[petsc-users] Generating xdmf from h5 file.
Wed Oct 8 02:15:21 CDT 2014
On Tue, Oct 7, 2014 at 10:09 PM, Justin Chang <jychang48 at gmail.com> wrote:
> Hi Matt,
> Bumping this thread. I have a similar question. The lines you wrote for
> testnum 39 have also worked perfectly for me. However, when I change a
> couple parameters, namely not interpolating the mesh and using
> -petscspace_order 1:
> ./ex12 -run_type full -refinement_limit 0.015625 -petscspace_order 1
> -pc_type gamg -ksp_rtol 1.0e-10 -ksp_monitor_short -ksp_converged_reason
> -snes_monitor_short -snes_converged_reason -dm_view hdf5:sol.h5
> -snes_view_solution hdf5:sol.h5::append
> I get the following error after I run the xdmf script:
> Traceback (most recent call last):
>   File "./bin/pythonscripts/petsc_gen_xdmf.py", line 223, in <module>
>     generateXdmf(sys.argv[1])
>   File "./bin/pythonscripts/petsc_gen_xdmf.py", line 218, in generateXdmf
>     Xdmf(xdmfFilename).write(hdfFilename, topoPath, numCells, numCorners,
> cellDim, geomPath, numVertices, spaceDim, time, vfields, cfields)
>   File "./bin/pythonscripts/petsc_gen_xdmf.py", line 176, in write
>     self.writeSpaceGridHeader(fp, numCells, numCorners, cellDim, spaceDim)
>   File "./bin/pythonscripts/petsc_gen_xdmf.py", line 75, in
>     ''' % (self.cellMap[cellDim][numCorners], numCells, "XYZ" if spaceDim
> > 2 else "XY"))
> Does the script so far only work for interpolated meshes/problems?
It should work for both. I think this is the same bug as reported yesterday
by Michael Lange, that the coordinate Vec
is sometimes missing the correct block size. I will track it down.
     Matt
> Thanks,
> Justin
> On Sun, Sep 28, 2014 at 11:15 AM, subramanya sadasiva <potaman at outlook.com
> > wrote:
>> Thanks Matt,
>> That worked perfectly.
>> Subramanya
>> Date: Fri, 26 Sep 2014 14:52:52 -0500
>> Subject: Re: [petsc-users] Generating xdmf from h5 file.
>> From: knepley at gmail.com
>> To: potaman at outlook.com
>> CC: petsc-users at mcs.anl.gov
>> On Thu, Sep 25, 2014 at 10:29 PM, subramanya sadasiva <
>> potaman at outlook.com> wrote:
>> Hi Matt,
>> Sorry about that,
>> I changed
>> if 'time' in h5:
>>     time        = np.array(h5['time']).flatten()
>>   else:
>>     time        = np.empty(1)
>> The code now fails in the writeSpaceGridHeader  function.  with the
>> error,
>>   File
>> "/Users/ssadasiv/software/petsc/bin/pythonscripts/petsc_gen_xdmf.py", line
>> 232, in <module>
>>   File
>> 227, in generateXdmf
>>   File
>> 180, in write
>>   File
>> 64, in writeSpaceGridHeader
>>     print self.cellMap[cellDim][numCorners]
>> The error is due to the fact that numCorners is set to be 1 , while
>> celldim=2. cellMap has the following elements.
>> {1: {1: 'Polyvertex', 2: 'Polyline'}, 2: {3: 'Triangle', 4:
>> 'Quadrilateral'}, 3: {8: 'Hexahedron', 4: 'Tetrahedron'}}
>> I  also  tried
>> ./ex12 -dm_view vtk:my.vtk:vtk_vtu . This doesn't seem to do anything.
>> Is there any specific option I need to build petsc with to get vtk output?
>> My current build has hdf5 and netcdf enabled.
>> I made the change in a branch, and merged to 'next', so it will work if
>> you pull. Here is a test from ex12 (testnum 39 in builder.py):
>>   ./ex12 -run_type full -refinement_limit 0.015625 -interpolate 1
>> -petscspace_order 2 -pc_type gamg -ksp_rtol 1.0e-10 -ksp_monitor_short
>> -ksp_converged_reason -snes_monitor_short -snes_converged_reason -dm_view
>> hdf5:sol.h5 -snes_view_solution hdf5:sol.h5::append
>> which makes sol.h5. Then I run
>>   ./bin/pythonscripts/petsc_gen_xdmf.py sol.h5
>> which makes sol.xmf. I load it up in Paraview and it makes the attached
>> picture.
>>   Thanks,
>>      Matt
>> Thanks,
>> Subramanya
>> Date: Wed, 24 Sep 2014 17:36:52 -0500
>> To: potaman at outlook.com; petsc-maint at mcs.anl.gov; petsc-users at mcs.anl.gov
>> On Wed, Sep 24, 2014 at 5:29 PM, subramanya sadasiva <potaman at outlook.com
>> > wrote:
>> Hi Matt,
>> That did not help.
>> That's not enough description to fix anything, and fixing it will require
>> programming.
>> Is there any other way to output the mesh to something that paraview can
>> view?  I tried outputting the file to a vtk file using
>> ex12 -dm_view vtk:my.vtk:ascii_vtk
>> which, I saw in another post on the forums, but that did not give me any
>> output.
>> This is mixing two different things. PETSc has a diagnostic ASCII vtk
>> output, so the type would be ascii, not vtk,
>> and format ascii_vtk . It also has a production VTU output, which is type
>> vtk with format vtk_vtu.
>>   Thanks,
>>      Matt
>> Subramanya
>> Date: Wed, 24 Sep 2014 17:19:51 -0500
>> On Wed, Sep 24, 2014 at 5:08 PM, subramanya sadasiva <potaman at outlook.com
>> > wrote:
>> Hi,
>> i was trying to use petsc_gen_xdmf.py to convert a h5 file to a xdmf
>> file. The h5 file was generated by snes/ex12 which was run as,
>> ex12 -dm_view hdf5:my.h5
>> When I do,
>> petsc_gen_xdmf.py my.h5
>> I get the following error,
>>  File
>> "/home/ssadasiv/software/petsc/bin/pythonscripts/petsc_gen_xdmf.py", line
>> 220, in <module>
>>   File
>> 208, in generateXdmf
>>   File "/usr/lib/python2.7/dist-packages/h5py/_hl/group.py", line 153, in
>> __getitem__
>>     oid = h5o.open(self.id, self._e(name), lapl=self._lapl)
>>   File "h5o.pyx", line 173, in h5py.h5o.open (h5py/h5o.c:3403)
>> KeyError: "unable to open object (Symbol table: Can't open object)"
>> I am not sure if the error is on my end. This is on Ubuntu 14.04 with the
>> serial version of hdf5. I built petsc with --download-hdf5, is it necessary
>> to use the same version of hdf5 to generate the xdmf file?
>> That code is alpha, and mainly built for me to experiment with an
>> application here, so it is not user-friendly. In your
>> HDF5 file, there is no 'time' since you are not running a TS. This access
>> to h5['time'] should just be protected, and
>> an empty array should be put in if its not there.
>>   Matt
>> Thanks
>> Subramanya
>> experiments lead.
>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141008/6a1980e6/attachment-0001.html>
