[petsc-users] Fieldsplit with LSC for constrained elasticity/poroelasticity?
Tabrez Ali stali at geology.wisc.edu
Thu Oct 23 07:20:00 CDT 2014
Hello
I am using the following options (below) for solving linear
elasticity/poroelasticity problems involving slip between two surfaces
involving non-trivial geometries, i.e., elements with high aspect
ratios, large contrasts in material properties etc. The constraints are
imposed using Lagrange Multipliers.
A picture (shows displacement magnitude) is attached. The boundary
nodes, i.e., the base and the four side are pinned.
The following options appear to work well for the saddle point problem:
-pc_type fieldsplit -pc_fieldsplit_type schur
-pc_fieldsplit_detect_saddle_point -fieldsplit_0_pc_type gamg
-fieldsplit_0_ksp_type preonly -fieldsplit_1_pc_type lsc
-fieldsplit_1_ksp_type preonly -pc_fieldsplit_schur_fact_type lower
-ksp_monitor
However, the number of iterations keep on increasing with the problems
size (see attached plot), e.g.,
120K Tets *507* Iterations (KSP Residual norm 8.827362494659e-05)in  17
secs on   3 cores
1 Million Tets *1374* Iterations (KSP Residual norm
7.164704416296e-05)in 117 secs on  20 cores
8 Million Tets *2495* Iterations (KSP Residual norm 9.101247550026e-05)
in 225 secs on 160 cores
So what other options should I try to improve solver performance? Any
tips/insights would be appreciated as preconditioning is black magic to me.
Thanks in advance.
Tabrez
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141023/ce401047/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141023/ce401047/attachment-0001.png>
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141023/ce401047/attachment-0001.pdf>
