[petsc-users] Check Array and String Bounds in PETSc
Danyang Su danyang.su at gmail.com
Mon Oct 20 13:44:41 CDT 2014
On 20/10/2014 11:00 AM, Barry Smith wrote:
>> On Oct 20, 2014, at 11:56 AM, Danyang Su <danyang.su at gmail.com> wrote:
>> On 19/10/2014 5:06 PM, Barry Smith wrote:
>>>    Use ISLocalToGlobalMappingGetIndicesF90()
>> Hi Barry,
>> Would you please give my a brief introduction or example on the parameters for this function? I didn't find it in the PETSc manual page.
>> The following codes will cause stack overflow. Maybe the idx data type is wrong here. Would you please let me know what data type should be used here?
>> PetscInt, pointer :: idx(:)
>> call DMGetLocalToGlobalMapping(dmda_flow%da,ltogm,ierr)
>> call ISLocalToGlobalMappingGetIndicesF90(ltogm,idx,ierr)
>     Your code above looks ok. You’ll have to be more specific as to what goes wrong. Can you reproduce it in a small example that demonstrates the problem?
>    Barry
It seems tricky. I tried different version of PETSc and different
method, as shown below.
When using PETSc 3.4.4 with the old functions, everything works fine.
When using PETSc 3.5.2 method 1, everything works except that I cannot
use "check array bounds" option, otherwise, the codes stop at
"node_idx_lg2pg(ivol) = ...". This is not a big problem but sometimes I
need to use this option to debug.
When using PETSc 3.5.2 method 2, the codes stop at
"ISLocalToGlobalMappingGetIndicesF90" with stack overflow. All the other
codes and compiling options are the same.
#ifdef PETSC_V3_5_X
         ISLocalToGlobalMapping :: ltogm
         !Method 1
         !PetscInt :: ltog(1)
         !PetscOffset :: idltog
         !Method 2
#else
#endif
#ifdef PETSC_V3_5_X
         !Method 1
         !call DMGetLocalToGlobalMapping(dmda_flow%da,ltogm,ierr)
         !call ISLocalToGlobalMappingGetIndices(ltogm,ltog,idltog,ierr)
         !Method 2
#else
         call DMDAGetGlobalIndicesF90(dmda_flow%da,PETSC_NULL_INTEGER,  &
                                      idx,ierr)
#endif
#ifdef PETSC_V3_5_X
             !Method 1
             !node_idx_lg2pg(ivol) = (ltog(ivol*dof + idltog)+1)/dof
             !Method 2
             node_idx_lg2pg(ivol) = (idx(ivol*dof)+1)/dof
#else
#endif
#ifdef PETSC_V3_5_X
         !Method 1
         !call ISLocalToGlobalMappingRestoreIndices(ltogm,ltog,idltog,ierr)
         !Method 2
         call ISLocalToGlobalMappingRestoreIndicesF90(ltogm,idx,ierr)
#endif
Danyang
>> Thanks,
>> Danyang
>>>> On Oct 19, 2014, at 6:38 PM, Danyang Su <danyang.su at gmail.com> wrote:
>>>> Hi All,
>>>> How can I avoid "array bounds" error when using PETSc. I have to debug my codes so I compiled the codes with option "Check Array and String Bounds". But  this results into array bounds error when I need to use ltog, as shown below.
>>>> Exactly the aforementioned two lines work fine and the bug is in somewhere else. But the debug process just stops at the codes when ltog is used. How can avoid this?
>>>> Thanks,
>>>> Danyang
