[petsc-users] -log_summary output in PETSc 3.5.2
Constantine Khroulev c.khroulev at gmail.com
Mon Oct 13 18:39:49 CDT 2014
Barry,
Thanks! Would you mind adding this to the manual?
A minor comment: even though -log_view :filename:format *is*
mentioned, supported formats are not documented in the PetscLogView
manual page.
Constantine
On Mon, Oct 13, 2014 at 3:26 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   -log_view :filename:ASCII_INFO_DETAIL
>    It saves information from each process in one file in Python so it is easy to process the summaries you want.
>  Barry
> On Oct 13, 2014, at 6:04 PM, Constantine Khroulev <c.khroulev at gmail.com> wrote:
>> Hello PETSc developers,
>> Is there a way to get profiling stats similar to -log_summary, but in
>> a format that can be processed programmatically?
>> As far as I can tell, current -log_summary output is tricky to parse:
>> whether output is space-separated depends on values that are printed.
>> In addition to this, a long event name changes offsets from the
>> beginning of the line for a given column, so extracting string subsets
>> using offsets is also unreliable.
>> Thanks!
>> Constantine
