[petsc-users] Partitioner type for DMPlex?
Aagaard, Brad baagaard at usgs.gov
Mon Oct 27 18:59:55 CDT 2014
Matt made it a PETSc parameter (petscpartitioner_type). Use -help and I
think you should get "chaco", "parmetis", and "shell" as partitioner types.
Brad
On Mon, Oct 27, 2014 at 4:56 PM, Justin Chang <jychang48 at gmail.com> wrote:
> Hi all,
> I just noticed that in petsc-dev the DMPlexDistribute() function no longer
> takes as input the partitioner type. I am assuming that it only uses Chaco
> and that METIS/ParMETIS are no longer options. Is there any particular
> reason for this?
> Thanks,
> Justin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141027/7e560ded/attachment-0001.html>
