[petsc-users] TSSetIJacobian is never called
Sharp Stone thronesf at gmail.com
Mon Oct 27 14:05:43 CDT 2014
Hi Jed and Matt,
Thank you very much for your replies.
This time I copied the whole output from my screen, from compile to
execution. This time I put the TSView() routine just after the TSSolve()
routine to make the tsview output. And I intentionally to do only 5 time
steps to make the test. Thank you in advance!
host206-47:streamer_Implicit_SG GPL$ make pStreamer
/Users/GPL/local/PETSc/petsc-3.5.2/arch-darwin-cxx-debug/bin/mpicxx -o
pStreamer.o -c -Wall -Wwrite-strings -Wno-strict-aliasing
-Wno-unknown-pragmas -g -O0  -fPIC
-I/Users/GPL/local/PETSc/petsc-3.5.2/include
-I/Users/GPL/local/PETSc/petsc-3.5.2/arch-darwin-cxx-debug/include
-I/opt/X11/include   -Wno-unused  `pwd`/pStreamer.cc
/Users/GPL/local/PETSc/petsc-3.5.2/arch-darwin-cxx-debug/bin/mpicc
-Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress
-Wl,-commons,use_dylibs -Wl,-search_paths_first
-Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall
-Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0
-Wno-unused  -o pStreamer flux.o field.o glob_streamer.o input.o
lookuptable.o nrutil.o pStreamer.o someutil.o photoionization.o heating.o
-L/Users/GPL/local/PETSc/petsc-3.5.2/arch-darwin-cxx-debug/lib
-L/Users/GPL/local/PETSc/petsc-3.5.2/arch-darwin-cxx-debug/lib  -lpetsc
-lsuperlu_4.3 -llapack -lblas -lparmetis -lmetis -L/opt/X11/lib -lX11
-lpthread -lssl -lcrypto
-L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/5.1/lib/darwin
-lmpichf90 -lgfortran
-L/usr/local/gfortran/lib/gcc/x86_64-apple-darwin13/4.8.2
-L/usr/local/gfortran/lib -lgfortran -lgcc_ext.10.5 -lquadmath -lm
-lclang_rt.osx -lmpichcxx -lc++
-L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/5.1/lib/darwin
-lclang_rt.osx
-L/Users/GPL/local/PETSc/petsc-3.5.2/arch-darwin-cxx-debug/lib -ldl
-lpmpich -lmpich -lopa -lmpl -lpthread -lSystem
-lclang_rt.osx -ldl
host206-47:streamer_Implicit_SG GPL$ mpiexec -n 1 ./pStreamer
time=0.000000         step=0
dt = 0.001000
time=0.002000         step=1
dt = 0.002000
time=0.005000         step=2
dt = 0.003000
time=0.009000         step=3
dt = 0.004000
time=0.014000         step=4
dt = 0.005000
time=0.020000         step=5
dt = 0.006000
Step time elapse = 0.854144 s     Total time elapse = 5.276643 s
TS Object: 1 MPI processes
  type: theta
  maximum steps=10
  maximum time=2e-11
  total number of nonlinear solver iterations=0
  total number of nonlinear solve failures=0
  total number of linear solver iterations=0
  total number of rejected steps=5
    Theta=1
    Extrapolation=no
  SNES Object:   1 MPI processes
    type: newtonls
    maximum iterations=50, maximum function evaluations=10000
    tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
    total number of function evaluations=1
    SNESLineSearch Object:     1 MPI processes
      type: bt
        interpolation: cubic
        alpha=1.000000e-04
      maxstep=1.000000e+08, minlambda=1.000000e-12
      tolerances: relative=1.000000e-08, absolute=1.000000e-15,
lambda=1.000000e-08
      maximum iterations=40
    KSP Object:     1 MPI processes
      type: gmres
        GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
        GMRES: happy breakdown tolerance 1e-30
      maximum iterations=10000, initial guess is zero
      tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
      left preconditioning
      using DEFAULT norm type for convergence test
    PC Object:     1 MPI processes
      type: ilu
      PC has not been set up so information may be incomplete
        ILU: out-of-place factorization
        0 levels of fill
        tolerance for zero pivot 2.22045e-14
        using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
        matrix ordering: natural
      linear system matrix = precond matrix:
      Mat Object:       1 MPI processes
        type: seqaij
        rows=20904, cols=20904, bs=4
        total: nonzeros=410816, allocated nonzeros=410816
        total number of mallocs used during MatSetValues calls =0
          using I-node routines: found 5226 nodes, limit used is 5
On Mon, Oct 27, 2014 at 2:46 PM, Jed Brown <jed at jedbrown.org> wrote:
> Sharp Stone <thronesf at gmail.com> writes:
> > Hi Matt,
> > Thank you very much for your reply.
> > The ts_view output is attached below. I found my code results say "SNES
> has
> > not been set up", and PC "has not been set up". Does this cause the
> > problem? If so I do not see example ex17 explicitly set up the snes
> object?
> Those objects are set up on the first time step (inside TSSolve).
> > PS: I don't know why the -ts_view option does not work in my command
> line,
> Are you sure it doesn't output after the TSSolve?  The example does.
> > so I use TSView() routine just before the TSSolve() routine.
> You should call it *after* the solve so we can see what happened during
> the solve.
Best regards,
Feng
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141027/9a3ccaf1/attachment.html>
