned resid norm 4.475548308156e+16 true resid norm
>>>> 7.579602548804e+15 ||r(i)||/||b|| 6.882531563606e-02
>>>>  10 KSP preconditioned resid norm 4.379582896462e+16 true resid norm
>>>> 6.844431748768e+15 ||r(i)||/||b|| 6.214971991278e-02
>>>>  11 KSP preconditioned resid norm 4.081432560058e+16 true resid norm
>>>> 7.719907534397e+15 ||r(i)||/||b|| 7.009933163578e-02
>>>>  12 KSP preconditioned resid norm 4.084955665921e+16 true resid norm
>>>> 6.376903215279e+15 ||r(i)||/||b|| 5.790440511177e-02
>>>>  13 KSP preconditioned resid norm 7.513638228384e+16 true resid norm
>>>> 1.130789675242e+16 ||r(i)||/||b|| 1.026794687656e-01
>>>>  14 KSP preconditioned resid norm 2.195838265499e+15 true resid norm
>>>> 3.518796225338e+14 ||r(i)||/||b|| 3.195184171050e-03
>>>>  15 KSP preconditioned resid norm 2.237408970122e+15 true resid norm
>>>> 3.676139977919e+14 ||r(i)||/||b|| 3.338057538948e-03
>>>>  16 KSP preconditioned resid norm 1.675719433917e+15 true resid norm
>>>> 3.658174858611e+14 ||r(i)||/||b|| 3.321744612262e-03
>>>>  17 KSP preconditioned resid norm 1.403876583239e+15 true resid norm
>>>> 2.164126267214e+14 ||r(i)||/||b|| 1.965098729891e-03
>>>>  18 KSP preconditioned resid norm 1.133854982860e+15 true resid norm
>>>> 2.692061619571e+14 ||r(i)||/||b|| 2.444481613457e-03
>>>>  19 KSP preconditioned resid norm 9.034784290513e+14 true resid norm
>>>> 1.408322491509e+14 ||r(i)||/||b|| 1.278803728446e-03
>>>>  20 KSP preconditioned resid norm 7.964711449547e+14 true resid norm
>>>> 1.641000281547e+14 ||r(i)||/||b|| 1.490082911460e-03
>>>>  21 KSP preconditioned resid norm 7.094597664828e+14 true resid norm
>>>> 1.088610845746e+14 ||r(i)||/||b|| 9.884949056480e-04
>>>>  22 KSP preconditioned resid norm 6.287860765855e+14 true resid norm
>>>> 1.439087926971e+14 ||r(i)||/||b|| 1.306739768531e-03
>>>>  23 KSP preconditioned resid norm 5.617871594119e+14 true resid norm
>>>> 8.640965180691e+13 ||r(i)||/||b|| 7.846284183530e-04
>>>>  24 KSP preconditioned resid norm 4.992037484390e+14 true resid norm
>>>> 1.232499062518e+14 ||r(i)||/||b|| 1.119150198876e-03
>>>>  25 KSP preconditioned resid norm 3.174300847299e+14 true resid norm
>>>> 1.199443314096e+14 ||r(i)||/||b|| 1.089134478340e-03
>>>>  26 KSP preconditioned resid norm 2.311461716948e+14 true resid norm
>>>> 3.806900580053e+13 ||r(i)||/||b|| 3.456792520850e-04
>>>>  27 KSP preconditioned resid norm 2.486080516907e+14 true resid norm
>>>> 3.795889860412e+13 ||r(i)||/||b|| 3.446794420688e-04
>>>>  28 KSP preconditioned resid norm 3.709940932117e+14 true resid norm
>>>> 6.158317563060e+13 ||r(i)||/||b|| 5.591957458661e-04
>>>>  29 KSP preconditioned resid norm 5.526902041486e+14 true resid norm
>>>> 8.543527855752e+13 ||r(i)||/||b|| 7.757807847199e-04
>>>>  30 KSP preconditioned resid norm 1.980272137271e+15 true resid norm
>>>> 3.202004161054e+14 ||r(i)||/||b|| 2.907526425475e-03
>>>>  31 KSP preconditioned resid norm 4.796148387368e+14 true resid norm
>>>> 7.312671161483e+13 ||r(i)||/||b|| 6.640148973394e-04
>>>>  32 KSP preconditioned resid norm 1.482366487345e+14 true resid norm
>>>> 3.206675205939e+13 ||r(i)||/||b|| 2.911767889807e-04
>>>>  33 KSP preconditioned resid norm 7.403721045502e+13 true resid norm
>>>> 1.122274917558e+13 ||r(i)||/||b|| 1.019063004083e-04
>>>>  34 KSP preconditioned resid norm 3.421203410880e+13 true resid norm
>>>> 9.812523407473e+12 ||r(i)||/||b|| 8.910098073838e-05
>>>>  35 KSP preconditioned resid norm 1.809542403951e+13 true resid norm
>>>> 2.774316021276e+12 ||r(i)||/||b|| 2.519171349804e-05
>>>>  36 KSP preconditioned resid norm 1.070863017107e+13 true resid norm
>>>> 1.674563212179e+12 ||r(i)||/||b|| 1.520559170335e-05
>>>>  37 KSP preconditioned resid norm 6.984609262190e+12 true resid norm
>>>> 1.277736482286e+12 ||r(i)||/||b|| 1.160227282721e-05
>>>>   0 KSP preconditioned resid norm 9.569153877844e+15 true resid norm
>>>> 5.893805322157e+15 ||r(i)||/||b|| 1.119437717455e-01
>>>>   1 KSP preconditioned resid norm 4.594033327917e+15 true resid norm
>>>> 8.149731925277e+14 ||r(i)||/||b|| 1.547916296116e-02
>>>>   2 KSP preconditioned resid norm 3.788286152976e+15 true resid norm
>>>> 6.151807578016e+14 ||r(i)||/||b|| 1.168441279773e-02
>>>>   3 KSP preconditioned resid norm 3.712195492568e+15 true resid norm
>>>> 6.206672982073e+14 ||r(i)||/||b|| 1.178862119847e-02
>>>>   4 KSP preconditioned resid norm 3.886667577513e+15 true resid norm
>>>> 6.330116967950e+14 ||r(i)||/||b|| 1.202308407301e-02
>>>>   5 KSP preconditioned resid norm 4.317240607103e+15 true resid norm
>>>> 6.816590875948e+14 ||r(i)||/||b|| 1.294706647725e-02
>>>>   6 KSP preconditioned resid norm 5.249548366505e+15 true resid norm
>>>> 7.833242603614e+14 ||r(i)||/||b|| 1.487804014750e-02
>>>>   7 KSP preconditioned resid norm 6.521511569741e+15 true resid norm
>>>> 1.182301409963e+15 ||r(i)||/||b|| 2.245599777001e-02
>>>>   8 KSP preconditioned resid norm 7.063327681244e+15 true resid norm
>>>> 1.110968116855e+15 ||r(i)||/||b|| 2.110113152571e-02
>>>>   9 KSP preconditioned resid norm 7.059112088082e+15 true resid norm
>>>> 1.341815038025e+15 ||r(i)||/||b|| 2.548571392011e-02
>>>>  10 KSP preconditioned resid norm 6.417041101993e+15 true resid norm
>>>> 1.020408664201e+15 ||r(i)||/||b|| 1.938109393654e-02
>>>>  11 KSP preconditioned resid norm 4.850416656929e+15 true resid norm
>>>> 8.501719778107e+14 ||r(i)||/||b|| 1.614770977770e-02
>>>>  12 KSP preconditioned resid norm 2.420686956668e+15 true resid norm
>>>> 3.735196627993e+14 ||r(i)||/||b|| 7.094431795646e-03
>>>>  13 KSP preconditioned resid norm 1.348084459782e+15 true resid norm
>>>> 2.753333760274e+14 ||r(i)||/||b|| 5.229534216894e-03
>>>>  14 KSP preconditioned resid norm 1.225904445555e+15 true resid norm
>>>> 2.239730314894e+14 ||r(i)||/||b|| 4.254023426925e-03
>>>>  15 KSP preconditioned resid norm 1.156415256406e+15 true resid norm
>>>> 2.064224387096e+14 ||r(i)||/||b|| 3.920676897010e-03
>>>>  16 KSP preconditioned resid norm 1.062658328422e+15 true resid norm
>>>> 1.696405409630e+14 ||r(i)||/||b|| 3.222061292889e-03
>>>>  17 KSP preconditioned resid norm 9.163863908341e+14 true resid norm
>>>> 1.701529770139e+14 ||r(i)||/||b|| 3.231794227925e-03
>>>>  18 KSP preconditioned resid norm 8.234055963962e+14 true resid norm
>>>> 1.322040551676e+14 ||r(i)||/||b|| 2.511012795057e-03
>>>>  19 KSP preconditioned resid norm 7.097124944641e+14 true resid norm
>>>> 1.155726966735e+14 ||r(i)||/||b|| 2.195125707289e-03
>>>>  20 KSP preconditioned resid norm 6.309033027960e+14 true resid norm
>>>> 1.023450925395e+14 ||r(i)||/||b|| 1.943887701115e-03
>>>>  21 KSP preconditioned resid norm 5.667708572251e+14 true resid norm
>>>> 8.941024380489e+13 ||r(i)||/||b|| 1.698210133710e-03
>>>>  22 KSP preconditioned resid norm 5.205793964231e+14 true resid norm
>>>> 8.689007901528e+13 ||r(i)||/||b|| 1.650343477697e-03
>>>>  23 KSP preconditioned resid norm 4.890134322830e+14 true resid norm
>>>> 7.566844928998e+13 ||r(i)||/||b|| 1.437205871699e-03
>>>>  24 KSP preconditioned resid norm 4.617102016960e+14 true resid norm
>>>> 8.638231658778e+13 ||r(i)||/||b|| 1.640699310952e-03
>>>>  25 KSP preconditioned resid norm 4.386224186730e+14 true resid norm
>>>> 6.736465167645e+13 ||r(i)||/||b|| 1.279488001179e-03
>>>>  26 KSP preconditioned resid norm 4.119635069909e+14 true resid norm
>>>> 8.360600093542e+13 ||r(i)||/||b|| 1.587967463073e-03
>>>>  27 KSP preconditioned resid norm 3.764202708342e+14 true resid norm
>>>> 5.766864517117e+13 ||r(i)||/||b|| 1.095327262956e-03
>>>>  28 KSP preconditioned resid norm 3.345193309034e+14 true resid norm
>>>> 7.248849449141e+13 ||r(i)||/||b|| 1.376807518738e-03
>>>>   0 KSP preconditioned resid norm 9.592548277384e+15 true resid norm
>>>> 5.933564471549e+15 ||r(i)||/||b|| 5.704186299543e-01
>>>>   1 KSP preconditioned resid norm 4.627892277467e+15 true resid norm
>>>> 8.123960687021e+14 ||r(i)||/||b|| 7.809906755228e-02
>>>>   2 KSP preconditioned resid norm 3.843955835291e+15 true resid norm
>>>> 6.217930929753e+14 ||r(i)||/||b|| 5.977559794129e-02
>>>>   3 KSP preconditioned resid norm 3.802651796154e+15 true resid norm
>>>> 6.334637368548e+14 ||r(i)||/||b|| 6.089754626161e-02
>>>>   4 KSP preconditioned resid norm 4.025480937197e+15 true resid norm
>>>> 6.491593110279e+14 ||r(i)||/||b|| 6.240642814182e-02
>>>>   5 KSP preconditioned resid norm 4.519579789539e+15 true resid norm
>>>> 7.102235297384e+14 ||r(i)||/||b|| 6.827678956506e-02
>>>>   6 KSP preconditioned resid norm 5.567308133052e+15 true resid norm
>>>> 8.274501588234e+14 ||r(i)||/||b|| 7.954628085944e-02
>>>>   7 KSP preconditioned resid norm 7.053789984861e+15 true resid norm
>>>> 1.260366188593e+15 ||r(i)||/||b|| 1.211643284547e-01
>>>>   8 KSP preconditioned resid norm 7.835759896085e+15 true resid norm
>>>> 1.231567591968e+15 ||r(i)||/||b|| 1.183957976482e-01
>>>>   9 KSP preconditioned resid norm 8.126559485840e+15 true resid norm
>>>> 1.514279927927e+15 ||r(i)||/||b|| 1.455741293445e-01
>>>>  10 KSP preconditioned resid norm 7.865908148994e+15 true resid norm
>>>> 1.247217430777e+15 ||r(i)||/||b|| 1.199002827947e-01
>>>>  11 KSP preconditioned resid norm 6.705237228445e+15 true resid norm
>>>> 1.156150868849e+15 ||r(i)||/||b|| 1.111456693176e-01
>>>>  12 KSP preconditioned resid norm 3.837356917105e+15 true resid norm
>>>> 5.892678306289e+14 ||r(i)||/||b|| 5.664880700887e-02
>>>>  13 KSP preconditioned resid norm 1.588477046031e+15 true resid norm
>>>> 3.087098247775e+14 ||r(i)||/||b|| 2.967758017080e-02
>>>>  14 KSP preconditioned resid norm 1.304101915863e+15 true resid norm
>>>> 2.634312731694e+14 ||r(i)||/||b|| 2.532476164182e-02
>>>>  15 KSP preconditioned resid norm 1.188980488344e+15 true resid norm
>>>> 2.212236776838e+14 ||r(i)||/||b|| 2.126716710384e-02
>>>>  16 KSP preconditioned resid norm 1.053945473260e+15 true resid norm
>>>> 1.687417173497e+14 ||r(i)||/||b|| 1.622185444993e-02
>>>>  17 KSP preconditioned resid norm 8.630322699779e+14 true resid norm
>>>> 2.032342536888e+14 ||r(i)||/||b|| 1.953776774564e-02
>>>>  18 KSP preconditioned resid norm 7.497367164260e+14 true resid norm
>>>> 1.258314731452e+14 ||r(i)||/||b|| 1.209671132095e-02
>>>>  19 KSP preconditioned resid norm 6.482413928213e+14 true resid norm
>>>> 1.007668116028e+14 ||r(i)||/||b|| 9.687139474922e-03
>>>>  20 KSP preconditioned resid norm 5.423124085977e+14 true resid norm
>>>> 1.262959277696e+14 ||r(i)||/||b|| 1.214136130695e-02
>>>>  21 KSP preconditioned resid norm 4.512195524384e+14 true resid norm
>>>> 7.029203398299e+13 ||r(i)||/||b|| 6.757470305334e-03
>>>>  22 KSP preconditioned resid norm 3.576286880164e+14 true resid norm
>>>> 9.097241124393e+13 ||r(i)||/||b|| 8.745562373884e-03
>>>>  23 KSP preconditioned resid norm 2.908403868181e+14 true resid norm
>>>> 4.482717971847e+13 ||r(i)||/||b|| 4.309426241567e-03
>>>>  24 KSP preconditioned resid norm 2.299942905294e+14 true resid norm
>>>> 6.485244464292e+13 ||r(i)||/||b|| 6.234539592478e-03
>>>>  25 KSP preconditioned resid norm 1.957293334591e+14 true resid norm
>>>> 3.000864324033e+13 ||r(i)||/||b|| 2.884857701642e-03
>>>>  26 KSP preconditioned resid norm 1.685971736537e+14 true resid norm
>>>> 4.568513443333e+13 ||r(i)||/||b|| 4.391905054321e-03
>>>>  27 KSP preconditioned resid norm 1.478986486404e+14 true resid norm
>>>> 2.270701271232e+13 ||r(i)||/||b|| 2.182921099758e-03
>>>>  28 KSP preconditioned resid norm 1.388836935911e+14 true resid norm
>>>> 2.435562734780e+13 ||r(i)||/||b|| 2.341409392284e-03
>>>>  29 KSP preconditioned resid norm 1.300875297573e+14 true resid norm
>>>> 2.023811842122e+13 ||r(i)||/||b|| 1.945575857149e-03
>>>>  30 KSP preconditioned resid norm 1.230463362777e+14 true resid norm
>>>> 2.013991197226e+13 ||r(i)||/||b|| 1.936134856156e-03
>>>>  31 KSP preconditioned resid norm 1.148174878708e+14 true resid norm
>>>> 1.790715664590e+13 ||r(i)||/||b|| 1.721490650234e-03
>>>>  32 KSP preconditioned resid norm 1.085020096185e+14 true resid norm
>>>> 1.697737976905e+13 ||r(i)||/||b|| 1.632107269502e-03
>>>>  33 KSP preconditioned resid norm 1.008662380835e+14 true resid norm
>>>> 1.575408064147e+13 ||r(i)||/||b|| 1.514506354280e-03
>>>>  34 KSP preconditioned resid norm 9.448474542578e+13 true resid norm
>>>> 1.450932025652e+13 ||r(i)||/||b|| 1.394842277686e-03
>>>>  35 KSP preconditioned resid norm 8.955256800693e+13 true resid norm
>>>> 1.427784032077e+13 ||r(i)||/||b|| 1.372589133148e-03
>>>>  36 KSP preconditioned resid norm 8.409700445745e+13 true resid norm
>>>> 1.287414873178e+13 ||r(i)||/||b|| 1.237646328210e-03
>>>>  37 KSP preconditioned resid norm 7.999039854664e+13 true resid norm
>>>> 1.307106382082e+13 ||r(i)||/||b|| 1.256576607951e-03
>>>>  38 KSP preconditioned resid norm 7.508174679474e+13 true resid norm
>>>> 1.150183263556e+13 ||r(i)||/||b|| 1.105719781996e-03
>>>>  39 KSP preconditioned resid norm 7.047760131088e+13 true resid norm
>>>> 1.131577846513e+13 ||r(i)||/||b|| 1.087833608263e-03
>>>>  40 KSP preconditioned resid norm 6.612188631103e+13 true resid norm
>>>> 1.012435424497e+13 ||r(i)||/||b|| 9.732969626060e-04
>>>>  41 KSP preconditioned resid norm 6.096165352930e+13 true resid norm
>>>> 1.005634567468e+13 ||r(i)||/||b|| 9.667590113164e-04
>>>>  42 KSP preconditioned resid norm 5.668115744306e+13 true resid norm
>>>> 8.662975702181e+12 ||r(i)||/||b|| 8.328084669947e-04
>>>>  43 KSP preconditioned resid norm 5.243169528258e+13 true resid norm
>>>> 8.972837494107e+12 ||r(i)||/||b|| 8.625967906361e-04
>>>>   0 KSP preconditioned resid norm 2.201027933913e+16 true resid norm
>>>> 1.374916449250e+16 ||r(i)||/||b|| 1.042532971848e-01
>>>>   1 KSP preconditioned resid norm 1.033786235817e+16 true resid norm
>>>> 1.769244185634e+15 ||r(i)||/||b|| 1.341532716246e-02
>>>>   2 KSP preconditioned resid norm 8.200152533928e+15 true resid norm
>>>> 1.329548327593e+15 ||r(i)||/||b|| 1.008132508660e-02
>>>>   3 KSP preconditioned resid norm 7.725254307721e+15 true resid norm
>>>> 1.292264285665e+15 ||r(i)||/||b|| 9.798618140627e-03
>>>>   4 KSP preconditioned resid norm 7.783851928031e+15 true resid norm
>>>> 1.241739377824e+15 ||r(i)||/||b|| 9.415512080968e-03
>>>>   5 KSP preconditioned resid norm 8.247256237278e+15 true resid norm
>>>> 1.289875346607e+15 ||r(i)||/||b|| 9.780503965494e-03
>>>>   6 KSP preconditioned resid norm 9.468674539247e+15 true resid norm
>>>> 1.409079612219e+15 ||r(i)||/||b|| 1.068437254131e-02
>>>>   7 KSP preconditioned resid norm 1.106031993220e+16 true resid norm
>>>> 1.997396506013e+15 ||r(i)||/||b|| 1.514529640334e-02
>>>>   8 KSP preconditioned resid norm 1.133839709036e+16 true resid norm
>>>> 1.772431554854e+15 ||r(i)||/||b|| 1.343949544924e-02
>>>>   9 KSP preconditioned resid norm 1.055805824819e+16 true resid norm
>>>> 2.045498232098e+15 ||r(i)||/||b|| 1.551002864197e-02
>>>>  10 KSP preconditioned resid norm 8.628048224174e+15 true resid norm
>>>> 1.368695682952e+15 ||r(i)||/||b|| 1.037816064155e-02
>>>>  11 KSP preconditioned resid norm 5.442091241360e+15 true resid norm
>>>> 9.810024540837e+14 ||r(i)||/||b|| 7.438469475027e-03
>>>>  12 KSP preconditioned resid norm 2.000681531075e+15 true resid norm
>>>> 3.042659606098e+14 ||r(i)||/||b|| 2.307102342980e-03
>>>>  13 KSP preconditioned resid norm 8.105673271529e+14 true resid norm
>>>> 1.475101242619e+14 ||r(i)||/||b|| 1.118498278992e-03
>>>>   0 KSP preconditioned resid norm 1.928660996668e+16 true resid norm
>>>> 1.203367101178e+16 ||r(i)||/||b|| 4.946564650623e-01
>>>>   1 KSP preconditioned resid norm 9.233394049572e+15 true resid norm
>>>> 1.583660413052e+15 ||r(i)||/||b|| 6.509799553373e-02
>>>>   2 KSP preconditioned resid norm 7.543213441610e+15 true resid norm
>>>> 1.216909563864e+15 ||r(i)||/||b|| 5.002232341004e-02
>>>>   3 KSP preconditioned resid norm 7.341955893763e+15 true resid norm
>>>> 1.220114169499e+15 ||r(i)||/||b|| 5.015405203166e-02
>>>>   4 KSP preconditioned resid norm 7.657405519141e+15 true resid norm
>>>> 1.212628294074e+15 ||r(i)||/||b|| 4.984633739730e-02
>>>>   5 KSP preconditioned resid norm 8.417297612797e+15 true resid norm
>>>> 1.311888034770e+15 ||r(i)||/||b|| 5.392651146949e-02
>>>>   6 KSP preconditioned resid norm 1.008979814671e+16 true resid norm
>>>> 1.496346817141e+15 ||r(i)||/||b|| 6.150888007071e-02
>>>>   7 KSP preconditioned resid norm 1.235951387667e+16 true resid norm
>>>> 2.203847820374e+15 ||r(i)||/||b|| 9.059143891287e-02
>>>>   8 KSP preconditioned resid norm 1.311708980126e+16 true resid norm
>>>> 2.061617788942e+15 ||r(i)||/||b|| 8.474492669688e-02
>>>>   9 KSP preconditioned resid norm 1.289258338081e+16 true resid norm
>>>> 2.353735302483e+15 ||r(i)||/||b|| 9.675271854106e-02
>>>>  10 KSP preconditioned resid norm 1.151089236912e+16 true resid norm
>>>> 1.820534806530e+15 ||r(i)||/||b|| 7.483496191971e-02
>>>>  11 KSP preconditioned resid norm 8.373719062509e+15 true resid norm
>>>> 1.433022884373e+15 ||r(i)||/||b|| 5.890588446727e-02
>>>>  12 KSP preconditioned resid norm 3.564533969408e+15 true resid norm
>>>> 5.439956922043e+14 ||r(i)||/||b|| 2.236150430334e-02
>>>>  13 KSP preconditioned resid norm 1.257109874849e+15 true resid norm
>>>> 2.286041152149e+14 ||r(i)||/||b|| 9.397008063476e-03
>>>>  14 KSP preconditioned resid norm 1.068785016666e+15 true resid norm
>>>> 1.971356784282e+14 ||r(i)||/||b|| 8.103465495567e-03
>>>>  15 KSP preconditioned resid norm 9.963029863724e+14 true resid norm
>>>> 1.558476632901e+14 ||r(i)||/||b|| 6.406279026229e-03
>>>>  16 KSP preconditioned resid norm 8.667425302785e+14 true resid norm
>>>> 2.560422780209e+14 ||r(i)||/||b|| 1.052488206037e-02
>>>>  17 KSP preconditioned resid norm 7.240699142388e+14 true resid norm
>>>> 1.131314963782e+14 ||r(i)||/||b|| 4.650386904448e-03
>>>>  18 KSP preconditioned resid norm 6.352047441583e+14 true resid norm
>>>> 1.637714957863e+14 ||r(i)||/||b|| 6.731996337968e-03
>>>>  19 KSP preconditioned resid norm 5.532686184638e+14 true resid norm
>>>> 8.631039548890e+13 ||r(i)||/||b|| 3.547877874413e-03
>>>>  20 KSP preconditioned resid norm 4.676701949378e+14 true resid norm
>>>> 1.246119427256e+14 ||r(i)||/||b|| 5.122302498784e-03
>>>>  21 KSP preconditioned resid norm 4.001088470241e+14 true resid norm
>>>> 6.181513171397e+13 ||r(i)||/||b|| 2.540974779106e-03
>>>>  22 KSP preconditioned resid norm 3.482451502111e+14 true resid norm
>>>> 6.477073783496e+13 ||r(i)||/||b|| 2.662468018741e-03
>>>>  23 KSP preconditioned resid norm 3.041601141164e+14 true resid norm
>>>> 4.679581096972e+13 ||r(i)||/||b|| 1.923590100755e-03
>>>>  24 KSP preconditioned resid norm 2.690997224286e+14 true resid norm
>>>> 4.294556821793e+13 ||r(i)||/||b|| 1.765321899192e-03
>>>>  25 KSP preconditioned resid norm 2.482501027210e+14 true resid norm
>>>> 3.840071688811e+13 ||r(i)||/||b|| 1.578501095230e-03
>>>>  26 KSP preconditioned resid norm 2.328482920528e+14 true resid norm
>>>> 3.868960801558e+13 ||r(i)||/||b|| 1.590376263145e-03
>>>>  27 KSP preconditioned resid norm 2.171581409229e+14 true resid norm
>>>> 3.334869397249e+13 ||r(i)||/||b|| 1.370832479858e-03
>>>>  28 KSP preconditioned resid norm 2.002313534549e+14 true resid norm
>>>> 3.534153915591e+13 ||r(i)||/||b|| 1.452750437635e-03
>>>>  29 KSP preconditioned resid norm 1.813916789125e+14 true resid norm
>>>> 2.780025874135e+13 ||r(i)||/||b|| 1.142758323985e-03
>>>>  30 KSP preconditioned resid norm 1.655865002619e+14 true resid norm
>>>> 2.941107681765e+13 ||r(i)||/||b|| 1.208972663292e-03
>>>>  31 KSP preconditioned resid norm 1.477358437937e+14 true resid norm
>>>> 2.263549873151e+13 ||r(i)||/||b|| 9.304555340168e-04
>>>>  32 KSP preconditioned resid norm 1.346388933582e+14 true resid norm
>>>> 2.267328899678e+13 ||r(i)||/||b|| 9.320089418685e-04
>>>>   0 KSP preconditioned resid norm 6.130047183925e+16 true resid norm
>>>> 4.019546453762e+16 ||r(i)||/||b|| 5.748521837148e-02
>>>>   1 KSP preconditioned resid norm 2.383257388870e+16 true resid norm
>>>> 4.333010621750e+15 ||r(i)||/||b|| 6.196820080636e-03
>>>>   2 KSP preconditioned resid norm 1.380338515654e+16 true resid norm
>>>> 2.902899468751e+15 ||r(i)||/||b|| 4.151558186756e-03
>>>>   3 KSP preconditioned resid norm 9.355621435823e+15 true resid norm
>>>> 1.914392486860e+15 ||r(i)||/||b|| 2.737852924995e-03
>>>>   4 KSP preconditioned resid norm 6.905538449399e+15 true resid norm
>>>> 1.160515328667e+15 ||r(i)||/||b|| 1.659701607116e-03
>>>>   5 KSP preconditioned resid norm 5.388961375964e+15 true resid norm
>>>> 9.343353155170e+14 ||r(i)||/||b|| 1.336232091419e-03
>>>>   6 KSP preconditioned resid norm 4.457024362952e+15 true resid norm
>>>> 7.443375401358e+14 ||r(i)||/||b|| 1.064508310303e-03
>>>>   7 KSP preconditioned resid norm 3.604925656449e+15 true resid norm
>>>> 7.177624609068e+14 ||r(i)||/||b|| 1.026502175773e-03
>>>>   8 KSP preconditioned resid norm 2.616540301450e+15 true resid norm
>>>> 4.566819450076e+14 ||r(i)||/||b|| 6.531199884630e-04
>>>>   9 KSP preconditioned resid norm 1.730734442406e+15 true resid norm
>>>> 3.416454932875e+14 ||r(i)||/||b|| 4.886015378397e-04
>>>>  10 KSP preconditioned resid norm 9.605665765368e+14 true resid norm
>>>> 1.715807715453e+14 ||r(i)||/||b|| 2.453848520993e-04
>>>>  11 KSP preconditioned resid norm 3.885455022454e+14 true resid norm
>>>> 7.526175493349e+13 ||r(i)||/||b|| 1.076349898463e-04
>>>>  12 KSP preconditioned resid norm 1.085553513563e+14 true resid norm
>>>> 1.877760955419e+13 ||r(i)||/||b|| 2.685464636705e-05
>>>>  13 KSP preconditioned resid norm 5.523836175310e+13 true resid norm
>>>> 1.483397872543e+13 ||r(i)||/||b|| 2.121469464673e-05
>>>>  14 KSP preconditioned resid norm 4.329267915925e+13 true resid norm
>>>> 6.950523101530e+12 ||r(i)||/||b|| 9.940234374291e-06
>>>>   0 KSP preconditioned resid norm 2.469234905564e+16 true resid norm
>>>> 1.581399294540e+16 ||r(i)||/||b|| 1.421323674244e-01
>>>>   1 KSP preconditioned resid norm 1.094883401656e+16 true resid norm
>>>> 1.827560974935e+15 ||r(i)||/||b|| 1.642567875658e-02
>>>>   2 KSP preconditioned resid norm 7.902898352613e+15 true resid norm
>>>> 1.331982197511e+15 ||r(i)||/||b|| 1.197153582609e-02
>>>>   3 KSP preconditioned resid norm 6.757313480243e+15 true resid norm
>>>> 1.177585457449e+15 ||r(i)||/||b|| 1.058385503836e-02
>>>>   4 KSP preconditioned resid norm 6.237102240639e+15 true resid norm
>>>> 9.859442147838e+14 ||r(i)||/||b|| 8.861429613598e-03
>>>>   5 KSP preconditioned resid norm 6.056820105725e+15 true resid norm
>>>> 9.499166634556e+14 ||r(i)||/||b|| 8.537622642110e-03
>>>>   6 KSP preconditioned resid norm 6.282037371920e+15 true resid norm
>>>> 9.440405134922e+14 ||r(i)||/||b|| 8.484809218675e-03
>>>>   7 KSP preconditioned resid norm 6.512961686254e+15 true resid norm
>>>> 1.175538616906e+15 ||r(i)||/||b|| 1.056545852755e-02
>>>>   8 KSP preconditioned resid norm 5.899315381141e+15 true resid norm
>>>> 9.360504236018e+14 ||r(i)||/||b|| 8.412996211297e-03
>>>>   9 KSP preconditioned resid norm 4.860546577526e+15 true resid norm
>>>> 9.070630816401e+14 ||r(i)||/||b|| 8.152464949358e-03
>>>>  10 KSP preconditioned resid norm 3.431569954082e+15 true resid norm
>>>> 5.519072654101e+14 ||r(i)||/||b|| 4.960409840975e-03
>>>>  11 KSP preconditioned resid norm 1.788273694951e+15 true resid norm
>>>> 3.211455497861e+14 ||r(i)||/||b|| 2.886379008546e-03
>>>>  12 KSP preconditioned resid norm 6.021242921522e+14 true resid norm
>>>> 9.258232372098e+13 ||r(i)||/||b|| 8.321076718289e-04
>>>>  13 KSP preconditioned resid norm 3.678076314547e+14 true resid norm
>>>> 7.160952479278e+13 ||r(i)||/||b|| 6.436091962400e-04
>>>>  14 KSP preconditioned resid norm 3.596149520932e+14 true resid norm
>>>> 5.543217762956e+13 ||r(i)||/||b|| 4.982110884443e-04
>>>>  15 KSP preconditioned resid norm 1.443083471369e+14 true resid norm
>>>> 3.905973798110e+13 ||r(i)||/||b|| 3.510595362853e-04
>>>>  16 KSP preconditioned resid norm 1.158730309561e+14 true resid norm
>>>> 1.821149714099e+13 ||r(i)||/||b|| 1.636805588525e-04
>>>>  17 KSP preconditioned resid norm 9.042472136695e+13 true resid norm
>>>> 2.428568415416e+13 ||r(i)||/||b|| 2.182738916901e-04
>>>>  18 KSP preconditioned resid norm 7.667332005406e+13 true resid norm
>>>> 1.178343148104e+13 ||r(i)||/||b|| 1.059066497984e-04
>>>>  19 KSP preconditioned resid norm 6.435860750477e+13 true resid norm
>>>> 1.303667702134e+13 ||r(i)||/||b|| 1.171705194752e-04
>>>>  20 KSP preconditioned resid norm 5.245023814970e+13 true resid norm
>>>> 8.751976411105e+12 ||r(i)||/||b|| 7.866066029293e-05
>>>>  21 KSP preconditioned resid norm 4.161239918955e+13 true resid norm
>>>> 6.811593020631e+12 ||r(i)||/||b|| 6.122096078432e-05
>>>>  22 KSP preconditioned resid norm 3.107777724805e+13 true resid norm
>>>> 6.092648679105e+12 ||r(i)||/||b|| 5.475926185348e-05
>>>>  23 KSP preconditioned resid norm 2.312582950537e+13 true resid norm
>>>> 3.536350440396e+12 ||r(i)||/||b|| 3.178386773481e-05
>>>>  24 KSP preconditioned resid norm 1.680324737468e+13 true resid norm
>>>> 4.383700522921e+12 ||r(i)||/||b|| 3.939964660118e-05
>>>>  25 KSP preconditioned resid norm 1.300784122000e+13 true resid norm
>>>> 1.953230538144e+12 ||r(i)||/||b|| 1.755516658383e-05
>>>>  26 KSP preconditioned resid norm 9.922666654442e+12 true resid norm
>>>> 3.054726768240e+12 ||r(i)||/||b|| 2.745514993611e-05
>>>>  27 KSP preconditioned resid norm 7.226267347787e+12 true resid norm
>>>> 1.085334598547e+12 ||r(i)||/||b|| 9.754726492653e-06
>>>> 2 TS dt 4e-12 time 5e-12
>>>>   0 KSP preconditioned resid norm 2.220258026867e+19 true resid norm
>>>> 1.204245784292e+19 ||r(i)||/||b|| 2.302282866910e+02
>>>>   1 KSP preconditioned resid norm 5.390122646802e+18 true resid norm
>>>> 1.775868988684e+18 ||r(i)||/||b|| 3.395114851018e+01
>>>>   2 KSP preconditioned resid norm 2.218369826326e+18 true resid norm
>>>> 5.319781926844e+17 ||r(i)||/||b|| 1.017038460556e+01
>>>>   3 KSP preconditioned resid norm 1.401713665358e+18 true resid norm
>>>> 2.963575488339e+17 ||r(i)||/||b|| 5.665777834223e+00
>>>>   4 KSP preconditioned resid norm 1.004075064815e+18 true resid norm
>>>> 1.656255011022e+17 ||r(i)||/||b|| 3.166436274762e+00
>>>>   5 KSP preconditioned resid norm 8.672862633339e+17 true resid norm
>>>> 1.510357773334e+17 ||r(i)||/||b|| 2.887509235913e+00
>>>>   6 KSP preconditioned resid norm 7.389427240230e+17 true resid norm
>>>> 1.526197236053e+17 ||r(i)||/||b|| 2.917791196717e+00
>>>>   7 KSP preconditioned resid norm 5.566238898025e+17 true resid norm
>>>> 1.017349876189e+17 ||r(i)||/||b|| 1.944974373301e+00
>>>>   8 KSP preconditioned resid norm 3.566703993070e+17 true resid norm
>>>> 6.306898440820e+16 ||r(i)||/||b|| 1.205755869196e+00
>>>>   9 KSP preconditioned resid norm 1.893399021800e+17 true resid norm
>>>> 3.268112455206e+16 ||r(i)||/||b|| 6.247993068277e-01
>>>>  10 KSP preconditioned resid norm 6.895422631218e+16 true resid norm
>>>> 1.153042493210e+16 ||r(i)||/||b|| 2.204392169408e-01
>>>>  11 KSP preconditioned resid norm 5.104209415340e+16 true resid norm
>>>> 9.274112790250e+15 ||r(i)||/||b|| 1.773029331827e-01
>>>>  12 KSP preconditioned resid norm 4.991932910946e+16 true resid norm
>>>> 8.397724827599e+15 ||r(i)||/||b|| 1.605481060744e-01
>>>>  13 KSP preconditioned resid norm 4.919289629176e+16 true resid norm
>>>> 8.425037065615e+15 ||r(i)||/||b|| 1.610702627509e-01
>>>>  14 KSP preconditioned resid norm 5.687556145039e+16 true resid norm
>>>> 9.761935947260e+15 ||r(i)||/||b|| 1.866291596982e-01
>>>>  15 KSP preconditioned resid norm 1.615122498031e+17 true resid norm
>>>> 4.345955527842e+16 ||r(i)||/||b|| 8.308618624718e-01
>>>>  16 KSP preconditioned resid norm 4.126010760136e+16 true resid norm
>>>> 7.099883585094e+15 ||r(i)||/||b|| 1.357359149456e-01
>>>>  17 KSP preconditioned resid norm 2.161057719247e+16 true resid norm
>>>> 5.853862804145e+15 ||r(i)||/||b|| 1.119144298865e-01
>>>>  18 KSP preconditioned resid norm 1.411351808998e+16 true resid norm
>>>> 2.426558230375e+15 ||r(i)||/||b|| 4.639105664496e-02
>>>>  19 KSP preconditioned resid norm 1.083945264815e+16 true resid norm
>>>> 2.485250997240e+15 ||r(i)||/||b|| 4.751314777723e-02
>>>>  20 KSP preconditioned resid norm 9.014213050640e+15 true resid norm
>>>> 1.580604299892e+15 ||r(i)||/||b|| 3.021806882344e-02
>>>>  21 KSP preconditioned resid norm 7.767372671831e+15 true resid norm
>>>> 1.339058517057e+15 ||r(i)||/||b|| 2.560018496078e-02
>>>>  22 KSP preconditioned resid norm 6.894209717493e+15 true resid norm
>>>> 1.176401403286e+15 ||r(i)||/||b|| 2.249049845740e-02
>>>>  23 KSP preconditioned resid norm 6.197326579110e+15 true resid norm
>>>> 1.015741229888e+15 ||r(i)||/||b|| 1.941898955585e-02
>>>>  24 KSP preconditioned resid norm 5.635415722302e+15 true resid norm
>>>> 9.407688590092e+14 ||r(i)||/||b|| 1.798566417314e-02
>>>>  25 KSP preconditioned resid norm 5.240066189102e+15 true resid norm
>>>> 8.479712706847e+14 ||r(i)||/||b|| 1.621155542826e-02
>>>>  26 KSP preconditioned resid norm 5.077381341025e+15 true resid norm
>>>> 8.489262350542e+14 ||r(i)||/||b|| 1.622981248288e-02
>>>>  27 KSP preconditioned resid norm 4.908170126730e+15 true resid norm
>>>> 9.447288544322e+14 ||r(i)||/||b|| 1.806137155559e-02
>>>>  28 KSP preconditioned resid norm 4.807291179172e+15 true resid norm
>>>> 7.514342780137e+14 ||r(i)||/||b|| 1.436595657171e-02
>>>>  29 KSP preconditioned resid norm 4.874566711284e+15 true resid norm
>>>> 7.721244730622e+14 ||r(i)||/||b|| 1.476151271311e-02
>>>>  30 KSP preconditioned resid norm 5.131077173970e+15 true resid norm
>>>> 8.050523689285e+14 ||r(i)||/||b|| 1.539102980576e-02
>>>>  31 KSP preconditioned resid norm 5.679198106771e+15 true resid norm
>>>> 8.990076632730e+14 ||r(i)||/||b|| 1.718727162987e-02
>>>>  32 KSP preconditioned resid norm 8.479698883566e+15 true resid norm
>>>> 1.362468331537e+15 ||r(i)||/||b|| 2.604773491692e-02
>>>>  33 KSP preconditioned resid norm 1.652298710742e+16 true resid norm
>>>> 2.658951324175e+15 ||r(i)||/||b|| 5.083395895960e-02
>>>>  34 KSP preconditioned resid norm 3.352309602032e+16 true resid norm
>>>> 5.485872403557e+15 ||r(i)||/||b|| 1.048791717564e-01
>>>>  35 KSP preconditioned resid norm 6.378357733800e+15 true resid norm
>>>> 1.047516366293e+15 ||r(i)||/||b|| 2.002646813784e-02
>>>>  36 KSP preconditioned resid norm 3.388128874134e+15 true resid norm
>>>> 5.554504439336e+14 ||r(i)||/||b|| 1.061912823085e-02
>>>>  37 KSP preconditioned resid norm 2.152326148598e+15 true resid norm
>>>> 3.939853481438e+14 ||r(i)||/||b|| 7.532230784419e-03
>>>>  38 KSP preconditioned resid norm 1.818288964313e+15 true resid norm
>>>> 2.940442100180e+14 ||r(i)||/||b|| 5.621551311776e-03
>>>>  39 KSP preconditioned resid norm 1.660791920226e+15 true resid norm
>>>> 2.869955671543e+14 ||r(i)||/||b|| 5.486795019399e-03
>>>>  40 KSP preconditioned resid norm 1.530575944029e+15 true resid norm
>>>> 2.452126997689e+14 ||r(i)||/||b|| 4.687988156493e-03
>>>>  41 KSP preconditioned resid norm 1.370742276038e+15 true resid norm
>>>> 2.241019638220e+14 ||r(i)||/||b|| 4.284392094026e-03
>>>>  42 KSP preconditioned resid norm 1.242467362496e+15 true resid norm
>>>> 2.048557595739e+14 ||r(i)||/||b|| 3.916442238011e-03
>>>>  43 KSP preconditioned resid norm 1.151462192104e+15 true resid norm
>>>> 1.847175725318e+14 ||r(i)||/||b|| 3.531439412157e-03
>>>>  44 KSP preconditioned resid norm 1.085430472672e+15 true resid norm
>>>> 1.860586924987e+14 ||r(i)||/||b|| 3.557079008015e-03
>>>>  45 KSP preconditioned resid norm 1.036632239565e+15 true resid norm
>>>> 1.638613644087e+14 ||r(i)||/||b|| 3.132709424833e-03
>>>>  46 KSP preconditioned resid norm 1.028748911897e+15 true resid norm
>>>> 1.653234224458e+14 ||r(i)||/||b|| 3.160661120519e-03
>>>>  47 KSP preconditioned resid norm 9.769896259678e+14 true resid norm
>>>> 1.886232302190e+14 ||r(i)||/||b|| 3.606107963166e-03
>>>>  48 KSP preconditioned resid norm 1.056096824670e+15 true resid norm
>>>> 1.655410058571e+14 ||r(i)||/||b|| 3.164820890613e-03
>>>>  49 KSP preconditioned resid norm 7.777695958066e+14 true resid norm
>>>> 2.880991932726e+14 ||r(i)||/||b|| 5.507894196468e-03
>>>>  50 KSP preconditioned resid norm 1.009825961040e+15 true resid norm
>>>> 1.550789761056e+14 ||r(i)||/||b|| 2.964807303982e-03
>>>>  51 KSP preconditioned resid norm 9.471596692833e+14 true resid norm
>>>> 2.053798093618e+14 ||r(i)||/||b|| 3.926461046995e-03
>>>>  52 KSP preconditioned resid norm 8.991518749617e+14 true resid norm
>>>> 1.386233583178e+14 ||r(i)||/||b|| 2.650208013776e-03
>>>>  53 KSP preconditioned resid norm 7.186213371144e+13 true resid norm
>>>> 1.103090149144e+13 ||r(i)||/||b|| 2.108893038414e-04
>>>>   0 KSP preconditioned resid norm 6.542826642292e+18 true resid norm
>>>> 3.545903145424e+18 ||r(i)||/||b|| 4.156717341790e+02
>>>>   1 KSP preconditioned resid norm 1.591157510957e+18 true resid norm
>>>> 5.223152980213e+17 ||r(i)||/||b|| 6.122888776501e+01
>>>>   2 KSP preconditioned resid norm 6.570525108060e+17 true resid norm
>>>> 1.552502546069e+17 ||r(i)||/||b|| 1.819935286374e+01
>>>>   3 KSP preconditioned resid norm 4.165816250413e+17 true resid norm
>>>> 8.738489300540e+16 ||r(i)||/||b|| 1.024377387845e+01
>>>>   4 KSP preconditioned resid norm 2.995010683652e+17 true resid norm
>>>> 4.934680552583e+16 ||r(i)||/||b|| 5.784724339013e+00
>>>>   5 KSP preconditioned resid norm 2.594493782706e+17 true resid norm
>>>> 4.469794627497e+16 ||r(i)||/||b|| 5.239757568206e+00
>>>>   6 KSP preconditioned resid norm 2.219609972421e+17 true resid norm
>>>> 4.652118621437e+16 ||r(i)||/||b|| 5.453488535001e+00
>>>>   7 KSP preconditioned resid norm 1.674912012123e+17 true resid norm
>>>> 2.988815541157e+16 ||r(i)||/||b|| 3.503666310619e+00
>>>>   8 KSP preconditioned resid norm 1.081901407775e+17 true resid norm
>>>> 1.908145564246e+16 ||r(i)||/||b|| 2.236841062001e+00
>>>>   9 KSP preconditioned resid norm 5.710123690945e+16 true resid norm
>>>> 9.635193037737e+15 ||r(i)||/||b|| 1.129494302267e+00
>>>>  10 KSP preconditioned resid norm 1.779373863118e+16 true resid norm
>>>> 2.952490629534e+15 ||r(i)||/||b|| 3.461084101266e-01
>>>>  11 KSP preconditioned resid norm 1.125622359514e+16 true resid norm
>>>> 2.030418337832e+15 ||r(i)||/||b|| 2.380176437376e-01
>>>>  12 KSP preconditioned resid norm 1.086650353983e+16 true resid norm
>>>> 1.877894898988e+15 ||r(i)||/||b|| 2.201379443417e-01
>>>>  13 KSP preconditioned resid norm 1.075411372217e+16 true resid norm
>>>> 1.822725565845e+15 ||r(i)||/||b|| 2.136706688859e-01
>>>>  14 KSP preconditioned resid norm 1.173963298627e+16 true resid norm
>>>> 2.130483772307e+15 ||r(i)||/||b|| 2.497479056692e-01
>>>>  15 KSP preconditioned resid norm 4.943816039086e+16 true resid norm
>>>> 1.362098103563e+16 ||r(i)||/||b|| 1.596731939959e+00
>>>>  16 KSP preconditioned resid norm 1.779827523151e+17 true resid norm
>>>> 3.369509176778e+16 ||r(i)||/||b|| 3.949937901296e+00
>>>>  17 KSP preconditioned resid norm 3.250308535899e+16 true resid norm
>>>> 8.719651405683e+15 ||r(i)||/||b|| 1.022169098418e+00
>>>>  18 KSP preconditioned resid norm 2.074788387365e+16 true resid norm
>>>> 3.942900424212e+15 ||r(i)||/||b|| 4.622101027047e-01
>>>>  19 KSP preconditioned resid norm 1.482962263858e+16 true resid norm
>>>> 3.390403569469e+15 ||r(i)||/||b|| 3.974431543926e-01
>>>>  20 KSP preconditioned resid norm 1.133931148892e+16 true resid norm
>>>> 2.488262609273e+15 ||r(i)||/||b|| 2.916888565398e-01
>>>>  21 KSP preconditioned resid norm 8.550489811072e+15 true resid norm
>>>> 1.657275963132e+15 ||r(i)||/||b|| 1.942756881268e-01
>>>>  22 KSP preconditioned resid norm 6.584107021814e+15 true resid norm
>>>> 1.285719379545e+15 ||r(i)||/||b|| 1.507196283273e-01
>>>>  23 KSP preconditioned resid norm 4.778317630297e+15 true resid norm
>>>> 9.061620975056e+14 ||r(i)||/||b|| 1.062256793459e-01
>>>>  24 KSP preconditioned resid norm 3.026263700342e+15 true resid norm
>>>> 6.175894175717e+14 ||r(i)||/||b|| 7.239748342928e-02
>>>>  25 KSP preconditioned resid norm 1.568620488361e+15 true resid norm
>>>> 2.753144451691e+14 ||r(i)||/||b|| 3.227398723952e-02
>>>>  26 KSP preconditioned resid norm 1.178330886619e+15 true resid norm
>>>> 2.275547590347e+14 ||r(i)||/||b|| 2.667531442045e-02
>>>>  27 KSP preconditioned resid norm 1.073508363176e+15 true resid norm
>>>> 2.033900922703e+14 ||r(i)||/||b|| 2.384258929293e-02
>>>>  28 KSP preconditioned resid norm 1.011358091649e+15 true resid norm
>>>> 1.668017917552e+14 ||r(i)||/||b|| 1.955349235427e-02
>>>>  29 KSP preconditioned resid norm 9.448460925412e+14 true resid norm
>>>> 1.798337339042e+14 ||r(i)||/||b|| 2.108117367287e-02
>>>>  30 KSP preconditioned resid norm 8.970299972493e+14 true resid norm
>>>> 1.456018479256e+14 ||r(i)||/||b|| 1.706830958004e-02
>>>>  31 KSP preconditioned resid norm 8.656072021210e+14 true resid norm
>>>> 1.578084000747e+14 ||r(i)||/||b|| 1.849923380218e-02
>>>>  32 KSP preconditioned resid norm 8.314911059315e+14 true resid norm
>>>> 1.333543211106e+14 ||r(i)||/||b|| 1.563258206526e-02
>>>>  33 KSP preconditioned resid norm 8.004072124456e+14 true resid norm
>>>> 1.582598207144e+14 ||r(i)||/||b|| 1.855215199888e-02
>>>>  34 KSP preconditioned resid norm 7.705686923615e+14 true resid norm
>>>> 1.334906781329e+14 ||r(i)||/||b|| 1.564856664172e-02
>>>>  35 KSP preconditioned resid norm 7.648238175354e+14 true resid norm
>>>> 1.202157111000e+14 ||r(i)||/||b|| 1.409239650919e-02
>>>>  36 KSP preconditioned resid norm 7.709241111814e+14 true resid norm
>>>> 1.292601566237e+14 ||r(i)||/||b|| 1.515263989468e-02
>>>>  37 KSP preconditioned resid norm 8.026855071425e+14 true resid norm
>>>> 1.264132558814e+14 ||r(i)||/||b|| 1.481890935550e-02
>>>>  38 KSP preconditioned resid norm 8.397026301556e+14 true resid norm
>>>> 1.379015425365e+14 ||r(i)||/||b|| 1.616563424923e-02
>>>>  39 KSP preconditioned resid norm 8.772641473437e+14 true resid norm
>>>> 1.384855714837e+14 ||r(i)||/||b|| 1.623409757587e-02
>>>>  40 KSP preconditioned resid norm 9.403663540144e+14 true resid norm
>>>> 1.523096876425e+14 ||r(i)||/||b|| 1.785464221614e-02
>>>>  41 KSP preconditioned resid norm 1.191025293024e+15 true resid norm
>>>> 1.883988208054e+14 ||r(i)||/||b|| 2.208522380610e-02
>>>>  42 KSP preconditioned resid norm 2.105592809750e+15 true resid norm
>>>> 3.674437948704e+14 ||r(i)||/||b|| 4.307393438656e-02
>>>>  43 KSP preconditioned resid norm 1.653069974154e+16 true resid norm
>>>> 2.622043044873e+15 ||r(i)||/||b|| 3.073713902652e-01
>>>>  44 KSP preconditioned resid norm 1.224677806349e+15 true resid norm
>>>> 2.078786938958e+14 ||r(i)||/||b|| 2.436876971726e-02
>>>>  45 KSP preconditioned resid norm 6.142260967855e+14 true resid norm
>>>> 9.787693095074e+13 ||r(i)||/||b|| 1.147371260744e-02
>>>>  46 KSP preconditioned resid norm 4.190317366481e+14 true resid norm
>>>> 7.181248026289e+13 ||r(i)||/||b|| 8.418283574692e-03
>>>>  47 KSP preconditioned resid norm 2.851377922408e+14 true resid norm
>>>> 4.551212829362e+13 ||r(i)||/||b|| 5.335200798815e-03
>>>>  48 KSP preconditioned resid norm 1.874725496828e+14 true resid norm
>>>> 3.515118139860e+13 ||r(i)||/||b|| 4.120629337903e-03
>>>>  49 KSP preconditioned resid norm 1.260137969667e+14 true resid norm
>>>> 2.018341951104e+13 ||r(i)||/||b|| 2.366019782758e-03
>>>>  50 KSP preconditioned resid norm 8.902880553848e+13 true resid norm
>>>> 2.353973309483e+13 ||r(i)||/||b|| 2.759466707450e-03
>>>>  51 KSP preconditioned resid norm 6.273228119323e+13 true resid norm
>>>> 1.015825242680e+13 ||r(i)||/||b|| 1.190810416783e-03
>>>>  52 KSP preconditioned resid norm 4.428322011916e+13 true resid norm
>>>> 1.394037459429e+13 ||r(i)||/||b|| 1.634173141528e-03
>>>>   0 KSP preconditioned resid norm 1.892236961136e+19 true resid norm
>>>> 1.028105836629e+19 ||r(i)||/||b|| 7.839481546009e+01
>>>>   1 KSP preconditioned resid norm 4.580244542528e+18 true resid norm
>>>> 1.519483928522e+18 ||r(i)||/||b|| 1.158632291804e+01
>>>>   2 KSP preconditioned resid norm 1.874052673028e+18 true resid norm
>>>> 4.645668462025e+17 ||r(i)||/||b|| 3.542401071890e+00
>>>>   3 KSP preconditioned resid norm 1.172977406681e+18 true resid norm
>>>> 2.550460309107e+17 ||r(i)||/||b|| 1.944769284904e+00
>>>>   4 KSP preconditioned resid norm 8.299170411979e+17 true resid norm
>>>> 1.381052822672e+17 ||r(i)||/||b|| 1.053076223446e+00
>>>>   5 KSP preconditioned resid norm 7.051011041666e+17 true resid norm
>>>> 1.287511951247e+17 ||r(i)||/||b|| 9.817497209388e-01
>>>>   6 KSP preconditioned resid norm 5.862228682149e+17 true resid norm
>>>> 1.166604371743e+17 ||r(i)||/||b|| 8.895556389170e-01
>>>>   7 KSP preconditioned resid norm 4.329574557115e+17 true resid norm
>>>> 8.609505694316e+16 ||r(i)||/||b|| 6.564894255647e-01
>>>>   8 KSP preconditioned resid norm 2.701974155126e+17 true resid norm
>>>> 4.802624326608e+16 ||r(i)||/||b|| 3.662082583277e-01
>>>>   9 KSP preconditioned resid norm 1.546976756797e+17 true resid norm
>>>> 2.878555741954e+16 ||r(i)||/||b|| 2.194947622532e-01
>>>>  10 KSP preconditioned resid norm 9.916116392638e+16 true resid norm
>>>> 1.649766880508e+16 ||r(i)||/||b|| 1.257975254509e-01
>>>>  11 KSP preconditioned resid norm 9.248895040376e+16 true resid norm
>>>> 1.560136782751e+16 ||r(i)||/||b|| 1.189630783317e-01
>>>>  12 KSP preconditioned resid norm 9.251831545179e+16 true resid norm
>>>> 1.508056895396e+16 ||r(i)||/||b|| 1.149918985048e-01
>>>>  13 KSP preconditioned resid norm 7.096157383949e+16 true resid norm
>>>> 1.151221892162e+16 ||r(i)||/||b|| 8.778262370879e-02
>>>>  14 KSP preconditioned resid norm 2.017629866031e+17 true resid norm
>>>> 3.268014415733e+16 ||r(i)||/||b|| 2.491916473135e-01
>>>>  15 KSP preconditioned resid norm 1.669814416925e+16 true resid norm
>>>> 4.397468530146e+15 ||r(i)||/||b|| 3.353144410138e-02
>>>>  16 KSP preconditioned resid norm 1.171914014315e+16 true resid norm
>>>> 1.865370183430e+15 ||r(i)||/||b|| 1.422376433288e-02
>>>>  17 KSP preconditioned resid norm 1.021030261775e+16 true resid norm
>>>> 2.000923353135e+15 ||r(i)||/||b|| 1.525738026477e-02
>>>>  18 KSP preconditioned resid norm 9.416598060128e+15 true resid norm
>>>> 1.541246281727e+15 ||r(i)||/||b|| 1.175226455582e-02
>>>>  19 KSP preconditioned resid norm 8.821999311745e+15 true resid norm
>>>> 1.426601243635e+15 ||r(i)||/||b|| 1.087807667707e-02
>>>>  20 KSP preconditioned resid norm 8.323362047556e+15 true resid norm
>>>> 1.490210405686e+15 ||r(i)||/||b|| 1.136310733664e-02
>>>>  21 KSP preconditioned resid norm 7.861641988008e+15 true resid norm
>>>> 1.251748347072e+15 ||r(i)||/||b|| 9.544793655962e-03
>>>>  22 KSP preconditioned resid norm 7.464952525350e+15 true resid norm
>>>> 1.325467789570e+15 ||r(i)||/||b|| 1.010691692037e-02
>>>>  23 KSP preconditioned resid norm 7.139096535480e+15 true resid norm
>>>> 1.125905927178e+15 ||r(i)||/||b|| 8.585223839986e-03
>>>>  24 KSP preconditioned resid norm 5.858113828393e+15 true resid norm
>>>> 2.042448137714e+15 ||r(i)||/||b|| 1.557401379686e-02
>>>>  25 KSP preconditioned resid norm 5.027356938946e+15 true resid norm
>>>> 7.946522117539e+14 ||r(i)||/||b|| 6.059358022871e-03
>>>>  26 KSP preconditioned resid norm 5.122614017475e+15 true resid norm
>>>> 7.976827488389e+14 ||r(i)||/||b|| 6.082466382639e-03
>>>>  27 KSP preconditioned resid norm 5.425317067876e+15 true resid norm
>>>> 8.948524578548e+14 ||r(i)||/||b|| 6.823401910404e-03
>>>>  28 KSP preconditioned resid norm 9.316529191423e+15 true resid norm
>>>> 1.453760069771e+15 ||r(i)||/||b|| 1.108516733711e-02
>>>>  29 KSP preconditioned resid norm 9.523628080058e+15 true resid norm
>>>> 2.109739324167e+15 ||r(i)||/||b|| 1.608712051759e-02
>>>>  30 KSP preconditioned resid norm 2.300173794637e+15 true resid norm
>>>> 3.594261469430e+14 ||r(i)||/||b|| 2.740685390281e-03
>>>>  31 KSP preconditioned resid norm 1.385027169120e+15 true resid norm
>>>> 2.935564708865e+14 ||r(i)||/||b|| 2.238417927644e-03
>>>>  32 KSP preconditioned resid norm 9.719758142764e+14 true resid norm
>>>> 1.523176597454e+14 ||r(i)||/||b|| 1.161448014555e-03
>>>>  33 KSP preconditioned resid norm 8.580268959656e+14 true resid norm
>>>> 1.580637131624e+14 ||r(i)||/||b|| 1.205262647368e-03
>>>>   0 KSP preconditioned resid norm 6.470797769938e+18 true resid norm
>>>> 3.511548722307e+18 ||r(i)||/||b|| 1.662246831388e+02
>>>>   1 KSP preconditioned resid norm 1.571597715354e+18 true resid norm
>>>> 5.187477038218e+17 ||r(i)||/||b|| 2.455573865428e+01
>>>>   2 KSP preconditioned resid norm 6.468337546861e+17 true resid norm
>>>> 1.566996108585e+17 ||r(i)||/||b|| 7.417622599812e+00
>>>>   3 KSP preconditioned resid norm 4.084044703454e+17 true resid norm
>>>> 8.688412887362e+16 ||r(i)||/||b|| 4.112796926342e+00
>>>>   4 KSP preconditioned resid norm 2.920894102259e+17 true resid norm
>>>> 4.831956260441e+16 ||r(i)||/||b|| 2.287282512214e+00
>>>>   5 KSP preconditioned resid norm 2.515869150351e+17 true resid norm
>>>> 4.435569840236e+16 ||r(i)||/||b|| 2.099646764259e+00
>>>>   6 KSP preconditioned resid norm 2.133085363553e+17 true resid norm
>>>> 4.355632900946e+16 ||r(i)||/||b|| 2.061807356479e+00
>>>>   7 KSP preconditioned resid norm 1.601295664581e+17 true resid norm
>>>> 2.999352167191e+16 ||r(i)||/||b|| 1.419790534148e+00
>>>>   8 KSP preconditioned resid norm 1.019894513782e+17 true resid norm
>>>> 1.811122934468e+16 ||r(i)||/||b|| 8.573235336161e-01
>>>>   9 KSP preconditioned resid norm 5.552366492146e+16 true resid norm
>>>> 9.849650352808e+15 ||r(i)||/||b|| 4.662486949199e-01
>>>>  10 KSP preconditioned resid norm 2.614329828139e+16 true resid norm
>>>> 4.400937150634e+15 ||r(i)||/||b|| 2.083252835795e-01
>>>>  11 KSP preconditioned resid norm 2.230447954838e+16 true resid norm
>>>> 4.002038016135e+15 ||r(i)||/||b|| 1.894427654999e-01
>>>>  12 KSP preconditioned resid norm 2.202888172936e+16 true resid norm
>>>> 3.669015023581e+15 ||r(i)||/||b|| 1.736785982356e-01
>>>>  13 KSP preconditioned resid norm 2.171444770780e+16 true resid norm
>>>> 3.746639147837e+15 ||r(i)||/||b|| 1.773530582755e-01
>>>>  14 KSP preconditioned resid norm 2.756620760322e+16 true resid norm
>>>> 4.738417417687e+15 ||r(i)||/||b|| 2.243004429444e-01
>>>>  15 KSP preconditioned resid norm 1.911455835947e+16 true resid norm
>>>> 7.274462982878e+15 ||r(i)||/||b|| 3.443481494796e-01
>>>>  16 KSP preconditioned resid norm 8.270124664006e+15 true resid norm
>>>> 1.450957167614e+15 ||r(i)||/||b|| 6.868334017480e-02
>>>>  17 KSP preconditioned resid norm 5.454864800054e+15 true resid norm
>>>> 1.779587764442e+15 ||r(i)||/||b|| 8.423958647728e-02
>>>>  18 KSP preconditioned resid norm 4.188178169772e+15 true resid norm
>>>> 7.356207570842e+14 ||r(i)||/||b|| 3.482176581514e-02
>>>>  19 KSP preconditioned resid norm 3.485885419242e+15 true resid norm
>>>> 7.684000525717e+14 ||r(i)||/||b|| 3.637342533543e-02
>>>>  20 KSP preconditioned resid norm 3.031526098420e+15 true resid norm
>>>> 5.668894180734e+14 ||r(i)||/||b|| 2.683460243492e-02
>>>>  21 KSP preconditioned resid norm 2.653824581081e+15 true resid norm
>>>> 5.337896513987e+14 ||r(i)||/||b|| 2.526777290683e-02
>>>>  22 KSP preconditioned resid norm 2.412624108418e+15 true resid norm
>>>> 3.917881686680e+14 ||r(i)||/||b|| 1.854590932504e-02
>>>>  23 KSP preconditioned resid norm 2.249293018506e+15 true resid norm
>>>> 3.520070992955e+14 ||r(i)||/||b|| 1.666280982271e-02
>>>>  24 KSP preconditioned resid norm 2.107969657718e+15 true resid norm
>>>> 3.433991961929e+14 ||r(i)||/||b|| 1.625534118740e-02
>>>>  25 KSP preconditioned resid norm 1.995899579616e+15 true resid norm
>>>> 3.124097002184e+14 ||r(i)||/||b|| 1.478840464277e-02
>>>>  26 KSP preconditioned resid norm 1.940326192847e+15 true resid norm
>>>> 3.197343858652e+14 ||r(i)||/||b|| 1.513513016106e-02
>>>>  27 KSP preconditioned resid norm 1.843618399864e+15 true resid norm
>>>> 4.284525431489e+14 ||r(i)||/||b|| 2.028147517148e-02
>>>>  28 KSP preconditioned resid norm 1.800569430365e+15 true resid norm
>>>> 2.810328443449e+14 ||r(i)||/||b|| 1.330313180793e-02
>>>>  29 KSP preconditioned resid norm 1.911265522964e+15 true resid norm
>>>> 3.078500227429e+14 ||r(i)||/||b|| 1.457256513619e-02
>>>>  30 KSP preconditioned resid norm 2.245578740852e+15 true resid norm
>>>> 3.522723048093e+14 ||r(i)||/||b|| 1.667536374293e-02
>>>>  31 KSP preconditioned resid norm 3.129444954320e+15 true resid norm
>>>> 5.056459987900e+14 ||r(i)||/||b|| 2.393554883500e-02
>>>>  32 KSP preconditioned resid norm 2.268235755551e+16 true resid norm
>>>> 3.663405821329e+15 ||r(i)||/||b|| 1.734130778226e-01
>>>>  33 KSP preconditioned resid norm 2.666354866266e+15 true resid norm
>>>> 4.420681584183e+14 ||r(i)||/||b|| 2.092599174035e-02
>>>>  34 KSP preconditioned resid norm 1.195729215971e+15 true resid norm
>>>> 1.967322086000e+14 ||r(i)||/||b|| 9.312628593187e-03
>>>>  35 KSP preconditioned resid norm 7.390918117697e+14 true resid norm
>>>> 1.247185996576e+14 ||r(i)||/||b|| 5.903751122089e-03
>>>>  36 KSP preconditioned resid norm 5.589675490221e+14 true resid norm
>>>> 9.067132579829e+13 ||r(i)||/||b|| 4.292069850790e-03
>>>>  37 KSP preconditioned resid norm 4.470335591004e+14 true resid norm
>>>> 9.109636100840e+13 ||r(i)||/||b|| 4.312189561126e-03
>>>>  38 KSP preconditioned resid norm 4.031608678043e+14 true resid norm
>>>> 6.399106058589e+13 ||r(i)||/||b|| 3.029117523568e-03
>>>>  39 KSP preconditioned resid norm 3.769205171045e+14 true resid norm
>>>> 7.200688789282e+13 ||r(i)||/||b|| 3.408559319641e-03
>>>>  40 KSP preconditioned resid norm 3.535103364248e+14 true resid norm
>>>> 5.569365215364e+13 ||r(i)||/||b|| 2.636346641945e-03
>>>>  41 KSP preconditioned resid norm 3.299087996116e+14 true resid norm
>>>> 5.691184302265e+13 ||r(i)||/||b|| 2.694011623187e-03
>>>>  42 KSP preconditioned resid norm 3.102396074559e+14 true resid norm
>>>> 5.072539063269e+13 ||r(i)||/||b|| 2.401166166782e-03
>>>>  43 KSP preconditioned resid norm 2.923631153501e+14 true resid norm
>>>> 5.690604160219e+13 ||r(i)||/||b|| 2.693737003823e-03
>>>>  44 KSP preconditioned resid norm 2.831787236990e+14 true resid norm
>>>> 4.398532156025e+13 ||r(i)||/||b|| 2.082114393761e-03
>>>>  45 KSP preconditioned resid norm 2.880585984465e+14 true resid norm
>>>> 4.666639157225e+13 ||r(i)||/||b|| 2.209027060639e-03
>>>>  46 KSP preconditioned resid norm 3.054400711070e+14 true resid norm
>>>> 4.771426500640e+13 ||r(i)||/||b|| 2.258629798159e-03
>>>>  47 KSP preconditioned resid norm 3.761477931303e+14 true resid norm
>>>> 5.957625439087e+13 ||r(i)||/||b|| 2.820135726954e-03
>>>>  48 KSP preconditioned resid norm 9.608784364697e+14 true resid norm
>>>> 1.580857575603e+14 ||r(i)||/||b|| 7.483238034628e-03
>>>>  49 KSP preconditioned resid norm 1.902148260101e+15 true resid norm
>>>> 2.982038509627e+14 ||r(i)||/||b|| 1.411594841961e-02
>>>>  50 KSP preconditioned resid norm 2.165055327372e+14 true resid norm
>>>> 4.058692191960e+13 ||r(i)||/||b|| 1.921245800409e-03
>>>>  51 KSP preconditioned resid norm 2.195213865618e+14 true resid norm
>>>> 3.429224338721e+13 ||r(i)||/||b|| 1.623277289290e-03
>>>>  52 KSP preconditioned resid norm 1.864119738188e+14 true resid norm
>>>> 5.012858400476e+13 ||r(i)||/||b|| 2.372915386152e-03
>>>>  53 KSP preconditioned resid norm 2.971924491921e+13 true resid norm
>>>> 4.598158953060e+12 ||r(i)||/||b|| 2.176610878666e-04
>>>>   0 KSP preconditioned resid norm 6.694681472101e+18 true resid norm
>>>> 3.650754008704e+18 ||r(i)||/||b|| 5.229798534711e+00
>>>>   1 KSP preconditioned resid norm 1.597667311920e+18 true resid norm
>>>> 5.366749653247e+17 ||r(i)||/||b|| 7.688006205237e-01
>>>>   2 KSP preconditioned resid norm 6.300446691769e+17 true resid norm
>>>> 1.705328302298e+17 ||r(i)||/||b|| 2.442926429799e-01
>>>>   3 KSP preconditioned resid norm 3.642174434692e+17 true resid norm
>>>> 9.481577406412e+16 ||r(i)||/||b|| 1.358260225383e-01
>>>>   4 KSP preconditioned resid norm 2.247332932327e+17 true resid norm
>>>> 3.802800659066e+16 ||r(i)||/||b|| 5.447609251997e-02
>>>>   5 KSP preconditioned resid norm 1.557523729879e+17 true resid norm
>>>> 3.829141784861e+16 ||r(i)||/||b|| 5.485343588727e-02
>>>>   6 KSP preconditioned resid norm 1.004692897232e+17 true resid norm
>>>> 1.699728149080e+16 ||r(i)||/||b|| 2.434904067015e-02
>>>>   7 KSP preconditioned resid norm 7.103483293598e+16 true resid norm
>>>> 1.472858902835e+16 ||r(i)||/||b|| 2.109908066531e-02
>>>>   8 KSP preconditioned resid norm 5.766848376574e+16 true resid norm
>>>> 9.397954931890e+15 ||r(i)||/||b|| 1.346281091931e-02
>>>>   9 KSP preconditioned resid norm 4.523472389397e+16 true resid norm
>>>> 1.246375028587e+16 ||r(i)||/||b|| 1.785464121292e-02
>>>>  10 KSP preconditioned resid norm 3.195342596604e+16 true resid norm
>>>> 5.030521805863e+15 ||r(i)||/||b|| 7.206351210301e-03
>>>>  11 KSP preconditioned resid norm 2.437460193025e+16 true resid norm
>>>> 4.974645265358e+15 ||r(i)||/||b|| 7.126306636231e-03
>>>>  12 KSP preconditioned resid norm 1.258045317564e+16 true resid norm
>>>> 1.885909944349e+15 ||r(i)||/||b|| 2.701614252848e-03
>>>>  13 KSP preconditioned resid norm 2.495567071066e+15 true resid norm
>>>> 4.460991862355e+14 ||r(i)||/||b|| 6.390484992820e-04
>>>>  14 KSP preconditioned resid norm 7.678105595258e+14 true resid norm
>>>> 1.316278119117e+14 ||r(i)||/||b|| 1.885602087190e-04
>>>>  15 KSP preconditioned resid norm 5.950875767888e+14 true resid norm
>>>> 1.439411571316e+14 ||r(i)||/||b|| 2.061993908263e-04
>>>>  16 KSP preconditioned resid norm 3.263039815738e+14 true resid norm
>>>> 5.046549667518e+13 ||r(i)||/||b|| 7.229311532250e-05
>>>>  17 KSP preconditioned resid norm 1.436785883111e+14 true resid norm
>>>> 7.588987254543e+13 ||r(i)||/||b|| 1.087141843277e-04
>>>>  18 KSP preconditioned resid norm 5.401544347363e+13 true resid norm
>>>> 8.625334293000e+12 ||r(i)||/||b|| 1.235601208391e-05
>>>>  19 KSP preconditioned resid norm 3.528863285477e+13 true resid norm
>>>> 1.233589079533e+13 ||r(i)||/||b|| 1.767147922099e-05
>>>>   0 KSP preconditioned resid norm 4.827871909881e+18 true resid norm
>>>> 2.629048338874e+18 ||r(i)||/||b|| 2.387243403092e+01
>>>>   1 KSP preconditioned resid norm 1.161059375885e+18 true resid norm
>>>> 3.885115498370e+17 ||r(i)||/||b|| 3.527784638492e+00
>>>>   2 KSP preconditioned resid norm 4.696929326234e+17 true resid norm
>>>> 1.228954029189e+17 ||r(i)||/||b|| 1.115921816843e+00
>>>>   3 KSP preconditioned resid norm 2.870100194440e+17 true resid norm
>>>> 6.759377089469e+16 ||r(i)||/||b|| 6.137687971441e-01
>>>>   4 KSP preconditioned resid norm 1.966638027618e+17 true resid norm
>>>> 3.310588396768e+16 ||r(i)||/||b|| 3.006099276942e-01
>>>>   5 KSP preconditioned resid norm 1.592573327953e+17 true resid norm
>>>> 3.239413757211e+16 ||r(i)||/||b|| 2.941470876529e-01
>>>>   6 KSP preconditioned resid norm 1.230114084345e+17 true resid norm
>>>> 2.280735920899e+16 ||r(i)||/||b|| 2.070966783247e-01
>>>>   7 KSP preconditioned resid norm 8.598639005636e+16 true resid norm
>>>> 1.938027655308e+16 ||r(i)||/||b|| 1.759778877677e-01
>>>>   8 KSP preconditioned resid norm 5.549090128976e+16 true resid norm
>>>> 9.386098364471e+15 ||r(i)||/||b|| 8.522818340779e-02
>>>>   9 KSP preconditioned resid norm 4.474765035679e+16 true resid norm
>>>> 7.579175521646e+15 ||r(i)||/||b|| 6.882085999480e-02
>>>>  10 KSP preconditioned resid norm 4.378403606928e+16 true resid norm
>>>> 6.842614495131e+15 ||r(i)||/||b|| 6.213269673237e-02
>>>>  11 KSP preconditioned resid norm 4.079517449398e+16 true resid norm
>>>> 7.704845808673e+15 ||r(i)||/||b|| 6.996197847191e-02
>>>>  12 KSP preconditioned resid norm 4.084405622719e+16 true resid norm
>>>> 6.377952548774e+15 ||r(i)||/||b|| 5.791344693880e-02
>>>>  13 KSP preconditioned resid norm 7.523868588173e+16 true resid norm
>>>> 1.132249240798e+16 ||r(i)||/||b|| 1.028111385699e-01
>>>>  14 KSP preconditioned resid norm 2.184581375390e+15 true resid norm
>>>> 3.502138477296e+14 ||r(i)||/||b|| 3.180031668881e-03
>>>>  15 KSP preconditioned resid norm 2.222269400035e+15 true resid norm
>>>> 3.654767263686e+14 ||r(i)||/||b|| 3.318622526282e-03
>>>>  16 KSP preconditioned resid norm 1.669508240008e+15 true resid norm
>>>> 3.629680148217e+14 ||r(i)||/||b|| 3.295842781223e-03
>>>>  17 KSP preconditioned resid norm 1.401913603747e+15 true resid norm
>>>> 2.161155966391e+14 ||r(i)||/||b|| 1.962385113858e-03
>>>>  18 KSP preconditioned resid norm 1.134372518022e+15 true resid norm
>>>> 2.686701598571e+14 ||r(i)||/||b|| 2.439594043376e-03
>>>>  19 KSP preconditioned resid norm 9.057728167563e+14 true resid norm
>>>> 1.409896456102e+14 ||r(i)||/||b|| 1.280222186904e-03
>>>>  20 KSP preconditioned resid norm 7.989861774441e+14 true resid norm
>>>> 1.659027150307e+14 ||r(i)||/||b|| 1.506439254676e-03
>>>>  21 KSP preconditioned resid norm 7.119014585200e+14 true resid norm
>>>> 1.092105820565e+14 ||r(i)||/||b|| 9.916601292842e-04
>>>>  22 KSP preconditioned resid norm 6.306860453827e+14 true resid norm
>>>> 1.460692513610e+14 ||r(i)||/||b|| 1.326346311515e-03
>>>>  23 KSP preconditioned resid norm 5.637172379886e+14 true resid norm
>>>> 8.672554380666e+13 ||r(i)||/||b|| 7.874902080372e-04
>>>>  24 KSP preconditioned resid norm 4.961067656606e+14 true resid norm
>>>> 1.292132364829e+14 ||r(i)||/||b|| 1.173289367962e-03
>>>>  25 KSP preconditioned resid norm 4.386188245672e+14 true resid norm
>>>> 8.044020700160e+13 ||r(i)||/||b|| 7.304177358342e-04
>>>>  26 KSP preconditioned resid norm 4.419078090293e+14 true resid norm
>>>> 6.703649620362e+13 ||r(i)||/||b|| 6.087085998464e-04
>>>>  27 KSP preconditioned resid norm 4.436677280477e+14 true resid norm
>>>> 1.368871842229e+14 ||r(i)||/||b|| 1.242970784036e-03
>>>>  28 KSP preconditioned resid norm 7.847692003240e+14 true resid norm
>>>> 1.196853324186e+14 ||r(i)||/||b|| 1.086773552386e-03
>>>>  29 KSP preconditioned resid norm 1.771704167839e+15 true resid norm
>>>> 6.548256652554e+14 ||r(i)||/||b|| 5.945985193355e-03
>>>>  30 KSP preconditioned resid norm 1.053899282998e+15 true resid norm
>>>> 1.880673778730e+14 ||r(i)||/||b|| 1.707700084953e-03
>>>>  31 KSP preconditioned resid norm 2.462670432282e+14 true resid norm
>>>> 3.919805233311e+13 ||r(i)||/||b|| 3.559283808617e-04
>>>>  32 KSP preconditioned resid norm 1.093017734594e+14 true resid norm
>>>> 1.903326631551e+13 ||r(i)||/||b|| 1.728269457018e-04
>>>>  33 KSP preconditioned resid norm 6.432042300545e+13 true resid norm
>>>> 1.002471721316e+13 ||r(i)||/||b|| 9.102700654495e-05
>>>>  34 KSP preconditioned resid norm 3.805689715853e+13 true resid norm
>>>> 7.047382673791e+12 ||r(i)||/||b|| 6.399204437707e-05
>>>>  35 KSP preconditioned resid norm 2.527168724251e+13 true resid norm
>>>> 4.009865388649e+12 ||r(i)||/||b|| 3.641060742320e-05
>>>>  36 KSP preconditioned resid norm 1.580947387777e+13 true resid norm
>>>> 2.531811988645e+12 ||r(i)||/||b|| 2.298950300149e-05
>>>>  37 KSP preconditioned resid norm 1.075548264218e+13 true resid norm
>>>> 1.788042513750e+12 ||r(i)||/||b|| 1.623588517670e-05
>>>>  38 KSP preconditioned resid norm 6.581274433602e+12 true resid norm
>>>> 1.035380330637e+12 ||r(i)||/||b|| 9.401519277742e-06
>>>>   0 KSP preconditioned resid norm 9.555736051823e+15 true resid norm
>>>> 5.892741751019e+15 ||r(i)||/||b|| 1.119235791581e-01
>>>>   1 KSP preconditioned resid norm 4.575036500991e+15 true resid norm
>>>> 8.101073993664e+14 ||r(i)||/||b|| 1.538674584270e-02
>>>>   2 KSP preconditioned resid norm 3.765161451471e+15 true resid norm
>>>> 6.105904357791e+14 ||r(i)||/||b|| 1.159722754867e-02
>>>>   3 KSP preconditioned resid norm 3.685525899039e+15 true resid norm
>>>> 6.160361102521e+14 ||r(i)||/||b|| 1.170065977151e-02
>>>>   4 KSP preconditioned resid norm 3.856425370708e+15 true resid norm
>>>> 6.278594964367e+14 ||r(i)||/||b|| 1.192522683307e-02
>>>>   5 KSP preconditioned resid norm 4.281981871434e+15 true resid norm
>>>> 6.756473177150e+14 ||r(i)||/||b|| 1.283288310305e-02
>>>>   6 KSP preconditioned resid norm 5.205822014832e+15 true resid norm
>>>> 7.760311477213e+14 ||r(i)||/||b|| 1.473951977891e-02
>>>>   7 KSP preconditioned resid norm 6.471690051175e+15 true resid norm
>>>> 1.171341036231e+15 ||r(i)||/||b|| 2.224782397211e-02
>>>>   8 KSP preconditioned resid norm 7.016914241690e+15 true resid norm
>>>> 1.103022939349e+15 ||r(i)||/||b|| 2.095022664859e-02
>>>>   9 KSP preconditioned resid norm 7.025590013206e+15 true resid norm
>>>> 1.330551872513e+15 ||r(i)||/||b|| 2.527178928238e-02
>>>>  10 KSP preconditioned resid norm 6.405136813848e+15 true resid norm
>>>> 1.017867183616e+15 ||r(i)||/||b|| 1.933282385541e-02
>>>>  11 KSP preconditioned resid norm 4.854020251396e+15 true resid norm
>>>> 8.473369029366e+14 ||r(i)||/||b|| 1.609386308386e-02
>>>>  12 KSP preconditioned resid norm 2.353499572340e+15 true resid norm
>>>> 3.616493792413e+14 ||r(i)||/||b|| 6.868974517339e-03
>>>>  13 KSP preconditioned resid norm 1.176204335431e+15 true resid norm
>>>> 2.390307465685e+14 ||r(i)||/||b|| 4.540021914275e-03
>>>>  14 KSP preconditioned resid norm 1.050288991204e+15 true resid norm
>>>> 1.923001174300e+14 ||r(i)||/||b|| 3.652445385304e-03
>>>>  15 KSP preconditioned resid norm 9.850224343838e+14 true resid norm
>>>> 1.772358652449e+14 ||r(i)||/||b|| 3.366323051568e-03
>>>>  16 KSP preconditioned resid norm 8.835883676210e+14 true resid norm
>>>> 1.426145250921e+14 ||r(i)||/||b|| 2.708743868757e-03
>>>>  17 KSP preconditioned resid norm 7.483591829964e+14 true resid norm
>>>> 1.680673516819e+14 ||r(i)||/||b|| 3.192181217957e-03
>>>>  18 KSP preconditioned resid norm 6.652269160454e+14 true resid norm
>>>> 1.088301440117e+14 ||r(i)||/||b|| 2.067061438079e-03
>>>>  19 KSP preconditioned resid norm 5.777832230782e+14 true resid norm
>>>> 9.220881620683e+13 ||r(i)||/||b|| 1.751364844390e-03
>>>>  20 KSP preconditioned resid norm 5.145663259773e+14 true resid norm
>>>> 8.255284700142e+13 ||r(i)||/||b|| 1.567964539511e-03
>>>>  21 KSP preconditioned resid norm 4.536494497263e+14 true resid norm
>>>> 7.162151119367e+13 ||r(i)||/||b|| 1.360340604800e-03
>>>>  22 KSP preconditioned resid norm 4.039727797390e+14 true resid norm
>>>> 6.757078541538e+13 ||r(i)||/||b|| 1.283403289972e-03
>>>>  23 KSP preconditioned resid norm 3.668438626905e+14 true resid norm
>>>> 5.700238490686e+13 ||r(i)||/||b|| 1.082672753854e-03
>>>>  24 KSP preconditioned resid norm 3.368796010179e+14 true resid norm
>>>> 6.388426371627e+13 ||r(i)||/||b|| 1.213383472264e-03
>>>>   0 KSP preconditioned resid norm 9.591788600089e+15 true resid norm
>>>> 5.932754803820e+15 ||r(i)||/||b|| 5.703607413375e-01
>>>>   1 KSP preconditioned resid norm 4.627577110935e+15 true resid norm
>>>> 8.119149369849e+14 ||r(i)||/||b|| 7.805554429176e-02
>>>>   2 KSP preconditioned resid norm 3.843546862524e+15 true resid norm
>>>> 6.215691855461e+14 ||r(i)||/||b|| 5.975616272433e-02
>>>>   3 KSP preconditioned resid norm 3.802220665831e+15 true resid norm
>>>> 6.332285028379e+14 ||r(i)||/||b|| 6.087706137495e-02
>>>>   4 KSP preconditioned resid norm 4.025305304206e+15 true resid norm
>>>> 6.486950645643e+14 ||r(i)||/||b|| 6.236397932519e-02
>>>>   5 KSP preconditioned resid norm 4.519185013022e+15 true resid norm
>>>> 7.100155628952e+14 ||r(i)||/||b|| 6.825918417416e-02
>>>>   6 KSP preconditioned resid norm 5.566187938033e+15 true resid norm
>>>> 8.272878114077e+14 ||r(i)||/||b|| 7.953345537054e-02
>>>>   7 KSP preconditioned resid norm 7.046115999320e+15 true resid norm
>>>> 1.260178524183e+15 ||r(i)||/||b|| 1.211505246783e-01
>>>>   8 KSP preconditioned resid norm 7.802424274220e+15 true resid norm
>>>> 1.227649475790e+15 ||r(i)||/||b|| 1.180232604022e-01
>>>>   9 KSP preconditioned resid norm 8.076065684234e+15 true resid norm
>>>> 1.496448814554e+15 ||r(i)||/||b|| 1.438649806820e-01
>>>>  10 KSP preconditioned resid norm 7.812303545308e+15 true resid norm
>>>> 1.236539634992e+15 ||r(i)||/||b|| 1.188779388714e-01
>>>>  11 KSP preconditioned resid norm 6.692698687119e+15 true resid norm
>>>> 1.122795851888e+15 ||r(i)||/||b|| 1.079428858312e-01
>>>>  12 KSP preconditioned resid norm 4.016544769049e+15 true resid norm
>>>> 6.096078457742e+14 ||r(i)||/||b|| 5.860622836074e-02
>>>>  13 KSP preconditioned resid norm 1.711147574309e+15 true resid norm
>>>> 2.966258404639e+14 ||r(i)||/||b|| 2.851689305581e-02
>>>>  14 KSP preconditioned resid norm 1.304839987953e+15 true resid norm
>>>> 2.700754536307e+14 ||r(i)||/||b|| 2.596440288593e-02
>>>>  15 KSP preconditioned resid norm 1.171070442303e+15 true resid norm
>>>> 2.199042966295e+14 ||r(i)||/||b|| 2.114106882828e-02
>>>>  16 KSP preconditioned resid norm 1.057836577493e+15 true resid norm
>>>> 1.660135728859e+14 ||r(i)||/||b|| 1.596014459292e-02
>>>>  17 KSP preconditioned resid norm 8.905346433993e+14 true resid norm
>>>> 1.613310037432e+14 ||r(i)||/||b|| 1.550997368650e-02
>>>>  18 KSP preconditioned resid norm 7.864866777768e+14 true resid norm
>>>> 1.268576094498e+14 ||r(i)||/||b|| 1.219578468395e-02
>>>>  19 KSP preconditioned resid norm 6.743846682412e+14 true resid norm
>>>> 1.066594941052e+14 ||r(i)||/||b|| 1.025398657793e-02
>>>>  20 KSP preconditioned resid norm 5.775523980161e+14 true resid norm
>>>> 1.005326356082e+14 ||r(i)||/||b|| 9.664965175573e-03
>>>>  21 KSP preconditioned resid norm 4.897344092103e+14 true resid norm
>>>> 7.691922473584e+13 ||r(i)||/||b|| 7.394828792721e-03
>>>>  22 KSP preconditioned resid norm 4.026909639422e+14 true resid norm
>>>> 7.643768412999e+13 ||r(i)||/||b|| 7.348534640001e-03
>>>>  23 KSP preconditioned resid norm 3.340361168756e+14 true resid norm
>>>> 5.217079213762e+13 ||r(i)||/||b|| 5.015574157998e-03
>>>>  24 KSP preconditioned resid norm 2.772587883161e+14 true resid norm
>>>> 6.149190087025e+13 ||r(i)||/||b|| 5.911683075799e-03
>>>>  25 KSP preconditioned resid norm 2.446809593449e+14 true resid norm
>>>> 3.772191549633e+13 ||r(i)||/||b|| 3.626493997916e-03
>>>>  26 KSP preconditioned resid norm 2.130893101456e+14 true resid norm
>>>> 5.402695231969e+13 ||r(i)||/||b|| 5.194020922190e-03
>>>>  27 KSP preconditioned resid norm 1.886821885223e+14 true resid norm
>>>> 2.887742158299e+13 ||r(i)||/||b|| 2.776205679591e-03
>>>>  28 KSP preconditioned resid norm 1.654479962436e+14 true resid norm
>>>> 4.199650238007e+13 ||r(i)||/||b|| 4.037442473714e-03
>>>>  29 KSP preconditioned resid norm 1.453563006355e+14 true resid norm
>>>> 2.222396036725e+13 ||r(i)||/||b|| 2.136557961634e-03
>>>>  30 KSP preconditioned resid norm 1.311692747504e+14 true resid norm
>>>> 2.933890714503e+13 ||r(i)||/||b|| 2.820571788757e-03
>>>>  31 KSP preconditioned resid norm 1.173199137783e+14 true resid norm
>>>> 1.793346595553e+13 ||r(i)||/||b|| 1.724080174451e-03
>>>>  32 KSP preconditioned resid norm 1.086053135569e+14 true resid norm
>>>> 2.009773461598e+13 ||r(i)||/||b|| 1.932147744820e-03
>>>>  33 KSP preconditioned resid norm 9.929347161574e+13 true resid norm
>>>> 1.516318812509e+13 ||r(i)||/||b|| 1.457752343733e-03
>>>>  34 KSP preconditioned resid norm 9.235712158960e+13 true resid norm
>>>> 1.538423395802e+13 ||r(i)||/||b|| 1.479003157109e-03
>>>>  35 KSP preconditioned resid norm 8.718922541063e+13 true resid norm
>>>> 1.331044977413e+13 ||r(i)||/||b|| 1.279634546134e-03
>>>>  36 KSP preconditioned resid norm 8.163106494702e+13 true resid norm
>>>> 1.369060193385e+13 ||r(i)||/||b|| 1.316181458118e-03
>>>>  37 KSP preconditioned resid norm 7.751439049037e+13 true resid norm
>>>> 1.182966275510e+13 ||r(i)||/||b|| 1.137275252708e-03
>>>>  38 KSP preconditioned resid norm 7.269591005999e+13 true resid norm
>>>> 1.225102361382e+13 ||r(i)||/||b|| 1.177783869649e-03
>>>>  39 KSP preconditioned resid norm 6.809139852739e+13 true resid norm
>>>> 1.039056641301e+13 ||r(i)||/||b|| 9.989240004362e-04
>>>>  40 KSP preconditioned resid norm 6.390023598760e+13 true resid norm
>>>> 1.042637257280e+13 ||r(i)||/||b|| 1.002366318301e-03
>>>>  41 KSP preconditioned resid norm 5.919860950635e+13 true resid norm
>>>> 9.048648521202e+12 ||r(i)||/||b|| 8.699152500509e-04
>>>>  42 KSP preconditioned resid norm 5.538975217584e+13 true resid norm
>>>> 8.775858022438e+12 ||r(i)||/||b|| 8.436898292725e-04
>>>>   0 KSP preconditioned resid norm 2.200871087933e+16 true resid norm
>>>> 1.375121498750e+16 ||r(i)||/||b|| 1.042688751858e-01
>>>>   1 KSP preconditioned resid norm 1.033852082172e+16 true resid norm
>>>> 1.769345381246e+15 ||r(i)||/||b|| 1.341609835098e-02
>>>>   2 KSP preconditioned resid norm 8.201114088620e+15 true resid norm
>>>> 1.330146487456e+15 ||r(i)||/||b|| 1.008586355500e-02
>>>>   3 KSP preconditioned resid norm 7.727276364323e+15 true resid norm
>>>> 1.292967289192e+15 ||r(i)||/||b|| 9.803951506731e-03
>>>>   4 KSP preconditioned resid norm 7.788308934018e+15 true resid norm
>>>> 1.241309862269e+15 ||r(i)||/||b|| 9.412257986909e-03
>>>>   5 KSP preconditioned resid norm 8.253685478294e+15 true resid norm
>>>> 1.290166199902e+15 ||r(i)||/||b|| 9.782712188615e-03
>>>>   6 KSP preconditioned resid norm 9.476714658211e+15 true resid norm
>>>> 1.410015893632e+15 ||r(i)||/||b|| 1.069147499743e-02
>>>>   7 KSP preconditioned resid norm 1.110541369388e+16 true resid norm
>>>> 1.990482855418e+15 ||r(i)||/||b|| 1.509287787295e-02
>>>>   8 KSP preconditioned resid norm 1.149682905149e+16 true resid norm
>>>> 1.789313061240e+15 ||r(i)||/||b|| 1.356750370206e-02
>>>>   9 KSP preconditioned resid norm 1.081618830942e+16 true resid norm
>>>> 1.972959789140e+15 ||r(i)||/||b|| 1.496000885648e-02
>>>>  10 KSP preconditioned resid norm 8.800226542664e+15 true resid norm
>>>> 1.343393349540e+15 ||r(i)||/||b|| 1.018630816375e-02
>>>>  11 KSP preconditioned resid norm 4.142701353678e+15 true resid norm
>>>> 6.194874024708e+14 ||r(i)||/||b|| 4.697276182950e-03
>>>>  12 KSP preconditioned resid norm 3.300703256438e+15 true resid norm
>>>> 1.133601440349e+15 ||r(i)||/||b|| 8.595556625482e-03
>>>>  13 KSP preconditioned resid norm 7.882205618989e+14 true resid norm
>>>> 1.186911081255e+14 ||r(i)||/||b|| 8.999778092374e-04
>>>>   0 KSP preconditioned resid norm 1.928554431739e+16 true resid norm
>>>> 1.203381747345e+16 ||r(i)||/||b|| 4.946634802067e-01
>>>>   1 KSP preconditioned resid norm 9.232243648078e+15 true resid norm
>>>> 1.583125971956e+15 ||r(i)||/||b|| 6.507615763833e-02
>>>>   2 KSP preconditioned resid norm 7.541746545280e+15 true resid norm
>>>> 1.216565269124e+15 ||r(i)||/||b|| 5.000827137780e-02
>>>>   3 KSP preconditioned resid norm 7.340199256082e+15 true resid norm
>>>> 1.219811880454e+15 ||r(i)||/||b|| 5.014172695523e-02
>>>>   4 KSP preconditioned resid norm 7.655426776880e+15 true resid norm
>>>> 1.212245393966e+15 ||r(i)||/||b|| 4.983069809450e-02
>>>>   5 KSP preconditioned resid norm 8.414958315915e+15 true resid norm
>>>> 1.311448634719e+15 ||r(i)||/||b|| 5.390855787813e-02
>>>>   6 KSP preconditioned resid norm 1.008678778264e+16 true resid norm
>>>> 1.495852838926e+15 ||r(i)||/||b|| 6.148869823002e-02
>>>>   7 KSP preconditioned resid norm 1.235685231672e+16 true resid norm
>>>> 2.203374571492e+15 ||r(i)||/||b|| 9.057216765485e-02
>>>>   8 KSP preconditioned resid norm 1.311846317918e+16 true resid norm
>>>> 2.061677565336e+15 ||r(i)||/||b|| 8.474755428051e-02
>>>>   9 KSP preconditioned resid norm 1.289737803434e+16 true resid norm
>>>> 2.355893652982e+15 ||r(i)||/||b|| 9.684163449812e-02
>>>>  10 KSP preconditioned resid norm 1.151803850475e+16 true resid norm
>>>> 1.821777204240e+15 ||r(i)||/||b|| 7.488618254339e-02
>>>>  11 KSP preconditioned resid norm 8.380110732685e+15 true resid norm
>>>> 1.434954901150e+15 ||r(i)||/||b|| 5.898542062058e-02
>>>>  12 KSP preconditioned resid norm 3.553409074636e+15 true resid norm
>>>> 5.423523740165e+14 ||r(i)||/||b|| 2.229399884295e-02
>>>>  13 KSP preconditioned resid norm 1.190458477552e+15 true resid norm
>>>> 2.162492452839e+14 ||r(i)||/||b|| 8.889166260017e-03
>>>>  14 KSP preconditioned resid norm 9.902014249371e+14 true resid norm
>>>> 1.847474743657e+14 ||r(i)||/||b|| 7.594250854373e-03
>>>>  15 KSP preconditioned resid norm 9.211725470007e+14 true resid norm
>>>> 1.442747306714e+14 ||r(i)||/||b|| 5.930573613672e-03
>>>>  16 KSP preconditioned resid norm 8.405580663519e+14 true resid norm
>>>> 2.201247255509e+14 ||r(i)||/||b|| 9.048472196027e-03
>>>>  17 KSP preconditioned resid norm 7.117085749555e+14 true resid norm
>>>> 1.108024781635e+14 ||r(i)||/||b|| 4.554659365975e-03
>>>>  18 KSP preconditioned resid norm 6.347627750827e+14 true resid norm
>>>> 1.457120949776e+14 ||r(i)||/||b|| 5.989658075575e-03
>>>>  19 KSP preconditioned resid norm 5.626851770343e+14 true resid norm
>>>> 8.750418282909e+13 ||r(i)||/||b|| 3.596956967843e-03
>>>>  20 KSP preconditioned resid norm 4.865367652981e+14 true resid norm
>>>> 1.207991751614e+14 ||r(i)||/||b|| 4.965584738448e-03
>>>>  21 KSP preconditioned resid norm 4.252070053539e+14 true resid norm
>>>> 6.577223220744e+13 ||r(i)||/||b|| 2.703640914986e-03
>>>>  22 KSP preconditioned resid norm 3.618870286814e+14 true resid norm
>>>> 8.993615915309e+13 ||r(i)||/||b|| 3.696926065336e-03
>>>>  23 KSP preconditioned resid norm 3.105522471772e+14 true resid norm
>>>> 4.771648977942e+13 ||r(i)||/||b|| 1.961439497451e-03
>>>>  24 KSP preconditioned resid norm 2.735005931489e+14 true resid norm
>>>> 4.708110884633e+13 ||r(i)||/||b|| 1.935321455997e-03
>>>>  25 KSP preconditioned resid norm 2.496548247596e+14 true resid norm
>>>> 3.887274137414e+13 ||r(i)||/||b|| 1.597907361960e-03
>>>>  26 KSP preconditioned resid norm 2.329765393701e+14 true resid norm
>>>> 3.903456593754e+13 ||r(i)||/||b|| 1.604559341009e-03
>>>>  27 KSP preconditioned resid norm 2.169265400605e+14 true resid norm
>>>> 3.334703074182e+13 ||r(i)||/||b|| 1.370766867430e-03
>>>>  28 KSP preconditioned resid norm 1.998370208104e+14 true resid norm
>>>> 3.474062054769e+13 ||r(i)||/||b|| 1.428051929704e-03
>>>>  29 KSP preconditioned resid norm 1.805920498739e+14 true resid norm
>>>> 2.773007978134e+13 ||r(i)||/||b|| 1.139875837515e-03
>>>>  30 KSP preconditioned resid norm 1.643922523062e+14 true resid norm
>>>> 2.817409671160e+13 ||r(i)||/||b|| 1.158127648337e-03
>>>>  31 KSP preconditioned resid norm 1.456868079593e+14 true resid norm
>>>> 2.236751337771e+13 ||r(i)||/||b|| 9.194415683468e-04
>>>>  32 KSP preconditioned resid norm 1.315816507773e+14 true resid norm
>>>> 2.157979387266e+13 ||r(i)||/||b|| 8.870614800950e-04
>>>>   0 KSP preconditioned resid norm 6.130010040591e+16 true resid norm
>>>> 4.019535303993e+16 ||r(i)||/||b|| 5.748506002867e-02
>>>>   1 KSP preconditioned resid norm 2.383231267167e+16 true resid norm
>>>> 4.333028232365e+15 ||r(i)||/||b|| 6.196845386481e-03
>>>>   2 KSP preconditioned resid norm 1.380314332389e+16 true resid norm
>>>> 2.902938687246e+15 ||r(i)||/||b|| 4.151614355275e-03
>>>>   3 KSP preconditioned resid norm 9.355423030603e+15 true resid norm
>>>> 1.914374573200e+15 ||r(i)||/||b|| 2.737827359010e-03
>>>>   4 KSP preconditioned resid norm 6.905389736952e+15 true resid norm
>>>> 1.160495154173e+15 ||r(i)||/||b|| 1.659672786910e-03
>>>>   5 KSP preconditioned resid norm 5.388850338707e+15 true resid norm
>>>> 9.343171842551e+14 ||r(i)||/||b|| 1.336206187053e-03
>>>>   6 KSP preconditioned resid norm 4.456941671648e+15 true resid norm
>>>> 7.443205431054e+14 ||r(i)||/||b|| 1.064484022780e-03
>>>>   7 KSP preconditioned resid norm 3.604897929141e+15 true resid norm
>>>> 7.177355376747e+14 ||r(i)||/||b|| 1.026463691635e-03
>>>>   8 KSP preconditioned resid norm 2.616552572944e+15 true resid norm
>>>> 4.566784838372e+14 ||r(i)||/||b|| 6.531150511630e-04
>>>>   9 KSP preconditioned resid norm 1.730753896972e+15 true resid norm
>>>> 3.416577764278e+14 ||r(i)||/||b|| 4.886191139484e-04
>>>>  10 KSP preconditioned resid norm 9.605912905151e+14 true resid norm
>>>> 1.715828170206e+14 ||r(i)||/||b|| 2.453877821777e-04
>>>>  11 KSP preconditioned resid norm 3.885469679759e+14 true resid norm
>>>> 7.526615556743e+13 ||r(i)||/||b|| 1.076412854646e-04
>>>>  12 KSP preconditioned resid norm 1.085402187481e+14 true resid norm
>>>> 1.877491024324e+13 ||r(i)||/||b|| 2.685078649001e-05
>>>>  13 KSP preconditioned resid norm 5.521537327924e+13 true resid norm
>>>> 1.482832280216e+13 ||r(i)||/||b|| 2.120660628506e-05
>>>>  14 KSP preconditioned resid norm 4.327780981098e+13 true resid norm
>>>> 6.949078996691e+12 ||r(i)||/||b|| 9.938169292156e-06
>>>>   0 KSP preconditioned resid norm 2.469228993807e+16 true resid norm
>>>> 1.581397706747e+16 ||r(i)||/||b|| 1.421322431696e-01
>>>>   1 KSP preconditioned resid norm 1.094866250702e+16 true resid norm
>>>> 1.827538407052e+15 ||r(i)||/||b|| 1.642547805430e-02
>>>>   2 KSP preconditioned resid norm 7.902646639796e+15 true resid norm
>>>> 1.331972302022e+15 ||r(i)||/||b|| 1.197144844200e-02
>>>>   3 KSP preconditioned resid norm 6.757113896005e+15 true resid norm
>>>> 1.177404713092e+15 ||r(i)||/||b|| 1.058223192536e-02
>>>>   4 KSP preconditioned resid norm 6.236819639281e+15 true resid norm
>>>> 9.858933018833e+14 ||r(i)||/||b|| 8.860973171059e-03
>>>>   5 KSP preconditioned resid norm 6.056207345085e+15 true resid norm
>>>> 9.498733496025e+14 ||r(i)||/||b|| 8.537234455953e-03
>>>>   6 KSP preconditioned resid norm 6.281149615757e+15 true resid norm
>>>> 9.439016000829e+14 ||r(i)||/||b|| 8.483561799717e-03
>>>>   7 KSP preconditioned resid norm 6.511636840454e+15 true resid norm
>>>> 1.175604965975e+15 ||r(i)||/||b|| 1.056605622877e-02
>>>>   8 KSP preconditioned resid norm 5.897282381771e+15 true resid norm
>>>> 9.358325816295e+14 ||r(i)||/||b|| 8.411039391972e-03
>>>>   9 KSP preconditioned resid norm 4.858643828149e+15 true resid norm
>>>> 9.074074922507e+14 ||r(i)||/||b|| 8.155561487934e-03
>>>>  10 KSP preconditioned resid norm 3.431226959566e+15 true resid norm
>>>> 5.523076022464e+14 ||r(i)||/||b|| 4.964008616682e-03
>>>>  11 KSP preconditioned resid norm 1.790601246330e+15 true resid norm
>>>> 3.233761759516e+14 ||r(i)||/||b|| 2.906427717678e-03
>>>>  12 KSP preconditioned resid norm 6.061504971272e+14 true resid norm
>>>> 9.361691978333e+13 ||r(i)||/||b|| 8.414064817893e-04
>>>>  13 KSP preconditioned resid norm 3.669164519745e+14 true resid norm
>>>> 7.433339410578e+13 ||r(i)||/||b|| 6.680907656304e-04
>>>>  14 KSP preconditioned resid norm 1.028448839513e+15 true resid norm
>>>> 1.739193394480e+14 ||r(i)||/||b|| 1.563145421348e-03
>>>>  15 KSP preconditioned resid norm 1.340577188948e+14 true resid norm
>>>> 2.477633902186e+13 ||r(i)||/||b|| 2.226838086134e-04
>>>>  16 KSP preconditioned resid norm 1.124181660974e+14 true resid norm
>>>> 1.917872742131e+13 ||r(i)||/||b|| 1.723738144997e-04
>>>>  17 KSP preconditioned resid norm 9.394070158671e+13 true resid norm
>>>> 1.682505899954e+13 ||r(i)||/||b|| 1.512196057236e-04
>>>>  18 KSP preconditioned resid norm 9.034650415597e+13 true resid norm
>>>> 1.892962426081e+13 ||r(i)||/||b|| 1.701349348787e-04
>>>>  19 KSP preconditioned resid norm 8.058877605551e+13 true resid norm
>>>> 1.275341142002e+13 ||r(i)||/||b|| 1.146246112195e-04
>>>>  20 KSP preconditioned resid norm 6.303186171389e+13 true resid norm
>>>> 1.900109222650e+13 ||r(i)||/||b|| 1.707772718592e-04
>>>>  21 KSP preconditioned resid norm 4.601610061053e+13 true resid norm
>>>> 6.959914424356e+12 ||r(i)||/||b|| 6.255404603042e-05
>>>>  22 KSP preconditioned resid norm 2.822582332621e+13 true resid norm
>>>> 1.013252988889e+13 ||r(i)||/||b|| 9.106875493415e-05
>>>>  23 KSP preconditioned resid norm 1.858033653578e+13 true resid norm
>>>> 2.785463510953e+12 ||r(i)||/||b|| 2.503507975190e-05
>>>>  24 KSP preconditioned resid norm 9.505670647827e+12 true resid norm
>>>> 4.268589348463e+12 ||r(i)||/||b|| 3.836506001486e-05
>>>>  25 KSP preconditioned resid norm 5.844140386668e+12 true resid norm
>>>> 8.921656809030e+11 ||r(i)||/||b|| 8.018571733391e-06
>>>>     0 SNES Function norm 0.000000000000e+00
>>>> 3 TS dt 5e-12 time 9e-12
>>>>   0 KSP preconditioned resid norm 2.220122692212e+19 true resid norm
>>>> 1.204173138214e+19 ||r(i)||/||b|| 2.302144004449e+02
>>>>   1 KSP preconditioned resid norm 5.389791318038e+18 true resid norm
>>>> 1.775764523088e+18 ||r(i)||/||b|| 3.394915166605e+01
>>>>   2 KSP preconditioned resid norm 2.218229032455e+18 true resid norm
>>>> 5.319501602511e+17 ||r(i)||/||b|| 1.016984878025e+01
>>>>   3 KSP preconditioned resid norm 1.401621992174e+18 true resid norm
>>>> 2.963396938661e+17 ||r(i)||/||b|| 5.665436537857e+00
>>>>   4 KSP preconditioned resid norm 1.004007060031e+18 true resid norm
>>>> 1.656144361093e+17 ||r(i)||/||b|| 3.166224764861e+00
>>>>   5 KSP preconditioned resid norm 8.672273682794e+17 true resid norm
>>>> 1.510259905938e+17 ||r(i)||/||b|| 2.887322160975e+00
>>>>   6 KSP preconditioned resid norm 7.388939161376e+17 true resid norm
>>>> 1.526077665500e+17 ||r(i)||/||b|| 2.917562629878e+00
>>>>   7 KSP preconditioned resid norm 5.565893055963e+17 true resid norm
>>>> 1.017298978392e+17 ||r(i)||/||b|| 1.944877085792e+00
>>>>   8 KSP preconditioned resid norm 3.566491384538e+17 true resid norm
>>>> 6.306517676931e+16 ||r(i)||/||b|| 1.205683086440e+00
>>>>   9 KSP preconditioned resid norm 1.893313432840e+17 true resid norm
>>>> 3.267997700517e+16 ||r(i)||/||b|| 6.247773741206e-01
>>>>  10 KSP preconditioned resid norm 6.895898463878e+16 true resid norm
>>>> 1.153123828824e+16 ||r(i)||/||b|| 2.204547688925e-01
>>>>  11 KSP preconditioned resid norm 5.104999855255e+16 true resid norm
>>>> 9.275473058095e+15 ||r(i)||/||b|| 1.773289405940e-01
>>>>  12 KSP preconditioned resid norm 4.992747088606e+16 true resid norm
>>>> 8.399049844320e+15 ||r(i)||/||b|| 1.605734393881e-01
>>>>  13 KSP preconditioned resid norm 4.920015136673e+16 true resid norm
>>>> 8.426577623649e+15 ||r(i)||/||b|| 1.610997167989e-01
>>>>  14 KSP preconditioned resid norm 5.688370526613e+16 true resid norm
>>>> 9.763030126011e+15 ||r(i)||/||b|| 1.866500800972e-01
>>>>  15 KSP preconditioned resid norm 1.613946025228e+17 true resid norm
>>>> 4.341380499600e+16 ||r(i)||/||b|| 8.299872145473e-01
>>>>  16 KSP preconditioned resid norm 4.125620543313e+16 true resid norm
>>>> 7.099475531667e+15 ||r(i)||/||b|| 1.357281150965e-01
>>>>  17 KSP preconditioned resid norm 2.163115342752e+16 true resid norm
>>>> 5.850497008723e+15 ||r(i)||/||b|| 1.118500835491e-01
>>>>  18 KSP preconditioned resid norm 1.414953599369e+16 true resid norm
>>>> 2.432122296311e+15 ||r(i)||/||b|| 4.649743118207e-02
>>>>  19 KSP preconditioned resid norm 1.088056550362e+16 true resid norm
>>>> 2.488538030816e+15 ||r(i)||/||b|| 4.757598991109e-02
>>>>  20 KSP preconditioned resid norm 9.058853458567e+15 true resid norm
>>>> 1.587978910975e+15 ||r(i)||/||b|| 3.035905729067e-02
>>>>  21 KSP preconditioned resid norm 7.813748136791e+15 true resid norm
>>>> 1.345999130102e+15 ||r(i)||/||b|| 2.573287618717e-02
>>>>  22 KSP preconditioned resid norm 6.941551759120e+15 true resid norm
>>>> 1.184314230023e+15 ||r(i)||/||b|| 2.264177648138e-02
>>>>  23 KSP preconditioned resid norm 6.244923673699e+15 true resid norm
>>>> 1.023439246806e+15 ||r(i)||/||b|| 1.956616080515e-02
>>>>  24 KSP preconditioned resid norm 5.681880462174e+15 true resid norm
>>>> 9.491910634069e+14 ||r(i)||/||b|| 1.814668045943e-02
>>>>  25 KSP preconditioned resid norm 5.283519017995e+15 true resid norm
>>>> 8.557005279630e+14 ||r(i)||/||b|| 1.635932390068e-02
>>>>  26 KSP preconditioned resid norm 5.117675200632e+15 true resid norm
>>>> 8.569254569155e+14 ||r(i)||/||b|| 1.638274215138e-02
>>>>  27 KSP preconditioned resid norm 4.944059018035e+15 true resid norm
>>>> 9.547778379458e+14 ||r(i)||/||b|| 1.825348868410e-02
>>>>  28 KSP preconditioned resid norm 4.840428844487e+15 true resid norm
>>>> 7.569152804275e+14 ||r(i)||/||b|| 1.447074278120e-02
>>>>  29 KSP preconditioned resid norm 4.909458338739e+15 true resid norm
>>>> 7.780937746322e+14 ||r(i)||/||b|| 1.487563425328e-02
>>>>  30 KSP preconditioned resid norm 5.172548892535e+15 true resid norm
>>>> 8.119476371329e+14 ||r(i)||/||b|| 1.552285402683e-02
>>>>  31 KSP preconditioned resid norm 5.734458283292e+15 true resid norm
>>>> 9.082595641858e+14 ||r(i)||/||b|| 1.736415008622e-02
>>>>  32 KSP preconditioned resid norm 8.602942487649e+15 true resid norm
>>>> 1.383459272467e+15 ||r(i)||/||b|| 2.644904099284e-02
>>>>  33 KSP preconditioned resid norm 1.681001901654e+16 true resid norm
>>>> 2.705594423024e+15 ||r(i)||/||b|| 5.172568446988e-02
>>>>  34 KSP preconditioned resid norm 3.498037913905e+16 true resid norm
>>>> 5.724738344713e+15 ||r(i)||/||b|| 1.094458233545e-01
>>>>  35 KSP preconditioned resid norm 6.660621055336e+15 true resid norm
>>>> 1.092449655644e+15 ||r(i)||/||b|| 2.088550512457e-02
>>>>  36 KSP preconditioned resid norm 3.564205941873e+15 true resid norm
>>>> 5.832825274169e+14 ||r(i)||/||b|| 1.115122344769e-02
>>>>  37 KSP preconditioned resid norm 2.275128811690e+15 true resid norm
>>>> 4.150874600928e+14 ||r(i)||/||b|| 7.935662050992e-03
>>>>  38 KSP preconditioned resid norm 1.923021972098e+15 true resid norm
>>>> 3.105449109783e+14 ||r(i)||/||b|| 5.937012562674e-03
>>>>  39 KSP preconditioned resid norm 1.756400018558e+15 true resid norm
>>>> 3.028037938881e+14 ||r(i)||/||b|| 5.789017513361e-03
>>>>  40 KSP preconditioned resid norm 1.618977002834e+15 true resid norm
>>>> 2.591473194248e+14 ||r(i)||/||b|| 4.954390932253e-03
>>>>  41 KSP preconditioned resid norm 1.449378745707e+15 true resid norm
>>>> 2.366294470672e+14 ||r(i)||/||b|| 4.523893164149e-03
>>>>  42 KSP preconditioned resid norm 1.311727507569e+15 true resid norm
>>>> 2.162961405943e+14 ||r(i)||/||b|| 4.135160031831e-03
>>>>  43 KSP preconditioned resid norm 1.220101213287e+15 true resid norm
>>>> 1.960093358179e+14 ||r(i)||/||b|| 3.747315921186e-03
>>>>  44 KSP preconditioned resid norm 1.141924730669e+15 true resid norm
>>>> 1.884563341884e+14 ||r(i)||/||b|| 3.602917272310e-03
>>>>  45 KSP preconditioned resid norm 1.062154013672e+15 true resid norm
>>>> 2.268601642641e+14 ||r(i)||/||b|| 4.337123545072e-03
>>>>  46 KSP preconditioned resid norm 1.050847341809e+15 true resid norm
>>>> 1.644035317108e+14 ||r(i)||/||b|| 3.143074636258e-03
>>>>  47 KSP preconditioned resid norm 8.268920862881e+14 true resid norm
>>>> 2.491484388741e+14 ||r(i)||/||b|| 4.763231852378e-03
>>>>  48 KSP preconditioned resid norm 6.970056044801e+14 true resid norm
>>>> 1.086553600705e+14 ||r(i)||/||b|| 2.077278406232e-03
>>>>  49 KSP preconditioned resid norm 8.789823309588e+14 true resid norm
>>>> 1.565701303869e+14 ||r(i)||/||b|| 2.993315292522e-03
>>>>  50 KSP preconditioned resid norm 9.889574125697e+14 true resid norm
>>>> 1.557528361421e+14 ||r(i)||/||b|| 2.977690221792e-03
>>>>  51 KSP preconditioned resid norm 3.685341349551e+14 true resid norm
>>>> 5.749337875960e+13 ||r(i)||/||b|| 1.099161183775e-03
>>>>  52 KSP preconditioned resid norm 2.728364862859e+15 true resid norm
>>>> 4.745949443528e+14 ||r(i)||/||b|| 9.073329000715e-03
>>>>  53 KSP preconditioned resid norm 8.484691724076e+15 true resid norm
>>>> 1.333040899485e+15 ||r(i)||/||b|| 2.548514011022e-02
>>>>  54 KSP preconditioned resid norm 8.341541248747e+13 true resid norm
>>>> 1.303089350822e+13 ||r(i)||/||b|| 2.491252496055e-04
>>>>   0 KSP preconditioned resid norm 6.542890621126e+18 true resid norm
>>>> 3.545938224251e+18 ||r(i)||/||b|| 4.156801777589e+02
>>>>   1 KSP preconditioned resid norm 1.591173149842e+18 true resid norm
>>>> 5.223204285160e+17 ||r(i)||/||b|| 6.123012721646e+01
>>>>   2 KSP preconditioned resid norm 6.570590492388e+17 true resid norm
>>>> 1.552517142001e+17 ||r(i)||/||b|| 1.819971360886e+01
>>>>   3 KSP preconditioned resid norm 4.165858181866e+17 true resid norm
>>>> 8.738575659546e+16 ||r(i)||/||b|| 1.024398185698e+01
>>>>   4 KSP preconditioned resid norm 2.995041215234e+17 true resid norm
>>>> 4.934730887237e+16 ||r(i)||/||b|| 5.784843622966e+00
>>>>   5 KSP preconditioned resid norm 2.594520327186e+17 true resid norm
>>>> 4.469839192099e+16 ||r(i)||/||b|| 5.239864409419e+00
>>>>   6 KSP preconditioned resid norm 2.219632225075e+17 true resid norm
>>>> 4.652171577038e+16 ||r(i)||/||b|| 5.453607439866e+00
>>>>   7 KSP preconditioned resid norm 1.674928029034e+17 true resid norm
>>>> 2.988841295071e+16 ||r(i)||/||b|| 3.503733010156e+00
>>>>   8 KSP preconditioned resid norm 1.081911414020e+17 true resid norm
>>>> 1.908165723430e+16 ||r(i)||/||b|| 2.236888002402e+00
>>>>   9 KSP preconditioned resid norm 5.710171826154e+16 true resid norm
>>>> 9.635278906551e+15 ||r(i)||/||b|| 1.129516137997e+00
>>>>  10 KSP preconditioned resid norm 1.779377501866e+16 true resid norm
>>>> 2.952494296810e+15 ||r(i)||/||b|| 3.461124465555e-01
>>>>  11 KSP preconditioned resid norm 1.125612460139e+16 true resid norm
>>>> 2.030403352863e+15 ||r(i)||/||b|| 2.380183672880e-01
>>>>  12 KSP preconditioned resid norm 1.086634567103e+16 true resid norm
>>>> 1.877885131752e+15 ||r(i)||/||b|| 2.201390932416e-01
>>>>  13 KSP preconditioned resid norm 1.075395224737e+16 true resid norm
>>>> 1.822688133743e+15 ||r(i)||/||b|| 2.136685073225e-01
>>>>  14 KSP preconditioned resid norm 1.173925328196e+16 true resid norm
>>>> 2.130469004546e+15 ||r(i)||/||b|| 2.497487769141e-01
>>>>  15 KSP preconditioned resid norm 4.944016549258e+16 true resid norm
>>>> 1.361939461929e+16 ||r(i)||/||b|| 1.596562607209e+00
>>>>  16 KSP preconditioned resid norm 1.780247590037e+17 true resid norm
>>>> 3.370503336823e+16 ||r(i)||/||b|| 3.951144485840e+00
>>>>  17 KSP preconditioned resid norm 3.251104571145e+16 true resid norm
>>>> 8.719659549123e+15 ||r(i)||/||b|| 1.022180704274e+00
>>>>  18 KSP preconditioned resid norm 2.075437272594e+16 true resid norm
>>>> 3.944434594682e+15 ||r(i)||/||b|| 4.623947654424e-01
>>>>  19 KSP preconditioned resid norm 1.483444135710e+16 true resid norm
>>>> 3.390829411015e+15 ||r(i)||/||b|| 3.974972160206e-01
>>>>  20 KSP preconditioned resid norm 1.134313319987e+16 true resid norm
>>>> 2.489467119154e+15 ||r(i)||/||b|| 2.918330972428e-01
>>>>  21 KSP preconditioned resid norm 8.553477032620e+15 true resid norm
>>>> 1.657674168535e+15 ||r(i)||/||b|| 1.943243930000e-01
>>>>  22 KSP preconditioned resid norm 6.586595023874e+15 true resid norm
>>>> 1.286251502369e+15 ||r(i)||/||b|| 1.507835780925e-01
>>>>  23 KSP preconditioned resid norm 4.780400299659e+15 true resid norm
>>>> 9.064518348736e+14 ||r(i)||/||b|| 1.062607513219e-01
>>>>  24 KSP preconditioned resid norm 3.028073960021e+15 true resid norm
>>>> 6.179142836679e+14 ||r(i)||/||b|| 7.243632094834e-02
>>>>  25 KSP preconditioned resid norm 1.570529076731e+15 true resid norm
>>>> 2.755631911412e+14 ||r(i)||/||b|| 3.230348331903e-02
>>>>  26 KSP preconditioned resid norm 1.180384548694e+15 true resid norm
>>>> 2.278461878994e+14 ||r(i)||/||b|| 2.670975575377e-02
>>>>  27 KSP preconditioned resid norm 1.075603583388e+15 true resid norm
>>>> 2.036512758236e+14 ||r(i)||/||b|| 2.387345553745e-02
>>>>  28 KSP preconditioned resid norm 1.013485206919e+15 true resid norm
>>>> 1.671016982388e+14 ||r(i)||/||b|| 1.958885328364e-02
>>>>  29 KSP preconditioned resid norm 9.469966879519e+14 true resid norm
>>>> 1.801244790801e+14 ||r(i)||/||b|| 2.111547656715e-02
>>>>  30 KSP preconditioned resid norm 8.991813841494e+14 true resid norm
>>>> 1.459100485336e+14 ||r(i)||/||b|| 1.710461690970e-02
>>>>  31 KSP preconditioned resid norm 8.677534755734e+14 true resid norm
>>>> 1.581142867341e+14 ||r(i)||/||b|| 1.853528478482e-02
>>>>  32 KSP preconditioned resid norm 8.336211910215e+14 true resid norm
>>>> 1.336646371267e+14 ||r(i)||/||b|| 1.566912241756e-02
>>>>  33 KSP preconditioned resid norm 8.025169227655e+14 true resid norm
>>>> 1.586001394574e+14 ||r(i)||/||b|| 1.859223990744e-02
>>>>  34 KSP preconditioned resid norm 7.724033526395e+14 true resid norm
>>>> 1.340849232530e+14 ||r(i)||/||b|| 1.571839135589e-02
>>>>  35 KSP preconditioned resid norm 7.664262315912e+14 true resid norm
>>>> 1.204381005271e+14 ||r(i)||/||b|| 1.411861343033e-02
>>>>  36 KSP preconditioned resid norm 7.727266103384e+14 true resid norm
>>>> 1.292430217432e+14 ||r(i)||/||b|| 1.515078911553e-02
>>>>  37 KSP preconditioned resid norm 8.047214262262e+14 true resid norm
>>>> 1.267167533285e+14 ||r(i)||/||b|| 1.485464190786e-02
>>>>  38 KSP preconditioned resid norm 8.419506152984e+14 true resid norm
>>>> 1.380565821207e+14 ||r(i)||/||b|| 1.618397754485e-02
>>>>  39 KSP preconditioned resid norm 8.796981754885e+14 true resid norm
>>>> 1.388509364066e+14 ||r(i)||/||b|| 1.627709742171e-02
>>>>  40 KSP preconditioned resid norm 9.432799067464e+14 true resid norm
>>>> 1.525727137977e+14 ||r(i)||/||b|| 1.788566206789e-02
>>>>  41 KSP preconditioned resid norm 1.193594717717e+15 true resid norm
>>>> 1.887759239390e+14 ||r(i)||/||b|| 2.212966065874e-02
>>>>  42 KSP preconditioned resid norm 2.117323854280e+15 true resid norm
>>>> 3.659661973675e+14 ||r(i)||/||b|| 4.290116870483e-02
>>>>  43 KSP preconditioned resid norm 1.749515464589e+16 true resid norm
>>>> 2.774904343458e+15 ||r(i)||/||b|| 3.252940851772e-01
>>>>  44 KSP preconditioned resid norm 1.219803820486e+15 true resid norm
>>>> 2.038867414461e+14 ||r(i)||/||b|| 2.390105849768e-02
>>>>  45 KSP preconditioned resid norm 6.218668840796e+14 true resid norm
>>>> 9.918031040094e+13 ||r(i)||/||b|| 1.162662360435e-02
>>>>  46 KSP preconditioned resid norm 4.213016096566e+14 true resid norm
>>>> 7.032265378826e+13 ||r(i)||/||b|| 8.243723206248e-03
>>>>  47 KSP preconditioned resid norm 2.932264460599e+14 true resid norm
>>>> 4.681093096736e+13 ||r(i)||/||b|| 5.487511308712e-03
>>>>  48 KSP preconditioned resid norm 1.890454719223e+14 true resid norm
>>>> 3.330632990756e+13 ||r(i)||/||b|| 3.904405621560e-03
>>>>  49 KSP preconditioned resid norm 1.361587907879e+14 true resid norm
>>>> 2.180429132446e+13 ||r(i)||/||b|| 2.556054595557e-03
>>>>  50 KSP preconditioned resid norm 1.041049830937e+14 true resid norm
>>>> 1.811134568183e+13 ||r(i)||/||b|| 2.123141159366e-03
>>>>  51 KSP preconditioned resid norm 9.375298557199e+13 true resid norm
>>>> 1.575768352161e+13 ||r(i)||/||b|| 1.847228088333e-03
>>>>  52 KSP preconditioned resid norm 1.220175150775e+14 true resid norm
>>>> 1.950548748269e+13 ||r(i)||/||b|| 2.286572408009e-03
>>>>  53 KSP preconditioned resid norm 7.051895161295e+13 true resid norm
>>>> 1.295324819768e+13 ||r(i)||/||b|| 1.518472170932e-03
>>>>  54 KSP preconditioned resid norm 5.292501274648e+13 true resid norm
>>>> 8.611444708372e+12 ||r(i)||/||b|| 1.009494988563e-03
>>>>   0 KSP preconditioned resid norm 1.892610202067e+19 true resid norm
>>>> 1.028308040523e+19 ||r(i)||/||b|| 7.841022917690e+01
>>>>   1 KSP preconditioned resid norm 4.581169591238e+18 true resid norm
>>>> 1.519782710159e+18 ||r(i)||/||b|| 1.158860048804e+01
>>>>   2 KSP preconditioned resid norm 1.874457569158e+18 true resid norm
>>>> 4.646597685037e+17 ||r(i)||/||b|| 3.543109409036e+00
>>>>   3 KSP preconditioned resid norm 1.173257076173e+18 true resid norm
>>>> 2.550995626245e+17 ||r(i)||/||b|| 1.945177357373e+00
>>>>   4 KSP preconditioned resid norm 8.301427099842e+17 true resid norm
>>>> 1.381385637907e+17 ||r(i)||/||b|| 1.053329937932e+00
>>>>   5 KSP preconditioned resid norm 7.053087339556e+17 true resid norm
>>>> 1.287851939525e+17 ||r(i)||/||b|| 9.820089092432e-01
>>>>   6 KSP preconditioned resid norm 5.863912202870e+17 true resid norm
>>>> 1.166954217660e+17 ||r(i)||/||b|| 8.898223493329e-01
>>>>   7 KSP preconditioned resid norm 4.330693111087e+17 true resid norm
>>>> 8.611440299479e+16 ||r(i)||/||b|| 6.566369033559e-01
>>>>   8 KSP preconditioned resid norm 2.702458300388e+17 true resid norm
>>>> 4.803465439349e+16 ||r(i)||/||b|| 3.662723727716e-01
>>>>   9 KSP preconditioned resid norm 1.546904751775e+17 true resid norm
>>>> 2.878502712633e+16 ||r(i)||/||b|| 2.194907055953e-01
>>>>  10 KSP preconditioned resid norm 9.910545254967e+16 true resid norm
>>>> 1.648892832929e+16 ||r(i)||/||b|| 1.257308703453e-01
>>>>  11 KSP preconditioned resid norm 9.242232753221e+16 true resid norm
>>>> 1.559261342084e+16 ||r(i)||/||b|| 1.188963174082e-01
>>>>  12 KSP preconditioned resid norm 9.244969774564e+16 true resid norm
>>>> 1.506990436290e+16 ||r(i)||/||b|| 1.149105723385e-01
>>>>  13 KSP preconditioned resid norm 7.091380549056e+16 true resid norm
>>>> 1.150476534699e+16 ||r(i)||/||b|| 8.772578370826e-02
>>>>  14 KSP preconditioned resid norm 2.015813147523e+17 true resid norm
>>>> 3.265267485752e+16 ||r(i)||/||b|| 2.489821743992e-01
>>>>  15 KSP preconditioned resid norm 1.668693825394e+16 true resid norm
>>>> 4.392881515438e+15 ||r(i)||/||b|| 3.349646533904e-02
>>>>  16 KSP preconditioned resid norm 1.171106201192e+16 true resid norm
>>>> 1.864120995445e+15 ||r(i)||/||b|| 1.421423821522e-02
>>>>  17 KSP preconditioned resid norm 1.020170882678e+16 true resid norm
>>>> 1.999245817269e+15 ||r(i)||/||b|| 1.524458786039e-02
>>>>  18 KSP preconditioned resid norm 9.407404703690e+15 true resid norm
>>>> 1.539877936168e+15 ||r(i)||/||b|| 1.174182998880e-02
>>>>  19 KSP preconditioned resid norm 8.812299187434e+15 true resid norm
>>>> 1.424937011002e+15 ||r(i)||/||b|| 1.086538597310e-02
>>>>  20 KSP preconditioned resid norm 8.313368595823e+15 true resid norm
>>>> 1.488773269648e+15 ||r(i)||/||b|| 1.135214825376e-02
>>>>  21 KSP preconditioned resid norm 7.851626197782e+15 true resid norm
>>>> 1.250085440746e+15 ||r(i)||/||b|| 9.532113144783e-03
>>>>  22 KSP preconditioned resid norm 7.455044400782e+15 true resid norm
>>>> 1.324254107888e+15 ||r(i)||/||b|| 1.009766178966e-02
>>>>  23 KSP preconditioned resid norm 7.129687083603e+15 true resid norm
>>>> 1.124533100660e+15 ||r(i)||/||b|| 8.574755293646e-03
>>>>  24 KSP preconditioned resid norm 5.784281419699e+15 true resid norm
>>>> 2.057123935555e+15 ||r(i)||/||b|| 1.568591831199e-02
>>>>  25 KSP preconditioned resid norm 4.924869719264e+15 true resid norm
>>>> 7.825081154476e+14 ||r(i)||/||b|| 5.966756871199e-03
>>>>  26 KSP preconditioned resid norm 5.016674985414e+15 true resid norm
>>>> 7.817733101871e+14 ||r(i)||/||b|| 5.961153856674e-03
>>>>  27 KSP preconditioned resid norm 5.308634596254e+15 true resid norm
>>>> 8.859615986698e+14 ||r(i)||/||b|| 6.755607197068e-03
>>>>  28 KSP preconditioned resid norm 9.149615612203e+15 true resid norm
>>>> 1.429126026168e+15 ||r(i)||/||b|| 1.089732792301e-02
>>>>  29 KSP preconditioned resid norm 8.897313413659e+15 true resid norm
>>>> 2.002400213933e+15 ||r(i)||/||b|| 1.526864066904e-02
>>>>  30 KSP preconditioned resid norm 2.145204463192e+15 true resid norm
>>>> 3.349465461999e+14 ||r(i)||/||b|| 2.554024126484e-03
>>>>  31 KSP preconditioned resid norm 1.279996253934e+15 true resid norm
>>>> 2.794251271078e+14 ||r(i)||/||b|| 2.130663905259e-03
>>>>  32 KSP preconditioned resid norm 8.936440443654e+14 true resid norm
>>>> 1.396095375555e+14 ||r(i)||/||b|| 1.064546361948e-03
>>>>   0 KSP preconditioned resid norm 6.470811776559e+18 true resid norm
>>>> 3.511555308471e+18 ||r(i)||/||b|| 1.662220839803e+02
>>>>   1 KSP preconditioned resid norm 1.571601370240e+18 true resid norm
>>>> 5.187483735196e+17 ||r(i)||/||b|| 2.455534033589e+01
>>>>   2 KSP preconditioned resid norm 6.468356854753e+17 true resid norm
>>>> 1.566993981909e+17 ||r(i)||/||b|| 7.417482635946e+00
>>>>   3 KSP preconditioned resid norm 4.084058718904e+17 true resid norm
>>>> 8.688424998267e+16 ||r(i)||/||b|| 4.112730636007e+00
>>>>   4 KSP preconditioned resid norm 2.920904676538e+17 true resid norm
>>>> 4.831974981420e+16 ||r(i)||/||b|| 2.287251319137e+00
>>>>   5 KSP preconditioned resid norm 2.515876340477e+17 true resid norm
>>>> 4.435582123557e+16 ||r(i)||/||b|| 2.099615809737e+00
>>>>   6 KSP preconditioned resid norm 2.133089016156e+17 true resid norm
>>>> 4.355659888860e+16 ||r(i)||/||b|| 2.061784025127e+00
>>>>   7 KSP preconditioned resid norm 1.601295948028e+17 true resid norm
>>>> 2.999342671961e+16 ||r(i)||/||b|| 1.419761176199e+00
>>>>   8 KSP preconditioned resid norm 1.019894482623e+17 true resid norm
>>>> 1.811123232414e+16 ||r(i)||/||b|| 8.573086612382e-01
>>>>   9 KSP preconditioned resid norm 5.552358385594e+16 true resid norm
>>>> 9.849609129144e+15 ||r(i)||/||b|| 4.662385786400e-01
>>>>  10 KSP preconditioned resid norm 2.614302078211e+16 true resid norm
>>>> 4.400897857400e+15 ||r(i)||/||b|| 2.083197754216e-01
>>>>  11 KSP preconditioned resid norm 2.230412831734e+16 true resid norm
>>>> 4.001989581448e+15 ||r(i)||/||b|| 1.894371552944e-01
>>>>  12 KSP preconditioned resid norm 2.202852939300e+16 true resid norm
>>>> 3.668964514289e+15 ||r(i)||/||b|| 1.736731658885e-01
>>>>  13 KSP preconditioned resid norm 2.171413942501e+16 true resid norm
>>>> 3.746648405904e+15 ||r(i)||/||b|| 1.773503907139e-01
>>>>  14 KSP preconditioned resid norm 2.756569557917e+16 true resid norm
>>>> 4.738274109991e+15 ||r(i)||/||b|| 2.242897314282e-01
>>>>  15 KSP preconditioned resid norm 1.911125733606e+16 true resid norm
>>>> 7.273426207009e+15 ||r(i)||/||b|| 3.442930427122e-01
>>>>  16 KSP preconditioned resid norm 8.267301781208e+15 true resid norm
>>>> 1.450502353903e+15 ||r(i)||/||b|| 6.866060844958e-02
>>>>  17 KSP preconditioned resid norm 5.452175853074e+15 true resid norm
>>>> 1.779140334910e+15 ||r(i)||/||b|| 8.421693186737e-02
>>>>  18 KSP preconditioned resid norm 4.185422899260e+15 true resid norm
>>>> 7.352001585133e+14 ||r(i)||/||b|| 3.480124667150e-02
>>>>  19 KSP preconditioned resid norm 3.483100692842e+15 true resid norm
>>>> 7.680069742951e+14 ||r(i)||/||b|| 3.635418171280e-02
>>>>  20 KSP preconditioned resid norm 3.028709630445e+15 true resid norm
>>>> 5.664408475792e+14 ||r(i)||/||b|| 2.681289909034e-02
>>>>  21 KSP preconditioned resid norm 2.650986791756e+15 true resid norm
>>>> 5.333477625647e+14 ||r(i)||/||b|| 2.524641328184e-02
>>>>  22 KSP preconditioned resid norm 2.409785359425e+15 true resid norm
>>>> 3.913611824173e+14 ||r(i)||/||b|| 1.852537283791e-02
>>>>  23 KSP preconditioned resid norm 2.246473514462e+15 true resid norm
>>>> 3.515886291592e+14 ||r(i)||/||b|| 1.664270942896e-02
>>>>  24 KSP preconditioned resid norm 2.105216345845e+15 true resid norm
>>>> 3.429537728013e+14 ||r(i)||/||b|| 1.623397207682e-02
>>>>  25 KSP preconditioned resid norm 1.993254024352e+15 true resid norm
>>>> 3.120073169264e+14 ||r(i)||/||b|| 1.476909855627e-02
>>>>  26 KSP preconditioned resid norm 1.937764630771e+15 true resid norm
>>>> 3.193060027359e+14 ||r(i)||/||b|| 1.511458728106e-02
>>>>  27 KSP preconditioned resid norm 1.841409046328e+15 true resid norm
>>>> 4.276359096161e+14 ||r(i)||/||b|| 2.024246404712e-02
>>>>  28 KSP preconditioned resid norm 1.798600034298e+15 true resid norm
>>>> 2.807262398909e+14 ||r(i)||/||b|| 1.328838549404e-02
>>>>  29 KSP preconditioned resid norm 1.909156742948e+15 true resid norm
>>>> 3.075705616539e+14 ||r(i)||/||b|| 1.455908144342e-02
>>>>  30 KSP preconditioned resid norm 2.243056909373e+15 true resid norm
>>>> 3.518787704137e+14 ||r(i)||/||b|| 1.665644348118e-02
>>>>  31 KSP preconditioned resid norm 3.125791809917e+15 true resid norm
>>>> 5.051797337710e+14 ||r(i)||/||b|| 2.391305867501e-02
>>>>  32 KSP preconditioned resid norm 2.268406906040e+16 true resid norm
>>>> 3.663605847107e+15 ||r(i)||/||b|| 1.734195093893e-01
>>>>  33 KSP preconditioned resid norm 2.663631019961e+15 true resid norm
>>>> 4.418031676456e+14 ||r(i)||/||b|| 2.091308174984e-02
>>>>  34 KSP preconditioned resid norm 1.194136462714e+15 true resid norm
>>>> 1.964734637439e+14 ||r(i)||/||b|| 9.300217630505e-03
>>>>  35 KSP preconditioned resid norm 7.378290473645e+14 true resid norm
>>>> 1.245828993721e+14 ||r(i)||/||b|| 5.897224261846e-03
>>>>  36 KSP preconditioned resid norm 5.578220476287e+14 true resid norm
>>>> 9.049566410806e+13 ||r(i)||/||b|| 4.283679611405e-03
>>>>  37 KSP preconditioned resid norm 4.459209275003e+14 true resid norm
>>>> 9.101333159944e+13 ||r(i)||/||b|| 4.308183787380e-03
>>>>  38 KSP preconditioned resid norm 4.020379023591e+14 true resid norm
>>>> 6.381912771158e+13 ||r(i)||/||b|| 3.020925907227e-03
>>>>  39 KSP preconditioned resid norm 3.758207934261e+14 true resid norm
>>>> 7.185355109637e+13 ||r(i)||/||b|| 3.401241317717e-03
>>>>  40 KSP preconditioned resid norm 3.524000257362e+14 true resid norm
>>>> 5.552480372659e+13 ||r(i)||/||b|| 2.628307908397e-03
>>>>  41 KSP preconditioned resid norm 3.288683013967e+14 true resid norm
>>>> 5.672396056313e+13 ||r(i)||/||b|| 2.685070889720e-03
>>>>  42 KSP preconditioned resid norm 3.091159619430e+14 true resid norm
>>>> 5.054650403677e+13 ||r(i)||/||b|| 2.392656387510e-03
>>>>  43 KSP preconditioned resid norm 2.914764729338e+14 true resid norm
>>>> 5.652869757159e+13 ||r(i)||/||b|| 2.675827970692e-03
>>>>  44 KSP preconditioned resid norm 2.823730992718e+14 true resid norm
>>>> 4.387571428023e+13 ||r(i)||/||b|| 2.076889589689e-03
>>>>  45 KSP preconditioned resid norm 2.874969520743e+14 true resid norm
>>>> 4.617969867525e+13 ||r(i)||/||b|| 2.185950405754e-03
>>>>  46 KSP preconditioned resid norm 3.038236713170e+14 true resid norm
>>>> 4.761130615995e+13 ||r(i)||/||b|| 2.253716611508e-03
>>>>  47 KSP preconditioned resid norm 3.972150696557e+14 true resid norm
>>>> 6.226543710285e+13 ||r(i)||/||b|| 2.947380805938e-03
>>>>  48 KSP preconditioned resid norm 7.035007479461e+14 true resid norm
>>>> 1.474495546291e+14 ||r(i)||/||b|| 6.979634406808e-03
>>>>  49 KSP preconditioned resid norm 2.896572855920e+13 true resid norm
>>>> 4.634266191547e+12 ||r(i)||/||b|| 2.193664392014e-04
>>>>   0 KSP preconditioned resid norm 6.694681597421e+18 true resid norm
>>>> 3.650754072308e+18 ||r(i)||/||b|| 5.229798618159e+00
>>>>   1 KSP preconditioned resid norm 1.597667334547e+18 true resid norm
>>>> 5.366749713724e+17 ||r(i)||/||b|| 7.688006280602e-01
>>>>   2 KSP preconditioned resid norm 6.300446759218e+17 true resid norm
>>>> 1.705328267289e+17 ||r(i)||/||b|| 2.442926376067e-01
>>>>   3 KSP preconditioned resid norm 3.642174486076e+17 true resid norm
>>>> 9.481576843120e+16 ||r(i)||/||b|| 1.358260142699e-01
>>>>   4 KSP preconditioned resid norm 2.247332959633e+17 true resid norm
>>>> 3.802800729913e+16 ||r(i)||/||b|| 5.447609345502e-02
>>>>   5 KSP preconditioned resid norm 1.557523701694e+17 true resid norm
>>>> 3.829141999854e+16 ||r(i)||/||b|| 5.485343888670e-02
>>>>   6 KSP preconditioned resid norm 1.004692846458e+17 true resid norm
>>>> 1.699728099753e+16 ||r(i)||/||b|| 2.434903992784e-02
>>>>   7 KSP preconditioned resid norm 7.103482800944e+16 true resid norm
>>>> 1.472858884839e+16 ||r(i)||/||b|| 2.109908037658e-02
>>>>   8 KSP preconditioned resid norm 5.766847884006e+16 true resid norm
>>>> 9.397954060610e+15 ||r(i)||/||b|| 1.346280965144e-02
>>>>   9 KSP preconditioned resid norm 4.523472015836e+16 true resid norm
>>>> 1.246374917128e+16 ||r(i)||/||b|| 1.785463959006e-02
>>>>  10 KSP preconditioned resid norm 3.195342481549e+16 true resid norm
>>>> 5.030521483345e+15 ||r(i)||/||b|| 7.206350737723e-03
>>>>  11 KSP preconditioned resid norm 2.437460220100e+16 true resid norm
>>>> 4.974645944970e+15 ||r(i)||/||b|| 7.126307599347e-03
>>>>  12 KSP preconditioned resid norm 1.258045555912e+16 true resid norm
>>>> 1.885910304740e+15 ||r(i)||/||b|| 2.701614765157e-03
>>>>  13 KSP preconditioned resid norm 2.495567167662e+15 true resid norm
>>>> 4.460991814847e+14 ||r(i)||/||b|| 6.390484915397e-04
>>>>  14 KSP preconditioned resid norm 7.678096336284e+14 true resid norm
>>>> 1.316276217008e+14 ||r(i)||/||b|| 1.885599359606e-04
>>>>  15 KSP preconditioned resid norm 5.950867488217e+14 true resid norm
>>>> 1.439410415068e+14 ||r(i)||/||b|| 2.061992248885e-04
>>>>  16 KSP preconditioned resid norm 3.263035982098e+14 true resid norm
>>>> 5.046543709851e+13 ||r(i)||/||b|| 7.229302987142e-05
>>>>  17 KSP preconditioned resid norm 1.436782483869e+14 true resid norm
>>>> 7.588970331259e+13 ||r(i)||/||b|| 1.087139417380e-04
>>>>  18 KSP preconditioned resid norm 5.401533723431e+13 true resid norm
>>>> 8.625318760812e+12 ||r(i)||/||b|| 1.235598981554e-05
>>>>  19 KSP preconditioned resid norm 3.528859982338e+13 true resid norm
>>>> 1.233587619696e+13 ||r(i)||/||b|| 1.767145828255e-05
>>>>   0 KSP preconditioned resid norm 4.827874033276e+18 true resid norm
>>>> 2.629049503582e+18 ||r(i)||/||b|| 2.387244449971e+01
>>>>   1 KSP preconditioned resid norm 1.161059891938e+18 true resid norm
>>>> 3.885117259710e+17 ||r(i)||/||b|| 3.527786222014e+00
>>>>   2 KSP preconditioned resid norm 4.696931551640e+17 true resid norm
>>>> 1.228954734511e+17 ||r(i)||/||b|| 1.115922452289e+00
>>>>   3 KSP preconditioned resid norm 2.870101730651e+17 true resid norm
>>>> 6.759381584873e+16 ||r(i)||/||b|| 6.137692025860e-01
>>>>   4 KSP preconditioned resid norm 1.966639305477e+17 true resid norm
>>>> 3.310590025777e+16 ||r(i)||/||b|| 3.006100742644e-01
>>>>   5 KSP preconditioned resid norm 1.592574496560e+17 true resid norm
>>>> 3.239415772489e+16 ||r(i)||/||b|| 2.941472693263e-01
>>>>   6 KSP preconditioned resid norm 1.230114823548e+17 true resid norm
>>>> 2.280737281236e+16 ||r(i)||/||b|| 2.070968009182e-01
>>>>   7 KSP preconditioned resid norm 8.598640814452e+16 true resid norm
>>>> 1.938029193987e+16 ||r(i)||/||b|| 1.759780266946e-01
>>>>   8 KSP preconditioned resid norm 5.549085767183e+16 true resid norm
>>>> 9.386094645880e+15 ||r(i)||/||b|| 8.522814925985e-02
>>>>   9 KSP preconditioned resid norm 4.474754629313e+16 true resid norm
>>>> 7.579167805290e+15 ||r(i)||/||b|| 6.882078961970e-02
>>>>  10 KSP preconditioned resid norm 4.378389532275e+16 true resid norm
>>>> 6.842593279419e+15 ||r(i)||/||b|| 6.213250380964e-02
>>>>  11 KSP preconditioned resid norm 4.079498017991e+16 true resid norm
>>>> 7.704710537522e+15 ||r(i)||/||b|| 6.996074986140e-02
>>>>  12 KSP preconditioned resid norm 4.084398127844e+16 true resid norm
>>>> 6.377957981626e+15 ||r(i)||/||b|| 5.791349601078e-02
>>>>  13 KSP preconditioned resid norm 7.523960004025e+16 true resid norm
>>>> 1.132262464871e+16 ||r(i)||/||b|| 1.028123388886e-01
>>>>  14 KSP preconditioned resid norm 2.184546709977e+15 true resid norm
>>>> 3.502101186681e+14 ||r(i)||/||b|| 3.179997793785e-03
>>>>  15 KSP preconditioned resid norm 2.222188254453e+15 true resid norm
>>>> 3.654675413503e+14 ||r(i)||/||b|| 3.318539109075e-03
>>>>  16 KSP preconditioned resid norm 1.669487552266e+15 true resid norm
>>>> 3.629534589137e+14 ||r(i)||/||b|| 3.295710595061e-03
>>>>  17 KSP preconditioned resid norm 1.401917499993e+15 true resid norm
>>>> 2.161165604483e+14 ||r(i)||/||b|| 1.962393856693e-03
>>>>  18 KSP preconditioned resid norm 1.134393254100e+15 true resid norm
>>>> 2.686682335159e+14 ||r(i)||/||b|| 2.439576540763e-03
>>>>  19 KSP preconditioned resid norm 9.058009036885e+14 true resid norm
>>>> 1.409928994873e+14 ||r(i)||/||b|| 1.280251727203e-03
>>>>  20 KSP preconditioned resid norm 7.990098022926e+14 true resid norm
>>>> 1.659150954933e+14 ||r(i)||/||b|| 1.506551665700e-03
>>>>  21 KSP preconditioned resid norm 7.119179981764e+14 true resid norm
>>>> 1.092130722300e+14 ||r(i)||/||b|| 9.916827362515e-04
>>>>  22 KSP preconditioned resid norm 6.306959704581e+14 true resid norm
>>>> 1.460783700778e+14 ||r(i)||/||b|| 1.326429105857e-03
>>>>  23 KSP preconditioned resid norm 5.637228678118e+14 true resid norm
>>>> 8.672640313846e+13 ||r(i)||/||b|| 7.874980074592e-04
>>>>  24 KSP preconditioned resid norm 4.960976390096e+14 true resid norm
>>>> 1.292271182132e+14 ||r(i)||/||b|| 1.173415412376e-03
>>>>  25 KSP preconditioned resid norm 4.386404742743e+14 true resid norm
>>>> 8.037964656859e+13 ||r(i)||/||b|| 7.298678282782e-04
>>>>  26 KSP preconditioned resid norm 4.419824802921e+14 true resid norm
>>>> 6.704823034514e+13 ||r(i)||/||b|| 6.088151461346e-04
>>>>  27 KSP preconditioned resid norm 4.437076279615e+14 true resid norm
>>>> 1.370394110315e+14 ||r(i)||/||b|| 1.244353036968e-03
>>>>  28 KSP preconditioned resid norm 7.848825686766e+14 true resid norm
>>>> 1.196984074237e+14 ||r(i)||/||b|| 1.086892271915e-03
>>>>  29 KSP preconditioned resid norm 1.771839364121e+15 true resid norm
>>>> 6.554952272410e+14 ||r(i)||/||b|| 5.952064961431e-03
>>>>  30 KSP preconditioned resid norm 1.052090569223e+15 true resid norm
>>>> 1.877636113350e+14 ||r(i)||/||b|| 1.704941799139e-03
>>>>  31 KSP preconditioned resid norm 2.459236824172e+14 true resid norm
>>>> 3.913333475140e+13 ||r(i)||/||b|| 3.553407270074e-04
>>>>  32 KSP preconditioned resid norm 1.091606883884e+14 true resid norm
>>>> 1.900051073024e+13 ||r(i)||/||b|| 1.725295158025e-04
>>>>  33 KSP preconditioned resid norm 6.424114279947e+13 true resid norm
>>>> 1.001416869814e+13 ||r(i)||/||b|| 9.093122291205e-05
>>>>  34 KSP preconditioned resid norm 3.801391191576e+13 true resid norm
>>>> 7.035993054761e+12 ||r(i)||/||b|| 6.388862342504e-05
>>>>  35 KSP preconditioned resid norm 2.524482106623e+13 true resid norm
>>>> 4.006294246762e+12 ||r(i)||/||b|| 3.637818037470e-05
>>>>  36 KSP preconditioned resid norm 1.579134058219e+13 true resid norm
>>>> 2.528643754315e+12 ||r(i)||/||b|| 2.296073451724e-05
>>>>  37 KSP preconditioned resid norm 1.074218958170e+13 true resid norm
>>>> 1.786180378482e+12 ||r(i)||/||b|| 1.621897643756e-05
>>>>  38 KSP preconditioned resid norm 6.572401461924e+12 true resid norm
>>>> 1.033900044668e+12 ||r(i)||/||b|| 9.388077858923e-06
>>>>   0 KSP preconditioned resid norm 9.558506771869e+15 true resid norm
>>>> 5.892974320929e+15 ||r(i)||/||b|| 1.119279921775e-01
>>>>   1 KSP preconditioned resid norm 4.577878026258e+15 true resid norm
>>>> 8.113551231445e+14 ||r(i)||/||b|| 1.541044384903e-02
>>>>   2 KSP preconditioned resid norm 3.768474917795e+15 true resid norm
>>>> 6.114238708763e+14 ||r(i)||/||b|| 1.161305692331e-02
>>>>   3 KSP preconditioned resid norm 3.689006206393e+15 true resid norm
>>>> 6.168086911615e+14 ||r(i)||/||b|| 1.171533331040e-02
>>>>   4 KSP preconditioned resid norm 3.859762637542e+15 true resid norm
>>>> 6.287723791867e+14 ||r(i)||/||b|| 1.194256518123e-02
>>>>   5 KSP preconditioned resid norm 4.285185348381e+15 true resid norm
>>>> 6.764146832146e+14 ||r(i)||/||b|| 1.284745753985e-02
>>>>   6 KSP preconditioned resid norm 5.208557345650e+15 true resid norm
>>>> 7.765898979336e+14 ||r(i)||/||b|| 1.475013181583e-02
>>>>   7 KSP preconditioned resid norm 6.471756089495e+15 true resid norm
>>>> 1.171552566673e+15 ||r(i)||/||b|| 2.225184081532e-02
>>>>   8 KSP preconditioned resid norm 7.012039525053e+15 true resid norm
>>>> 1.102268075574e+15 ||r(i)||/||b|| 2.093588836833e-02
>>>>   9 KSP preconditioned resid norm 7.014970322733e+15 true resid norm
>>>> 1.328280835862e+15 ||r(i)||/||b|| 2.522865346245e-02
>>>>  10 KSP preconditioned resid norm 6.390016130531e+15 true resid norm
>>>> 1.015385597333e+15 ||r(i)||/||b|| 1.928568919633e-02
>>>>  11 KSP preconditioned resid norm 4.845316666400e+15 true resid norm
>>>> 8.456481888760e+14 ||r(i)||/||b|| 1.606178793844e-02
>>>>  12 KSP preconditioned resid norm 2.410560854094e+15 true resid norm
>>>> 3.709640804249e+14 ||r(i)||/||b|| 7.045892690295e-03
>>>>  13 KSP preconditioned resid norm 1.334157374345e+15 true resid norm
>>>> 2.713196530598e+14 ||r(i)||/||b|| 5.153299904502e-03
>>>>  14 KSP preconditioned resid norm 1.217530036393e+15 true resid norm
>>>> 2.232136761716e+14 ||r(i)||/||b|| 4.239600792372e-03
>>>>  15 KSP preconditioned resid norm 1.145671346103e+15 true resid norm
>>>> 2.123551517116e+14 ||r(i)||/||b|| 4.033359805286e-03
>>>>  16 KSP preconditioned resid norm 1.048828510236e+15 true resid norm
>>>> 1.668978069044e+14 ||r(i)||/||b|| 3.169967389692e-03
>>>>  17 KSP preconditioned resid norm 9.144204694073e+14 true resid norm
>>>> 1.578839852075e+14 ||r(i)||/||b|| 2.998763697051e-03
>>>>  18 KSP preconditioned resid norm 8.235850213860e+14 true resid norm
>>>> 1.321988157805e+14 ||r(i)||/||b|| 2.510913371198e-03
>>>>  19 KSP preconditioned resid norm 6.978607225935e+14 true resid norm
>>>> 1.125789224246e+14 ||r(i)||/||b|| 2.138263644512e-03
>>>>  20 KSP preconditioned resid norm 6.009340490988e+14 true resid norm
>>>> 1.003011158758e+14 ||r(i)||/||b|| 1.905065574997e-03
>>>>  21 KSP preconditioned resid norm 5.123703002158e+14 true resid norm
>>>> 8.114653676231e+13 ||r(i)||/||b|| 1.541253777351e-03
>>>>  22 KSP preconditioned resid norm 4.394549158605e+14 true resid norm
>>>> 8.003106905102e+13 ||r(i)||/||b|| 1.520067182184e-03
>>>>  23 KSP preconditioned resid norm 3.852402878098e+14 true resid norm
>>>> 5.993269339949e+13 ||r(i)||/||b|| 1.138329419521e-03
>>>>  24 KSP preconditioned resid norm 3.390788847804e+14 true resid norm
>>>> 7.376626581336e+13 ||r(i)||/||b|| 1.401076871080e-03
>>>>   0 KSP preconditioned resid norm 9.592017367891e+15 true resid norm
>>>> 5.933298102242e+15 ||r(i)||/||b|| 5.704123038824e-01
>>>>   1 KSP preconditioned resid norm 4.627662883687e+15 true resid norm
>>>> 8.121175703537e+14 ||r(i)||/||b|| 7.807493342594e-02
>>>>   2 KSP preconditioned resid norm 3.843678575472e+15 true resid norm
>>>> 6.216594738645e+14 ||r(i)||/||b|| 5.976477274644e-02
>>>>   3 KSP preconditioned resid norm 3.802359495548e+15 true resid norm
>>>> 6.332926539714e+14 ||r(i)||/||b|| 6.088315731972e-02
>>>>   4 KSP preconditioned resid norm 4.025235313693e+15 true resid norm
>>>> 6.488898363947e+14 ||r(i)||/||b|| 6.238263107055e-02
>>>>   5 KSP preconditioned resid norm 4.519136017232e+15 true resid norm
>>>> 7.100489487455e+14 ||r(i)||/||b|| 6.826231376612e-02
>>>>   6 KSP preconditioned resid norm 5.566459161126e+15 true resid norm
>>>> 8.272746471009e+14 ||r(i)||/||b|| 7.953209652789e-02
>>>>   7 KSP preconditioned resid norm 7.051037635374e+15 true resid norm
>>>> 1.259719337020e+15 ||r(i)||/||b|| 1.211062375246e-01
>>>>   8 KSP preconditioned resid norm 7.825859719364e+15 true resid norm
>>>> 1.230378249193e+15 ||r(i)||/||b|| 1.182854593980e-01
>>>>   9 KSP preconditioned resid norm 8.112136766042e+15 true resid norm
>>>> 1.509007778424e+15 ||r(i)||/||b|| 1.450721990763e-01
>>>>  10 KSP preconditioned resid norm 7.849971536540e+15 true resid norm
>>>> 1.244897342905e+15 ||r(i)||/||b|| 1.196812884212e-01
>>>>  11 KSP preconditioned resid norm 6.691547560102e+15 true resid norm
>>>> 1.152431148742e+15 ||r(i)||/||b|| 1.107918218994e-01
>>>>  12 KSP preconditioned resid norm 3.838210718255e+15 true resid norm
>>>> 5.898239658450e+14 ||r(i)||/||b|| 5.670418735838e-02
>>>>  13 KSP preconditioned resid norm 1.585805121666e+15 true resid norm
>>>> 3.093588848689e+14 ||r(i)||/||b|| 2.974098236828e-02
>>>>  14 KSP preconditioned resid norm 1.284246821472e+15 true resid norm
>>>> 2.667115224243e+14 ||r(i)||/||b|| 2.564097258496e-02
>>>>  15 KSP preconditioned resid norm 1.153005952878e+15 true resid norm
>>>> 2.281947914341e+14 ||r(i)||/||b|| 2.193807128394e-02
>>>>  16 KSP preconditioned resid norm 1.029063568485e+15 true resid norm
>>>> 1.605944355705e+14 ||r(i)||/||b|| 1.543914369478e-02
>>>>  17 KSP preconditioned resid norm 8.755986525312e+14 true resid norm
>>>> 1.474488326268e+14 ||r(i)||/||b|| 1.417535860732e-02
>>>>  18 KSP preconditioned resid norm 7.769999155370e+14 true resid norm
>>>> 1.263847845681e+14 ||r(i)||/||b|| 1.215031419270e-02
>>>>  19 KSP preconditioned resid norm 6.633003954457e+14 true resid norm
>>>> 1.037940616116e+14 ||r(i)||/||b|| 9.978499106727e-03
>>>>  20 KSP preconditioned resid norm 5.634039280371e+14 true resid norm
>>>> 1.015458370156e+14 ||r(i)||/||b|| 9.762360468599e-03
>>>>  21 KSP preconditioned resid norm 4.739327677772e+14 true resid norm
>>>> 7.392362794765e+13 ||r(i)||/||b|| 7.106831007366e-03
>>>>  22 KSP preconditioned resid norm 3.847430187788e+14 true resid norm
>>>> 7.626771651358e+13 ||r(i)||/||b|| 7.332185765606e-03
>>>>  23 KSP preconditioned resid norm 3.166693300565e+14 true resid norm
>>>> 4.910897850051e+13 ||r(i)||/||b|| 4.721213241789e-03
>>>>  24 KSP preconditioned resid norm 2.603961739838e+14 true resid norm
>>>> 5.903512955155e+13 ||r(i)||/||b|| 5.675488350193e-03
>>>>  25 KSP preconditioned resid norm 2.300385519514e+14 true resid norm
>>>> 3.524302891352e+13 ||r(i)||/||b|| 3.388175846206e-03
>>>>  26 KSP preconditioned resid norm 1.995854205790e+14 true resid norm
>>>> 5.125398452570e+13 ||r(i)||/||b|| 4.927428707047e-03
>>>>  27 KSP preconditioned resid norm 1.777736693158e+14 true resid norm
>>>> 2.713391594494e+13 ||r(i)||/||b|| 2.608586192838e-03
>>>>  28 KSP preconditioned resid norm 1.569155636768e+14 true resid norm
>>>> 4.045925214031e+13 ||r(i)||/||b|| 3.889650381462e-03
>>>>  29 KSP preconditioned resid norm 1.392286125087e+14 true resid norm
>>>> 2.127117420025e+13 ||r(i)||/||b|| 2.044956999086e-03
>>>>  30 KSP preconditioned resid norm 1.268134787155e+14 true resid norm
>>>> 2.836210701297e+13 ||r(i)||/||b|| 2.726661382160e-03
>>>>  31 KSP preconditioned resid norm 1.148332814766e+14 true resid norm
>>>> 1.759485016641e+13 ||r(i)||/||b|| 1.691524485529e-03
>>>>  32 KSP preconditioned resid norm 1.072826684457e+14 true resid norm
>>>> 1.915166944365e+13 ||r(i)||/||b|| 1.841193161425e-03
>>>>  33 KSP preconditioned resid norm 9.907876839152e+13 true resid norm
>>>> 1.514435361562e+13 ||r(i)||/||b|| 1.455939932199e-03
>>>>  34 KSP preconditioned resid norm 9.246074413874e+13 true resid norm
>>>> 1.530899883812e+13 ||r(i)||/||b|| 1.471768508325e-03
>>>>  35 KSP preconditioned resid norm 8.716833484735e+13 true resid norm
>>>> 1.331822154534e+13 ||r(i)||/||b|| 1.280380204127e-03
>>>>  36 KSP preconditioned resid norm 8.124134503515e+13 true resid norm
>>>> 1.344545385639e+13 ||r(i)||/||b|| 1.292611997376e-03
>>>>  37 KSP preconditioned resid norm 7.675303961825e+13 true resid norm
>>>> 1.172301521125e+13 ||r(i)||/||b|| 1.127021093474e-03
>>>>  38 KSP preconditioned resid norm 7.135475879451e+13 true resid norm
>>>> 1.180708573448e+13 ||r(i)||/||b|| 1.135103421383e-03
>>>>  39 KSP preconditioned resid norm 6.615399842578e+13 true resid norm
>>>> 1.009923425569e+13 ||r(i)||/||b|| 9.709148908363e-04
>>>>  40 KSP preconditioned resid norm 6.137620595303e+13 true resid norm
>>>> 9.912104999293e+12 ||r(i)||/||b|| 9.529247564410e-04
>>>>  41 KSP preconditioned resid norm 5.598390411354e+13 true resid norm
>>>> 8.555770285650e+12 ||r(i)||/||b|| 8.225301604653e-04
>>>>   0 KSP preconditioned resid norm 2.200654561303e+16 true resid norm
>>>> 1.374535903551e+16 ||r(i)||/||b|| 1.042244800141e-01
>>>>   1 KSP preconditioned resid norm 1.033788570768e+16 true resid norm
>>>> 1.766933748516e+15 ||r(i)||/||b|| 1.339781308605e-02
>>>>   2 KSP preconditioned resid norm 8.199712159807e+15 true resid norm
>>>> 1.328504928257e+15 ||r(i)||/||b|| 1.007341714291e-02
>>>>   3 KSP preconditioned resid norm 7.724963557325e+15 true resid norm
>>>> 1.290091137776e+15 ||r(i)||/||b|| 9.782143751798e-03
>>>>   4 KSP preconditioned resid norm 7.785648142256e+15 true resid norm
>>>> 1.238722001104e+15 ||r(i)||/||b|| 9.392636170038e-03
>>>>   5 KSP preconditioned resid norm 8.249045346662e+15 true resid norm
>>>> 1.288778250144e+15 ||r(i)||/||b|| 9.772188753144e-03
>>>>   6 KSP preconditioned resid norm 9.469275305646e+15 true resid norm
>>>> 1.408770770519e+15 ||r(i)||/||b|| 1.068203461525e-02
>>>>   7 KSP preconditioned resid norm 1.105611185924e+16 true resid norm
>>>> 1.994387714295e+15 ||r(i)||/||b|| 1.512248766524e-02
>>>>   8 KSP preconditioned resid norm 1.130059557946e+16 true resid norm
>>>> 1.768360656538e+15 ||r(i)||/||b|| 1.340863264676e-02
>>>>   9 KSP preconditioned resid norm 1.052660615325e+16 true resid norm
>>>> 1.953565171874e+15 ||r(i)||/||b|| 1.481294986084e-02
>>>>  10 KSP preconditioned resid norm 8.559164814525e+15 true resid norm
>>>> 1.322544665666e+15 ||r(i)||/||b|| 1.002822332384e-02
>>>>  11 KSP preconditioned resid norm 4.990037328467e+15 true resid norm
>>>> 7.740616289621e+14 ||r(i)||/||b|| 5.869338921523e-03
>>>>  12 KSP preconditioned resid norm 1.334591152980e+17 true resid norm
>>>> 2.007497042766e+16 ||r(i)||/||b|| 1.522188942984e-01
>>>>  13 KSP preconditioned resid norm 7.977709053830e+14 true resid norm
>>>> 2.666709181112e+14 ||r(i)||/||b|| 2.022037962283e-03
>>>>   0 KSP preconditioned resid norm 1.928493598618e+16 true resid norm
>>>> 1.203377031534e+16 ||r(i)||/||b|| 4.946657154689e-01
>>>>   1 KSP preconditioned resid norm 9.231841001478e+15 true resid norm
>>>> 1.582820058439e+15 ||r(i)||/||b|| 6.506413170177e-02
>>>>   2 KSP preconditioned resid norm 7.541228065487e+15 true resid norm
>>>> 1.216411600127e+15 ||r(i)||/||b|| 5.000237653817e-02
>>>>   3 KSP preconditioned resid norm 7.339567418801e+15 true resid norm
>>>> 1.219667619599e+15 ||r(i)||/||b|| 5.013621997708e-02
>>>>   4 KSP preconditioned resid norm 7.654746286546e+15 true resid norm
>>>> 1.212045913869e+15 ||r(i)||/||b|| 4.982291862433e-02
>>>>   5 KSP preconditioned resid norm 8.414088698130e+15 true resid norm
>>>> 1.311254037213e+15 ||r(i)||/||b|| 5.390101352132e-02
>>>>   6 KSP preconditioned resid norm 1.008553581054e+16 true resid norm
>>>> 1.495637339777e+15 ||r(i)||/||b|| 6.148035863870e-02
>>>>   7 KSP preconditioned resid norm 1.235521461592e+16 true resid norm
>>>> 2.202862093934e+15 ||r(i)||/||b|| 9.055186572627e-02
>>>>   8 KSP preconditioned resid norm 1.311621757723e+16 true resid norm
>>>> 2.061404522413e+15 ||r(i)||/||b|| 8.473704551686e-02
>>>>   9 KSP preconditioned resid norm 1.289521641859e+16 true resid norm
>>>> 2.354903652303e+15 ||r(i)||/||b|| 9.680175618294e-02
>>>>  10 KSP preconditioned resid norm 1.151646040420e+16 true resid norm
>>>> 1.821568826477e+15 ||r(i)||/||b|| 7.487824872947e-02
>>>>  11 KSP preconditioned resid norm 8.378553284195e+15 true resid norm
>>>> 1.434374156491e+15 ||r(i)||/||b|| 5.896204595714e-02
>>>>  12 KSP preconditioned resid norm 3.545538676243e+15 true resid norm
>>>> 5.411687842502e+14 ||r(i)||/||b|| 2.224553376337e-02
>>>>  13 KSP preconditioned resid norm 1.159722122499e+15 true resid norm
>>>> 2.107714204908e+14 ||r(i)||/||b|| 8.664067269472e-03
>>>>  14 KSP preconditioned resid norm 9.539010029354e+14 true resid norm
>>>> 1.788314612223e+14 ||r(i)||/||b|| 7.351128565343e-03
>>>>  15 KSP preconditioned resid norm 8.844744179759e+14 true resid norm
>>>> 1.382762666459e+14 ||r(i)||/||b|| 5.684048023218e-03
>>>>  16 KSP preconditioned resid norm 7.998051624629e+14 true resid norm
>>>> 2.151800146054e+14 ||r(i)||/||b|| 8.845288973459e-03
>>>>  17 KSP preconditioned resid norm 6.751752084065e+14 true resid norm
>>>> 1.049375541763e+14 ||r(i)||/||b|| 4.313611524562e-03
>>>>  18 KSP preconditioned resid norm 6.016391198259e+14 true resid norm
>>>> 1.405509222696e+14 ||r(i)||/||b|| 5.777551066910e-03
>>>>  19 KSP preconditioned resid norm 5.356608668579e+14 true resid norm
>>>> 8.319469793388e+13 ||r(i)||/||b|| 3.419839642795e-03
>>>>  20 KSP preconditioned resid norm 4.666955314009e+14 true resid norm
>>>> 1.159814975417e+14 ||r(i)||/||b|| 4.767588956680e-03
>>>>  21 KSP preconditioned resid norm 4.123539296814e+14 true resid norm
>>>> 6.367161120725e+13 ||r(i)||/||b|| 2.617314631039e-03
>>>>  22 KSP preconditioned resid norm 3.572486233332e+14 true resid norm
>>>> 8.643344455842e+13 ||r(i)||/||b|| 3.552973056037e-03
>>>>  23 KSP preconditioned resid norm 3.110551508962e+14 true resid norm
>>>> 4.773889823616e+13 ||r(i)||/||b|| 1.962377179627e-03
>>>>  24 KSP preconditioned resid norm 2.787205893436e+14 true resid norm
>>>> 4.531540777818e+13 ||r(i)||/||b|| 1.862756062561e-03
>>>>  25 KSP preconditioned resid norm 2.574052602586e+14 true resid norm
>>>> 4.020202768069e+13 ||r(i)||/||b|| 1.652563100745e-03
>>>>  26 KSP preconditioned resid norm 2.417321052344e+14 true resid norm
>>>> 3.935243057179e+13 ||r(i)||/||b|| 1.617639169947e-03
>>>>  27 KSP preconditioned resid norm 2.257728086711e+14 true resid norm
>>>> 3.470313603079e+13 ||r(i)||/||b|| 1.426523123165e-03
>>>>  28 KSP preconditioned resid norm 2.082687407590e+14 true resid norm
>>>> 3.533906053355e+13 ||r(i)||/||b|| 1.452663729217e-03
>>>>  29 KSP preconditioned resid norm 1.877437540892e+14 true resid norm
>>>> 2.879571658728e+13 ||r(i)||/||b|| 1.183690013589e-03
>>>>  30 KSP preconditioned resid norm 1.698389677822e+14 true resid norm
>>>> 2.905672512335e+13 ||r(i)||/||b|| 1.194419150913e-03
>>>>  31 KSP preconditioned resid norm 1.483411237433e+14 true resid norm
>>>> 2.274318996948e+13 ||r(i)||/||b|| 9.348920615478e-04
>>>>  32 KSP preconditioned resid norm 1.319650244589e+14 true resid norm
>>>> 2.174098043497e+13 ||r(i)||/||b|| 8.936947739606e-04
>>>>   0 KSP preconditioned resid norm 6.130010037542e+16 true resid norm
>>>> 4.019535297204e+16 ||r(i)||/||b|| 5.748505993040e-02
>>>>   1 KSP preconditioned resid norm 2.383231272294e+16 true resid norm
>>>> 4.333028202793e+15 ||r(i)||/||b|| 6.196845344062e-03
>>>>   2 KSP preconditioned resid norm 1.380314308424e+16 true resid norm
>>>> 2.902938638811e+15 ||r(i)||/||b|| 4.151614285921e-03
>>>>   3 KSP preconditioned resid norm 9.355422663861e+15 true resid norm
>>>> 1.914374541722e+15 ||r(i)||/||b|| 2.737827313936e-03
>>>>   4 KSP preconditioned resid norm 6.905389449720e+15 true resid norm
>>>> 1.160495113499e+15 ||r(i)||/||b|| 1.659672728707e-03
>>>>   5 KSP preconditioned resid norm 5.388850196885e+15 true resid norm
>>>> 9.343171628690e+14 ||r(i)||/||b|| 1.336206156440e-03
>>>>   6 KSP preconditioned resid norm 4.456941607393e+15 true resid norm
>>>> 7.443205302890e+14 ||r(i)||/||b|| 1.064484004428e-03
>>>>   7 KSP preconditioned resid norm 3.604897945956e+15 true resid norm
>>>> 7.177354673261e+14 ||r(i)||/||b|| 1.026463591006e-03
>>>>   8 KSP preconditioned resid norm 2.616552593649e+15 true resid norm
>>>> 4.566784798390e+14 ||r(i)||/||b|| 6.531150454316e-04
>>>>   9 KSP preconditioned resid norm 1.730753896393e+15 true resid norm
>>>> 3.416577992882e+14 ||r(i)||/||b|| 4.886191466320e-04
>>>>  10 KSP preconditioned resid norm 9.605913238033e+14 true resid norm
>>>> 1.715828091641e+14 ||r(i)||/||b|| 2.453877709368e-04
>>>>  11 KSP preconditioned resid norm 3.885469473149e+14 true resid norm
>>>> 7.526615944264e+13 ||r(i)||/||b|| 1.076412910045e-04
>>>>  12 KSP preconditioned resid norm 1.085402135701e+14 true resid norm
>>>> 1.877490961949e+13 ||r(i)||/||b|| 2.685078559740e-05
>>>>  13 KSP preconditioned resid norm 5.521535097548e+13 true resid norm
>>>> 1.482831670997e+13 ||r(i)||/||b|| 2.120659757192e-05
>>>>  14 KSP preconditioned resid norm 4.327778991064e+13 true resid norm
>>>> 6.949075957635e+12 ||r(i)||/||b|| 9.938164945670e-06
>>>>   0 KSP preconditioned resid norm 2.469229041488e+16 true resid norm
>>>> 1.581397714283e+16 ||r(i)||/||b|| 1.421322439001e-01
>>>>   1 KSP preconditioned resid norm 1.094866313372e+16 true resid norm
>>>> 1.827538507852e+15 ||r(i)||/||b|| 1.642547896642e-02
>>>>   2 KSP preconditioned resid norm 7.902647446780e+15 true resid norm
>>>> 1.331972422469e+15 ||r(i)||/||b|| 1.197144952903e-02
>>>>   3 KSP preconditioned resid norm 6.757114900348e+15 true resid norm
>>>> 1.177404752019e+15 ||r(i)||/||b|| 1.058223227919e-02
>>>>   4 KSP preconditioned resid norm 6.236820681429e+15 true resid norm
>>>> 9.858934558838e+14 ||r(i)||/||b|| 8.860974558495e-03
>>>>   5 KSP preconditioned resid norm 6.056208231119e+15 true resid norm
>>>> 9.498735329089e+14 ||r(i)||/||b|| 8.537236106662e-03
>>>>   6 KSP preconditioned resid norm 6.281150442631e+15 true resid norm
>>>> 9.439017368810e+14 ||r(i)||/||b|| 8.483563032401e-03
>>>>   7 KSP preconditioned resid norm 6.511637444968e+15 true resid norm
>>>> 1.175605283055e+15 ||r(i)||/||b|| 1.056605908257e-02
>>>>   8 KSP preconditioned resid norm 5.897282453520e+15 true resid norm
>>>> 9.358326231502e+14 ||r(i)||/||b|| 8.411039768298e-03
>>>>   9 KSP preconditioned resid norm 4.858643646570e+15 true resid norm
>>>> 9.074077133036e+14 ||r(i)||/||b|| 8.155563477757e-03
>>>>  10 KSP preconditioned resid norm 3.431227043473e+15 true resid norm
>>>> 5.523077341885e+14 ||r(i)||/||b|| 4.964009804403e-03
>>>>  11 KSP preconditioned resid norm 1.790602152143e+15 true resid norm
>>>> 3.233768236148e+14 ||r(i)||/||b|| 2.906433539808e-03
>>>>  12 KSP preconditioned resid norm 6.061523931075e+14 true resid norm
>>>> 9.361733206500e+13 ||r(i)||/||b|| 8.414101875932e-04
>>>>  13 KSP preconditioned resid norm 3.669173259935e+14 true resid norm
>>>> 7.433445474494e+13 ||r(i)||/||b|| 6.681002986515e-04
>>>>  14 KSP preconditioned resid norm 1.034316883992e+15 true resid norm
>>>> 1.749783469552e+14 ||r(i)||/||b|| 1.572663528097e-03
>>>>  15 KSP preconditioned resid norm 1.340579303848e+14 true resid norm
>>>> 2.477734260421e+13 ||r(i)||/||b|| 2.226928286548e-04
>>>>  16 KSP preconditioned resid norm 1.124182191319e+14 true resid norm
>>>> 1.917839477947e+13 ||r(i)||/||b|| 1.723708248589e-04
>>>>  17 KSP preconditioned resid norm 9.394060484065e+13 true resid norm
>>>> 1.682558945581e+13 ||r(i)||/||b|| 1.512243733944e-04
>>>>  18 KSP preconditioned resid norm 9.034672558986e+13 true resid norm
>>>> 1.892870450718e+13 ||r(i)||/||b|| 1.701266684168e-04
>>>>  19 KSP preconditioned resid norm 8.058964131802e+13 true resid norm
>>>> 1.275370577304e+13 ||r(i)||/||b|| 1.146272568369e-04
>>>>  20 KSP preconditioned resid norm 6.303390378547e+13 true resid norm
>>>> 1.900069972515e+13 ||r(i)||/||b|| 1.707737442148e-04
>>>>  21 KSP preconditioned resid norm 4.601826552473e+13 true resid norm
>>>> 6.960266416937e+12 ||r(i)||/||b|| 6.255720967895e-05
>>>>  22 KSP preconditioned resid norm 2.822788042823e+13 true resid norm
>>>> 1.013300658091e+13 ||r(i)||/||b|| 9.107303936204e-05
>>>>  23 KSP preconditioned resid norm 1.858182222289e+13 true resid norm
>>>> 2.785683196819e+12 ||r(i)||/||b|| 2.503705424529e-05
>>>>  24 KSP preconditioned resid norm 9.506926663598e+12 true resid norm
>>>> 4.268961211449e+12 ||r(i)||/||b|| 3.836840224479e-05
>>>>  25 KSP preconditioned resid norm 5.845171932356e+12 true resid norm
>>>> 8.923162702109e+11 ||r(i)||/||b|| 8.019925197071e-06
>>>> 4 TS dt 6e-12 time 1.4e-11
>>>>   0 KSP preconditioned resid norm 2.220105437401e+19 true resid norm
>>>> 1.204162959566e+19 ||r(i)||/||b|| 2.302124615573e+02
>>>>   1 KSP preconditioned resid norm 5.389751984623e+18 true resid norm
>>>> 1.775745946542e+18 ||r(i)||/||b|| 3.394879756150e+01
>>>>   2 KSP preconditioned resid norm 2.218217192238e+18 true resid norm
>>>> 5.319400119211e+17 ||r(i)||/||b|| 1.016965507636e+01
>>>>   3 KSP preconditioned resid norm 1.401615472906e+18 true resid norm
>>>> 2.963370402601e+17 ||r(i)||/||b|| 5.665385980104e+00
>>>>   4 KSP preconditioned resid norm 1.004001983833e+18 true resid norm
>>>> 1.656139793050e+17 ||r(i)||/||b|| 3.166216128906e+00
>>>>   5 KSP preconditioned resid norm 8.672200498511e+17 true resid norm
>>>> 1.510248645324e+17 ||r(i)||/||b|| 2.887300721564e+00
>>>>   6 KSP preconditioned resid norm 7.388847075384e+17 true resid norm
>>>> 1.526081348396e+17 ||r(i)||/||b|| 2.917569760470e+00
>>>>   7 KSP preconditioned resid norm 5.565797182786e+17 true resid norm
>>>> 1.017271957075e+17 ||r(i)||/||b|| 1.944825486043e+00
>>>>   8 KSP preconditioned resid norm 3.566434137336e+17 true resid norm
>>>> 6.306431985913e+16 ||r(i)||/||b|| 1.205666741023e+00
>>>>   9 KSP preconditioned resid norm 1.893287605930e+17 true resid norm
>>>> 3.267942353405e+16 ||r(i)||/||b|| 6.247668120231e-01
>>>>  10 KSP preconditioned resid norm 6.895870882324e+16 true resid norm
>>>> 1.153127225742e+16 ||r(i)||/||b|| 2.204554250883e-01
>>>>  11 KSP preconditioned resid norm 5.104972946485e+16 true resid norm
>>>> 9.275497869859e+15 ||r(i)||/||b|| 1.773294203933e-01
>>>>  12 KSP preconditioned resid norm 4.992720890366e+16 true resid norm
>>>> 8.399052910493e+15 ||r(i)||/||b|| 1.605735029394e-01
>>>>  13 KSP preconditioned resid norm 4.919979261885e+16 true resid norm
>>>> 8.426637216788e+15 ||r(i)||/||b|| 1.611008610517e-01
>>>>  14 KSP preconditioned resid norm 5.688292138515e+16 true resid norm
>>>> 9.762950550877e+15 ||r(i)||/||b|| 1.866485645090e-01
>>>>  15 KSP preconditioned resid norm 1.614157649132e+17 true resid norm
>>>> 4.341833601566e+16 ||r(i)||/||b|| 8.300738642954e-01
>>>>  16 KSP preconditioned resid norm 4.125579354715e+16 true resid norm
>>>> 7.099585962609e+15 ||r(i)||/||b|| 1.357302304896e-01
>>>>  17 KSP preconditioned resid norm 2.163051916179e+16 true resid norm
>>>> 5.849969022355e+15 ||r(i)||/||b|| 1.118399929155e-01
>>>>  18 KSP preconditioned resid norm 1.415003279507e+16 true resid norm
>>>> 2.432246275858e+15 ||r(i)||/||b|| 4.649980285729e-02
>>>>  19 KSP preconditioned resid norm 1.088163683743e+16 true resid norm
>>>> 2.488576155885e+15 ||r(i)||/||b|| 4.757672024934e-02
>>>>  20 KSP preconditioned resid norm 9.060374162401e+15 true resid norm
>>>> 1.588297599957e+15 ||r(i)||/||b|| 3.036515093466e-02
>>>>  21 KSP preconditioned resid norm 7.815461281280e+15 true resid norm
>>>> 1.346385634634e+15 ||r(i)||/||b|| 2.574026619006e-02
>>>>  22 KSP preconditioned resid norm 6.943207518072e+15 true resid norm
>>>> 1.184751633436e+15 ||r(i)||/||b|| 2.265013947659e-02
>>>>  23 KSP preconditioned resid norm 6.246190157097e+15 true resid norm
>>>> 1.023840274541e+15 ||r(i)||/||b|| 1.957382827391e-02
>>>>  24 KSP preconditioned resid norm 5.682318425500e+15 true resid norm
>>>> 9.496257176169e+14 ||r(i)||/||b|| 1.815499075718e-02
>>>>  25 KSP preconditioned resid norm 5.282641218542e+15 true resid norm
>>>> 8.559439950771e+14 ||r(i)||/||b|| 1.636397901932e-02
>>>>  26 KSP preconditioned resid norm 5.115699254805e+15 true resid norm
>>>> 8.571023693113e+14 ||r(i)||/||b|| 1.638612487439e-02
>>>>  27 KSP preconditioned resid norm 4.941038732000e+15 true resid norm
>>>> 9.550184315260e+14 ||r(i)||/||b|| 1.825808892456e-02
>>>>  28 KSP preconditioned resid norm 4.836641976772e+15 true resid norm
>>>> 7.564719174843e+14 ||r(i)||/||b|| 1.446226699132e-02
>>>>  29 KSP preconditioned resid norm 4.905885514019e+15 true resid norm
>>>> 7.773698572205e+14 ||r(i)||/||b|| 1.486179482182e-02
>>>>  30 KSP preconditioned resid norm 5.169672483375e+15 true resid norm
>>>> 8.117514654202e+14 ||r(i)||/||b|| 1.551910408326e-02
>>>>  31 KSP preconditioned resid norm 5.732174203621e+15 true resid norm
>>>> 9.079138157636e+14 ||r(i)||/||b|| 1.735754058438e-02
>>>>  32 KSP preconditioned resid norm 8.584579912384e+15 true resid norm
>>>> 1.381429969496e+15 ||r(i)||/||b|| 2.641024549212e-02
>>>>  33 KSP preconditioned resid norm 1.658456221337e+16 true resid norm
>>>> 2.668310391151e+15 ||r(i)||/||b|| 5.101288811997e-02
>>>>  34 KSP preconditioned resid norm 3.797117274875e+16 true resid norm
>>>> 6.214594485387e+15 ||r(i)||/||b|| 1.188109202908e-01
>>>>  35 KSP preconditioned resid norm 6.896188371971e+15 true resid norm
>>>> 1.129650731508e+15 ||r(i)||/||b|| 2.159671774774e-02
>>>>  36 KSP preconditioned resid norm 3.678389972715e+15 true resid norm
>>>> 6.014447539523e+14 ||r(i)||/||b|| 1.149845012239e-02
>>>>  37 KSP preconditioned resid norm 2.344506104501e+15 true resid norm
>>>> 4.262436512363e+14 ||r(i)||/||b|| 8.148946900809e-03
>>>>  38 KSP preconditioned resid norm 1.979277723710e+15 true resid norm
>>>> 3.194432632084e+14 ||r(i)||/||b|| 6.107131876701e-03
>>>>  39 KSP preconditioned resid norm 1.806670892810e+15 true resid norm
>>>> 3.108273060962e+14 ||r(i)||/||b|| 5.942411588660e-03
>>>>  40 KSP preconditioned resid norm 1.663957842585e+15 true resid norm
>>>> 2.662101226861e+14 ||r(i)||/||b|| 5.089418101442e-03
>>>>  41 KSP preconditioned resid norm 1.486329834699e+15 true resid norm
>>>> 2.427881601889e+14 ||r(i)||/||b|| 4.641635880760e-03
>>>>  42 KSP preconditioned resid norm 1.346929765546e+15 true resid norm
>>>> 2.207126725819e+14 ||r(i)||/||b|| 4.219595632660e-03
>>>>  43 KSP preconditioned resid norm 1.242596801597e+15 true resid norm
>>>> 2.017748115787e+14 ||r(i)||/||b|| 3.857540682909e-03
>>>>  44 KSP preconditioned resid norm 1.178815061343e+15 true resid norm
>>>> 1.881589524072e+14 ||r(i)||/||b|| 3.597232023587e-03
>>>>  45 KSP preconditioned resid norm 9.347996687830e+14 true resid norm
>>>> 2.754924905110e+14 ||r(i)||/||b|| 5.266878861971e-03
>>>>  46 KSP preconditioned resid norm 7.515414326072e+14 true resid norm
>>>> 1.170313953112e+14 ||r(i)||/||b|| 2.237411920043e-03
>>>>  47 KSP preconditioned resid norm 7.344982573734e+14 true resid norm
>>>> 1.334969192887e+14 ||r(i)||/||b|| 2.552200610027e-03
>>>>  48 KSP preconditioned resid norm 8.030126805909e+14 true resid norm
>>>> 1.311086080593e+14 ||r(i)||/||b|| 2.506540759528e-03
>>>>  49 KSP preconditioned resid norm 9.282223496248e+14 true resid norm
>>>> 1.446635532628e+14 ||r(i)||/||b|| 2.765684862641e-03
>>>>  50 KSP preconditioned resid norm 1.074003818336e+15 true resid norm
>>>> 3.137568207714e+14 ||r(i)||/||b|| 5.998418193015e-03
>>>>  51 KSP preconditioned resid norm 1.638671425800e+15 true resid norm
>>>> 2.543484445494e+14 ||r(i)||/||b|| 4.862645960648e-03
>>>>  52 KSP preconditioned resid norm 2.418883444028e+15 true resid norm
>>>> 6.581384678327e+14 ||r(i)||/||b|| 1.258232330779e-02
>>>>  53 KSP preconditioned resid norm 8.572181890774e+14 true resid norm
>>>> 1.327918910006e+14 ||r(i)||/||b|| 2.538721844848e-03
>>>>  54 KSP preconditioned resid norm 2.577275091696e+14 true resid norm
>>>> 8.010767963629e+13 ||r(i)||/||b|| 1.531502523990e-03
>>>>   0 KSP preconditioned resid norm 6.542967041071e+18 true resid norm
>>>> 3.545980595607e+18 ||r(i)||/||b|| 4.156826068038e+02
>>>>   1 KSP preconditioned resid norm 1.591191551470e+18 true resid norm
>>>> 5.223269779130e+17 ||r(i)||/||b|| 6.123052112913e+01
>>>>   2 KSP preconditioned resid norm 6.570663371928e+17 true resid norm
>>>> 1.552539857829e+17 ||r(i)||/||b|| 1.819986877731e+01
>>>>   3 KSP preconditioned resid norm 4.165904471738e+17 true resid norm
>>>> 8.738677344351e+16 ||r(i)||/||b|| 1.024403851227e+01
>>>>   4 KSP preconditioned resid norm 2.995075360323e+17 true resid norm
>>>> 4.934782956985e+16 ||r(i)||/||b|| 5.784869342240e+00
>>>>   5 KSP preconditioned resid norm 2.594552595600e+17 true resid norm
>>>> 4.469892332113e+16 ||r(i)||/||b|| 5.239894710780e+00
>>>>   6 KSP preconditioned resid norm 2.219662091794e+17 true resid norm
>>>> 4.652217437246e+16 ||r(i)||/||b|| 5.453627902330e+00
>>>>   7 KSP preconditioned resid norm 1.674952385698e+17 true resid norm
>>>> 2.988890119169e+16 ||r(i)||/||b|| 3.503768852333e+00
>>>>   8 KSP preconditioned resid norm 1.081926357303e+17 true resid norm
>>>> 1.908191297028e+16 ||r(i)||/||b|| 2.236904323761e+00
>>>>   9 KSP preconditioned resid norm 5.710239913499e+16 true resid norm
>>>> 9.635393149266e+15 ||r(i)||/||b|| 1.129522633832e+00
>>>>  10 KSP preconditioned resid norm 1.779371916701e+16 true resid norm
>>>> 2.952475144259e+15 ||r(i)||/||b|| 3.461080881292e-01
>>>>  11 KSP preconditioned resid norm 1.125590077314e+16 true resid norm
>>>> 2.030360591090e+15 ||r(i)||/||b|| 2.380119012218e-01
>>>>  12 KSP preconditioned resid norm 1.086608349874e+16 true resid norm
>>>> 1.877856566597e+15 ||r(i)||/||b|| 2.201344005587e-01
>>>>  13 KSP preconditioned resid norm 1.075368648574e+16 true resid norm
>>>> 1.822636849246e+15 ||r(i)||/||b|| 2.136611908395e-01
>>>>  14 KSP preconditioned resid norm 1.173878698877e+16 true resid norm
>>>> 2.130421173676e+15 ||r(i)||/||b|| 2.497416449940e-01
>>>>  15 KSP preconditioned resid norm 4.944017897832e+16 true resid norm
>>>> 1.361808358525e+16 ||r(i)||/||b|| 1.596399171332e+00
>>>>  16 KSP preconditioned resid norm 1.780572750257e+17 true resid norm
>>>> 3.371295639234e+16 ||r(i)||/||b|| 3.952049149280e+00
>>>>  17 KSP preconditioned resid norm 3.251503916379e+16 true resid norm
>>>> 8.719191629936e+15 ||r(i)||/||b|| 1.022119610706e+00
>>>>  18 KSP preconditioned resid norm 2.075735168556e+16 true resid norm
>>>> 3.945307122742e+15 ||r(i)||/||b|| 4.624942255619e-01
>>>>  19 KSP preconditioned resid norm 1.483613863843e+16 true resid norm
>>>> 3.390657011871e+15 ||r(i)||/||b|| 3.974745793076e-01
>>>>  20 KSP preconditioned resid norm 1.134405248775e+16 true resid norm
>>>> 2.490065225313e+15 ||r(i)||/||b|| 2.919014292554e-01
>>>>  21 KSP preconditioned resid norm 8.553736210329e+15 true resid norm
>>>> 1.657655420050e+15 ||r(i)||/||b|| 1.943210087055e-01
>>>>  22 KSP preconditioned resid norm 6.586515952486e+15 true resid norm
>>>> 1.286392357530e+15 ||r(i)||/||b|| 1.507991694069e-01
>>>>  23 KSP preconditioned resid norm 4.780127454522e+15 true resid norm
>>>> 9.064248964802e+14 ||r(i)||/||b|| 1.062569446397e-01
>>>>  24 KSP preconditioned resid norm 3.027986246405e+15 true resid norm
>>>> 6.179735775190e+14 ||r(i)||/||b|| 7.244282948339e-02
>>>>  25 KSP preconditioned resid norm 1.571830581724e+15 true resid norm
>>>> 2.758055375192e+14 ||r(i)||/||b|| 3.233169548331e-02
>>>>  26 KSP preconditioned resid norm 1.182949949046e+15 true resid norm
>>>> 2.283703518838e+14 ||r(i)||/||b|| 2.677103854019e-02
>>>>  27 KSP preconditioned resid norm 1.078564628165e+15 true resid norm
>>>> 2.041848112402e+14 ||r(i)||/||b|| 2.393585422076e-02
>>>>  28 KSP preconditioned resid norm 1.016575362098e+15 true resid norm
>>>> 1.676746397025e+14 ||r(i)||/||b|| 1.965589755702e-02
>>>>  29 KSP preconditioned resid norm 9.501065512919e+14 true resid norm
>>>> 1.807838083536e+14 ||r(i)||/||b|| 2.119263845308e-02
>>>>  30 KSP preconditioned resid norm 9.022105299639e+14 true resid norm
>>>> 1.464542351381e+14 ||r(i)||/||b|| 1.716830552177e-02
>>>>  31 KSP preconditioned resid norm 8.706508374697e+14 true resid norm
>>>> 1.587763993315e+14 ||r(i)||/||b|| 1.861278870358e-02
>>>>  32 KSP preconditioned resid norm 8.363545887412e+14 true resid norm
>>>> 1.341498283380e+14 ||r(i)||/||b|| 1.572590397559e-02
>>>>  33 KSP preconditioned resid norm 8.049250107078e+14 true resid norm
>>>> 1.594310708223e+14 ||r(i)||/||b|| 1.868953349802e-02
>>>>  34 KSP preconditioned resid norm 7.730163706333e+14 true resid norm
>>>> 1.360746921537e+14 ||r(i)||/||b|| 1.595154886763e-02
>>>>  35 KSP preconditioned resid norm 7.656443951451e+14 true resid norm
>>>> 1.202971650940e+14 ||r(i)||/||b|| 1.410200587090e-02
>>>>  36 KSP preconditioned resid norm 7.731881795958e+14 true resid norm
>>>> 1.274146022068e+14 ||r(i)||/||b|| 1.493635753557e-02
>>>>  37 KSP preconditioned resid norm 8.066446225342e+14 true resid norm
>>>> 1.271087970298e+14 ||r(i)||/||b|| 1.490050908979e-02
>>>>  38 KSP preconditioned resid norm 8.449932808607e+14 true resid norm
>>>> 1.374808484319e+14 ||r(i)||/||b|| 1.611638753257e-02
>>>>  39 KSP preconditioned resid norm 8.841110986186e+14 true resid norm
>>>> 1.396540752943e+14 ||r(i)||/||b|| 1.637114713515e-02
>>>>  40 KSP preconditioned resid norm 9.488359303223e+14 true resid norm
>>>> 1.529468173159e+14 ||r(i)||/||b|| 1.792940768006e-02
>>>>  41 KSP preconditioned resid norm 1.207535627829e+15 true resid norm
>>>> 1.911287075526e+14 ||r(i)||/||b|| 2.240533394033e-02
>>>>  42 KSP preconditioned resid norm 2.145532208476e+15 true resid norm
>>>> 3.678432914805e+14 ||r(i)||/||b|| 4.312095178618e-02
>>>>  43 KSP preconditioned resid norm 1.285566323841e+16 true resid norm
>>>> 2.041241798720e+15 ||r(i)||/||b|| 2.392874662258e-01
>>>>  44 KSP preconditioned resid norm 1.228721458245e+15 true resid norm
>>>> 2.037912017178e+14 ||r(i)||/||b|| 2.388971278599e-02
>>>>  45 KSP preconditioned resid norm 6.120797893644e+14 true resid norm
>>>> 9.792977962736e+13 ||r(i)||/||b|| 1.147995737192e-02
>>>>  46 KSP preconditioned resid norm 4.263304414021e+14 true resid norm
>>>> 6.948352885735e+13 ||r(i)||/||b|| 8.145305262283e-03
>>>>  47 KSP preconditioned resid norm 2.943667166575e+14 true resid norm
>>>> 4.740665276317e+13 ||r(i)||/||b|| 5.557312136691e-03
>>>>  48 KSP preconditioned resid norm 1.946102625201e+14 true resid norm
>>>> 3.133411275125e+13 ||r(i)||/||b|| 3.673185828050e-03
>>>>  49 KSP preconditioned resid norm 1.369383238938e+14 true resid norm
>>>> 2.605829767015e+13 ||r(i)||/||b|| 3.054720919178e-03
>>>>  50 KSP preconditioned resid norm 9.297342410318e+13 true resid norm
>>>> 1.484605459745e+13 ||r(i)||/||b|| 1.740349815638e-03
>>>>  51 KSP preconditioned resid norm 6.674823642018e+13 true resid norm
>>>> 2.111621172189e+13 ||r(i)||/||b|| 2.475377881439e-03
>>>>  52 KSP preconditioned resid norm 5.794642992605e+13 true resid norm
>>>> 9.469052681739e+12 ||r(i)||/||b|| 1.110023136501e-03
>>>>  53 KSP preconditioned resid norm 4.582540149696e+13 true resid norm
>>>> 7.443523694856e+12 ||r(i)||/||b|| 8.725776269382e-04
>>>>   0 KSP preconditioned resid norm 1.892653228182e+19 true resid norm
>>>> 1.028330526045e+19 ||r(i)||/||b|| 7.841194129911e+01
>>>>   1 KSP preconditioned resid norm 4.581281818866e+18 true resid norm
>>>> 1.519814562161e+18 ||r(i)||/||b|| 1.158884300480e+01
>>>>   2 KSP preconditioned resid norm 1.874494262231e+18 true resid norm
>>>> 4.646649902787e+17 ||r(i)||/||b|| 3.543149115843e+00
>>>>   3 KSP preconditioned resid norm 1.173263764111e+18 true resid norm
>>>> 2.551017670341e+17 ||r(i)||/||b|| 1.945194105918e+00
>>>>   4 KSP preconditioned resid norm 8.301325588811e+17 true resid norm
>>>> 1.381381450838e+17 ||r(i)||/||b|| 1.053326712486e+00
>>>>   5 KSP preconditioned resid norm 7.052947600755e+17 true resid norm
>>>> 1.287824897888e+17 ||r(i)||/||b|| 9.819882590194e-01
>>>>   6 KSP preconditioned resid norm 5.863848966069e+17 true resid norm
>>>> 1.166961566059e+17 ||r(i)||/||b|| 8.898279249584e-01
>>>>   7 KSP preconditioned resid norm 4.330736686179e+17 true resid norm
>>>> 8.611330077675e+16 ||r(i)||/||b|| 6.566284783504e-01
>>>>   8 KSP preconditioned resid norm 2.702589924096e+17 true resid norm
>>>> 4.803726753137e+16 ||r(i)||/||b|| 3.662922870069e-01
>>>>   9 KSP preconditioned resid norm 1.546977321412e+17 true resid norm
>>>> 2.878601764016e+16 ||r(i)||/||b|| 2.194982516096e-01
>>>>  10 KSP preconditioned resid norm 9.910027101694e+16 true resid norm
>>>> 1.648820746608e+16 ||r(i)||/||b|| 1.257253697341e-01
>>>>  11 KSP preconditioned resid norm 9.241668505040e+16 true resid norm
>>>> 1.559203946128e+16 ||r(i)||/||b|| 1.188919371745e-01
>>>>  12 KSP preconditioned resid norm 9.244329678182e+16 true resid norm
>>>> 1.506886748242e+16 ||r(i)||/||b|| 1.149026623784e-01
>>>>  13 KSP preconditioned resid norm 7.090985777634e+16 true resid norm
>>>> 1.150411231671e+16 ||r(i)||/||b|| 8.772080151562e-02
>>>>  14 KSP preconditioned resid norm 2.014608975967e+17 true resid norm
>>>> 3.263298275594e+16 ||r(i)||/||b|| 2.488320110574e-01
>>>>  15 KSP preconditioned resid norm 1.667109940317e+16 true resid norm
>>>> 4.390284971711e+15 ||r(i)||/||b|| 3.347666521311e-02
>>>>  16 KSP preconditioned resid norm 1.169352181037e+16 true resid norm
>>>> 1.861078956987e+15 ||r(i)||/||b|| 1.419104171589e-02
>>>>  17 KSP preconditioned resid norm 1.018452985290e+16 true resid norm
>>>> 1.996695440591e+15 ||r(i)||/||b|| 1.522514033324e-02
>>>>  18 KSP preconditioned resid norm 9.390559252345e+15 true resid norm
>>>> 1.536845912378e+15 ||r(i)||/||b|| 1.171870992984e-02
>>>>  19 KSP preconditioned resid norm 8.796086996183e+15 true resid norm
>>>> 1.422370571244e+15 ||r(i)||/||b|| 1.084581609835e-02
>>>>  20 KSP preconditioned resid norm 8.297954532675e+15 true resid norm
>>>> 1.485654737712e+15 ||r(i)||/||b|| 1.132836856767e-02
>>>>  21 KSP preconditioned resid norm 7.837153561450e+15 true resid norm
>>>> 1.247795221846e+15 ||r(i)||/||b|| 9.514649542211e-03
>>>>  22 KSP preconditioned resid norm 7.441474574169e+15 true resid norm
>>>> 1.321880544976e+15 ||r(i)||/||b|| 1.007956265733e-02
>>>>  23 KSP preconditioned resid norm 7.117292465449e+15 true resid norm
>>>> 1.122736430687e+15 ||r(i)||/||b|| 8.561055114844e-03
>>>>  24 KSP preconditioned resid norm 5.694316647476e+15 true resid norm
>>>> 2.071287152890e+15 ||r(i)||/||b|| 1.579391475139e-02
>>>>  25 KSP preconditioned resid norm 4.803477075252e+15 true resid norm
>>>> 7.688470974380e+14 ||r(i)||/||b|| 5.862589113657e-03
>>>>  26 KSP preconditioned resid norm 4.890644639484e+15 true resid norm
>>>> 7.629702578172e+14 ||r(i)||/||b|| 5.817777217899e-03
>>>>  27 KSP preconditioned resid norm 5.168669214975e+15 true resid norm
>>>> 8.754612707062e+14 ||r(i)||/||b|| 6.675540211016e-03
>>>>  28 KSP preconditioned resid norm 8.939764002038e+15 true resid norm
>>>> 1.397979783339e+15 ||r(i)||/||b|| 1.065983221661e-02
>>>>  29 KSP preconditioned resid norm 8.205557149295e+15 true resid norm
>>>> 1.863983796228e+15 ||r(i)||/||b|| 1.421319160626e-02
>>>>  30 KSP preconditioned resid norm 1.967760781914e+15 true resid norm
>>>> 3.069470515034e+14 ||r(i)||/||b|| 2.340523165932e-03
>>>>  31 KSP preconditioned resid norm 1.158003829729e+15 true resid norm
>>>> 2.612136672864e+14 ||r(i)||/||b|| 1.991798378735e-03
>>>>  32 KSP preconditioned resid norm 8.020817038350e+14 true resid norm
>>>> 1.249397423467e+14 ||r(i)||/||b|| 9.526866600465e-04
>>>>   0 KSP preconditioned resid norm 6.470845423033e+18 true resid norm
>>>> 3.511573094792e+18 ||r(i)||/||b|| 1.662215647083e+02
>>>>   1 KSP preconditioned resid norm 1.571609661901e+18 true resid norm
>>>> 5.187508694693e+17 ||r(i)||/||b|| 2.455525739870e+01
>>>>   2 KSP preconditioned resid norm 6.468393005498e+17 true resid norm
>>>> 1.566999779328e+17 ||r(i)||/||b|| 7.417449336415e+00
>>>>   3 KSP preconditioned resid norm 4.084082755984e+17 true resid norm
>>>> 8.688467105425e+16 ||r(i)||/||b|| 4.112716888400e+00
>>>>   4 KSP preconditioned resid norm 2.920922708944e+17 true resid norm
>>>> 4.832004038605e+16 ||r(i)||/||b|| 2.287246343141e+00
>>>>   5 KSP preconditioned resid norm 2.515891595070e+17 true resid norm
>>>> 4.435607154638e+16 ||r(i)||/||b|| 2.099610464520e+00
>>>>   6 KSP preconditioned resid norm 2.133101049372e+17 true resid norm
>>>> 4.355693207474e+16 ||r(i)||/||b|| 2.061782912647e+00
>>>>   7 KSP preconditioned resid norm 1.601303798951e+17 true resid norm
>>>> 2.999351550015e+16 ||r(i)||/||b|| 1.419753752223e+00
>>>>   8 KSP preconditioned resid norm 1.019899000725e+17 true resid norm
>>>> 1.811131044506e+16 ||r(i)||/||b|| 8.573053386130e-01
>>>>   9 KSP preconditioned resid norm 5.552370825926e+16 true resid norm
>>>> 9.849613114257e+15 ||r(i)||/||b|| 4.662349492457e-01
>>>>  10 KSP preconditioned resid norm 2.614277580792e+16 true resid norm
>>>> 4.400858558792e+15 ||r(i)||/||b|| 2.083162092759e-01
>>>>  11 KSP preconditioned resid norm 2.230379890809e+16 true resid norm
>>>> 4.001941486401e+15 ||r(i)||/||b|| 1.894333273960e-01
>>>>  12 KSP preconditioned resid norm 2.202819377737e+16 true resid norm
>>>> 3.668912744052e+15 ||r(i)||/||b|| 1.736692931151e-01
>>>>  13 KSP preconditioned resid norm 2.171381974288e+16 true resid norm
>>>> 3.746629440349e+15 ||r(i)||/||b|| 1.773480406489e-01
>>>>  14 KSP preconditioned resid norm 2.756519085776e+16 true resid norm
>>>> 4.738155898553e+15 ||r(i)||/||b|| 2.242822991374e-01
>>>>  15 KSP preconditioned resid norm 1.910971370209e+16 true resid norm
>>>> 7.272906924885e+15 ||r(i)||/||b|| 3.442656428895e-01
>>>>  16 KSP preconditioned resid norm 8.265967788035e+15 true resid norm
>>>> 1.450280377529e+15 ||r(i)||/||b|| 6.864953885656e-02
>>>>  17 KSP preconditioned resid norm 5.450920356042e+15 true resid norm
>>>> 1.778917951827e+15 ||r(i)||/||b|| 8.420571563182e-02
>>>>  18 KSP preconditioned resid norm 4.184159413509e+15 true resid norm
>>>> 7.350039137637e+14 ||r(i)||/||b|| 3.479167236863e-02
>>>>  19 KSP preconditioned resid norm 3.481860538622e+15 true resid norm
>>>> 7.678205813365e+14 ||r(i)||/||b|| 3.634506103098e-02
>>>>  20 KSP preconditioned resid norm 3.027493421078e+15 true resid norm
>>>> 5.662352682787e+14 ||r(i)||/||b|| 2.680294834981e-02
>>>>  21 KSP preconditioned resid norm 2.649808113090e+15 true resid norm
>>>> 5.331458151920e+14 ||r(i)||/||b|| 2.523664728788e-02
>>>>  22 KSP preconditioned resid norm 2.408644968014e+15 true resid norm
>>>> 3.911896234018e+14 ||r(i)||/||b|| 1.851710032633e-02
>>>>  23 KSP preconditioned resid norm 2.245371706567e+15 true resid norm
>>>> 3.514281238053e+14 ||r(i)||/||b|| 1.663497556353e-02
>>>>  24 KSP preconditioned resid norm 2.104176299070e+15 true resid norm
>>>> 3.427795705053e+14 ||r(i)||/||b|| 1.622559320890e-02
>>>>  25 KSP preconditioned resid norm 1.992290690493e+15 true resid norm
>>>> 3.118626867030e+14 ||r(i)||/||b|| 1.476213148881e-02
>>>>  26 KSP preconditioned resid norm 1.936852873636e+15 true resid norm
>>>> 3.191431362940e+14 ||r(i)||/||b|| 1.510675416649e-02
>>>>  27 KSP preconditioned resid norm 1.840320660654e+15 true resid norm
>>>> 4.277077423449e+14 ||r(i)||/||b|| 2.024569850927e-02
>>>>  28 KSP preconditioned resid norm 1.797325493063e+15 true resid norm
>>>> 2.805438081480e+14 ||r(i)||/||b|| 1.327964120375e-02
>>>>  29 KSP preconditioned resid norm 1.907733126356e+15 true resid norm
>>>> 3.072709450643e+14 ||r(i)||/||b|| 1.454477976088e-02
>>>>  30 KSP preconditioned resid norm 2.241086833192e+15 true resid norm
>>>> 3.515931723170e+14 ||r(i)||/||b|| 1.664278819369e-02
>>>>  31 KSP preconditioned resid norm 3.121906541214e+15 true resid norm
>>>> 5.044161632328e+14 ||r(i)||/||b|| 2.387671896708e-02
>>>>  32 KSP preconditioned resid norm 2.288516501159e+16 true resid norm
>>>> 3.696560518057e+15 ||r(i)||/||b|| 1.749780103571e-01
>>>>  33 KSP preconditioned resid norm 2.665344016377e+15 true resid norm
>>>> 4.419048360378e+14 ||r(i)||/||b|| 2.091772300206e-02
>>>>  34 KSP preconditioned resid norm 1.193724857597e+15 true resid norm
>>>> 1.964465911853e+14 ||r(i)||/||b|| 9.298869448811e-03
>>>>  35 KSP preconditioned resid norm 7.370892713374e+14 true resid norm
>>>> 1.243994812053e+14 ||r(i)||/||b|| 5.888493805102e-03
>>>>  36 KSP preconditioned resid norm 5.570336976172e+14 true resid norm
>>>> 9.038862530299e+13 ||r(i)||/||b|| 4.278577812313e-03
>>>>  37 KSP preconditioned resid norm 4.452876529911e+14 true resid norm
>>>> 9.072905275923e+13 ||r(i)||/||b|| 4.294692067355e-03
>>>>  38 KSP preconditioned resid norm 4.015373409323e+14 true resid norm
>>>> 6.374984875718e+13 ||r(i)||/||b|| 3.017621824831e-03
>>>>  39 KSP preconditioned resid norm 3.753907061691e+14 true resid norm
>>>> 7.170117945509e+13 ||r(i)||/||b|| 3.394000898950e-03
>>>>  40 KSP preconditioned resid norm 3.520150126535e+14 true resid norm
>>>> 5.546554172401e+13 ||r(i)||/||b|| 2.625481197140e-03
>>>>  41 KSP preconditioned resid norm 3.283953946659e+14 true resid norm
>>>> 5.672854000420e+13 ||r(i)||/||b|| 2.685265671132e-03
>>>>  42 KSP preconditioned resid norm 3.086422594501e+14 true resid norm
>>>> 5.033158713486e+13 ||r(i)||/||b|| 2.382463625836e-03
>>>>  43 KSP preconditioned resid norm 2.903330837015e+14 true resid norm
>>>> 5.711996083788e+13 ||r(i)||/||b|| 2.703793715879e-03
>>>>  44 KSP preconditioned resid norm 2.805776139313e+14 true resid norm
>>>> 4.359341431583e+13 ||r(i)||/||b|| 2.063509812540e-03
>>>>  45 KSP preconditioned resid norm 2.850165946773e+14 true resid norm
>>>> 4.589953632859e+13 ||r(i)||/||b|| 2.172670920403e-03
>>>>  46 KSP preconditioned resid norm 3.036441891069e+14 true resid norm
>>>> 4.745822530443e+13 ||r(i)||/||b|| 2.246452018920e-03
>>>>  47 KSP preconditioned resid norm 3.630944657131e+14 true resid norm
>>>> 5.763700439451e+13 ||r(i)||/||b|| 2.728268157016e-03
>>>>  48 KSP preconditioned resid norm 1.221109219167e+15 true resid norm
>>>> 1.980487895228e+14 ||r(i)||/||b|| 9.374710078478e-03
>>>>  49 KSP preconditioned resid norm 3.188684128549e+15 true resid norm
>>>> 5.020159499531e+14 ||r(i)||/||b|| 2.376310401554e-02
>>>>  50 KSP preconditioned resid norm 3.895126724245e+13 true resid norm
>>>> 6.299322456844e+12 ||r(i)||/||b|| 2.981806749036e-04
>>>>   0 KSP preconditioned resid norm 6.694681597053e+18 true resid norm
>>>> 3.650754072115e+18 ||r(i)||/||b|| 5.229798617888e+00
>>>>   1 KSP preconditioned resid norm 1.597667334483e+18 true resid norm
>>>> 5.366749713509e+17 ||r(i)||/||b|| 7.688006280303e-01
>>>>   2 KSP preconditioned resid norm 6.300446759111e+17 true resid norm
>>>> 1.705328267334e+17 ||r(i)||/||b|| 2.442926376135e-01
>>>>   3 KSP preconditioned resid norm 3.642174486049e+17 true resid norm
>>>> 9.481576844129e+16 ||r(i)||/||b|| 1.358260142845e-01
>>>>   4 KSP preconditioned resid norm 2.247332959635e+17 true resid norm
>>>> 3.802800729856e+16 ||r(i)||/||b|| 5.447609345427e-02
>>>>   5 KSP preconditioned resid norm 1.557523701769e+17 true resid norm
>>>> 3.829141999541e+16 ||r(i)||/||b|| 5.485343888228e-02
>>>>   6 KSP preconditioned resid norm 1.004692846569e+17 true resid norm
>>>> 1.699728099873e+16 ||r(i)||/||b|| 2.434903992959e-02
>>>>   7 KSP preconditioned resid norm 7.103482802189e+16 true resid norm
>>>> 1.472858884963e+16 ||r(i)||/||b|| 2.109908037838e-02
>>>>   8 KSP preconditioned resid norm 5.766847885215e+16 true resid norm
>>>> 9.397954062732e+15 ||r(i)||/||b|| 1.346280965449e-02
>>>>   9 KSP preconditioned resid norm 4.523472016725e+16 true resid norm
>>>> 1.246374917365e+16 ||r(i)||/||b|| 1.785463959348e-02
>>>>  10 KSP preconditioned resid norm 3.195342481960e+16 true resid norm
>>>> 5.030521484214e+15 ||r(i)||/||b|| 7.206350738975e-03
>>>>  11 KSP preconditioned resid norm 2.437460220226e+16 true resid norm
>>>> 4.974645944208e+15 ||r(i)||/||b|| 7.126307598263e-03
>>>>  12 KSP preconditioned resid norm 1.258045555577e+16 true resid norm
>>>> 1.885910304237e+15 ||r(i)||/||b|| 2.701614764439e-03
>>>>  13 KSP preconditioned resid norm 2.495567167302e+15 true resid norm
>>>> 4.460991814541e+14 ||r(i)||/||b|| 6.390484914966e-04
>>>>  14 KSP preconditioned resid norm 7.678096351052e+14 true resid norm
>>>> 1.316276220022e+14 ||r(i)||/||b|| 1.885599363926e-04
>>>>  15 KSP preconditioned resid norm 5.950867501843e+14 true resid norm
>>>> 1.439410416931e+14 ||r(i)||/||b|| 2.061992251557e-04
>>>>  16 KSP preconditioned resid norm 3.263035989760e+14 true resid norm
>>>> 5.046543721443e+13 ||r(i)||/||b|| 7.229303003757e-05
>>>>  17 KSP preconditioned resid norm 1.436782488882e+14 true resid norm
>>>> 7.588970356348e+13 ||r(i)||/||b|| 1.087139420975e-04
>>>>  18 KSP preconditioned resid norm 5.401533739797e+13 true resid norm
>>>> 8.625318785849e+12 ||r(i)||/||b|| 1.235598985142e-05
>>>>  19 KSP preconditioned resid norm 3.528859989845e+13 true resid norm
>>>> 1.233587622450e+13 ||r(i)||/||b|| 1.767145832202e-05
>>>>   0 KSP preconditioned resid norm 4.827874033841e+18 true resid norm
>>>> 2.629049503905e+18 ||r(i)||/||b|| 2.387244450275e+01
>>>>   1 KSP preconditioned resid norm 1.161059892070e+18 true resid norm
>>>> 3.885117260269e+17 ||r(i)||/||b|| 3.527786222537e+00
>>>>   2 KSP preconditioned resid norm 4.696931552127e+17 true resid norm
>>>> 1.228954734891e+17 ||r(i)||/||b|| 1.115922452639e+00
>>>>   3 KSP preconditioned resid norm 2.870101730937e+17 true resid norm
>>>> 6.759381587642e+16 ||r(i)||/||b|| 6.137692028400e-01
>>>>   4 KSP preconditioned resid norm 1.966639305793e+17 true resid norm
>>>> 3.310590026030e+16 ||r(i)||/||b|| 3.006100742887e-01
>>>>   5 KSP preconditioned resid norm 1.592574497021e+17 true resid norm
>>>> 3.239415772705e+16 ||r(i)||/||b|| 2.941472693472e-01
>>>>   6 KSP preconditioned resid norm 1.230114824013e+17 true resid norm
>>>> 2.280737281616e+16 ||r(i)||/||b|| 2.070968009535e-01
>>>>   7 KSP preconditioned resid norm 8.598640818077e+16 true resid norm
>>>> 1.938029194893e+16 ||r(i)||/||b|| 1.759780267776e-01
>>>>   8 KSP preconditioned resid norm 5.549085768793e+16 true resid norm
>>>> 9.386094648379e+15 ||r(i)||/||b|| 8.522814928290e-02
>>>>   9 KSP preconditioned resid norm 4.474754629124e+16 true resid norm
>>>> 7.579167807628e+15 ||r(i)||/||b|| 6.882078964122e-02
>>>>  10 KSP preconditioned resid norm 4.378389530908e+16 true resid norm
>>>> 6.842593278076e+15 ||r(i)||/||b|| 6.213250379770e-02
>>>>  11 KSP preconditioned resid norm 4.079498014536e+16 true resid norm
>>>> 7.704710526729e+15 ||r(i)||/||b|| 6.996074976369e-02
>>>>  12 KSP preconditioned resid norm 4.084398125729e+16 true resid norm
>>>> 6.377957983596e+15 ||r(i)||/||b|| 5.791349602893e-02
>>>>  13 KSP preconditioned resid norm 7.523960017073e+16 true resid norm
>>>> 1.132262466824e+16 ||r(i)||/||b|| 1.028123390664e-01
>>>>  14 KSP preconditioned resid norm 2.184546755774e+15 true resid norm
>>>> 3.502101254985e+14 ||r(i)||/||b|| 3.179997855820e-03
>>>>  15 KSP preconditioned resid norm 2.222188316359e+15 true resid norm
>>>> 3.654675514798e+14 ||r(i)||/||b|| 3.318539201068e-03
>>>>  16 KSP preconditioned resid norm 1.669487598659e+15 true resid norm
>>>> 3.629534674524e+14 ||r(i)||/||b|| 3.295710672608e-03
>>>>  17 KSP preconditioned resid norm 1.401917540926e+15 true resid norm
>>>> 2.161165666331e+14 ||r(i)||/||b|| 1.962393912861e-03
>>>>  18 KSP preconditioned resid norm 1.134393288674e+15 true resid norm
>>>> 2.686682412462e+14 ||r(i)||/||b|| 2.439576610967e-03
>>>>  19 KSP preconditioned resid norm 9.058009317761e+14 true resid norm
>>>> 1.409929037370e+14 ||r(i)||/||b|| 1.280251765797e-03
>>>>  20 KSP preconditioned resid norm 7.990098269893e+14 true resid norm
>>>> 1.659151006791e+14 ||r(i)||/||b|| 1.506551712794e-03
>>>>  21 KSP preconditioned resid norm 7.119180202197e+14 true resid norm
>>>> 1.092130755589e+14 ||r(i)||/||b|| 9.916827664832e-04
>>>>  22 KSP preconditioned resid norm 6.306959900843e+14 true resid norm
>>>> 1.460783745609e+14 ||r(i)||/||b|| 1.326429146571e-03
>>>>  23 KSP preconditioned resid norm 5.637228851054e+14 true resid norm
>>>> 8.672640572399e+13 ||r(i)||/||b|| 7.874980309399e-04
>>>>  24 KSP preconditioned resid norm 4.960976586203e+14 true resid norm
>>>> 1.292271181476e+14 ||r(i)||/||b|| 1.173415411786e-03
>>>>  25 KSP preconditioned resid norm 4.386404759546e+14 true resid norm
>>>> 8.037967670881e+13 ||r(i)||/||b|| 7.298681019622e-04
>>>>  26 KSP preconditioned resid norm 4.419824575339e+14 true resid norm
>>>> 6.704822670651e+13 ||r(i)||/||b|| 6.088151130974e-04
>>>>  27 KSP preconditioned resid norm 4.437076214979e+14 true resid norm
>>>> 1.370393448160e+14 ||r(i)||/||b|| 1.244352435720e-03
>>>>  28 KSP preconditioned resid norm 7.848825938920e+14 true resid norm
>>>> 1.196984132854e+14 ||r(i)||/||b|| 1.086892325146e-03
>>>>  29 KSP preconditioned resid norm 1.771840029177e+15 true resid norm
>>>> 6.554951997284e+14 ||r(i)||/||b|| 5.952064711635e-03
>>>>  30 KSP preconditioned resid norm 1.052090974187e+15 true resid norm
>>>> 1.877636782214e+14 ||r(i)||/||b|| 1.704942406491e-03
>>>>  31 KSP preconditioned resid norm 2.459238084389e+14 true resid norm
>>>> 3.913335964196e+13 ||r(i)||/||b|| 3.553409530216e-04
>>>>  32 KSP preconditioned resid norm 1.091607449298e+14 true resid norm
>>>> 1.900052367477e+13 ||r(i)||/||b|| 1.725296333429e-04
>>>>  33 KSP preconditioned resid norm 6.424117612547e+13 true resid norm
>>>> 1.001417309383e+13 ||r(i)||/||b|| 9.093126282646e-05
>>>>  34 KSP preconditioned resid norm 3.801393062657e+13 true resid norm
>>>> 7.035998067262e+12 ||r(i)||/||b|| 6.388866894011e-05
>>>>  35 KSP preconditioned resid norm 2.524483314829e+13 true resid norm
>>>> 4.006295820236e+12 ||r(i)||/||b|| 3.637819466241e-05
>>>>  36 KSP preconditioned resid norm 1.579134906712e+13 true resid norm
>>>> 2.528645237998e+12 ||r(i)||/||b|| 2.296074798956e-05
>>>>  37 KSP preconditioned resid norm 1.074219589287e+13 true resid norm
>>>> 1.786181249150e+12 ||r(i)||/||b|| 1.621898434352e-05
>>>>  38 KSP preconditioned resid norm 6.572405677048e+12 true resid norm
>>>> 1.033900747383e+12 ||r(i)||/||b|| 9.388084239790e-06
>>>>   0 KSP preconditioned resid norm 9.565416792628e+15 true resid norm
>>>> 5.898678788482e+15 ||r(i)||/||b|| 1.120363504643e-01
>>>>   1 KSP preconditioned resid norm 4.584205668003e+15 true resid norm
>>>> 8.149165580746e+14 ||r(i)||/||b|| 1.547808931009e-02
>>>>   2 KSP preconditioned resid norm 3.775899089492e+15 true resid norm
>>>> 6.134705686008e+14 ||r(i)||/||b|| 1.165193191355e-02
>>>>   3 KSP preconditioned resid norm 3.695846031998e+15 true resid norm
>>>> 6.195110682482e+14 ||r(i)||/||b|| 1.176666193357e-02
>>>>   4 KSP preconditioned resid norm 3.863984235758e+15 true resid norm
>>>> 6.333337603322e+14 ||r(i)||/||b|| 1.202920275504e-02
>>>>   5 KSP preconditioned resid norm 4.289553507880e+15 true resid norm
>>>> 6.781260017663e+14 ||r(i)||/||b|| 1.287996263523e-02
>>>>   6 KSP preconditioned resid norm 5.214022047398e+15 true resid norm
>>>> 7.772905386519e+14 ||r(i)||/||b|| 1.476344081849e-02
>>>>   7 KSP preconditioned resid norm 6.520856882448e+15 true resid norm
>>>> 1.156631144536e+15 ||r(i)||/||b|| 2.196843342618e-02
>>>>   8 KSP preconditioned resid norm 7.245755589579e+15 true resid norm
>>>> 1.125518734778e+15 ||r(i)||/||b|| 2.137750095326e-02
>>>>   9 KSP preconditioned resid norm 7.402293382659e+15 true resid norm
>>>> 1.342363548018e+15 ||r(i)||/||b|| 2.549613537355e-02
>>>>  10 KSP preconditioned resid norm 6.814780966449e+15 true resid norm
>>>> 1.040341685629e+15 ||r(i)||/||b|| 1.975969363197e-02
>>>>  11 KSP preconditioned resid norm 4.531806636058e+15 true resid norm
>>>> 6.813426758243e+14 ||r(i)||/||b|| 1.294105842210e-02
>>>>  12 KSP preconditioned resid norm 4.019547715129e+15 true resid norm
>>>> 1.067806433320e+15 ||r(i)||/||b|| 2.028134436224e-02
>>>>  13 KSP preconditioned resid norm 1.578855518519e+15 true resid norm
>>>> 2.462140978868e+14 ||r(i)||/||b|| 4.676458907031e-03
>>>>  14 KSP preconditioned resid norm 1.216192317102e+15 true resid norm
>>>> 3.547355821423e+14 ||r(i)||/||b|| 6.737657944804e-03
>>>>  15 KSP preconditioned resid norm 1.068138625918e+15 true resid norm
>>>> 1.711364338225e+14 ||r(i)||/||b|| 3.250473905172e-03
>>>>  16 KSP preconditioned resid norm 1.009888628733e+15 true resid norm
>>>> 1.725105447584e+14 ||r(i)||/||b|| 3.276573033454e-03
>>>>  17 KSP preconditioned resid norm 9.012147556868e+14 true resid norm
>>>> 1.461953215911e+14 ||r(i)||/||b|| 2.776755757239e-03
>>>>  18 KSP preconditioned resid norm 8.184497465452e+14 true resid norm
>>>> 1.394097869305e+14 ||r(i)||/||b|| 2.647874940607e-03
>>>>  19 KSP preconditioned resid norm 6.946418330368e+14 true resid norm
>>>> 1.094539907094e+14 ||r(i)||/||b|| 2.078910566681e-03
>>>>  20 KSP preconditioned resid norm 5.822189800664e+14 true resid norm
>>>> 1.086460879389e+14 ||r(i)||/||b|| 2.063565693502e-03
>>>>  21 KSP preconditioned resid norm 4.765744627590e+14 true resid norm
>>>> 7.425312666441e+13 ||r(i)||/||b|| 1.410324179423e-03
>>>>  22 KSP preconditioned resid norm 3.785099184439e+14 true resid norm
>>>> 8.229511757789e+13 ||r(i)||/||b|| 1.563069454208e-03
>>>>  23 KSP preconditioned resid norm 3.069654165781e+14 true resid norm
>>>> 4.744586000483e+13 ||r(i)||/||b|| 9.011612922478e-04
>>>>   0 KSP preconditioned resid norm 9.591954950201e+15 true resid norm
>>>> 5.933293318674e+15 ||r(i)||/||b|| 5.704140552403e-01
>>>>   1 KSP preconditioned resid norm 4.627616930759e+15 true resid norm
>>>> 8.120897483902e+14 ||r(i)||/||b|| 7.807256134471e-02
>>>>   2 KSP preconditioned resid norm 3.843607704549e+15 true resid norm
>>>> 6.216441009903e+14 ||r(i)||/||b|| 5.976352651335e-02
>>>>   3 KSP preconditioned resid norm 3.802257051246e+15 true resid norm
>>>> 6.332758127660e+14 ||r(i)||/||b|| 6.088177425993e-02
>>>>   4 KSP preconditioned resid norm 4.025094330467e+15 true resid norm
>>>> 6.488587775849e+14 ||r(i)||/||b|| 6.237988697367e-02
>>>>   5 KSP preconditioned resid norm 4.518903996358e+15 true resid norm
>>>> 7.100173385586e+14 ||r(i)||/||b|| 6.825953945399e-02
>>>>   6 KSP preconditioned resid norm 5.566041493723e+15 true resid norm
>>>> 8.272295550982e+14 ||r(i)||/||b|| 7.952806979104e-02
>>>>   7 KSP preconditioned resid norm 7.050235529471e+15 true resid norm
>>>> 1.259531120704e+15 ||r(i)||/||b|| 1.210886122891e-01
>>>>   8 KSP preconditioned resid norm 7.824426472314e+15 true resid norm
>>>> 1.230246429464e+15 ||r(i)||/||b|| 1.182732450740e-01
>>>>   9 KSP preconditioned resid norm 8.110342869221e+15 true resid norm
>>>> 1.508507345577e+15 ||r(i)||/||b|| 1.450246509206e-01
>>>>  10 KSP preconditioned resid norm 7.848071091100e+15 true resid norm
>>>> 1.244716713436e+15 ||r(i)||/||b|| 1.196643870448e-01
>>>>  11 KSP preconditioned resid norm 6.689698623315e+15 true resid norm
>>>> 1.152050117302e+15 ||r(i)||/||b|| 1.107556198481e-01
>>>>  12 KSP preconditioned resid norm 3.836259156428e+15 true resid norm
>>>> 5.895445738700e+14 ||r(i)||/||b|| 5.667754703239e-02
>>>>  13 KSP preconditioned resid norm 1.583619332521e+15 true resid norm
>>>> 3.090404276347e+14 ||r(i)||/||b|| 2.971048186772e-02
>>>>  14 KSP preconditioned resid norm 1.282447478166e+15 true resid norm
>>>> 2.666239295029e+14 ||r(i)||/||b|| 2.563265098882e-02
>>>>  15 KSP preconditioned resid norm 1.151484666969e+15 true resid norm
>>>> 2.280596910606e+14 ||r(i)||/||b|| 2.192516806902e-02
>>>>  16 KSP preconditioned resid norm 1.027737067851e+15 true resid norm
>>>> 1.605668418840e+14 ||r(i)||/||b|| 1.543655074795e-02
>>>>  17 KSP preconditioned resid norm 8.747586168174e+14 true resid norm
>>>> 1.470663481317e+14 ||r(i)||/||b|| 1.413864232250e-02
>>>>  18 KSP preconditioned resid norm 7.765674155007e+14 true resid norm
>>>> 1.265290838281e+14 ||r(i)||/||b|| 1.216423391459e-02
>>>>  19 KSP preconditioned resid norm 6.633620818064e+14 true resid norm
>>>> 1.039325479930e+14 ||r(i)||/||b|| 9.991851571798e-03
>>>>  20 KSP preconditioned resid norm 5.640296981466e+14 true resid norm
>>>> 1.018948133357e+14 ||r(i)||/||b|| 9.795948145668e-03
>>>>  21 KSP preconditioned resid norm 4.751732697839e+14 true resid norm
>>>> 7.431313741469e+13 ||r(i)||/||b|| 7.144305159654e-03
>>>>  22 KSP preconditioned resid norm 3.865078030089e+14 true resid norm
>>>> 7.686807394274e+13 ||r(i)||/||b|| 7.389931260973e-03
>>>>  23 KSP preconditioned resid norm 3.183297004119e+14 true resid norm
>>>> 4.953673129366e+13 ||r(i)||/||b|| 4.762354777175e-03
>>>>  24 KSP preconditioned resid norm 2.612111917568e+14 true resid norm
>>>> 5.971714747402e+13 ||r(i)||/||b|| 5.741078087414e-03
>>>>  25 KSP preconditioned resid norm 2.296313138344e+14 true resid norm
>>>> 3.527848689641e+13 ||r(i)||/||b|| 3.391597834880e-03
>>>>  26 KSP preconditioned resid norm 1.981337219705e+14 true resid norm
>>>> 5.164126794406e+13 ||r(i)||/||b|| 4.964680403211e-03
>>>>  27 KSP preconditioned resid norm 1.751049134665e+14 true resid norm
>>>> 2.675806111216e+13 ||r(i)||/||b|| 2.572462430151e-03
>>>>  28 KSP preconditioned resid norm 1.533798667157e+14 true resid norm
>>>> 3.995390488198e+13 ||r(i)||/||b|| 3.841082461690e-03
>>>>  29 KSP preconditioned resid norm 1.350471089065e+14 true resid norm
>>>> 2.063214947275e+13 ||r(i)||/||b|| 1.983530463939e-03
>>>>  30 KSP preconditioned resid norm 1.221880384902e+14 true resid norm
>>>> 2.772903253208e+13 ||r(i)||/||b|| 2.665809533591e-03
>>>>  31 KSP preconditioned resid norm 1.099123503540e+14 true resid norm
>>>> 1.682484274214e+13 ||r(i)||/||b|| 1.617504185596e-03
>>>>  32 KSP preconditioned resid norm 1.022845787224e+14 true resid norm
>>>> 1.853354426028e+13 ||r(i)||/||b|| 1.781775073585e-03
>>>>  33 KSP preconditioned resid norm 9.416346598487e+13 true resid norm
>>>> 1.438140346990e+13 ||r(i)||/||b|| 1.382597190584e-03
>>>>  34 KSP preconditioned resid norm 8.782252733286e+13 true resid norm
>>>> 1.465353724876e+13 ||r(i)||/||b|| 1.408759546637e-03
>>>>  35 KSP preconditioned resid norm 8.286435025538e+13 true resid norm
>>>> 1.264742128603e+13 ||r(i)||/||b|| 1.215895873779e-03
>>>>  36 KSP preconditioned resid norm 7.744963280138e+13 true resid norm
>>>> 1.290903292754e+13 ||r(i)||/||b|| 1.241046654183e-03
>>>>  37 KSP preconditioned resid norm 7.340074137876e+13 true resid norm
>>>> 1.120214736846e+13 ||r(i)||/||b|| 1.076950348592e-03
>>>>  38 KSP preconditioned resid norm 6.860608702874e+13 true resid norm
>>>> 1.142914172047e+13 ||r(i)||/||b|| 1.098773097257e-03
>>>>  39 KSP preconditioned resid norm 6.401516623396e+13 true resid norm
>>>> 9.766911914727e+12 ||r(i)||/||b|| 9.389698997216e-04
>>>>  40 KSP preconditioned resid norm 5.980495528832e+13 true resid norm
>>>> 9.707430083091e+12 ||r(i)||/||b|| 9.332514443927e-04
>>>>  41 KSP preconditioned resid norm 5.502664117143e+13 true resid norm
>>>> 8.404607061129e+12 ||r(i)||/||b|| 8.080008418514e-04
>>>>   0 KSP preconditioned resid norm 2.200733964807e+16 true resid norm
>>>> 1.374508262416e+16 ||r(i)||/||b|| 1.042223674371e-01
>>>>   1 KSP preconditioned resid norm 1.033612993855e+16 true resid norm
>>>> 1.767505005693e+15 ||r(i)||/||b|| 1.340214251070e-02
>>>>   2 KSP preconditioned resid norm 8.198008013445e+15 true resid norm
>>>> 1.328272543525e+15 ||r(i)||/||b|| 1.007165346861e-02
>>>>   3 KSP preconditioned resid norm 7.723889011566e+15 true resid norm
>>>> 1.289831076731e+15 ||r(i)||/||b|| 9.780170267923e-03
>>>>   4 KSP preconditioned resid norm 7.785469249486e+15 true resid norm
>>>> 1.238697760343e+15 ||r(i)||/||b|| 9.392450860579e-03
>>>>   5 KSP preconditioned resid norm 8.250177532689e+15 true resid norm
>>>> 1.288999707195e+15 ||r(i)||/||b|| 9.773866391570e-03
>>>>   6 KSP preconditioned resid norm 9.471871112821e+15 true resid norm
>>>> 1.409248720218e+15 ||r(i)||/||b|| 1.068565696875e-02
>>>>   7 KSP preconditioned resid norm 1.106232045691e+16 true resid norm
>>>> 1.993194297637e+15 ||r(i)||/||b|| 1.511343613874e-02
>>>>   8 KSP preconditioned resid norm 1.131471113452e+16 true resid norm
>>>> 1.768387012694e+15 ||r(i)||/||b|| 1.340883034665e-02
>>>>   9 KSP preconditioned resid norm 1.055003108779e+16 true resid norm
>>>> 1.935924228946e+15 ||r(i)||/||b|| 1.467918468275e-02
>>>>  10 KSP preconditioned resid norm 8.569038225337e+15 true resid norm
>>>> 1.316932619063e+15 ||r(i)||/||b|| 9.985668261662e-03
>>>>  11 KSP preconditioned resid norm 4.806783660704e+15 true resid norm
>>>> 7.346602562794e+14 ||r(i)||/||b|| 5.570576275535e-03
>>>>  12 KSP preconditioned resid norm 6.311127886872e+15 true resid norm
>>>> 1.031465284608e+15 ||r(i)||/||b|| 7.821106415332e-03
>>>>  13 KSP preconditioned resid norm 9.706706695861e+14 true resid norm
>>>> 2.189061895566e+14 ||r(i)||/||b|| 1.659860616781e-03
>>>>  14 KSP preconditioned resid norm 6.844878378158e+14 true resid norm
>>>> 1.339168617782e+14 ||r(i)||/||b|| 1.015427317239e-03
>>>>   0 KSP preconditioned resid norm 1.928571496492e+16 true resid norm
>>>> 1.203387628158e+16 ||r(i)||/||b|| 4.946666172277e-01
>>>>   1 KSP preconditioned resid norm 9.232456268915e+15 true resid norm
>>>> 1.583223656595e+15 ||r(i)||/||b|| 6.508026775390e-02
>>>>   2 KSP preconditioned resid norm 7.541947576336e+15 true resid norm
>>>> 1.216650042172e+15 ||r(i)||/||b|| 5.001182882627e-02
>>>>   3 KSP preconditioned resid norm 7.340367763150e+15 true resid norm
>>>> 1.219887358936e+15 ||r(i)||/||b|| 5.014490253381e-02
>>>>   4 KSP preconditioned resid norm 7.655525114233e+15 true resid norm
>>>> 1.212298323935e+15 ||r(i)||/||b|| 4.983294633744e-02
>>>>   5 KSP preconditioned resid norm 8.414914513850e+15 true resid norm
>>>> 1.311466433986e+15 ||r(i)||/||b|| 5.390936796484e-02
>>>>   6 KSP preconditioned resid norm 1.008643582787e+16 true resid norm
>>>> 1.495807999597e+15 ||r(i)||/||b|| 6.148694451139e-02
>>>>   7 KSP preconditioned resid norm 1.235608743666e+16 true resid norm
>>>> 2.203234082057e+15 ||r(i)||/||b|| 9.056652443733e-02
>>>>   8 KSP preconditioned resid norm 1.311751365507e+16 true resid norm
>>>> 2.061480991281e+15 ||r(i)||/||b|| 8.473959716509e-02
>>>>   9 KSP preconditioned resid norm 1.289621791383e+16 true resid norm
>>>> 2.355792563000e+15 ||r(i)||/||b|| 9.683761996231e-02
>>>>  10 KSP preconditioned resid norm 1.151686987354e+16 true resid norm
>>>> 1.821530468335e+15 ||r(i)||/||b|| 7.487614911976e-02
>>>>  11 KSP preconditioned resid norm 8.379707704664e+15 true resid norm
>>>> 1.435040037498e+15 ||r(i)||/||b|| 5.898900606299e-02
>>>>  12 KSP preconditioned resid norm 3.557464484347e+15 true resid norm
>>>> 5.430083136124e+14 ||r(i)||/||b|| 2.232099444401e-02
>>>>  13 KSP preconditioned resid norm 1.204545626126e+15 true resid norm
>>>> 2.194281091480e+14 ||r(i)||/||b|| 9.019850124522e-03
>>>>  14 KSP preconditioned resid norm 1.005673666245e+15 true resid norm
>>>> 1.883222474780e+14 ||r(i)||/||b|| 7.741207149622e-03
>>>>  15 KSP preconditioned resid norm 9.379382960505e+14 true resid norm
>>>> 1.480571711312e+14 ||r(i)||/||b|| 6.086063898783e-03
>>>>  16 KSP preconditioned resid norm 8.825746357103e+14 true resid norm
>>>> 2.025244331207e+14 ||r(i)||/||b|| 8.325004669617e-03
>>>>  17 KSP preconditioned resid norm 7.524485997458e+14 true resid norm
>>>> 1.181787653170e+14 ||r(i)||/||b|| 4.857876938371e-03
>>>>  18 KSP preconditioned resid norm 6.768878630597e+14 true resid norm
>>>> 1.383948785570e+14 ||r(i)||/||b|| 5.688884015051e-03
>>>>  19 KSP preconditioned resid norm 6.018014871695e+14 true resid norm
>>>> 9.381957375927e+13 ||r(i)||/||b|| 3.856563761775e-03
>>>>  20 KSP preconditioned resid norm 5.246326908653e+14 true resid norm
>>>> 1.170575496120e+14 ||r(i)||/||b|| 4.811788050053e-03
>>>>  21 KSP preconditioned resid norm 4.606732721936e+14 true resid norm
>>>> 7.159556750064e+13 ||r(i)||/||b|| 2.943019884477e-03
>>>>  22 KSP preconditioned resid norm 3.919505243136e+14 true resid norm
>>>> 9.177422576855e+13 ||r(i)||/||b|| 3.772487330545e-03
>>>>  23 KSP preconditioned resid norm 3.382362447667e+14 true resid norm
>>>> 5.210255290014e+13 ||r(i)||/||b|| 2.141736626583e-03
>>>>  24 KSP preconditioned resid norm 2.828412329842e+14 true resid norm
>>>> 7.512251290427e+13 ||r(i)||/||b|| 3.087999117364e-03
>>>>  25 KSP preconditioned resid norm 2.453088437412e+14 true resid norm
>>>> 3.770320821115e+13 ||r(i)||/||b|| 1.549834652446e-03
>>>>  26 KSP preconditioned resid norm 2.155681340535e+14 true resid norm
>>>> 5.419527743350e+13 ||r(i)||/||b|| 2.227760526238e-03
>>>>  27 KSP preconditioned resid norm 1.897133167426e+14 true resid norm
>>>> 2.950727994670e+13 ||r(i)||/||b|| 1.212931395777e-03
>>>>  28 KSP preconditioned resid norm 1.747505144272e+14 true resid norm
>>>> 2.784171913979e+13 ||r(i)||/||b|| 1.144466562762e-03
>>>>  29 KSP preconditioned resid norm 1.591031918648e+14 true resid norm
>>>> 2.517709500033e+13 ||r(i)||/||b|| 1.034934058155e-03
>>>>  30 KSP preconditioned resid norm 1.457115463937e+14 true resid norm
>>>> 2.260424017892e+13 ||r(i)||/||b|| 9.291738391412e-04
>>>>  31 KSP preconditioned resid norm 1.296458013341e+14 true resid norm
>>>> 2.025545529149e+13 ||r(i)||/||b|| 8.326242779131e-04
>>>>   0 KSP preconditioned resid norm 6.130010037612e+16 true resid norm
>>>> 4.019535297216e+16 ||r(i)||/||b|| 5.748505993058e-02
>>>>   1 KSP preconditioned resid norm 2.383231272358e+16 true resid norm
>>>> 4.333028202730e+15 ||r(i)||/||b|| 6.196845343971e-03
>>>>   2 KSP preconditioned resid norm 1.380314308485e+16 true resid norm
>>>> 2.902938638700e+15 ||r(i)||/||b|| 4.151614285761e-03
>>>>   3 KSP preconditioned resid norm 9.355422664357e+15 true resid norm
>>>> 1.914374541766e+15 ||r(i)||/||b|| 2.737827313999e-03
>>>>   4 KSP preconditioned resid norm 6.905389450100e+15 true resid norm
>>>> 1.160495113546e+15 ||r(i)||/||b|| 1.659672728773e-03
>>>>   5 KSP preconditioned resid norm 5.388850197186e+15 true resid norm
>>>> 9.343171629150e+14 ||r(i)||/||b|| 1.336206156506e-03
>>>>   6 KSP preconditioned resid norm 4.456941607624e+15 true resid norm
>>>> 7.443205303349e+14 ||r(i)||/||b|| 1.064484004494e-03
>>>>   7 KSP preconditioned resid norm 3.604897946036e+15 true resid norm
>>>> 7.177354673946e+14 ||r(i)||/||b|| 1.026463591104e-03
>>>>   8 KSP preconditioned resid norm 2.616552593607e+15 true resid norm
>>>> 4.566784798486e+14 ||r(i)||/||b|| 6.531150454453e-04
>>>>   9 KSP preconditioned resid norm 1.730753896325e+15 true resid norm
>>>> 3.416577992536e+14 ||r(i)||/||b|| 4.886191465826e-04
>>>>  10 KSP preconditioned resid norm 9.605913237294e+14 true resid norm
>>>> 1.715828091570e+14 ||r(i)||/||b|| 2.453877709266e-04
>>>>  11 KSP preconditioned resid norm 3.885469473062e+14 true resid norm
>>>> 7.526615943221e+13 ||r(i)||/||b|| 1.076412909896e-04
>>>>  12 KSP preconditioned resid norm 1.085402136107e+14 true resid norm
>>>> 1.877490962768e+13 ||r(i)||/||b|| 2.685078560912e-05
>>>>  13 KSP preconditioned resid norm 5.521535103061e+13 true resid norm
>>>> 1.482831672696e+13 ||r(i)||/||b|| 2.120659759623e-05
>>>>  14 KSP preconditioned resid norm 4.327778995114e+13 true resid norm
>>>> 6.949075963503e+12 ||r(i)||/||b|| 9.938164954062e-06
>>>>   0 KSP preconditioned resid norm 2.469229041475e+16 true resid norm
>>>> 1.581397714280e+16 ||r(i)||/||b|| 1.421322438999e-01
>>>>   1 KSP preconditioned resid norm 1.094866313351e+16 true resid norm
>>>> 1.827538507817e+15 ||r(i)||/||b|| 1.642547896610e-02
>>>>   2 KSP preconditioned resid norm 7.902647446500e+15 true resid norm
>>>> 1.331972422409e+15 ||r(i)||/||b|| 1.197144952849e-02
>>>>   3 KSP preconditioned resid norm 6.757114899989e+15 true resid norm
>>>> 1.177404752006e+15 ||r(i)||/||b|| 1.058223227906e-02
>>>>   4 KSP preconditioned resid norm 6.236820681061e+15 true resid norm
>>>> 9.858934558297e+14 ||r(i)||/||b|| 8.860974558006e-03
>>>>   5 KSP preconditioned resid norm 6.056208230839e+15 true resid norm
>>>> 9.498735328449e+14 ||r(i)||/||b|| 8.537236106085e-03
>>>>   6 KSP preconditioned resid norm 6.281150442401e+15 true resid norm
>>>> 9.439017368432e+14 ||r(i)||/||b|| 8.483563032058e-03
>>>>   7 KSP preconditioned resid norm 6.511637444792e+15 true resid norm
>>>> 1.175605282966e+15 ||r(i)||/||b|| 1.056605908176e-02
>>>>   8 KSP preconditioned resid norm 5.897282453446e+15 true resid norm
>>>> 9.358326231383e+14 ||r(i)||/||b|| 8.411039768188e-03
>>>>   9 KSP preconditioned resid norm 4.858643646559e+15 true resid norm
>>>> 9.074077132105e+14 ||r(i)||/||b|| 8.155563476918e-03
>>>>  10 KSP preconditioned resid norm 3.431227043388e+15 true resid norm
>>>> 5.523077341519e+14 ||r(i)||/||b|| 4.964009804073e-03
>>>>  11 KSP preconditioned resid norm 1.790602151882e+15 true resid norm
>>>> 3.233768234561e+14 ||r(i)||/||b|| 2.906433538380e-03
>>>>  12 KSP preconditioned resid norm 6.061523925825e+14 true resid norm
>>>> 9.361733195934e+13 ||r(i)||/||b|| 8.414101866433e-04
>>>>  13 KSP preconditioned resid norm 3.669173256365e+14 true resid norm
>>>> 7.433445448820e+13 ||r(i)||/||b|| 6.681002963438e-04
>>>>  14 KSP preconditioned resid norm 1.034315631221e+15 true resid norm
>>>> 1.749781208578e+14 ||r(i)||/||b|| 1.572661495987e-03
>>>>  15 KSP preconditioned resid norm 1.340579302998e+14 true resid norm
>>>> 2.477734238014e+13 ||r(i)||/||b|| 2.226928266408e-04
>>>>  16 KSP preconditioned resid norm 1.124182190968e+14 true resid norm
>>>> 1.917839484668e+13 ||r(i)||/||b|| 1.723708254629e-04
>>>>  17 KSP preconditioned resid norm 9.394060483803e+13 true resid norm
>>>> 1.682558933028e+13 ||r(i)||/||b|| 1.512243722661e-04
>>>>  18 KSP preconditioned resid norm 9.034672550576e+13 true resid norm
>>>> 1.892870471110e+13 ||r(i)||/||b|| 1.701266702495e-04
>>>>  19 KSP preconditioned resid norm 8.058964108831e+13 true resid norm
>>>> 1.275370569496e+13 ||r(i)||/||b|| 1.146272561351e-04
>>>>  20 KSP preconditioned resid norm 6.303390314758e+13 true resid norm
>>>> 1.900069985546e+13 ||r(i)||/||b|| 1.707737453860e-04
>>>>  21 KSP preconditioned resid norm 4.601826493253e+13 true resid norm
>>>> 6.960266318594e+12 ||r(i)||/||b|| 6.255720879505e-05
>>>>  22 KSP preconditioned resid norm 2.822787946131e+13 true resid norm
>>>> 1.013300639920e+13 ||r(i)||/||b|| 9.107303772884e-05
>>>>  23 KSP preconditioned resid norm 1.858182164082e+13 true resid norm
>>>> 2.785683110677e+12 ||r(i)||/||b|| 2.503705347106e-05
>>>>  24 KSP preconditioned resid norm 9.506925688468e+12 true resid norm
>>>> 4.268960894748e+12 ||r(i)||/||b|| 3.836839939834e-05
>>>>  25 KSP preconditioned resid norm 5.845171242291e+12 true resid norm
>>>> 8.923161711832e+11 ||r(i)||/||b|| 8.019924307031e-06
>>>>     0 SNES Function norm 0.000000000000e+00
>>>> 5 TS dt 7e-12 time 2e-11
>>>> TS Object: 1 MPI processes
>>>>   type: theta
>>>>   maximum steps=10
>>>>   maximum time=2e-11
>>>>   total number of nonlinear solver iterations=0
>>>>   total number of nonlinear solve failures=0
>>>>   total number of linear solver iterations=0
>>>>   total number of rejected steps=5
>>>>     Theta=1
>>>>     Extrapolation=no
>>>>   SNES Object:   1 MPI processes
>>>>     type: newtonls
>>>>     maximum iterations=50, maximum function evaluations=10000
>>>>     tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
>>>>     total number of function evaluations=1
>>>>     SNESLineSearch Object:     1 MPI processes
>>>>       type: bt
>>>>         interpolation: cubic
>>>>         alpha=1.000000e-04
>>>>       maxstep=1.000000e+08, minlambda=1.000000e-12
>>>>       tolerances: relative=1.000000e-08, absolute=1.000000e-15,
>>>> lambda=1.000000e-08
>>>>       maximum iterations=40
>>>>     KSP Object:     1 MPI processes
>>>>       type: gmres
>>>>         GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>>>> Orthogonalization with no iterative refinement
>>>>         GMRES: happy breakdown tolerance 1e-30
>>>>       maximum iterations=10000, initial guess is zero
>>>>       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>>>>       left preconditioning
>>>>       using DEFAULT norm type for convergence test
>>>>     PC Object:     1 MPI processes
>>>>       type: ilu
>>>>       PC has not been set up so information may be incomplete
>>>>         ILU: out-of-place factorization
>>>>         0 levels of fill
>>>>         tolerance for zero pivot 2.22045e-14
>>>>         using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
>>>>         matrix ordering: natural
>>>>       linear system matrix = precond matrix:
>>>>       Mat Object:       1 MPI processes
>>>>         type: seqaij
>>>>         rows=20904, cols=20904, bs=4
>>>>         total: nonzeros=410816, allocated nonzeros=410816
>>>>         total number of mallocs used during MatSetValues calls =0
>>>>           using I-node routines: found 5226 nodes, limit used is 5
>>>> On Mon, Oct 27, 2014 at 3:09 PM, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Mon, Oct 27, 2014 at 2:05 PM, Sharp Stone <thronesf at gmail.com>
>>>>> wrote:
>>>>>> Hi Jed and Matt,
>>>>>> Thank you very much for your replies.
>>>>>> This time I copied the whole output from my screen, from compile to
>>>>>> execution. This time I put the TSView() routine just after the TSSolve()
>>>>>> routine to make the tsview output. And I intentionally to do only 5 time
>>>>>> steps to make the test. Thank you in advance!
>>>>> You have to make the command line arguments work. Quit calling
>>>>> TSView() in the code. We need many more options
>>>>> for debugging. First track down why you are not processing options. Do
>>>>> the examples take options for you?
>>>>> Once that works, run with -ts_view -ts_monitor -snes_monitor
>>>>> -ksp_monitor_true_residual
>>>>>    Matt
>>>>>> host206-47:streamer_Implicit_SG GPL$ make pStreamer
>>>>>> /Users/GPL/local/PETSc/petsc-3.5.2/arch-darwin-cxx-debug/bin/mpicxx
>>>>>> -o pStreamer.o -c -Wall -Wwrite-strings -Wno-strict-aliasing
>>>>>> -Wno-unknown-pragmas -g -O0  -fPIC
>>>>>> -I/Users/GPL/local/PETSc/petsc-3.5.2/include
>>>>>> -I/Users/GPL/local/PETSc/petsc-3.5.2/arch-darwin-cxx-debug/include
>>>>>> -I/opt/X11/include   -Wno-unused  `pwd`/pStreamer.cc
>>>>>> /Users/GPL/local/PETSc/petsc-3.5.2/arch-darwin-cxx-debug/bin/mpicc
>>>>>> -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress
>>>>>> -Wl,-commons,use_dylibs -Wl,-search_paths_first
>>>>>> -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall
>>>>>> -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0
>>>>>> -Wno-unused  -o pStreamer flux.o field.o glob_streamer.o input.o
>>>>>> lookuptable.o nrutil.o pStreamer.o someutil.o photoionization.o heating.o
>>>>>> -L/Users/GPL/local/PETSc/petsc-3.5.2/arch-darwin-cxx-debug/lib
>>>>>> -L/Users/GPL/local/PETSc/petsc-3.5.2/arch-darwin-cxx-debug/lib  -lpetsc
>>>>>> -lsuperlu_4.3 -llapack -lblas -lparmetis -lmetis -L/opt/X11/lib -lX11
>>>>>> -lpthread -lssl -lcrypto
>>>>>> -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/5.1/lib/darwin
>>>>>> -lmpichf90 -lgfortran
>>>>>> -L/usr/local/gfortran/lib/gcc/x86_64-apple-darwin13/4.8.2
>>>>>> -L/usr/local/gfortran/lib -lgfortran -lgcc_ext.10.5 -lquadmath -lm
>>>>>> -lclang_rt.osx -lmpichcxx -lc++
>>>>>> -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/5.1/lib/darwin
>>>>>> -lclang_rt.osx
>>>>>> -L/Users/GPL/local/PETSc/petsc-3.5.2/arch-darwin-cxx-debug/lib -ldl
>>>>>> -lpmpich -lmpich -lopa -lmpl -lpthread -lSystem
>>>>>> -lclang_rt.osx -ldl
>>>>>> host206-47:streamer_Implicit_SG GPL$ mpiexec -n 1 ./pStreamer
>>>>>> time=0.000000         step=0
>>>>>> dt = 0.001000
>>>>>> time=0.002000         step=1
>>>>>> dt = 0.002000
>>>>>> time=0.005000         step=2
>>>>>> dt = 0.003000
>>>>>> time=0.009000         step=3
>>>>>> dt = 0.004000
>>>>>> time=0.014000         step=4
>>>>>> dt = 0.005000
>>>>>> time=0.020000         step=5
>>>>>> dt = 0.006000
>>>>>> Step time elapse = 0.854144 s     Total time elapse = 5.276643 s
>>>>>>   type: theta
>>>>>>   maximum steps=10
>>>>>>   maximum time=2e-11
>>>>>>     Theta=1
>>>>>>     Extrapolation=no
>>>>>>     type: newtonls
>>>>>>       type: bt
>>>>>>         alpha=1.000000e-04
>>>>>> lambda=1.000000e-08
>>>>>>       type: gmres
>>>>>>       type: ilu
>>>>>>         0 levels of fill
>>>>>> [INBLOCKS]
>>>>>>         type: seqaij
>>>>>> On Mon, Oct 27, 2014 at 2:46 PM, Jed Brown <jed at jedbrown.org> wrote:
>>>>>>> Sharp Stone <thronesf at gmail.com> writes:
>>>>>>> > Hi Matt,
>>>>>>> > Thank you very much for your reply.
>>>>>>> > The ts_view output is attached below. I found my code results say
>>>>>>> "SNES has
>>>>>>> > not been set up", and PC "has not been set up". Does this cause the
>>>>>>> > problem? If so I do not see example ex17 explicitly set up the
>>>>>>> snes object?
>>>>>>> Those objects are set up on the first time step (inside TSSolve).
>>>>>>> > PS: I don't know why the -ts_view option does not work in my
>>>>>>> command line,
>>>>>>> Are you sure it doesn't output after the TSSolve?  The example does.
>>>>>>> > so I use TSView() routine just before the TSSolve() routine.
>>>>>>> You should call it *after* the solve so we can see what happened
>>>>>>> during
>>>>>>> the solve.
>>>>>> Best regards,
>>>>>> Feng
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> Best regards,
>>>> Feng
>>> experiments lead.
>>> -- Norbert Wiener
>> Best regards,
>> Feng
> experiments lead.
> -- Norbert Wiener
Best regards,
Feng
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141028/8c16a8f3/attachment-0001.html>
