[petsc-users] PetscFEIntegrateResidual_OpenCL w/ viennacl
Karl Rupp rupp at iue.tuwien.ac.at
Mon Oct 13 14:16:37 CDT 2014
Hi David,
 > when using the snes/ex12 example
> https://bitbucket.org/petsc/petsc/src/f5476a2b443e0eedb22d31cb1b2d85b9b918f73f/src/snes/examples/tutorials/ex12.c?at=master
> with
> -variable_coefficient field  -petscfe_type opencl -mat_petscfe_type opencl
> and
> -dm_vec_type  viennacl -dm_mat_type seqaijviennacl -mat_type seqaijviennacl
> will PetscFEIntegrateResidual_OpenCL transfer the residual vector
> directly to the
> viennacl datastructures on the GPU for the solve ?
No, unfortunately this doesn't work yet. The residual implementation is
'matrix free', so there is no matrix set up and *mat_type without
effect. Setting
will be supported in the future, but currently the OpenCL buffer is only
set up to compute the residual.
> is the output residual of PetscFEIntegrateResidual_OpenCL a vector on
> the CPU ?
yes, it is read back to elemVec[], which is passed to
PetscFEIntegrateResidual_OpenCL()
Best regards,
Karli
