[petsc-users] Multiple solves with PCMG fail
Mark Adams mfadams at lbl.gov
Wed Oct 22 08:31:40 CDT 2014
I think we have a fix for this.  You can test by using the branch.  In
PETSC_DIR:
$ git checkout mark/ksp-zero-eig
$ make
Now remake your code and test,
On Wed, Oct 22, 2014 at 8:36 AM, Filippo Leonardi <
filippo.leonardi at sam.math.ethz.ch> wrote:
> Granted that I solved my problem by **not** solving the system if the Rhs
> is
> zero. Here's some result:
> 1) Using Multigrid with debug crashes (see below)
> 2) Using MG without debug doesn't crash, but gives wrong solution
> 3) defaults or gamg or wathever*works both with and without debug
> Now weirder:
> 4) changing line 145 from
>   for(int i = 1; i < N; ++i) {
> to
>   for(int i = 0; i < N; ++i) {
> i.e. avoiding broken case 1) above (rhs never 0) makes 1), 2) and 3) work
> perfectly (and any combination thereof)
> (You can look at the differences in the pictures given by Draw to see that
> the
> solution is more or less wrong.)
> Details:
> Release build with no debug:
> mpirun -np 4 ./test1 -pc_type mg -pc_mg_levels 5 -draw_pause -1
> -ksp_monitor -
> ksp_monitor_true_residual
>   0 KSP Residual norm 0.000000000000e+00
>   0 KSP preconditioned resid norm 0.000000000000e+00 true resid norm
> 0.000000000000e+00 ||r(i)||/||b||           -nan
>   0 KSP Residual norm 3.964678029172e+02
>   0 KSP preconditioned resid norm 3.964678029172e+02 true resid norm
> 1.118033988750e+00 ||r(i)||/||b|| 1.000000000000e+00
>   1 KSP Residual norm 6.290716828453e-13
>   1 KSP preconditioned resid norm 6.290716828453e-13 true resid norm
> 3.788861141557e+00 ||r(i)||/||b|| 3.388860427931e+00
>   0 KSP Residual norm 7.929356058344e+02
>   0 KSP preconditioned resid norm 7.929356058344e+02 true resid norm
> 2.236067977500e+00 ||r(i)||/||b|| 1.000000000000e+00
>   1 KSP Residual norm 1.258143365691e-12
>   1 KSP preconditioned resid norm 1.258143365691e-12 true resid norm
> 7.577722283114e+00 ||r(i)||/||b|| 3.388860427931e+00
> i.e. I don't see the residual to be zero each time.
> Debug build:
> -ksp_monitor -
> [1]PETSC ERROR: [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Null argument, when expecting valid pointer
> [0]PETSC ERROR: Null Pointer: Parameter # 3
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for
> trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.5.0, Jun, 30, 2014
> [0]PETSC ERROR: ./test1 on a arch-linux2-cxx-debug named Besikovitch-II by
> filippo Wed Oct 22 14:20:46 2014
> [0]PETSC ERROR: Configure options --with-clanguage=cxx
> --download-scalapack --
> download-mumps --download-parmetis --download-metis --download-fftw
> [0]PETSC ERROR: #1 KSPComputeEigenvalues() line 119 in
> /home/filippo/Workspace/petsc-3.5.0/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #2 KSPChebyshevComputeExtremeEigenvalues_Private() line
> 328 in
> /home/filippo/Workspace/petsc-3.5.0/src/ksp/ksp/impls/cheby/cheby.c
> [0]PETSC ERROR: #3 KSPSolve_Chebyshev() line 373 in
> [0]PETSC ERROR: #4 KSPSolve() line 459 in
> [0]PETSC ERROR: #5 PCMGMCycle_Private() line 19 in
> /home/filippo/Workspace/petsc-3.5.0/src/ksp/pc/impls/mg/mg.c
> Debug build again with defaults:
> mpirun -np 4 ./test1 -draw_pause -1 -ksp_monitor -ksp_monitor_true_residual
>   0 KSP Residual norm 1.839181443725e+00
>   0 KSP preconditioned resid norm 1.839181443725e+00 true resid norm
>   1 KSP Residual norm 1.767908128952e+00
>   1 KSP preconditioned resid norm 1.767908128952e+00 true resid norm
> 1.182712814433e+00 ||r(i)||/||b|| 1.057850500373e+00
>  82 KSP Residual norm 1.642117972681e-05
>  82 KSP preconditioned resid norm 1.642117972681e-05 true resid norm
> 1.556660502826e-05 ||r(i)||/||b|| 1.392319480883e-05
> 0 KSP Residual norm 3.678362887450e+00
>   0 KSP preconditioned resid norm 3.678362887450e+00 true resid norm
>   1 KSP Residual norm 3.535816257904e+00
>   1 KSP preconditioned resid norm 3.535816257904e+00 true resid norm
> 2.365425628867e+00 ||r(i)||/||b|| 1.057850500373e+00
> On Wednesday 22 October 2014 07:12:50 you wrote:
> > > On Oct 22, 2014, at 1:09 AM, Leonardi Filippo
> > > <filippo.leonardi at sam.math.ethz.ch> wrote:
> > > For 1): I must be missing something then: in main i set and scale
> ctx.rhs,
> > > then I call KSPSolve that calls ComputeRhs that further scales ctx.rhs
> > > and copy it to b, which is then used by the solve. To my understanding
> I
> > > never override ctx.rhs.
> >   Oh yes. I missed that.
> >   What I observed was when I ran your code each solve had an initial
> > residual norm of exactly zero. I’m not sure why that happens.
> > > For 2): that was a small typo, problem is present no matter what
> number of
> > > levels I use.
> > > Thanks,
> > > Filippo
> > >> On 22-ott-2014, at 04:27, "Barry Smith" <bsmith at mcs.anl.gov> wrote:
> > >> There are a few issues with your code
> > >> 1) If you use KSPSetComputeRHS() then the function you provide is
> called
> > >> immediately before the solve automatically for every solve. Thus your
> > >> code with the vector operations here
> > >>  ierr = VecSet(ctx.rhs, (float) i * mx); CHKERRQ(ierr);
> > >>   ierr = VecScale(ctx.rhs,  rank); CHKERRQ(ierr);
> > >>   ierr = KSPSolve(ksp, NULL, NULL); CHKERRQ(ierr);
> > >> does nothing. And each linear solve ends up being with a zero right
> hand
> > >> side.
> > >> 2) -pc_type mg doesn’t give enough information for the multigrid to
> know
> > >> how many levels to use. In fact it is always using one hence it is not
> > >> multigrid. You  need to use -p_mg_levels 2 or 3 or whatever to get it
> to
> > >> use more than one level.
> > >> Barry
> > >>> On Oct 21, 2014, at 1:50 AM, Filippo Leonardi
> > >>> Here,
> > >>> run this e.g. with
> > >>> mpirun -np 4 ./test1 -draw_pause -1 -pc_type mg -pc_mg_galerkin
> > >>> In Debug mode it crashes, in standard mode it fails. Using Petsc
> > >>> current.
> > >>> Run without mg and works!
> > >>> Hope it's not me being stupid and doing something terribly wrong!
> > >>> Best,
> > >>> Filippo
> > >>>> On Monday 20 October 2014 07:29:04 Barry Smith wrote:
> > >>>> Can you send us the code: to petsc-maint at mcs.anl.gov or
> > >>>> petsc-users at mcs.anl.gov ? Or something that reproduces the problem?
> > >>>> Barry
> > >>>>> On Oct 20, 2014, at 3:31 AM, Filippo Leonardi
> > >>>>> Hi,
> > >>>>> I have a very specific problem that I cannot figure out with PCMG
> and
> > >>>>> multiple solves. I got a linear system that I solve many times,
> with
> > >>>>> same
> > >>>>> matrix but different RHS. I can successfully solve the system with
> > >>>>> standard techniques, such as default solver or LU or PCGAMG. Even
> MG
> > >>>>> works if I destroy the ksp each time or I recompute the matrices at
> > >>>>> each
> > >>>>> time. But when I try and go to MG and not recomputing the matrices
> > >>>>> each
> > >>>>> time the solver fails. Any idea?
> > >>>>> Here some detail: the setup:
> > >>>>> ierr = KSPSetDMActive(ksp, PETSC_FALSE); CHKERRQ(ierr);
> > >>>>> ierr = KSPSetDM(ksp,  da); CHKERRQ(ierr);
> > >>>>> ierr = KSPSetComputeOperators(ksp, ComputeMatrix, ctx);
> CHKERRQ(ierr);
> > >>>>> ierr = KSPSetComputeRHS(ksp, ComputeRHS, ctx); CHKERRQ(ierr);
> > >>>>> ierr = KSPSetFromOptions(ksp); CHKERRQ(ierr);
> > >>>>> Then I solve as usual, for a large number of time steps:
> > >>>>> ierr = KSPGetSolution(ksp, &phi);
> > >>>>> The solver converges and does that in a reasonable number of
> > >>>>> iterations:
> > >>>>> Linear solve converged due to CONVERGED_RTOL iterations 7
> > >>>>> And ksp_view and ksp_monitor do not show any weird stuff.
> > >>>>> - Weirdly enough using any solver (for instance cg+bjacobi or gamg)
> > >>>>> everything works (So the matrix and RHS are working fine).
> > >>>>> - But the problem persists with Galerkin matrices (-pc_mg_galerkin)
> > >>>>> (So is
> > >>>>> not a ComputeMatrix problem).
> > >>>>> - If I do:
> > >>>>> ierr = KSPSetComputeOperators(ksp, ComputeMatrix, this);
> > >>>>> CHKERRQ(ierr);
> > >>>>> between each solve or destroy the ksp entirely each time the
> solution
> > >>>>> is
> > >>>>> also perfect (So is not a boundary scaling or other stuff problem).
> > >>>>> - If I run MG with only 2 levels (so just coarse) I also get a fine
> > >>>>> result.
> > >>>>> Setup RHS is called each time as expected, setup matrix is called
> just
> > >>>>> once, also as expected.
> > >>>>> The only thing I can think is that MG does not update some value
> that
> > >>>>> actually needs to be recomputed.
> > >>>>> Any idea?
> > >>>>> The solution is not that different from:
> http://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutori
> > >>>>> als/
> > >>>>> ex29.c.html
> > >>>>> Best,
> > >>>>> Filippo
> > >>> <test1.cpp>
> Filippo Leonardi
> SAM ETH Zürich
> (HG J 45) Rämistrasse 101, Zürich (CH)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141022/dcc03c33/attachment.html>
