[petsc-users] Penalization vs. setting interior points for Laplace eqn
Jed Brown jed at jedbrown.org
Sat Oct 4 18:56:49 CDT 2014
Barry Smith <bsmith at mcs.anl.gov> writes:
>   I think you can just set the values there. The advantage is
>   simplicity plus it won’t mess up the convergence of the iterative
>   methods as a penalization likely would.
Write the trivial equations for those rows (u = "what_you_want") and
have all the neighboring equations use what_you_want.  That is
"symmetric" removal of those equations.
See this description with notation.
https://scicomp.stackexchange.com/questions/3298/appropriate-space-for-weak-solutions-to-an-elliptical-pde-with-mixed-inhomogeneo/3300#3300
Of course you can use other methods, but I recommend the above because
it maintains symmetry, decouples the boundary dofs, and does not
introduce poor scaling.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141004/78e51a72/attachment.pgp>
