[petsc-users] Invalid MAT_CLASSID
Harshad Sahasrabudhe hsahasra at purdue.edu
Mon Oct 20 17:21:06 CDT 2014
Hi Matt,
If I have 2 instances of PETSc, one which is initialized by LibMesh and the
other which is initialized in my code, then would getting a Mat from one
version to the other cause this issue? I know that this is not the right
way to do it, I'm just trying to zero in on the problem.
a) is not the problem, since I create and assemble the matrix using LibMesh
API. b) is not it either, I ran a simple example and it works in that case.
For c), I ran my code with Valgrind and didn't get any invalid write errors.
Harshad
On Mon, Oct 20, 2014 at 4:19 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Oct 20, 2014 at 3:17 PM, Harshad Sahasrabudhe <hsahasra at purdue.edu
> > wrote:
>> I get the Mat object from libMesh::PetscMatrix<>::mat()
>> <http://libmesh.github.io/libmesh/doxygen/classlibMesh_1_1PetscMatrix.html#aaca7a5afeb063716ee67fa11302c2aea>,
>> and it's been created and assembled before I call MatGetType.
> But what you are getting is invalid, so either
>   a) it has not been created and assembled in LibMesh
>   b) the right thing is not getting passed back (LibMesh problem)
> or
>   c) you are overwriting memory and it manifests here (check with valgrind)
> It is very easy to look in these structures using the debugger. We are
> just checking an integer
> in the header for the object that identifies it as a Mat.
>    Matt
>> On Mon, Oct 20, 2014 at 4:12 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Mon, Oct 20, 2014 at 3:07 PM, Harshad Sahasrabudhe <
>>> hsahasra at purdue.edu> wrote:
>>>> Hi,
>>>> I get the following error when I call MatGetType even though I'm
>>>> calling the function with a Mat object.
>>>> [0]PETSC ERROR: Invalid argument!
>>>> [0]PETSC ERROR: Wrong type of object: Parameter # 1!
>>>> What could be going wrong?
>>> You are not calling it with a valid Mat object. Did you call MatCreate?
>>>    Matt
>>>> Thanks,
>>>> Harshad
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141020/ee419d4a/attachment.html>
