[petsc-users] Handling dense matrices in RBF interpolation
Fri Oct 24 09:45:43 CDT 2014
On Fri, Oct 24, 2014 at 4:23 AM, Florian Lindner <mailinglists at xgm.de>
wrote:
> Hello,
> I am redoing an radial basis function interpolation algorithm using petsc
> in our software.
> Using basis function with compact carrier is blazingly fast. These basis
> function result in sparse matrices.
>   ierr = MatSetType(matrixC, MATSBAIJ); CHKERRV(ierr); // create
> symmetric, block sparse matrix.
>   ierr = MatSetSizes(matrixC, PETSC_DECIDE, PETSC_DECIDE, n, n);
> CHKERRV(ierr);
>   ierr = MatSetOption(matrixC, MAT_SYMMETRY_ETERNAL, PETSC_TRUE);
> CHKERRV(ierr);
>   ierr = MatSetUp(matrixC); CHKERRV(ierr);
>   ierr = MatSetType(matrixA, MATAIJ); CHKERRV(ierr); // create sparse
> matrix.
>   ierr = MatSetSizes(matrixA, PETSC_DECIDE, PETSC_DECIDE, outputSize, n);
> CHKERRV(ierr);
>   ierr = MatSetUp(matrixA); CHKERRV(ierr);
> Benchmark is a direct dense matrix / LU decomposition, a rather naive
> implementation. The code runs sequentially, using PETSC_COMM_SELF.
> Using the matrix creation code above it's about 10 or 20 times faster,
> still without preallocation. During matrix assembly, which involves looping
> over rows and then over columns I collect all columns in an array and set
> each row using MatSetValues.
> Since the user can select the basis function for the RBF at runtime, my
> code is not aware if it's a compact carrier or not, thus it don't know if
> it results in sparse or dense matrices. Basis functions that produce dense
> matrices make the petsc code more then 50 time slower.
> Running the code with n = 503 (mesh size of 500 + polynom) it takes about
> 16 seconds, with 32% filling matrix A, 15% filling matrix C and 51% doing
> KSPSolve of matrix C (A is not KSPSolved). (dense matrices)
> If I just preallocate a practically dense matrix:
>   ierr = MatSeqAIJSetPreallocation(matrixA, n, NULL); CHKERRV(ierr);
> runtime changes to 10 seconds, with 0% (zero) percent spent with filling
> matrix A. (KSPSolve 76%, Matrix C: 22%). For the sparse case it's that way
> still a lot faster then before, though slower then without preallocation.
> However, trying to preallocate C, which is of type MATSBAIJ fails for me:
>   ierr = MatSeqSBAIJSetPreallocation(_matrixC.matrix, n, n, NULL);
> results in:
>   [0]PETSC ERROR: Arguments are incompatible
>   [0]PETSC ERROR: Cannot change block size 1 to 503
> What would you advise me to do here? How can I make the KSPSolve faster
> when it is a dense matrix?
> I could guess the preallocation. Create a list of possible basis functions
> and if they produce sparse or dense matrices. Preallocate full or select
> MATDENSE type for dense matrices.
1) You should be preallocating all sparse matrices. It is much much much
faster. Just run through your loop
     twice.
2) I would look at your basis and decide whether to use dense or sparse. A
densely preallocated sparse matrix is
     much slower than a dense matrix.
3) You can also look at what we did in
  http://arxiv.org/abs/0909.5413
     Matt
> Any ideas?
> Thanks a lot,
> Florian
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141024/5d7ce7be/attachment.html>
