[petsc-users] unreliable AMG in PETSc
Arne Morten Kvarving arne.morten.kvarving at sintef.no
Wed Oct 22 08:21:26 CDT 2014
hi there.
we (sintef ict) use (parts of) PETSc in our (isogeometric) finite
element library.
sadly i find that the AMG in petsc is somewhat unreliable and it's a
pain to deal with users (students) due to this fact.
now, we all know that linear algebra, and AMG in particular, is more art
than craft at times, certainly to the uneducated, and you can only do
this much to automate it. but segfaults are bad. preconditioners which
break the symmetry of the systems are bad. preconditioners that breaks
the definiteness of systems is also bad. and worse; here it depends on
the number of MPI processes. meshes are typically targeted a given world
size and if you are unlucky, this number is one that does not work.
as an example to illustrate this, consider
http://www.math.ntnu.no/~arnemort/petsc-amg-bug.tar.bz2
it's about 30MB due to a somewhat large matrix, hopefully your pipes
will survive.
this is a (isogeometric) standard Poisson problem using cubic splines,
with homogenous dirichlet boundaries and a uniform source (f = 1) on a
mesh intended for simulating flow around wings, but i used the Poisson
to keep it simple. see
http://www.math.ntnu.no/~arnemort/wing.png
if you want to get an idea.
the tarball has the matrix and vector, as well as a cmake-based
buildsystem for a simple test app (hacked ex23.c). it contains a number
of tests (64 in total) to illustrate the unreliable behavior.
in particular it solves the stored linear system using 1 through 32
processors, with either amg + sor or asm + ilu. the former fails and
crashes for several runs, while the latter runs through for all (there
to illustrate that the systems are solvable so that it is not drawn into
question).
i have tried this with v3.4.2, v3.4.4 and v3.5.2 - they all fail. in
v3.4.2 one more test fails compared to the others. i have also confirmed
that i can produce across systems and across toolchains (gcc 4.8 and icc
14.0). the fails i get are
27:amg_14
39:amg_20
41:amg_21
43:amg_22
45:amg_23
49:amg_25
51:amg_26
53:amg_27
55:amg_28
57:amg_29
61:amg_31
63:amg_32
do not put much thought into the configurations, or the high iteration
counts. in the "real" code stronger smoothers etc are employed. but
again i wanted to keep it simple.
i do suspect that eventually the cause is ML. disclaimer: i have never
been able to (find the energy to) decode the "slightly unreadable" code
of petsc so i haven't tried to dig.
i do realize this "bug report" has a number of holes (as far as the
information it contains is entailed), and i can provide whatever you
need upon request. but i have already sunk too much time into this and
are behind on my projects :)
usage instructions below.
regards,
arnem
usage: requires petsc >= 3.4, some c++ compiler and cmake.
export PETSC_DIR=<dir to petsc>
export PETSC_ARCH=<petsc configuration>
basic usage:
tar jxvf petsc-amg-bug.tar.bz2
cd petsc-amg-bug
cmake . -DCMAKE_BUILD_TYPE=Release
make
make test
for verbose output of the process - replace make test with 'ctest -V'
if your system does not provide the mpi spawner as 'mpirun', you can
pass -DMPIRUN_COMMAND=<path-to-binary> to cmake. DO NOTE: you cannot use
petscmpiexec as that does not return the error code to the terminal
(probably should report that as a separate bug). or well, you can use
it, but if you do, a failed tests with be reported as a success.
you can execute particular tests only using ctest -R <re to match> -V
to run only the amg tests do
ctest -R amg.* -V
to run only a given amg test do
ctest -R amg_5 -V
