[petsc-users] TS example tutorial example 4 adapted - not parallelizing
Analabha Roy hariseldon99 at gmail.com
Thu Oct 16 02:48:50 CDT 2014
Hi all,
Thanks for the response.
On Wed, Oct 15, 2014 at 4:15 PM, Matthew Knepley <knepley at gmail.com> wrote:
> I am not sure what you are doing at line 483. You seem to have all
> processes indexing a Vec
> at all entries, which cannot be correct.
Yes, you're right, of course. I have removed that bit (I'll do it in
post-processing after I have dumped the full state data to file).
In the meantime, the graphical output is still messed up when the code is
run with debug flag in parallel. However, parallel graphical output works
fine in the original ex4.c. I can;t figure out why...
I have updated diff (link to pretty version
<http://www.diffnow.com/?report=49thu>) attached and posted below.
Thanks and Regards,
Analabha
0a1,2
> //PROBLEMS:
> //FIX PARALLELIZATION PROBLEM
3,8c5,11
<   "Solves a simple time-dependent linear PDE (the heat equation).\n\
< Input parameters include:\n\
<   -m <points>, where <points> = number of grid points\n\
<   -time_dependent_rhs : Treat the problem as having a time-dependent
right-hand side\n\
<   -debug              : Activate debugging printouts\n\
<   -nox                : Deactivate x-window graphics\n\n";
>   "Solves a simple time-dependent Schroedinger equation for a TB model
with periodic drive.\n\
> Apart from PetSc's routine options, input parameters include:\n\
>   -m <pnts>,   where <pnts>   = lattice size\n\
>   -a <ampl>,   where <ampl>   = drive amplitude\n\
>   -d <strg>,   where <strg>   = disorder strength\n\
>   -w <freq>,   where <freq>   = drive frequency\n\
>   -debug              : Activate debugging printouts\n\n";
11,14c14
<    Concepts: TS^time-dependent linear problems
<    Concepts: TS^heat equation
<    Concepts: TS^diffusion equation
<    Processors: n
>    Default problem parameters. These are overwritten by argument vectors
15a16,29
> #define DEFAULT_SIZE 100
> #define DEFAULT_ALPHA 0.3
> #define DEFAULT_AMPL 3.0
> #define DEFAULT_W 3.0
> #define TIME_TOTAL_MAX 100.0 /* default max total time */
> #define TIME_STEPS_MAX 1E5 /* default max timesteps */
>    Default problem parameters. These are always hard coded and never
>    overwritten
> #define INIT_STEP 1E-4
> #define INIT_TIME 0.0
> #define ABSERROR 1E-9
> #define RELERROR 1E-9
19,31c33,39
<    This program solves the one-dimensional heat equation (also called the
<    diffusion equation),
<        u_t = u_xx,
<    on the domain 0 <= x <= 1, with the boundary conditions
<        u(t,0) = 0, u(t,1) = 0,
<    and the initial condition
<        u(0,x) = sin(6*pi*x) + 3*sin(2*pi*x).
<    This is a linear, second-order, parabolic equation.
<    We discretize the right-hand side using finite differences with
<    uniform grid spacing h:
<        u_xx = (u_{i+1} - 2u_{i} + u_{i-1})/(h^2)
<    We then demonstrate time evolution using the various TS methods by
>    This program solves the one-dimensional Schroedinger equation in a
>    tightly bound lattice with a periodic time dependence
>        \partial_t u_m(t) = \sum_m J_{lm}(t) u_m(t),
>    on the domain 0 <= m < L, with the boundary conditions
>        u_m(0) = 0 for all m except m=[L/2], where u_m(0) = 1
>    This is a set of linear, first-order ODEs
>    The time evolution using the various TS methods can be run by
34,46d41
<    We compare the approximate solution with the exact solution, given by
<        u_exact(x,t) = exp(-36*pi*pi*t) * sin(6*pi*x) +
<                       3*exp(-4*pi*pi*t) * sin(2*pi*x)
<    Notes:
<    This code demonstrates the TS solver interface to two variants of
<    linear problems, u_t = f(u,t), namely
<      - time-dependent f:   f(u,t) is a function of t
<      - time-independent f: f(u,t) is simply f(u)
<     The uniprocessor version of this code is ts/examples/tutorials/ex3.c
59a55
64d59
75d69
<   Vec solution; /* global exact solution vector */
77d70
<   PetscReal h; /* mesh width h = 1/(m-1) */
79,80c72,77
<   PetscViewer viewer1, viewer2; /* viewers for the solution and error */
<   PetscReal norm_2, norm_max; /* error norms */
>   PetscViewer viewer1; /* viewer for the solution  */
>   PetscReal norm_2; /* wavefunction norm */
>   Vec randoms; /* random numbers between -1 and 1 */
>   PetscReal alpha; /* disorder strength */
>   PetscReal h0; /* drive amplitude */
>   PetscReal w; /* drive frequency */
85a83
> extern PetscInt kdel (PetscInt, PetscInt);
87,88c85,86
< extern PetscErrorCode RHSMatrixHeat (TS, PetscReal, Vec, Mat, Mat, void
< extern PetscErrorCode RHSFunctionHeat (TS, PetscReal, Vec, Vec, void *);
> extern PetscErrorCode RHSMatrixSchrodinger (TS, PetscReal, Vec, Mat, Mat,
>     void *);
90d87
< extern PetscErrorCode ExactSolution (PetscReal, Vec, AppCtx *);
101,102c98,99
<   PetscReal time_total_max = 1.0; /* default max total time */
<   PetscInt time_steps_max = 100; /* default max timesteps */
>   PetscReal time_total_max = TIME_TOTAL_MAX; /* default max total time */
>   PetscInt time_steps_max = TIME_STEPS_MAX; /* default max timesteps */
108,109c105,107
<   PetscBool flg;
<   TSProblemType tsproblem = TS_LINEAR;
>   PetscReal alpha; /* Disorder strength */
>   PetscReal h0; /* Drive amplitude */
119c117
<   m = 60;
>   m = DEFAULT_SIZE;
121a120,132
>   h0 = DEFAULT_AMPL;
>   ierr = PetscOptionsGetReal (NULL, "-a", &h0, NULL);
>   CHKERRQ (ierr);
>   alpha = DEFAULT_ALPHA;
>   ierr = PetscOptionsGetReal (NULL, "-d", &alpha, NULL);
>   CHKERRQ (ierr);
>   w = DEFAULT_W;
>   ierr = PetscOptionsGetReal (NULL, "-w", &w, NULL);
>   CHKERRQ (ierr);
123a135
125,127c137,141
<   appctx.h = 1.0 / (m - 1.0);
<   appctx.norm_2 = 0.0;
<   appctx.norm_max = 0.0;
>   appctx.alpha = alpha;
>   appctx.h0 = h0;
>   appctx.w = w;
>   appctx.norm_2 = 1.0;
163d176
<      create global work vector for storing exact solution.
167,168d179
<   ierr = VecDuplicate (u, &appctx.solution);
<   CHKERRQ (ierr);
171c182
<      Set up displays to show graphs of the solution and error
173,189c184,195
<   ierr =
<     PetscViewerDrawOpen (PETSC_COMM_WORLD, 0, "", 80, 380, 400, 160,
<  &appctx.viewer1);
<   CHKERRQ (ierr);
<   ierr = PetscViewerDrawGetDraw (appctx.viewer1, 0, &draw);
<   CHKERRQ (ierr);
<   ierr = PetscDrawSetDoubleBuffer (draw);
<   CHKERRQ (ierr);
<   ierr =
<     PetscViewerDrawOpen (PETSC_COMM_WORLD, 0, "", 80, 0, 400, 160,
<  &appctx.viewer2);
<   CHKERRQ (ierr);
<   ierr = PetscViewerDrawGetDraw (appctx.viewer2, 0, &draw);
<   CHKERRQ (ierr);
<   CHKERRQ (ierr);
>   if (appctx.debug)
>       ierr =
> PetscViewerDrawOpen (PETSC_COMM_WORLD, 0, "Probability Distribution",
>      PETSC_DECIDE, PETSC_DECIDE, PETSC_DRAW_HALF_SIZE,
>      PETSC_DRAW_HALF_SIZE, &appctx.viewer1);
>       CHKERRQ (ierr);
>       CHKERRQ (ierr);
>       CHKERRQ (ierr);
197,202c203
<   flg = PETSC_FALSE;
<   ierr = PetscOptionsGetBool (NULL, "-nonlinear", &flg, NULL);
<   CHKERRQ (ierr);
<   ierr = TSSetProblemType (ts, flg ? TS_NONLINEAR : TS_LINEAR);
<   CHKERRQ (ierr);
>   TSSetProblemType (ts, TS_LINEAR); /* In this case, the dynamics is
always linear */
205c206
<      Set optional user-defined monitoring routine
>      Set user-defined monitoring routine
211d211
224,225c224,257
<   ierr = PetscOptionsGetBool (NULL, "-time_dependent_rhs", &flg, NULL);
>      Create random number context and generate random numbers
>      into application context
>   PetscRandom rctx; /* random number generator context */
>   PetscScalar randomscale = 2.0 * PETSC_i * alpha;
>   ierr = PetscRandomCreate (PETSC_COMM_SELF, &rctx);
>   CHKERRQ (ierr);
>   ierr = PetscRandomSetFromOptions (rctx);
>   CHKERRQ (ierr);
>   ierr = PetscRandomSetInterval (rctx, -1.0, 1.0);
>   CHKERRQ (ierr);
>   ierr = VecCreate (PETSC_COMM_SELF, &appctx.randoms);
>   CHKERRQ (ierr);
>   ierr = VecSetSizes (appctx.randoms, PETSC_DECIDE, m);
>   CHKERRQ (ierr);
>   ierr = VecSetFromOptions (appctx.randoms);
>   CHKERRQ (ierr);
>   ierr = VecSetRandom (appctx.randoms, rctx);
>   CHKERRQ (ierr);
>   ierr = VecScale (appctx.randoms, randomscale);
>   CHKERRQ (ierr);
>   ierr = PetscRandomDestroy (&rctx);
>   CHKERRQ (ierr);
>      For linear problems with a time-dependent f(u,t) in the equation
>      u_t = f(u,t), the user provides the discretized right-hand-side
>      as a time-dependent matrix.
>   ierr = TSSetRHSFunction (ts, NULL, TSComputeRHSFunctionLinear, &appctx);
>   CHKERRQ (ierr);
>   ierr = TSSetRHSJacobian (ts, A, A, RHSMatrixSchrodinger, &appctx);
227,254d258
<   if (flg)
<          For linear problems with a time-dependent f(u,t) in the equation
<          u_t = f(u,t), the user provides the discretized right-hand-side
<          as a time-dependent matrix.
<       ierr = TSSetRHSFunction (ts, NULL, TSComputeRHSFunctionLinear,
&appctx);
<       CHKERRQ (ierr);
<       ierr = TSSetRHSJacobian (ts, A, A, RHSMatrixHeat, &appctx);
<       CHKERRQ (ierr);
<   else
<          For linear problems with a time-independent f(u) in the equation
<          u_t = f(u), the user provides the discretized right-hand-side
<          as a matrix only once, and then sets a null matrix evaluation
<          routine.
<       ierr = RHSMatrixHeat (ts, 0.0, u, A, A, &appctx);
<       CHKERRQ (ierr);
&appctx);
<       CHKERRQ (ierr);
<       ierr =
< TSSetRHSJacobian (ts, A, A, TSComputeRHSJacobianConstant, &appctx);
<       CHKERRQ (ierr);
256,266d259
<   if (tsproblem == TS_NONLINEAR)
<       SNES snes;
<       ierr = TSSetRHSFunction (ts, NULL, RHSFunctionHeat, &appctx);
<       CHKERRQ (ierr);
<       ierr = TSGetSNES (ts, &snes);
<       CHKERRQ (ierr);
<       ierr =
< SNESSetJacobian (snes, NULL, NULL, SNESComputeJacobianDefault, NULL);
<       CHKERRQ (ierr);
272,273c265,266
<   dt = appctx.h * appctx.h / 2.0;
<   ierr = TSSetInitialTimeStep (ts, 0.0, dt);
>   dt = INIT_STEP;
>   ierr = TSSetInitialTimeStep (ts, INIT_TIME, dt);
281a275
>      - Set default tolerances
287a282,285
>   ierr = TSSetType (ts, TSRK);
>   CHKERRQ (ierr);
>   ierr = TSRKSetType (ts, TSRK5DP); //Default solver is Runge Kutta (5)
Prince-Dormand (4)
>   CHKERRQ (ierr);
289a288,291
>   ierr = TSSetTolerances (ts, ABSERROR, NULL, RELERROR, NULL);
>   CHKERRQ (ierr);
321,324c323,324
<     PetscPrintf (PETSC_COMM_WORLD,
<  "Avg. error (2 norm) = %g Avg. error (max norm) = %g\n",
<  (double) (appctx.norm_2 / steps),
<  (double) (appctx.norm_max / steps));
>     PetscPrintf (PETSC_COMM_WORLD, "Final. (2 norm) = %g \n",
>  (double) (appctx.norm_2));
338,341c338,343
<   ierr = PetscViewerDestroy (&appctx.viewer1);
<   CHKERRQ (ierr);
<   ierr = PetscViewerDestroy (&appctx.viewer2);
<   CHKERRQ (ierr);
>   if (appctx.debug)
>       CHKERRQ (ierr);
344,345d345
<   ierr = VecDestroy (&appctx.solution);
<   CHKERRQ (ierr);
347a348,349
>   ierr = VecDestroy (&appctx.randoms);
>   CHKERRQ (ierr);
377c379
<   PetscScalar *u_localptr, h = appctx->h;
>   PetscScalar *u_localptr;
379a382
>   PetscScalar zero = 0.0, one = 1.0;
394,395d396
<      - Note that the Fortran interface to VecGetArray() differs from the
<      C version.  See the users manual for details.
402,403c403,404
<      directly into the array locations.  Alternatively, we could use
<      VecSetValues() or VecSetValuesLocal().
>      This will set the midpoint to unity
406,408c407,410
<     u_localptr[i - mybase] =
<       PetscSinScalar (PETSC_PI * i * 6. * h) +
<       3. * PetscSinScalar (PETSC_PI * i * 2. * h);
>     if (i - mybase == floor ((appctx->m) / 2))
>       u_localptr[i - mybase] = one;
>     else
>       u_localptr[i - mybase] = zero;
421c423
<       ierr = PetscPrintf (appctx->comm, "initial guess vector\n");
>       ierr = PetscPrintf (appctx->comm, "initial vector\n");
432,486d433
< #define __FUNCT__ "ExactSolution"
<    ExactSolution - Computes the exact solution at a given time.
<    Input Parameters:
<    t - current time
<    solution - vector in which exact solution will be computed
<    appctx - user-defined application context
<    Output Parameter:
<    solution - vector with the newly computed exact solution
< PetscErrorCode
< ExactSolution (PetscReal t, Vec solution, AppCtx * appctx)
<   PetscScalar *s_localptr, h = appctx->h, ex1, ex2, sc1, sc2;
<   PetscInt i, mybase, myend;
<   PetscErrorCode ierr;
<      Determine starting and ending points of each processor's
<      range of grid values
<   ierr = VecGetOwnershipRange (solution, &mybase, &myend);
<   CHKERRQ (ierr);
<      Get a pointer to vector data.
<   ierr = VecGetArray (solution, &s_localptr);
<   CHKERRQ (ierr);
<      Simply write the solution directly into the array locations.
<      Alternatively, we culd use VecSetValues() or VecSetValuesLocal().
<   ex1 = PetscExpReal (-36. * PETSC_PI * PETSC_PI * t);
<   ex2 = PetscExpReal (-4. * PETSC_PI * PETSC_PI * t);
<   sc1 = PETSC_PI * 6. * h;
<   sc2 = PETSC_PI * 2. * h;
<   for (i = mybase; i < myend; i++)
<     s_localptr[i - mybase] =
<       PetscSinScalar (sc1 * (PetscReal) i) * ex1 +
<       3. * PetscSinScalar (sc2 * (PetscReal) i) * ex2;
<      Restore vector
<   ierr = VecRestoreArray (solution, &s_localptr);
<   CHKERRQ (ierr);
<   return 0;
< #undef __FUNCT__
490,491c437
<    each timestep.  This example plots the solution and computes the
<    error in two different norms.
>    each timestep.  This example plots the solution and returns the norm
509,515c455
<      View a graph of the current iterate
<   ierr = VecView (u, appctx->viewer2);
<   CHKERRQ (ierr);
>   PetscReal norm_2;
518c458
<      Compute the exact solution
>      Compute and store norm of wavefunction in norm_2
520c460
<   ierr = ExactSolution (time, appctx->solution, appctx);
>   ierr = VecNorm (u, NORM_2, &norm_2);
521a462
>   appctx->norm_2 = norm_2;
523,536d463
<      Print debugging information if desired
<   if (appctx->debug)
<       ierr = PetscPrintf (appctx->comm, "Computed solution vector\n");
<       CHKERRQ (ierr);
<       ierr = VecView (u, PETSC_VIEWER_STDOUT_WORLD);
<       CHKERRQ (ierr);
<       ierr = PetscPrintf (appctx->comm, "Exact solution vector\n");
<       CHKERRQ (ierr);
<       ierr = VecView (appctx->solution, PETSC_VIEWER_STDOUT_WORLD);
<       CHKERRQ (ierr);
538,541c465,467
<      Compute the 2-norm and max-norm of the error
<   ierr = VecAXPY (appctx->solution, -1.0, u);
>   /* Build the lattice sites */
>   Vec uabs;
>   ierr = VecDuplicate (u, &uabs);
543c469,470
<   ierr = VecNorm (appctx->solution, NORM_2, &norm_2);
>   ierr = VecCopy (u, uabs);
545,546c472
<   norm_2 = PetscSqrtReal (appctx->h) * norm_2;
<   ierr = VecNorm (appctx->solution, NORM_MAX, &norm_max);
>   ierr = VecAbs (uabs);
549,556c475
<      PetscPrintf() causes only the first processor in this
<      communicator to print the timestep information.
<   ierr =
<     PetscPrintf (appctx->comm,
<  "Timestep %D: time = %g 2-norm error = %g max norm error = %g\n",
<  step, (double) time, (double) norm_2, (double) norm_max);
>   ierr = VecPointwiseMult (uabs, uabs, uabs);
558,559d476
<   appctx->norm_2 += norm_2;
<   appctx->norm_max += norm_max;
561,565c478,483
<      View a graph of the error
<   ierr = VecView (appctx->solution, appctx->viewer1);
<   CHKERRQ (ierr);
>   //if (!appctx->debug)
>   /* Create another viewer in application context and dump full output to
it */
>   //ierr = VecView (u, appctx->viewer2);
>   //CHKERRQ (ierr);
572,574c490,497
<       ierr = PetscPrintf (appctx->comm, "Error vector\n");
<       CHKERRQ (ierr);
>       ierr =
> PetscPrintf (PETSC_COMM_WORLD, "time = %lf\t norm = %lf\n", time,
>      norm_2);
>       ierr = VecView (uabs, appctx->viewer1);
576a500,501
>   ierr = VecDestroy (&uabs);
>   CHKERRQ (ierr);
583c508
< #define __FUNCT__ "RHSMatrixHeat"
> #define __FUNCT__ "RHSMatrixSchrodinger"
585c510
<    RHSMatrixHeat - User-provided routine to compute the right-hand-side
>    RHSMatrixSchrodinger - User-provided routine to compute the
right-hand-side
599,600c524
<   Notes:
<   RHSMatrixHeat computes entries for the locally owned part of the system.
>   RHSMatrixSchrodinger computes entries for the locally owned part of the
system.
613c537
< RHSMatrixHeat (TS ts, PetscReal t, Vec X, Mat AA, Mat BB, void *ctx)
> RHSMatrixSchrodinger (TS ts, PetscReal t, Vec X, Mat AA, Mat BB, void
*ctx)
618,619c542,554
<   PetscInt i, mstart, mend, idx[3];
<   PetscScalar v[3], stwo = -2. / (appctx->h * appctx->h), sone = -.5 *
stwo;
>   PetscInt m = appctx->m;
>   PetscScalar drive;
>   PetscReal h0 = appctx->h0;
>   PetscReal w = appctx->w;
>   PetscScalar *randoms_loc;
>   ierr = VecGetArray (appctx->randoms, &randoms_loc);
>   CHKERRQ (ierr);
>   /*Calculate drive amplitude at this time */
>   drive = w * t;
>   drive = PetscSinReal (drive);
>   drive = 2.0 * PETSC_i * h0 * drive;
623,625c558,566
<   ierr = MatGetOwnershipRange (A, &mstart, &mend);
>      The Jacobian Matrix in our case is blocked
>      - The values are A_{lm} =
 i\left(\delta_{lm+1}+\delta_{lm-1}\right)+2i \alpha h_m\delta_{lm} + 2i
h(t) \delta_{lm}
>      - Thus the superdiagonal and subdiagonal elements are just i, and
diagonal elements are random + drive
>      - The elements are set rowwise.
>   PetscInt rowstart, rowend, rowcount;
>   PetscScalar edge[2], middle[3];
>   PetscInt idxedge[2], idxmiddle[3];
>   ierr = MatGetOwnershipRange (A, &rowstart, &rowend);
627,655c568
<      Set matrix rows corresponding to boundary data
<   if (mstart == 0)
<     { /* first processor only */
<       v[0] = 1.0;
<       ierr = MatSetValues (A, 1, &mstart, 1, &mstart, v, INSERT_VALUES);
<       CHKERRQ (ierr);
<       mstart++;
<   if (mend == appctx->m)
<     { /* last processor only */
<       mend--;
<       v[0] = 1.0;
<       ierr = MatSetValues (A, 1, &mend, 1, &mend, v, INSERT_VALUES);
<       CHKERRQ (ierr);
<      Set matrix rows corresponding to interior data.  We construct the
<      matrix one row at a time.
<   v[0] = sone;
<   v[1] = stwo;
<   v[2] = sone;
<   for (i = mstart; i < mend; i++)
>   for (rowcount = rowstart; rowcount < rowend; rowcount++)
657,661c570,602
<       idx[0] = i - 1;
<       idx[1] = i;
<       idx[2] = i + 1;
<       ierr = MatSetValues (A, 1, &i, 3, idx, v, INSERT_VALUES);
<       CHKERRQ (ierr);
>       if (rowcount == 0) //If it is the first row of the whole matrix
>   edge[0] = drive + randoms_loc[0];
>   edge[1] = PETSC_i;
>   idxedge[0] = 0;
>   idxedge[1] = 1;
>   ierr =
>     MatSetValues (A, 1, &rowcount, 2, idxedge, edge, INSERT_VALUES);
>   CHKERRQ (ierr);
>       else if (rowcount == m - 1) //If it is the last row of the whole
matrix
>   edge[0] = PETSC_i;
>   edge[1] = drive + randoms_loc[m - 1];
>   idxedge[0] = m - 2;
>   idxedge[1] = m - 1;
>   ierr =
>   CHKERRQ (ierr);
>       else
>   middle[0] = PETSC_i;
>   middle[1] = drive + randoms_loc[rowcount];
>   middle[2] = PETSC_i;
>   idxmiddle[0] = rowcount - 1;
>   idxmiddle[1] = rowcount;
>   idxmiddle[2] = rowcount + 1;
>   ierr =
>     MatSetValues (A, 1, &rowcount, 3, idxmiddle, middle,
>   INSERT_VALUES);
>   CHKERRQ (ierr);
683a625,626
>   ierr = VecRestoreArray (appctx->randoms, &randoms_loc);
>   CHKERRQ (ierr);
689,691c632,634
< #define __FUNCT__ "RHSFunctionHeat"
< PetscErrorCode
< RHSFunctionHeat (TS ts, PetscReal t, Vec globalin, Vec globalout, void
*ctx)
> #define __FUNCT__ "kdel"
> PetscInt
> kdel (PetscInt i, PetscInt j)
693,704c636,639
<   Mat A;
<   PetscFunctionBeginUser;
<   ierr = TSGetRHSJacobian (ts, &A, NULL, NULL, &ctx);
<   CHKERRQ (ierr);
<   ierr = RHSMatrixHeat (ts, t, globalin, A, NULL, ctx);
<   CHKERRQ (ierr);
<   /* ierr = MatView(A,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr); */
<   ierr = MatMult (A, globalin, globalout);
<   CHKERRQ (ierr);
<   PetscFunctionReturn (0);
>   PetscInt value = 0;
>   if (i == j)
>     value = 1;
>   return value;
> experiments lead.
> -- Norbert Wiener
*Analabha Roy*
C.S.I.R <http://www.csir.res.in>  Senior Research Associate
<http://csirhrdg.res.in/poolsra.htm>
Saha Institute of Nuclear Physics <http://www.saha.ac.in>
Section 1, Block AF
Bidhannagar, Calcutta 700064
India
*Emails*: daneel at physics.utexas.edu, hariseldon99 at gmail.com
*Webpage*: http://www.ph.utexas.edu/~daneel/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141016/8c8299c3/attachment-0001.html>
0a1,2
> //PROBLEMS:
3,8c5,11
<   -time_dependent_rhs : Treat the problem as having a time-dependent right-hand side\n\
>   "Solves a simple time-dependent Schroedinger equation for a TB model with periodic drive.\n\
11,14c14
<    Processors: n
15a16,29
>    overwritten
19,31c33,39
<        u_t = u_xx,
34,46d41
<    Notes:
59a55
64d59
75d69
77d70
79,80c72,77
85a83
87,88c85,86
< extern PetscErrorCode RHSMatrixHeat (TS, PetscReal, Vec, Mat, Mat, void *);
> 					    void *);
90d87
101,102c98,99
108,109c105,107
<   PetscBool flg;
119c117
<   m = 60;
>   m = DEFAULT_SIZE;
121a120,132
>   h0 = DEFAULT_AMPL;
>   CHKERRQ (ierr);
>   CHKERRQ (ierr);
>   w = DEFAULT_W;
>   CHKERRQ (ierr);
123a135
125,127c137,141
>   appctx.h0 = h0;
>   appctx.w = w;
163d176
167,168d179
<   CHKERRQ (ierr);
171c182
173,189c184,195
<   ierr =
< 			 &appctx.viewer1);
<   CHKERRQ (ierr);
<   CHKERRQ (ierr);
<   CHKERRQ (ierr);
<   ierr =
< 			 &appctx.viewer2);
<   CHKERRQ (ierr);
<   CHKERRQ (ierr);
<   CHKERRQ (ierr);
>   if (appctx.debug)
>       ierr =
>       CHKERRQ (ierr);
>       CHKERRQ (ierr);
>       CHKERRQ (ierr);
197,202c203
<   CHKERRQ (ierr);
<   CHKERRQ (ierr);
>   TSSetProblemType (ts, TS_LINEAR);	/* In this case, the dynamics is always linear */
205c206
211d211
224,225c224,257
>   CHKERRQ (ierr);
>   CHKERRQ (ierr);
>   CHKERRQ (ierr);
>   CHKERRQ (ierr);
>   CHKERRQ (ierr);
>   CHKERRQ (ierr);
>   CHKERRQ (ierr);
>   CHKERRQ (ierr);
>   CHKERRQ (ierr);
>   CHKERRQ (ierr);
227,254d258
<   if (flg)
<       ierr = TSSetRHSFunction (ts, NULL, TSComputeRHSFunctionLinear, &appctx);
<       CHKERRQ (ierr);
<       CHKERRQ (ierr);
<   else
<          routine.
<       CHKERRQ (ierr);
<       CHKERRQ (ierr);
<       ierr =
<       CHKERRQ (ierr);
256,266d259
<       SNES snes;
<       CHKERRQ (ierr);
<       CHKERRQ (ierr);
<       ierr =
<       CHKERRQ (ierr);
272,273c265,266
>   dt = INIT_STEP;
281a275
287a282,285
>   CHKERRQ (ierr);
>   ierr = TSRKSetType (ts, TSRK5DP);	//Default solver is Runge Kutta (5) Prince-Dormand (4)
>   CHKERRQ (ierr);
289a288,291
>   CHKERRQ (ierr);
321,324c323,324
338,341c338,343
<   CHKERRQ (ierr);
<   CHKERRQ (ierr);
>   if (appctx.debug)
>       CHKERRQ (ierr);
344,345d345
<   CHKERRQ (ierr);
347a348,349
>   CHKERRQ (ierr);
377c379
379a382
394,395d396
402,403c403,404
406,408c407,410
>     else
421c423
432,486d433
<    Input Parameters:
<    t - current time
<    Output Parameter:
< PetscErrorCode
<   CHKERRQ (ierr);
<   CHKERRQ (ierr);
<      Restore vector
<   CHKERRQ (ierr);
<   return 0;
< #undef __FUNCT__
490,491c437
509,515c455
<   CHKERRQ (ierr);
>   PetscReal norm_2;
518c458
520c460
521a462
523,536d463
<       CHKERRQ (ierr);
<       CHKERRQ (ierr);
<       CHKERRQ (ierr);
<       CHKERRQ (ierr);
538,541c465,467
>   Vec uabs;
543c469,470
545,546c472
549,556c475
<   ierr =
558,559d476
561,565c478,483
<   CHKERRQ (ierr);
>   /* Create another viewer in application context and dump full output to it */
>   //CHKERRQ (ierr);
572,574c490,497
<       CHKERRQ (ierr);
>       ierr =
> 		     norm_2);
576a500,501
>   CHKERRQ (ierr);
583c508
585c510
>    RHSMatrixSchrodinger - User-provided routine to compute the right-hand-side
599,600c524
<   Notes:
>   RHSMatrixSchrodinger computes entries for the locally owned part of the system.
613c537
> RHSMatrixSchrodinger (TS ts, PetscReal t, Vec X, Mat AA, Mat BB, void *ctx)
618,619c542,554
<   PetscScalar v[3], stwo = -2. / (appctx->h * appctx->h), sone = -.5 * stwo;
>   PetscScalar drive;
>   CHKERRQ (ierr);
>   drive = w * t;
623,625c558,566
>      - The values are A_{lm} =  i\left(\delta_{lm+1}+\delta_{lm-1}\right)+2i \alpha h_m\delta_{lm} + 2i h(t) \delta_{lm}
>      - Thus the superdiagonal and subdiagonal elements are just i, and diagonal elements are random + drive
627,655c568
<   if (mstart == 0)
<       v[0] = 1.0;
<       CHKERRQ (ierr);
<       mstart++;
<       mend--;
<       v[0] = 1.0;
<       CHKERRQ (ierr);
<   v[0] = sone;
<   v[1] = stwo;
<   v[2] = sone;
657,661c570,602
<       idx[0] = i - 1;
<       idx[1] = i;
<       idx[2] = i + 1;
<       CHKERRQ (ierr);
> 	  edge[1] = PETSC_i;
> 	  idxedge[0] = 0;
> 	  idxedge[1] = 1;
> 	  ierr =
> 	  CHKERRQ (ierr);
>       else if (rowcount == m - 1)	//If it is the last row of the whole matrix
> 	  edge[0] = PETSC_i;
> 	  idxedge[0] = m - 2;
> 	  idxedge[1] = m - 1;
> 	  ierr =
> 	  CHKERRQ (ierr);
>       else
> 	  ierr =
> 			  INSERT_VALUES);
> 	  CHKERRQ (ierr);
683a625,626
>   CHKERRQ (ierr);
689,691c632,634
< PetscErrorCode
< RHSFunctionHeat (TS ts, PetscReal t, Vec globalin, Vec globalout, void *ctx)
> PetscInt
693,704c636,639
<   Mat A;
<   CHKERRQ (ierr);
<   CHKERRQ (ierr);
<   CHKERRQ (ierr);
>   PetscInt value = 0;
>   if (i == j)
>     value = 1;
>   return value;
