[petsc-users] Block size
Natacha BEREUX natacha.bereux at gmail.com
Thu Oct 9 03:12:39 CDT 2014
Dear PETSc users,
I am a bit confused  about blocksizes in MPI matrices.
I define a MPI matrix A with a certain blocksize, let say bs = 3.
As far as I understand, the sparse pattern of the matrix A is made of
square blocks of size 3x3, regardless of the actual values of the terms of
A.
Am I right ?
The matrix A is distributed among several processors: does the local number
of rows of A on each processor have to be a multiple of bs   ?
I want to use a multigrid preconditionner to  solve the linear system of
matrix A : A x = b
Is it mandatory to define the right hand side b as a vector with the same
blocksize bs=3 ?
Thank you very much of your help,
Best regards,
Natacha
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141009/3b2f6124/attachment.html>
