[petsc-users] Save matrix to binary file on sub directory
Thu Oct 2 14:44:06 CDT 2014
On Thu, Oct 2, 2014 at 12:17 PM, Robert Rezk <robertrezk at yahoo.ca> wrote:
> This is the code I used
>   PetscViewer viewer;
>   PetscErrorCode ierr;
>   PetscViewerBinaryOpen(comm_,File_Name.c_str(),FILE_MODE_WRITE,&viewer);
Can you check all return codes with CHKERRQ(ierr)?
     Matt
    ierr = MatView(*petsc_matrix, viewer);
>   PetscViewerDestroy(&viewer);
> and I can't see any output or crash
> Best Regards
> Robert Andrawis
>  *From:* Jed Brown <jed at jedbrown.org>
> *To:* Robert Rezk <robertrezk at yahoo.ca>; "petsc-users at mcs.anl.gov" <
> petsc-users at mcs.anl.gov>
> *Sent:* Thursday, October 2, 2014 1:04 PM
> *Subject:* Re: [petsc-users] Save matrix to binary file on sub directory
> Robert Rezk <robertrezk at yahoo.ca> writes:
> > I am using the pets viewer and I want to save binary file to sub
> directory.
> > I tried to save file to the current directory and it work fine.
> > when I try to use file name like this "./xyz_dir/file_name" it doesn't
> work.
> What symptoms do you see?  Can you reproduce with an example?
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141002/81e36c10/attachment.html>
