[petsc-users] Adaptive controllers in TS
Miguel Angel Salazar de Troya salazardetroya at gmail.com
Sun Oct 19 12:25:45 CDT 2014
Hi all
I'm trying to find out what is the adaptive controller scheme used in the
Runge-Kutta time stepping algorithm. Basically I want to know the function
that determines the next time step. I see that the next time step is set
with the function TSAdaptChoose(), which calls the pointer function
(*choose)() within the structure _TSAdaptOps, but where is this set?
I need to know this for an adjoint analysis to calculate gradients. I was
wondering if there is an example of such analysis with the TS structure.
I've seen that the RK source file includes a funciton to interpolate the
solution, something that is necessary in an adjoint analysis, hence my
question about the example.
Thanks
Miguel
*Miguel Angel Salazar de Troya*
Graduate Research Assistant
Department of Mechanical Science and Engineering
University of Illinois at Urbana-Champaign
(217) 550-2360
salaza11 at illinois.edu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141019/6dc57d86/attachment.html>
