[petsc-users] -log_summary output in PETSc 3.5.2
Constantine Khroulev c.khroulev at gmail.com
Mon Oct 13 18:04:16 CDT 2014
Hello PETSc developers,
Is there a way to get profiling stats similar to -log_summary, but in
a format that can be processed programmatically?
As far as I can tell, current -log_summary output is tricky to parse:
whether output is space-separated depends on values that are printed.
In addition to this, a long event name changes offsets from the
beginning of the line for a given column, so extracting string subsets
using offsets is also unreliable.
Thanks!
Constantine
